| not a lot of success on the first try [message #4671] |
Thu, 28 April 2005 22:13  |
I downloaded the zip file this afternoon and extracted it into the
eclipse/plugins directory as usual. I see the plugin in the directory
and in the list of plugins displayed by Eclipse, so it seems the very
basics are in order.
I can see “Voice Tools” in the Help Contents.
When I try the first task, to create a VXML file, the task instructions
say to choose "New > Other > Voice Tools > VoiceXML File".
Unfortunately, I do not see "Voice Tools" as an option under Other.
Is there some other configuration needed? I do not recall seeing any
instructions.
-- Mike Greenawalt
Tellme Networks
| Re: not a lot of success on the first try [message #4976 is a reply to message #4879] |
Fri, 29 April 2005 21:33   |
Uh-Oh. My bad.
I overlooked the prerequisite statement, so I did not get the webtools
build first.
I will tackle that on Monday.
-- Mike
Brent D. Metz wrote:
> When you open Help->About Eclipse Platform->Plug-in Details, does the plugin
> ID "org.eclipse.vtp.editor.vxml" appear in the list? That contributes the
> wizard entry you should see. I installed the VTP from scratch on top of the
> M3 WTP+GEF+EMF+etc build, Win32 build available here:
> http://www.eclipse.org/downloads/download.php?file=/webtools /downloads/drops/S-1.0M3-200502260707/wtp-eclipse-prereqs-sd k-1.0M3-win32.zip&url=http://download.eclipse.org/webtoo ls/downloads/drops/S-1.0M3-200502260707/wtp-eclipse-prereqs- sdk-1.0M3-win32.zip&mirror_id=1
> When I select File->New->Other.. the dialog that comes up has the voice
> tools group. (Screenshot attached) An alternative to using the wizards is
> just to create a new simple file (File->New->Other...->Simple->File) and use
> the extension .vxml.
> I'm curious, are you using the Win32 builds of WTP? I am not sure if we have
> tested the contribution on other platforms.
> "Mike Greenawalt" <mgreenawalt@tellme.com> wrote in message
> news:d4tuis$2g6$1@news.eclipse.org...
>>Thanks, Brent.
>>The documentation seems clear enough. The problem is that Voice Tools
>>does not appear in the "Other..." list.
>>-- Mike
>>>Thanks for checking it out! I think the documentation is just confusing
>>>If you select "Other.." does the Voice Tools group appear in the dialog
>>>that
>>>comes up? You should be able to create a VoiceXML file from there.
>>>news:d4s5g3$tlu$1@news.eclipse.org...
>>>>eclipse/plugins directory as usual. I see the plugin in the directory and
>>>>in the list of plugins displayed by Eclipse, so it seems the very basics
>>>>are in order.
>>>>say to choose "New > Other > Voice Tools > VoiceXML File". Unfortunately,
>>>>instructions.
>>>>-- Mike Greenawalt
>>>>Tellme Networks
| Re: not a lot of success on the first try [message #5044 is a reply to message #4976] |
Tue, 03 May 2005 14:09  |
Great! It worked as advertised when I got the webtools version installed.
-- Mike
Mike Greenawalt wrote:
> Uh-Oh. My bad.
> build first.
> -- Mike
| Re: not a lot of success on the first try [message #571642 is a reply to message #4671] |
Thu, 28 April 2005 23:01  |
Thanks for checking it out! I think the documentation is just confusing :)
If you select "Other.." does the Voice Tools group appear in the dialog that
>are in order.
> I can see
| Re: not a lot of success on the first try [message #571662 is a reply to message #4741] |
Fri, 29 April 2005 14:27  |
Thanks, Brent.
-- Mike
>>are in order.
>>instructions.
>>-- Mike Greenawalt
>>Tellme Networks
| Re: not a lot of success on the first try [message #571724 is a reply to message #4879] |
Uh-Oh. My bad.
build first.
-- Mike
>>Thanks, Brent.
>>-- Mike
>>>that
>>>>are in order.
>>>>instructions.
>>>>-- Mike Greenawalt
>>>>Tellme Networks
| Re: not a lot of success on the first try [message #571750 is a reply to message #4976] |
-- Mike
> Uh-Oh. My bad.
> build first.
> -- Mike
FUDForum. Page generated in 0.05882 seconds
