Home » Language IDEs » AspectJ » Convert to AspectJ project breaks Junit
Convert to AspectJ project breaks Junit [message #481410] Thu, 20 August 2009 16:36 Go to next message
I just installed the plugin from
http://download.eclipse.org/tools/ajdt/35/update. Converting a current
Java project to an AspectJ breaks the "Run As" option in the Editor popup
menu. Specifically, when editing a TestCase, selecting "Run As" from the
popup menu no longer shows Junit as an option. However, if selecting "Run
Configurations..." displays the dialog within the Junit section. Selecting
"Run" from this dialog does run the test. Any ideas?
Thanks in advance
Steve
Re: Convert to AspectJ project breaks Junit [message #482000 is a reply to message #481410] Tue, 25 August 2009 01:06 Go to previous message
I'm not seeing that behavior myself with the latest dev build from
http://download.eclipse.org/tools/ajdt/35/dev/update.
Some questions:
1. Does this only happen for AspectJ projects or all projects with AJDT
installed?
2. Does this happen for all AspectJ projects? Even a simple AJ project with
no aspects and a test case?
3. Do you see any errors in the error log?
On 20/08/09 1:36 PM, in article
296d1abd3e162620b9ce4ad460f1c03e$1@www.eclipse.org, "Steve Wall"
<steve.wall@primetimesoftware.com> wrote:
> Hello,
> Thanks in advance
> Steve
Re: Convert to AspectJ project breaks Junit [message #600510 is a reply to message #481410] Tue, 25 August 2009 01:06 Go to previous message
Some questions:
installed?
> Hello,
> http://download.eclipse.org/tools/ajdt/35/update Converting a current
> Thanks in advance
> Steve
Previous Topic:Convert to AspectJ project breaks Junit
Next Topic:Aspectj export fails because IMessageHandler cannot be found
Current Time: Sat Jul 26 20:40:41 EDT 2025
Powered by FUDForum. Page generated in 0.03752 seconds
