subversive does not recognizes project differences [message #468424] |
Wed, 05 August 2009 08:54  |
Hello all,
I got very annoying problem on my Eclipse.
Till yesterday everything worked fine and without any problems. But since
few days my SVN plugin seems not to notice project changes.
Normaly in project explorer window, when there was some differences
between files on disk and on base SVN marked my files (and projects) with
'>' sign.
Now it just doesent do that.
Refreshing view doesent work. I downloaded latest Eclipse and reinstalled
all plugins, but even this didn't helped.
It seems to work correct when I'm doing some changes on my local PC (it
marks files), but when someone else made a change on SVN database it
doesn't recognises that.
Comparing with latest from repository works fine, resynchronizing as well,
it just doesnt mark files :/
I found these links:
http://forums.polarion.com/viewtopic.php?f=8&t=2710& start=0
http://svn.haxx.se/subusers/archive-2006-06/0208.shtml
but it's not the same issue.
Any ideas?
Lukasz
Re: subversive does not recognizes project differences [message #480973 is a reply to message #468424] |
Wed, 19 August 2009 04:47   |
Hello Lukasz,
As I understood, if you modify file content inside Eclipse, it's decorated
as changed; but if someone commits changes to file, it's not marked as
changed. If it's so, then this is a correct behaviour, because
resources should not be decorated in Package Explorer if they have incoming
changes.
Also please check errors in Error Log view, probably something can break
decoration. You can also check decoration settings in
Windows/Preferences/Team/SVN/Label Decorations.
> Hello all,
> '>' sign.
> Any ideas?
> Lukasz
Re: subversive does not recognizes project differences [message #481477 is a reply to message #481467] |
Fri, 21 August 2009 04:13  |
Yes, i knew about synchronize. I just thought that there will be some auto
feature which inform me that somebody made changes in the project (so I
don't have to worry and remember about it).
Never mind. Many thanks for the replies, now I know anything I wanted.
Cheers
Lukasz
FUDForum. Page generated in 0.04185 seconds
