[EMF Compare] Comparing failed for custom uml2 model and no error-log entry [message #481277] |
Thu, 20 August 2009 06:37  |
I am having some problems using the EMF Compare tool when I compare 2 extended uml models. This is the error I receive :
Comparison throught EMF Compare failed.
Reason:
Value ' x.NoteImpl@123 ( name :<unset> ...etc)' is not legal.
Next is displayed the line and column in the A.myuml file where the error happens.
A.myuml file is a model containg uml2 elements and also elements from a custom metadata (this being extended from uml2).
I am having difficulties find out why this error happens because it apears only a pop-up message and nothing in error log is entered.
Does anybody else has encountered this type of error? If yes can you please guide me?
I would also like some hints where could I put some breakpoints to find out what is the source of the error.
Thank you in advance for your help,
Sorin.
Re: [EMF Compare] Comparing failed for custom uml2 model and no error-log entry [message #481290 is a reply to message #481277] |
Thu, 20 August 2009 07:24  |
--------------010208040705000908010806
Hi Sorin,
What I can say for sure is that it isn't specific to EMF Compare. Other
than that, it seems to be a validation error with your model (which
should also be displayed when you try to open your model in the sample
Ecore/uml editor.
How are you using EMF Compare (from GUI (right-click => compare with),
from code, ...)? And which versions of EMF Compare and Eclipse are you
using?
Laurent Goubet
Obeo
Sorin Fagateanu a écrit :
> Reason:
> Value ' mailto:x.NoteImpl@123 ( name :<unset> ...etc)' is not legal.
> error happens.
> please guide me?
> Sorin.
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyLyI+T2JlbzwvYT4NCmVtYWls O2ludGVybmV0
OmxhdXJlbnQuZ291YmV0QG9iZW8uZnINCnVybDpodHRwOi8vd3d3Lm9iZW8u ZnINCnZlcnNp
b246Mi4xDQplbmQ6dmNhcmQNCg0K
--------------010208040705000908010806--
FUDForum. Page generated in 0.05685 seconds
