Home » Archived » DSDP - Mobile Tools for Java (MTJ) » Boolean clauses in preprocessor directives
Boolean clauses in preprocessor directives [message #481281] Thu, 20 August 2009 06:49 Go to next message
I am trying to use the preprocessor like the C preprocessor, but I fail.
I've read that boolean clauses ( && and || ) can be used, but this does not work:
//#ifdef DEFINED_VALUE && (DEFINED_VALUE == 2)
//#else
//#endif
How can I make it work?
Thank you.
[Updated on: Thu, 20 August 2009 07:03] by Moderator
Re: Boolean clauses in preprocessor directives [message #481286 is a reply to message #481281] Thu, 20 August 2009 07:05 Go to previous messageGo to next message
I think i found a workaround.
//#if (DEFINED_VALUE) && (DEFINED_VALUE == 2)
//#else
//#endif
The code above seems to work. Is that the correct way of doing it?
Re: Boolean clauses in preprocessor directive s [message #481293 is a reply to message #481286] Thu, 20 August 2009 08:00 Go to previous messageGo to next message
Hi David,
You can check this on our documentation
http://help.eclipse.org/galileo/topic/org.eclipse.mtj.doc.us er/html/tasks/preprocessProject.html
about preprocessing or you can use the one on the Antenna Preprocessor
page: http://antenna.sourceforge.net/wtkpreprocess.php
Cheers
Diego
Re: Boolean clauses in preprocessor directive s [message #481301 is a reply to message #481293] Thu, 20 August 2009 08:42 Go to previous messageGo to next message
Yes, I've already read the documentation, and not only it seems that #ifdef, #ifndef does not accept added complexity, but moreover one cannot define a variable to have a value.
Why cannot I have
#define VALUE "true"
when I can do it throught the project properties?
About the ant preprocessor... I don't know if it can be used "silently" like MTJ does. If it is possible, then I'll take a look.
Thanks for you answer.
Re: Boolean clauses in preprocessor directives [message #481313 is a reply to message #481301] Thu, 20 August 2009 09:11 Go to previous messageGo to next message
Hi David,
MTJ uses antenna preprocessor behind the scenes. So, every thing that goes
with antenna preprocessor backend v3 should be supported by MTJ.
About )#define VALUE "true") if I'm not mistaken, the correct syntax is
#define VALUE=true
Diego
Re: Boolean clauses in preprocessor directives [message #481362 is a reply to message #481313] Thu, 20 August 2009 11:58 Go to previous messageGo to next message
Yes Diego, you're right about the #define issue. I got that solution before reading your message but forgot to post it here.
Thanks for the response anyway, and thanks for the information about the ant task.
Re: Boolean clauses in preprocessor directive s [message #576061 is a reply to message #481286] Thu, 20 August 2009 08:00 Go to previous messageGo to next message
Hi David,
Cheers
Diego
Re: Boolean clauses in preprocessor directive s [message #576088 is a reply to message #481293] Thu, 20 August 2009 08:42 Go to previous messageGo to next message
Why cannot I have
Re: Boolean clauses in preprocessor directives [message #576108 is a reply to message #576088] Thu, 20 August 2009 09:11 Go to previous messageGo to next message
Hi David,
#define VALUE=true
Diego
Re: Boolean clauses in preprocessor directives [message #576130 is a reply to message #481313] Thu, 20 August 2009 11:58 Go to previous message
Previous Topic:Boolean clauses in preprocessor directives
Next Topic:Bug in MTJ preprocessor documentation
Current Time: Sat Aug 30 22:16:01 EDT 2025
Powered by FUDForum. Page generated in 0.04383 seconds
