Avoid showing errors in editor that are caused because of preprocessing directives [message #480749] |
Tue, 18 August 2009 07:57  |
Hi. My name's David. I recently started using MTJ, and as I needed the preprocessor, I developed some code including directives. The build tree shows no errors, and I can launch the Midlet without a problem because no real errors exist when the code is already preprocessed.
The problem arises in code editor windows. Seems that the code there is trying to be compiled in search of correctness before it is preprocessed.
Is there a way to make eclipse editor windows be affected with the preprocessor from MJT so that this kind of "phantom errors" are not shown?
Thank you in advance.
[Updated on: Tue, 18 August 2009 07:57] by Moderator
FUDForum. Page generated in 0.03969 seconds
