Home » Eclipse Projects » Eclipse Platform » [commands] notify about property changes
[commands] notify about property changes [message #481146] Wed, 19 August 2009 14:22 Go to next message
Is there a way to notify the framework when a PropertyTester's property has
changed? In my particular case, I have a handler with an enabledWhen that
references the property:
<enabledWhen>
<with
variable="activePart">
<test
property="org.example.booleanProperty"
value="true">
</test>
</with>
</enabledWhen>
I'd like to refresh the enablement state as soon as the property value
changes. Right now, I have to refocus the view for the PropertyTester to be
invoked again.
Will
Re: [commands] notify about property changes [message #481148 is a reply to message #481146] Wed, 19 August 2009 14:50 Go to previous message
You need org.eclipse.ui.services.IEvaluationService.requestEvaluation (String)
This will update evaluations for things like visibleWhen, enabledWhen, and activeWhen.
PW
Previous Topic:Unable To Refresh After Changing A Folder
Next Topic:Errors running builder 'Script Builder' on project '***'.
Current Time: Sat Jul 26 15:23:23 EDT 2025
Powered by FUDForum. Page generated in 0.17805 seconds
