Home » Modeling » M2T (model-to-text transformation) » [MTL] How to reverse lists ?
[MTL] How to reverse lists ? [message #480033] Thu, 13 August 2009 10:06 Go to next message
Hey,
is there a MTL command to reverse a list (Collection ?, Sequence ?)
content (as acceleo's reverse() method ?)
Guillaume
Re: [MTL] How to reverse lists ? [message #480192 is a reply to message #480033] Fri, 14 August 2009 06:31 Go to previous messageGo to next message
I don't know about hidden features of Acceleo, but it seems that OCL does
not provide such a method on Collections and the MOF Model To Text
standard does not include such a method in it's library. Here is a query I
used for creating a new sequence that contains the elements in reverse
order:
[query reverse(s : Collection(T)) : Sequence(T) =
s->iterate(x; acc : Sequence(T) = Sequence{} |
acc->prepend(x) )/]
You will have troubles with the returned collection, due to the inferred
type of the sequence. Here is an example how to use it:
[template operationInfo(o : Operation)]
Operation name: [o.name/]
Parameters (reverse):
[o.ownedParameter->reverse()->collect(oclAsType(uml::Parameter)).name/]
[/template]
I hope this helps.
Re: [MTL] How to reverse lists ? [message #480215 is a reply to message #480192] Fri, 14 August 2009 08:09 Go to previous messageGo to next message
> does not provide such a method on Collections and the MOF Model To Text
> I used for creating a new sequence that contains the elements in reverse
> order:
> acc->prepend(x) )/]
> [/template]
> I hope this helps.
It works well :)
Thanks a lot Mr.Bureck !
Re: [MTL] How to reverse lists ? [message #480491 is a reply to message #480215] Mon, 17 August 2009 07:49 Go to previous messageGo to next message
Thanks a lot for using Acceleo
You have to put the tag [Acceleo] at the beginning of the subject (and
not MTL)
MTL is the name of the OMG standard, so we can understand ;-)
but the name of the eclipse implementation is Acceleo
Jonathan
>> Text standard does not include such a method in it's library. Here is
>> a query I used for creating a new sequence that contains the elements
>> in reverse order:
>> acc->prepend(x) )/]
>> inferred type of the sequence. Here is an example how to use it:
>> [/template]
>> I hope this helps.
> It works well :)
Re: [MTL] How to reverse lists ? [message #480773 is a reply to message #480215] Tue, 18 August 2009 08:52 Go to previous message
--------------050605020300040506090009
This iterate is indeed the way to go for now, the "old" acceleo's
"nReverse" method has been proposed no equivalent for a simple reason :
the incoming version of OCL should have its own "collection::reverse()"
method for this.
Laurent Goubet
Obeo
Guillaume Bourel a
Previous Topic:Run JET template from java error
Next Topic:[XPAND] Xpand/Xtend Invoker builder slowdown
Current Time: Sun Jul 27 11:44:56 EDT 2025
Powered by FUDForum. Page generated in 0.04321 seconds
