Home » Modeling » Modeling (top-level project) » How to use ecore2xml?
How to use ecore2xml? [message #480474] Mon, 17 August 2009 05:58 Go to next message
I have created an ecore2xml mapping. Now I want to make it work. Is it
correct that ecore2xml only works with the resource type xml in my
genmodel? How can I tell my genmodel to use the ecore2xml mapping? Is it
even possible to give the genmodel the ecore2xml mapping?
Mark
Re: How to use ecore2xml? [message #480505 is a reply to message #480474] Mon, 17 August 2009 08:47 Go to previous messageGo to next message
Mark,
This question is probably more appropriate for the EMF newsgroup (copied).
It's not really expected that Ecore2XML models be used as input to a
generator model... what were you looking to achieve? The original intent
of Ecore2XML models was to use them as input to a resource
implementation, to help drive the way resources are (de)serialized
to/from XML...
Kenn
Mark Hoffmann wrote:
> Hello,
> Mark
Re: How to use ecore2xml? [message #480507 is a reply to message #480474] Mon, 17 August 2009 08:50 Go to previous message
--------------040108070608090607060904
Mark,
It's best to use the EMF newsgroup to ask EMF questions. I've added it
to the "to" list of the reply.
This presentation has some information about how to use it:
< http://www.eclipse.org/modeling/emf/docs/presentations/Eclip seCon/EclipseCon2006_EMF_Advanced.pdf>
You can't tell the GenModel to generated code to use it...
> Hello,
> Mark
<html>
<head>
http-equiv="Content-Type">
</head>
Mark,<br>
<br>
Re: How to use ecore2xml? [message #617775 is a reply to message #480474] Mon, 17 August 2009 08:47 Go to previous message
Mark,
to/from XML...
Kenn
> Hello,
> Mark
Re: How to use ecore2xml? [message #617778 is a reply to message #480474] Mon, 17 August 2009 08:50 Go to previous message
Mark,
> Hello,
> Mark
<html>
<head>
</head>
Mark,<br>
<br>
Previous Topic:How to use ecore2xml?
Next Topic:[Announce] Eclipse Modeling Days
Current Time: Sat Jul 26 12:48:22 EDT 2025
Powered by FUDForum. Page generated in 0.03336 seconds
