Home » Eclipse Projects » Buckminster dev » [buckminster-dev] having new trouble running hello world xml example.
[buckminster-dev] having new trouble running hello world xml example. [message #480899] Tue, 18 August 2009 15:39 Go to next message
I've been running the "hello XML world" example in Chapter 13 of the
Bucky book. Last week it worked fine for me, but today I get the
following error message that occurs when I want to "Resolve and
Materialize" the cquery.
<error message>
Errors and Warnings
E [0001] : Provider eclipse.platform(plugin/org.demo.hello.xml.world):
Missing CSpec source required by component type osgi.bundle
</errormessage>
Here's what I did (which used to work ... I dont think I've changed
anything in my eclipse config ... at least I cannot find a
difference).
I have a project called BuckyXMLdemo which has two files. They are
HelloXMLworld.rmap and new_query.cquery. I dont think I actually need
the HelloXMLworld.rmap because the new_query.cquery has "Use Resource
Maps" checked and points to
http://www.eclipse.org/buckminster/samples/rmaps/demo.rmap. I found
out earlier that I could run the example by choosing "Use Resource
maps" and pointing to
file:/home/ted/EclipseProjects/workBucky/BuckyXMLdemo/HelloX MLworld.rmap
.... so in that instance I needed my HelloXMLworld.rmap.
However, today when I "Resolve and Materialize" my cquery, I dont get
those three projects in my workspace, Instead I just get the error
message shown above.
My HelloXMLworld.rmap is just what I copied from
<rmap
xmlns="http://www.eclipse.org/buckminster/RMap-1.0"
xmlns:mp="http://www.eclipse.org/buckminster/MavenProvider-1.0"
xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0">
<searchPath name="default">
<provider readerType="svn"
componentTypes="eclipse.feature,osgi.bundle,buckminster"
source="true">
<uri format=" http://dev.eclipse.org/svnroot/tools/org.eclipse.buckminster /trunk/org.eclipse.buckminster/demo/{0}">
<bc:propertyRef key="buckminster.component" />
</uri>
</provider>
</searchPath>
<locator searchPathRef="default" pattern="^org\.demo\..*" />
<redirect href=" http://www.eclipse.org/buckminster/samples/rmaps/dogfood.rma p"
pattern=".*"/>
</rmap>
Here is my copy of new_query.cquery
<cq:componentQuery
xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0"
resourceMap=" file:/home/ted/EclipseProjects/workBucky/BuckyXMLdemo/HelloX MLworld.rmap ">
<cq:rootRequest name="org.demo.hello.xml.world"
componentType="osgi.bundle"/>
</cq:componentQuery>
-Ted
Re: [buckminster-dev] having new trouble running hello world xml example. [message #480985 is a reply to message #480899] Wed, 19 August 2009 05:13 Go to previous messageGo to next message
I wonder if the reference to the local rmap needs file:///home/ted/...
instead of just file:/home/ted/...
Does it work if you use the URL
http://www.eclipse.org/buckminster/samples/rmaps/demo.rmap ?
- henrik
> <error message>
> Errors and Warnings
> </errormessage>
> difference).
> <rmap
> source="true">
> </uri>
> </provider>
> </searchPath>
> pattern=".*"/>
> </rmap>
> <cq:componentQuery
Re: [buckminster-dev] having new trouble running hello world xml example. [message #481188 is a reply to message #480985] Thu, 20 August 2009 00:21 Go to previous messageGo to next message
Thansk. No, it didn't work with
http://www.eclipse.org/buckminster/samples/rmaps/demo.rmap either but
I can try again. The problem was reproducible yesterday. I was able
to checkout files with svn from the command line.
-ted
On Wed, Aug 19, 2009 at 2:13 AM, Henrik
> - henrik
>> <error message>
>> Errors and Warnings
>> </errormessage>
>> difference).
>> <?xml version="1.0" encoding="UTF-8"?>
>> <rmap
>> source="true">
>>                        <uri
>>                        </uri>
>>                </provider>
>>        </searchPath>
>>        <locator searchPathRef="default" pattern="^org\.demo\...*" />
>>        <redirect
>> pattern=".*"/>
>> </rmap>
>> <cq:componentQuery
> _______________________________________________
> buckminster-dev mailing list
> buckminster-dev@eclipse.org
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
-Ted
Re: [buckminster-dev] having new trouble running hello world xml example. [message #481358 is a reply to message #480985] Thu, 20 August 2009 11:42 Go to previous messageGo to next message
This is really not working and I honestly it used to and I cannot
discover a change I have made. I apologize if I have made a simple
error, but really need some help. I made a cquery that has the
following code.
<cq:componentQuery
resourceMap="http://www.eclipse.org/buckminster/samples/rmaps/demo.rmap">
<cq:rootRequest name="XMLquery" componentType="osgi.bundle"/>
and I set the uri for resource map to be
and I now get
ERROR [0001] : No suitable provider for component
XMLquery:osgi.bundle was found in resourceMap
XMLquery:osgi.bundle was found in searchPath orbit
ERROR [0001] : Rejecting provider
eclipse.import( http://download.eclipse.org/tools/orbit/downloads/drops/R200 90529135407/updateSite?importType=binary):
No component match was found
XMLquery:osgi.bundle was found in searchPath galileo
eclipse.import( http://download.eclipse.org/releases/galileo?importType=bina ry):
XMLquery:osgi.bundle was found in searchPath maven
maven2(http://repo1.maven.org/maven2): Components of type osgi.bundle
are not supported
Errors and Warnings
E [0001] : No suitable provider for component XMLquery:osgi.bundle was
E [0001] : Rejecting provider
are not supported
> - henrik
>> <error message>
>> Errors and Warnings
>> </errormessage>
>> difference).
>> <rmap
>> source="true">
>>                        <uri
>>                        </uri>
>>                </provider>
>>        </searchPath>
>>        <redirect
>> pattern=".*"/>
>> </rmap>
>> <cq:componentQuery
-Ted
Re: [buckminster-dev] having new trouble running hello world xml example. [message #481359 is a reply to message #480985] Thu, 20 August 2009 11:45 Go to previous messageGo to next message
Oh the name of the cquery I made was XMLquery.cquery -ted
> following code.
> <cq:componentQuery
> and I now get
> are not supported
> Errors and Warnings
> are not supported
>> - henrik
>>> <error message>
>>> Errors and Warnings
>>> </errormessage>
>>> difference).
>>> <rmap
>>> source="true">
>>>                        <uri
>>>                        </uri>
>>>                </provider>
>>>        </searchPath>
>>>        <redirect
>>> pattern=".*"/>
>>> </rmap>
>>> <cq:componentQuery
>  -Ted
-Ted
Re: [buckminster-dev] having new trouble running hello world xml example. [message #481387 is a reply to message #480985] Thu, 20 August 2009 14:00 Go to previous message
Sigh ... this was my error. Sometimes I wonder how I get my shoes on
the right feet in the morning.
I had the wrong component name ... need org.demo.hello.xml.world not
the name of my query file.
Your Chapter 14 has the correct information ... all I have to do is
read it correctly which I did a few days ago but the read incorrectly
yesterday and today.
-ted
> - henrik
>> <error message>
>> Errors and Warnings
>> </errormessage>
>> difference).
>> <rmap
>> source="true">
>>                        <uri
>>                        </uri>
>>                </provider>
>>        </searchPath>
>>        <redirect
>> pattern=".*"/>
>> </rmap>
>> <cq:componentQuery
-Ted
Previous Topic:Check-in comments
Next Topic:Buckminster and Bamboo
Current Time: Thu Jul 24 21:41:18 EDT 2025
Powered by FUDForum. Page generated in 0.06974 seconds
