Cache Problem when using Xulrunner in Eclipse RCP? [message #479270] |
Mon, 10 August 2009 09:51  |
in my RCP I explicitly use the Mozilla Engine (Xulrunner).
browser = new Browser(parent, SWT.MOZILLA);
Currently I work under Windows.
When doing so, a new Mozilla profile named eclipse is created and
automatically chosen when starting my application.
This seems to be a default.
Within this eclipse profile the Cache folder is filled when browsing around.
Now I start a second RCP application, that also uses the Gecko engine.
This other application also uses the eclipse profile folder and the
Cache folder.
If now I reload my page in the first application, loading does not
finish. No images are shown (they should come from cache)...
Can somebody else confirm this behaviour? Is there a solution?
Martin
Re: Cache Problem when using Xulrunner in Eclipse RCP? [message #480818 is a reply to message #480683] |
Tue, 18 August 2009 10:58   |
Thank you...
Am 18.08.2009 10:25, schrieb Jiyul:
> Yeah that problem killed me couple of times.
> use it:
> nsICacheService cacheService = (nsICacheService)
> Mozilla.getInstance().getServiceManager().getServiceByContra ctID(
> "@mozilla.org/network/cache-service;1",
> nsICacheService.NS_ICACHESERVICE_IID);
> cacheService.evictEntries(1);
> cacheService.evictEntries(2);
What will these two lines do exactly?
> And you should ask this problem Mozilla news group.
> PS. You can override default GRE choosing by setting system property:
> "org.eclipse.swt.browser.XULRunnerPath"
I do not use default GRE choosing. I use an adapted Version of
*org.eclipse.atf.mozilla.swt.browser* together with two plugins, that I
packed with *Xulrunner 1.9.1.3*. This works pretty cool
> System.getProperties().put(
> "org.eclipse.swt.browser.XULRunnerPath",
> "YOUR XUL RUNNER PATH");
> SWT loads Mozilla browser with that. (XUL Runner must be uncompressed.)
I know ;)
> Martin Burchard wrote:
>> Hello,
>> around.
>> Cache folder.
>> Regards
>> Martin
FUDForum. Page generated in 0.25043 seconds
