Home » Eclipse Projects » Buckminster dev » [buckminster-dev] having new trouble running hello world xml example.
Re: [buckminster-dev] having new trouble running hello world xml example. [message #481188 is a reply to message #480985] |
Thu, 20 August 2009 00:21   |
Thansk. No, it didn't work with
http://www.eclipse.org/buckminster/samples/rmaps/demo.rmap either but
I can try again. The problem was reproducible yesterday. I was able
to checkout files with svn from the command line.
-ted
On Wed, Aug 19, 2009 at 2:13 AM, Henrik
Lindberg<henrik.lindberg@cloudsmith.com> wrote:
> I wonder if the reference to the local rmap needs file:///home/ted/...
> instead of just file:/home/ted/...
> Does it work if you use the URL
> http://www.eclipse.org/buckminster/samples/rmaps/demo.rmap ?
> - henrik
> Ted Kubaska wrote:
>> I've been running the "hello XML world" example in Chapter 13 of the
>> Bucky book. Last week it worked fine for me, but today I get the
>> following error message that occurs when I want to "Resolve and
>> Materialize" the cquery.
>> <error message>
>> Errors and Warnings
>> E [0001] : Provider eclipse.platform(plugin/org.demo.hello.xml.world):
>> Missing CSpec source required by component type osgi.bundle
>> </errormessage>
>> Here's what I did (which used to work ... I dont think I've changed
>> anything in my eclipse config ... at least I cannot find a
>> difference).
>> I have a project called BuckyXMLdemo which has two files. They are
>> HelloXMLworld.rmap and new_query.cquery. I dont think I actually need
>> the HelloXMLworld.rmap because the new_query.cquery has "Use Resource
>> Maps" checked and points to
>> http://www.eclipse.org/buckminster/samples/rmaps/demo.rmap. I found
>> out earlier that I could run the example by choosing "Use Resource
>> maps" and pointing to
>> file:/home/ted/EclipseProjects/workBucky/BuckyXMLdemo/HelloX MLworld.rmap
>> .... so in that instance I needed my HelloXMLworld.rmap.
>> However, today when I "Resolve and Materialize" my cquery, I dont get
>> those three projects in my workspace, Instead I just get the error
>> message shown above.
>> My HelloXMLworld.rmap is just what I copied from
>> <?xml version="1.0" encoding="UTF-8"?>
>> <rmap
>> xmlns="http://www.eclipse.org/buckminster/RMap-1.0"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xmlns:mp="http://www.eclipse.org/buckminster/MavenProvider-1.0"
>> xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0">
>> <searchPath name="default">
>> <provider readerType="svn"
>> componentTypes="eclipse.feature,osgi.bundle,buckminster"
>> source="true">
>> <uri
>> format=" http://dev.eclipse.org/svnroot/tools/org.eclipse.buckminster /trunk/org.eclipse.buckminster/demo/{0}">
>> <bc:propertyRef key="buckminster.component"
>> </uri>
>> </provider>
>> </searchPath>
>> <locator searchPathRef="default" pattern="^org\.demo\...*" />
>> <redirect
>> href=" http://www.eclipse.org/buckminster/samples/rmaps/dogfood.rma p"
>> pattern=".*"/>
>> </rmap>
>> Here is my copy of new_query.cquery
>> <cq:componentQuery
>> xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0"
>> resourceMap=" file:/home/ted/EclipseProjects/workBucky/BuckyXMLdemo/HelloX MLworld.rmap ">
>> <cq:rootRequest name="org.demo.hello.xml.world"
>> componentType="osgi.bundle"/>
>> </cq:componentQuery>
> _______________________________________________
> buckminster-dev mailing list
> buckminster-dev@eclipse.org
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
-Ted
Re: [buckminster-dev] having new trouble running hello world xml example. [message #481358 is a reply to message #480985] |
Thu, 20 August 2009 11:42   |
This is really not working and I honestly it used to and I cannot
discover a change I have made. I apologize if I have made a simple
error, but really need some help. I made a cquery that has the
following code.
<cq:componentQuery
resourceMap="http://www.eclipse.org/buckminster/samples/rmaps/demo.rmap">
<cq:rootRequest name="XMLquery" componentType="osgi.bundle"/>
and I set the uri for resource map to be
and I now get
ERROR [0001] : No suitable provider for component
XMLquery:osgi.bundle was found in resourceMap
XMLquery:osgi.bundle was found in searchPath orbit
ERROR [0001] : Rejecting provider
eclipse.import( http://download.eclipse.org/tools/orbit/downloads/drops/R200 90529135407/updateSite?importType=binary):
No component match was found
XMLquery:osgi.bundle was found in searchPath galileo
eclipse.import( http://download.eclipse.org/releases/galileo?importType=bina ry):
XMLquery:osgi.bundle was found in searchPath maven
maven2(http://repo1.maven.org/maven2): Components of type osgi.bundle
are not supported
Errors and Warnings
E [0001] : No suitable provider for component XMLquery:osgi.bundle was
E [0001] : Rejecting provider
are not supported
> - henrik
>> <error message>
>> Errors and Warnings
>> </errormessage>
>> difference).
>> <rmap
>> source="true">
>> <uri
>> </uri>
>> </provider>
>> </searchPath>
>> <redirect
>> pattern=".*"/>
>> </rmap>
>> <cq:componentQuery
-Ted
Re: [buckminster-dev] having new trouble running hello world xml example. [message #481359 is a reply to message #480985] |
Thu, 20 August 2009 11:45   |
Oh the name of the cquery I made was XMLquery.cquery -ted
> following code.
> <cq:componentQuery
> and I now get
> are not supported
> Errors and Warnings
> are not supported
>> - henrik
>>> <error message>
>>> Errors and Warnings
>>> </errormessage>
>>> difference).
>>> <rmap
>>> source="true">
>>> <uri
>>> </uri>
>>> </provider>
>>> </searchPath>
>>> <locator searchPathRef="default" pattern="^org\.demo\..*" />
>>> <redirect
>>> pattern=".*"/>
>>> </rmap>
>>> <cq:componentQuery
> -Ted
-Ted
Re: [buckminster-dev] having new trouble running hello world xml example. [message #481387 is a reply to message #480985] |
Thu, 20 August 2009 14:00  |
Sigh ... this was my error. Sometimes I wonder how I get my shoes on
the right feet in the morning.
I had the wrong component name ... need org.demo.hello.xml.world not
the name of my query file.
Your Chapter 14 has the correct information ... all I have to do is
read it correctly which I did a few days ago but the read incorrectly
yesterday and today.
-ted
> - henrik
>> <error message>
>> Errors and Warnings
>> </errormessage>
>> difference).
>> <rmap
>> source="true">
>> <uri
>> </uri>
>> </provider>
>> </searchPath>
>> <redirect
>> pattern=".*"/>
>> </rmap>
>> <cq:componentQuery
-Ted
Current Time: Fri Jul 25 23:40:06 EDT 2025
Powered by FUDForum. Page generated in 0.26743 seconds
