Home » Modeling » GMF (Graphical Modeling Framework) » Problem with Link Constraint (OCL)
Problem with Link Constraint (OCL) [message #480395] Sun, 16 August 2009 14:08 Go to next message
Hi all,
If few words:
a CompositeMode is part of my model, it can contain subModes and conditionalConnectors, a connection between these two nodes exists, but I want to allow such connection if both nodes are in one and the same CompositeMode.
I tried with the following target link constraint in the GMFMAP:
CompositeMode.allInstances()->exists(cm| cm.subModes->exists(sm| sm = self) and cm.conditionalConnectors->exists(cc| cc = oppositeEnd))
and this doesn't work because allIntances doesn't work for me, here are the debug logs:
[OCL] Evaluate: remes::CompositeMode
[OCL] Result : org.eclipse.emf.ecore.impl.EClassImpl@9cd7cd (name: CompositeMode) (instanceClassName: null) (abstract: false, interface: false)
[OCL] Evaluate: remes::CompositeMode.allInstances()
[OCL] Result : null
[OCL] Evaluate: remes::CompositeMode.allInstances()->exists(cm : CompositeMode | cm.subModes->exists(sm : SubMode | sm.=(self)).and(cm.conditionalConnectors->exists(cc : ConditionalConnector | cc.=(oppositeEnd))))
[OCL] Result : OclInvalid
Please help me to fix this problem.
Thanks in advance,
Ivo
Re: Problem with Link Constraint (OCL) [message #480782 is a reply to message #480395] Tue, 18 August 2009 09:04 Go to previous messageGo to next message
Hello Ivo,
You have to add parentMode reference to a CompositeMode EClass. This reference
should be opposite to a containment reference from parent CompositeMode to
this one.
Then OCL constraint will be like: self.parentMode.conditionalConnectors->exists(cc|
cc = oppositeEnd)
Alex Shatalin
Re: Problem with Link Constraint (OCL) [message #480839 is a reply to message #480782] Tue, 18 August 2009 12:05 Go to previous messageGo to next message
Thanks Alex,
I thought of this way, but I didn't want to make modifications to the model.
Is this the only way?
Because in my case the SubMode can be contained in two totally different containers CompositeMode and RemesDiagram - so the parent cannot be unified.
Ivo
Re: Problem with Link Constraint (OCL) [message #480853 is a reply to message #480839] Tue, 18 August 2009 12:56 Go to previous messageGo to next message
--=-oIY2sPBPWmDKHQCIzBbb
Content-Type: text/plain
Hi, Ivo,
There is a GMF enhancement request open for GMF validation to apply the
OCL option to treat EObject as the implicit root class of model classes.
This would provide access to eContainer() and the other operations that
EObject defines.
Perhaps there is something that you can override/extend in your
application to apply this option?
Christian
On Tue, 2009-08-18 at 12:05 -0400, Ivo Petkov wrote:
> Thanks Alex,
> Regards,
> Ivo
Content-Type: text/html; charset="utf-8"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.24.1.1">
</HEAD>
<BODY>
Hi, Ivo,<BR>
<BR>
There is a GMF enhancement request open for GMF validation to apply the OCL option to treat EObject as the implicit root class of model classes.&nbsp; This would provide access to eContainer() and the other operations that EObject defines.<BR>
<BR>
Perhaps there is something that you can override/extend in your application to apply this option?<BR>
<BR>
Cheers,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
Thanks Alex,
Ivo
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-oIY2sPBPWmDKHQCIzBbb--
Re: Problem with Link Constraint (OCL) [message #516458 is a reply to message #480853] Tue, 23 February 2010 19:08 Go to previous message
For the interested, the enhancement request appears to be the following:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=256461
Strangely enough, the documentation at
http://wiki.eclipse.org/index.php/GMF_Constraints#Link_Const raints
suggests that 'eContainer' etc. are actually available, when they are
not (for nodes, at least).
In the meantime, you can set the Constraint language to "java", set
"Inject Expression Body" to true in the gmfgen [1], and use a constraint
similar to the following:
return domainElement.eContainer() != null;
Hope this helps someone :-)
Jevon
[1]: http://wiki.eclipse.org/GMF_Constraints#Java
Christian W. Damus wrote:
> Hi, Ivo,
> classes. This would provide access to eContainer() and the other
> Cheers,
> Christian
>> Thanks Alex,
>> Regards,
>> Ivo
Previous Topic:2 palettes in GMF
Next Topic:Potential bug in PathmapManager.notifyChanged(Notification msg)
Current Time: Sat Jul 26 06:14:12 EDT 2025
Powered by FUDForum. Page generated in 0.07992 seconds
