Home » Eclipse Projects » Eclipse Platform » How to link a contentType to an existing editor?
How to link a contentType to an existing editor? [message #439875] Fri, 31 July 2009 02:50 Go to next message
Originally posted by: loic.fejoz.realtimeatwork.com
I got a simple problem about content type. Just imagine I would like to
add a new serialization type for Ecore, let's say HUTN [1]. I know how
to declare a new type content in a plugin. I know how to create a
content parser.
But, HUTN is a textual file format which is not xml. Thus the declared
HUTN content type inherit from org.eclipse.core.runtime.text and not
org.eclipse.emf.ecore (or emof).
The problem is that, now, none of the ecore editor are available even if
the content parser return an EPackage object.
I have try to declare an editor with same ID as the ecore editor with a
contentTypeBinding, but it does not appear properly as such in the gui.
Indeed the menu entry loss the icon and the translated label. This is
because the attribute name is mandatory for an editor in the plugin.xml.
Thus so far it is the best option. But still you need to do that for
every known editor.
Is there an extension to add contentTypeBinding to editor declared in
other plugins?
Is that the correct way to go?
More globally, it appears that there should be 2 hierarchies, one for
content types, one for models...
PS : I have post the same question on eclipse.tools.emf, but maybe you
will have other ideas...
Loïc Fejoz
[1] Human-Usable Textual Notation
<http://www.omg.org/technology/documents/formal/hutn.htm>
Re: How to link a contentType to an existing editor? [message #468117 is a reply to message #439875] Tue, 04 August 2009 04:51 Go to previous messageGo to next message
Loïc Fejoz wrote:
> Hello,
> to add a new serialization type for Ecore, let's say HUTN [1]. I know
> how to declare a new type content in a plugin. I know how to create a
> content parser.
> if the content parser return an EPackage object.
> a contentTypeBinding, but it does not appear properly as such in the gui.
> every known editor.
> other plugins?
No.
Yes, but unfortunately this means to copy the strings and icons and
sometimes referring to an internal class.
Dani
Re: How to link a contentType to an existing editor? [message #479710 is a reply to message #468117] Wed, 12 August 2009 03:09 Go to previous messageGo to next message
Thank you.
Loïc Fejoz
Daniel Megert a écrit :
> Loïc Fejoz wrote:
>> Hello,
>> content parser.
>> every known editor.
>> other plugins?
> No.
> Dani
Re: How to link a contentType to an existing editor? [message #480269 is a reply to message #479710] Fri, 14 August 2009 11:33 Go to previous message
Loïc Fejoz ha scritto:
> Thank you.
I know it is OT (it has nothing to do with your question), but have you
ever considered doing your project with XText? It looks like the best fit...
Previous Topic:switching perspective doesn't seem to restore selection variable in Eclipse 3.5
Next Topic:own update site: "software install" not showing features / website does ... ?
Current Time: Sat Jul 26 18:54:33 EDT 2025
Powered by FUDForum. Page generated in 0.24134 seconds
