Failed while installing Dynamic Web Module 2.5 [message #480304] |
Fri, 14 August 2009 16:55  |
Originally posted by: louisseize.gmx.de
Eclipse IDE for Java Developers (Galileo)
Build id: 20090619-0625
Eclipse Web Developer Tools:
3.1.0.v200905242131-7R77FShEVw2xUGpF1LiNxdVAELXy
The creation of a Dynamic Web Project in Galileo with WTP via the Dynamic
Web Project wizard elicits an error message:
Reason: [ditto]
Details: java.lang.NullPointerException
Project contents: Use default
Target runtime: Apache Tomcat v6.0 (works)
Dynamic web module version: 2.5
Configuration: Default Configuration for Apache Tomcat v6.0
[all defaults accepted]
The error occurs on clicking "Finish".
The project "xxx" is created; however, when trying to add a servlet to
"xxx" via the wizard, the project "xxx" is not available in the selector
labeled "Web project". The web project creation appears to have been a
failure.
Googling for the error message brings up some hits (for 2.5 and 2.4), but
no resolution. What could it be?
Being an Eclipe noob, what could I do to track this down?
Note that I'm *not* using the "Eclipse IDE for Java EE Developers", but
the simply the "Eclipse IDE for Java Developers" with additional
components such as WST, Subclipse, Java EE Developer Tools installed.
Re: Failed while installing Dynamic Web Module 2.5 [message #480575 is a reply to message #480304] |
Mon, 17 August 2009 13:03   |
> Dynamic Web Project wizard elicits an error message:
> Reason: [ditto]
> failure.
> but no resolution. What could it be?
Michael,
Is this still a problem? If so, seeing the stack trace leading to the
NullPointerException would help.
Larry
FUDForum. Page generated in 0.08293 seconds
