Home » Eclipse Projects » Eclipse Platform » tell me some popupmenu items
tell me some popupmenu items [message #480421] Mon, 17 August 2009 01:02 Go to next message
Originally posted by: shenji.ecquaria.com
now i want create a menu on top of popupmenu,see org.eclipse.ui.menus and
org.eclipse.ui.popupMenus often used "additions",why i can't find another
items
similar with "additions"£¬could you tell me some other existing popupmenu
items?thank you.
<extension
point="org.eclipse.ui.menus">
<menuContribution
locationURI="popup:org.eclipse.ui.popup.any?before=additions ">
<menu
id="xxx.menu1"
label="test">
</menu>
</menuContribution>
</extension>
Re: tell me some popupmenu items [message #480585 is a reply to message #480421] Mon, 17 August 2009 14:12 Go to previous messageGo to next message
You would need to put a separator named "additions" in your created menu.
Then you have to put items in it in order to make that menu appear.
PW
Re: tell me some popupmenu items [message #480629 is a reply to message #480585] Mon, 17 August 2009 21:51 Go to previous messageGo to next message
but eclipse had a separator named "additions" already,i have know how to
do,you can write as "before=group.new" or "before=group.show" and so
on,then the menu will appear above the popupmenu "new" or "show".
Re: tell me some popupmenu items [message #480634 is a reply to message #480421] Mon, 17 August 2009 22:36 Go to previous messageGo to next message
when used "before=group.new","test" appear on top of popupmenu in Package
Explorer view,but there is no change in Navigator view.is there any way to
let it top of popupmenu in the Navigator view.
<extension
<menuContribution
locationURI="popup:org.eclipse.ui.popup.any?before=group.new ">
<menu
id="xxx.menu1"
label="test">
</menu>
</menuContribution>
</extension>
Re: tell me some popupmenu items [message #480704 is a reply to message #480634] Tue, 18 August 2009 05:46 Go to previous messageGo to next message
Oh, you mean how could you add your menu at the top of every popup menu where it would appear?
The answer is you cannot. Each part uses different group markers in different places when creating their popup menus, and some parts don't use any other group marker than "additions". That you were able to do it in the Package Explorer is impressive Smile
PW
Re: tell me some popupmenu items [message #480716 is a reply to message #480704] Tue, 18 August 2009 06:05 Go to previous message
Thank you!
Previous Topic:Opening drop down menu from cheat sheet
Next Topic:3.6 I-Build update site not working
Current Time: Wed Jul 23 06:44:32 EDT 2025
Powered by FUDForum. Page generated in 0.03784 seconds
