Home » Archived » Buckminster » New version of Buckminster Book available (rev 0.5)
New version of Buckminster Book available (rev 0.5) [message #388396] Tue, 28 July 2009 21:31 Go to next message
New Draft of Buckminster Book is available at http://tinyurl.com/ncv4lq
This is version 0.5 of the book, and it is now getting near completion.
I (think) have one or two more examples to write, and then final editing
and polish.
Your feedback is much appreciated.
- henrik
Re: New version of Buckminster Book available (rev 0.5) [message #388399 is a reply to message #388396] Wed, 29 July 2009 04:01 Go to previous messageGo to next message
> and polish.
> Regards
> - henrik
Hi Henrik,
thanks a lot for the new version of the book!
As for the feedback: maybe you should correct the advanced property
section after my issues in the 'dynamic property refs' discussion.
This one:
Here is another more advanced example:
<«element» format="/tmp/somewhere/${{0}}">
<«function» ...>
</«element»>
In this example an element that has a format where {0} is expanded to
the value of the first child
element, uses this value (i.e. {0}) as the name of a property that
should be expanded as the final value.
Re: New version of Buckminster Book available (rev 0.5) [message #388495 is a reply to message #388399] Wed, 29 July 2009 09:00 Go to previous messageGo to next message
Fixed in 0.6.
Thanks.
>> completion. I (think) have one or two more examples to write, and then
>> final editing and polish.
>> Regards
>> - henrik
> Hi Henrik,
> This one:
> <«function» ...>
> </«element»>
Re: New version of Buckminster Book available (rev 0.5) [message #468492 is a reply to message #388396] Wed, 05 August 2009 12:19 Go to previous messageGo to next message
First line on page 69 is hard to follow. Might be a typo.
Tas
"Henrik Lindberg" <henrik.lindberg@cloudsmith.com> wrote in message
news:h4o8q9$ria$1@build.eclipse.org...
> This is version 0.5 of the book, and it is now getting near completion. I
> (think) have one or two more examples to write, and then final editing and
> polish.
> Regards
> - henrik
Re: New version of Buckminster Book available (rev 0.5) [message #468505 is a reply to message #468492] Wed, 05 August 2009 13:17 Go to previous messageGo to next message
Hi, no, not a typo, but some commas would make it easier to read. I will
rephrase it.
- henrik
> Tas
>> Regards
>> - henrik
Re: New version of Buckminster Book available (rev 0.5) [message #476280 is a reply to message #468505] Wed, 05 August 2009 19:48 Go to previous messageGo to next message
The text is now changed to read:
"As an example, if you want an attribute in component-C to include the
artifacts ‘g’, and ‘h’, you can declare the attribute’s base to be an
empty string (base=""), and use the paths ‘plugins/g’,
and ‘plugins/h’. You get the same result if you instead set the base
like this: base="plugins", and set the paths to just ‘g’ and ‘h’. Does
it matter which you use? The same files are referenced in both cases.
The answer is: yes, it matters when you are copying the result. Let’s
say you copy the result to a location ‘Z’. In the first case you would
get ‘Z/plugins/g’ and ‘Z/plugins/h’, and in the second case you would
get ‘Z/g’, and ‘Z/h’."
I hope that is clearer.
- henrik
> rephrase it.
> - henrik
>> Tas
>>> then final editing and polish.
>>> Regards
>>> - henrik
Re: New version of Buckminster Book available (rev 0.5) [message #480470 is a reply to message #388396] Mon, 17 August 2009 05:47 Go to previous messageGo to next message
Hi Henrik,
The propertyElement example at the top of page 101 doesn't look like proper
XML. Does it need to be something like this?
<propertyElement
key="hatType"
mutable="true">
<constant value="bandana" />
</propertyElement>
Tas.
> polish.
> Regards
> - henrik
Re: New version of Buckminster Book available (rev 0.5) [message #480478 is a reply to message #480470] Mon, 17 August 2009 06:04 Go to previous messageGo to next message
Yes, thanks. Fixed in 0.6.
- henrik
> proper XML. Does it need to be something like this?
> <propertyElement
> key="hatType"
> mutable="true">
> </propertyElement>
Re: New version of Buckminster Book available (rev 0.5) [message #480844 is a reply to message #388396] Tue, 18 August 2009 12:20 Go to previous messageGo to next message
Hi Henrik,
Page 152, Section "Access to prerequisites and product location", First
sentence. There appears to be a small typo on the word 'though', which I
think should be 'thought'.
Tas
> polish.
> Regards
> - henrik
Re: New version of Buckminster Book available (rev 0.5) [message #480858 is a reply to message #480844] Tue, 18 August 2009 13:16 Go to previous messageGo to next message
fixed in 0.6.
- henrik
> Hi Henrik,
> Tas
Re: New version of Buckminster Book available (rev 0.5) [message #480863 is a reply to message #480858] Tue, 18 August 2009 13:27 Go to previous message
Please stop cross-posting this topic over both newsgroups.
Thomas Hallgren
On 08/18/2009 07:16 PM, Henrik Lindberg wrote:
> fixed in 0.6.
> - henrik
>> Hi Henrik,
>> First sentence. There appears to be a small typo on the word 'though',
>> which I think should be 'thought'.
>> Tas
Previous Topic:Best way to include launchers in an RCP build
Next Topic:How to include component version with an action path
Current Time: Sun Aug 31 05:43:13 EDT 2025
Powered by FUDForum. Page generated in 0.06961 seconds
