Home » Modeling » M2T (model-to-text transformation) » resolving cross-references to imported model in xpand/xtend
resolving cross-references to imported model in xpand/xtend [message #480306] Fri, 14 August 2009 17:01 Go to next message
I'm trying to use xtext to create an entity model and a separate gui model
that references the entity model.
I created two simple of xtext projects to demonstrate this issue:
model.entity
model.entity.generator
model.entity.ui
model.gui
model.gui.generator
model.gui.ui
The entity project just has the standard unmodified example xtext model.
The Gui.xtext file looks like:
grammar model.Gui with model.Entity
generate gui "http://www.Gui.model"
import "http://www.Entity.model"
GuiModel :
(imports+=Import)*
'gui' entity=[Entity];
The model.gui.generator project has a MyModel.gui file that looks like:
import "classpath:/model/MyModel.entity"
gui Leaf
The problem I'm running into is that the Xpand and Xtend files in my
model.gui.generator project are unable to see the entity cross-reference
in the GuiModel.
I have an Extensions.ext file:
import entity;
import gui;
Entity getEntity(GuiModel this) :
this.entity;
Eclipse reports "Couldn't find property 'entity' for type 'gui::GuiModel'"
I get the same error in my xpt file when referencing the entity property
of GuiModel.
The funny thing is that I am able to run generation successfully from the
mwe workflow, so the workflow is able to resolve this cross-reference just
fine. It is just the xpand/xtend editors in the dependent
model.gui.generator project that don't work properly. Can anyone tell me
what I might be doing wrong? Or is this a bug with the tooling?
Edwin
Re: resolving cross-references to imported model in xpand/xtend [message #480307 is a reply to message #480306] Fri, 14 August 2009 17:06 Go to previous messageGo to next message
One other thing I found, which may be a clue or may be nothing - if I open
the model.gui/src-gen/model/Gui.ecore model file in the Sample Ecore Model
Editor and try to navigate to the entity property under GuiModel, I get an
error: FileNotFoundException http://www.Entity.model
Edwin
Re: resolving cross-references to imported model in xpand/xtend [message #480324 is a reply to message #480307] Fri, 14 August 2009 22:02 Go to previous messageGo to next message
A zipfile containing these projects is here:
http://esp1.freeshell.org/model_projects.zip
Edwin
Re: resolving cross-references to imported model in xpand/xtend [message #480373 is a reply to message #480324] Sun, 16 August 2009 07:05 Go to previous messageGo to next message
Hi Edwin,
this seems to be a bug. The Xtend editor should work fine if you install
the entity Ecore model into your eclipse instance or edit the Xtend file
in a runtime workbench. However, I think the Xtend editor should resolve
the meta model in the development workspace as well.
Would you please be so kind and file a bugzilla ticket?
Sebastian
Am 15.08.09 04:02, schrieb Edwin Park:
> Edwin
Re: resolving cross-references to imported model in xpand/xtend [message #480408 is a reply to message #480373] Sun, 16 August 2009 18:47 Go to previous message
Filed bugzilla here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=286745
Edwin
Previous Topic:how to query xmi model-file
Next Topic:Run JET template from java error
Current Time: Wed Jul 23 06:09:28 EDT 2025
Powered by FUDForum. Page generated in 0.27808 seconds
