Home » Modeling » Epsilon » ClassCastException when assigning enum literal to attribute
ClassCastException when assigning enum literal to attribute [message #480082] Thu, 13 August 2009 13:28 Go to next message
Originally posted by: nyoescape.gmail.com
--------------040603060700070605090205
Content-Type: text/plain; charset=ISO-8859-1
Hello everyone,
This EOL script produces an ClassCastException in its very last line,
saying it can't convert an EEnumLiteralImpl into a LabelAccessMethod:
var lm := new GmfMap!FeatureLabelMapping;
var y := GmfMap!LabelTextAccessMethod#PRINTF;
y.println();
lm.viewMethod := y; -- ** here **
I've looked around and it seems to be as simple as applying the attached
patch, so we use the enumeration instance itself instead of the wrapper,
but I'm not sure if that's the right way to do it. I've sent a bug
report with more information and a test project over here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=286549
Antonio
Content-Type: text/x-patch;
name="fix-enum-classcastexception.patch"
Content-Disposition: inline;
filename="fix-enum-classcastexception.patch"
SW5kZXg6IHNyYy9vcmcvZWNsaXBzZS9lcHNpbG9uL2VtYy9lbWYvQWJzdHJh Y3RFbWZNb2Rl
bC5qYXZhCj09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09
PT09PT09PT09PT09PT09PT09PT0KLS0tIHNyYy9vcmcvZWNsaXBzZS9lcHNp bG9uL2VtYy9l
bWYvQWJzdHJhY3RFbWZNb2RlbC5qYXZhCShyZXZpc2lvbiA1MjIpCisrKyBz cmMvb3JnL2Vj
bGlwc2UvZXBzaWxvbi9lbWMvZW1mL0Fic3RyYWN0RW1mTW9kZWwuamF2YQko d29ya2luZyBj
b3B5KQpAQCAtMTIxLDcgKzEyMSw3IEBACiAJCQkJCQlFRW51bSBlRW51bSA9 IChFRW51bSkg
Y2xhc3NpZmllcjsNCiAJCQkJCQlFRW51bUxpdGVyYWwgbGl0ZXJhbCA9IGVF bnVtLmdldEVF
bnVtTGl0ZXJhbChsYWJlbCk7DQogCQkJCQkJDQotCQkJCQkJaWYgKGxpdGVy YWwgIT0gbnVs
bCkgcmV0dXJuIGxpdGVyYWw7DQorCQkJCQkJaWYgKGxpdGVyYWwgIT0gbnVs bCkgcmV0dXJu
IGxpdGVyYWwuZ2V0SW5zdGFuY2UoKTsNCiAJCQkJCX0NCiAJCQkJfQ0KIAkJ CX0NCg==
--------------040603060700070605090205--
Re: ClassCastException when assigning enum literal to attribute [message #480083 is a reply to message #480082] Thu, 13 August 2009 13:39 Go to previous messageGo to next message
Hi Antonio,
Many thanks for your patch. I'll look into this for 0.8.7. As an
alternative workaround you could use
var y := GmfMap!LabelTextAccessMethod#PRINTF.instance;
Dimitris
Antonio García Domínguez wrote:
> Hello everyone,
> y.println();
> Cheers,
> Antonio
Re: ClassCastException when assigning enum literal to attribute [message #480198 is a reply to message #480083] Fri, 14 August 2009 06:45 Go to previous messageGo to next message
Hello Dimitris,
You might want to avoid that patch, as it seems I did break something
with it :-/. I noticed that Eugenia suddenly stopped setting some of my
links to be dashed lines. In fact, the following code in the formatLine
operation of Formatting.eol stopped doing anything:
if (style.isDefined() and self.isKindOf(GmfGraph!Shape)) {
if (style = 'dash') {
self.lineKind := GmfGraph!LineKind#LINE_DASH.instance;
else if (style = 'dot') {
self.lineKind := GmfGraph!LineKind#LINE_DOT.instance;
else if (style = 'solid') {
self.lineKind := GmfGraph!LineKind#LINE_SOLID.instance;
I set up println() calls all over the place, and the right line is being
reached properly. Changing this:
to this:
self.lineKind := GmfGraph!LineKind#LINE_DASH;
did the trick. It's probably because after applying the patch,
GmfGraph!LineKind#LINE_DASH itself returns the instance, and trying to
get the instance of the instance results in an undefined value. This
undefined value is then replaced by the default value, LINE_SOLID.
I'll add a notice about this in the bug report.
Antonio
Re: ClassCastException when assigning enum literal to attribute [message #480249 is a reply to message #480198] Fri, 14 August 2009 10:37 Go to previous message
Hi Antonio,
I thought that this might happen... I'll look into this next week to see
if I can come up with a workaround that allows both things to work so
that we don't end up breaking existing code.
Dimitris
> Hello Dimitris,
> to this:
> Cheers,
> Antonio
Re: ClassCastException when assigning enum literal to attribute [message #574078 is a reply to message #480082] Thu, 13 August 2009 13:39 Go to previous message
Hi Antonio,
Dimitris
> Hello everyone,
> y.println();
> Cheers,
> Antonio
Re: ClassCastException when assigning enum literal to attribute [message #574106 is a reply to message #480083] Fri, 14 August 2009 06:45 Go to previous message
Hello Dimitris,
to this:
Antonio
Re: ClassCastException when assigning enum literal to attribute [message #574136 is a reply to message #480198] Fri, 14 August 2009 10:37 Go to previous message
Hi Antonio,
Dimitris
> Hello Dimitris,
> to this:
> Cheers,
> Antonio
Previous Topic:ClassCastException when assigning enum literal to attribute
Next Topic:Problem with generated wizards
Current Time: Thu Jul 24 23:10:26 EDT 2025
Powered by FUDForum. Page generated in 0.35752 seconds
