Home » Eclipse Projects » DSDP - Target Management » CVS checkout to remote project folder fails
CVS checkout to remote project folder fails [message #17738] Sat, 12 January 2008 11:38 Go to next message
1. I have created a remote ssh connection to host "mavis"
2. I created a new empty folder "foo" on remote host via sftp browser.
3. I used right-click option to "Create Remote project" on the new empty
folder "foo". This created a project called mavis_foo in my eclipse
workspace
4. I changed to CVS Repository Explorer view and selected a module "tas"
for checkout. The cvs server is connected via extssh. I right clicked on
"tas" module and selected "Checkout as" option which opens the project
wizard
5. I selected "Checkout into existing project" and clicked on next
6. I then selected "mavis_foo" project name and clicked on next/finish.
It tries to checkout the tas module into remote folder but fails with the
following error in popup window:
Errors saving CVS synchronization information to disk. Please fix the
problems listed below and then update the affected resources from the CVS
repository.
Could not get input stream
Operation failed. File system input or output error
The cvs console logs show:
cvs co -d "tas" -P -A "/mavis_foo/tas"
cvs server: Updating tas
U tas/VERSION
failed due to an internal error (took 0:04.203)
Error: The file store does not exist
I am running eclipse on windows platform and remote ssh connection is to
solaris host. Version details are:
Eclipse SDK
Version: 3.3.1.1
Build id: M20071023-1652
RSE: 2.0.2.v20071030
Has anyone tried to do this or know what is the issue here?
Hemang.
Re: CVS checkout to remote project folder fails [message #480187 is a reply to message #17738] Fri, 14 August 2009 06:07 Go to previous messageGo to next message
I repply to this message cause I have the same problem and I see there is
no answer.
- On Windows XP I have Eclipse 3.4.2 with CDT, RSE and RDT
- I have a remote C project on a IBM AIX
I would like to get sources on CVS, to put it on my project.
It works perfectly localy. But with a remote target it seemes to have some
problems.
Some times I get "file store does not exist" when I make a commit or an
update, or when I open a project.
I have this error on a commit, but if I make a commit agin, it works fine
without this error.
Can anyone help me to understand where this error can come from ?
Thank you.
Guillaume Le Priol
Re: CVS checkout to remote project folder fails [message #480236 is a reply to message #480187] Fri, 14 August 2009 09:53 Go to previous messageGo to next message
I just want to add the log I got with Eclipse in my workspace, just in case it can help someone.
________________________________________
!MESSAGE The file store does not exist
!STACK 1
org.eclipse.core.runtime.CoreException: The file store does not exist
at org.eclipse.rse.internal.efs.RSEFileStoreImpl.getRemoteFileO bject(RSEFileStoreImpl.java:329)
at org.eclipse.rse.internal.efs.RSEFileStoreImpl.openInputStrea m(RSEFileStoreImpl.java:607)
at org.eclipse.rse.internal.efs.RSEFileStore.openInputStream(RS EFileStore.java:292)
at org.eclipse.team.internal.ccvs.core.util.SyncFileWriter.getI nputStream(SyncFileWriter.java:528)
at org.eclipse.team.internal.ccvs.core.util.SyncFileWriter.read Lines(SyncFileWriter.java:546)
at org.eclipse.team.internal.ccvs.core.util.SyncFileWriter.read AllNotifyInfo(SyncFileWriter.java:332)
at org.eclipse.team.internal.ccvs.core.resources.EclipseSynchro nizer.getNotifyInfo(EclipseSynchronizer.java:1242)
at org.eclipse.team.internal.ccvs.core.resources.EclipseFile.ge tNotifyInfo(EclipseFile.java:316)
at org.eclipse.team.internal.ccvs.core.resources.EclipseFile.ge tPendingNotification(EclipseFile.java:454)
at org.eclipse.team.internal.ccvs.core.client.AbstractStructure Visitor.sendPendingNotification(AbstractStructureVisitor.jav a:230)
at org.eclipse.team.internal.ccvs.core.client.AbstractStructure Visitor.sendFile(AbstractStructureVisitor.java:171)
at org.eclipse.team.internal.ccvs.core.client.ModifiedFileSende r.sendFile(ModifiedFileSender.java:39)
at org.eclipse.team.internal.ccvs.core.client.FileStructureVisi tor.visitFile(FileStructureVisitor.java:48)
at org.eclipse.team.internal.ccvs.core.resources.EclipseFile.ac cept(EclipseFile.java:133)
at org.eclipse.team.internal.ccvs.core.client.AbstractStructure Visitor.visit(AbstractStructureVisitor.java:281)
at org.eclipse.team.internal.ccvs.core.client.Commit.sendLocalR esourceState(Commit.java:50)
at org.eclipse.team.internal.ccvs.core.client.Command.doExecute (Command.java:394)
at org.eclipse.team.internal.ccvs.core.client.Command$1.run(Com mand.java:326)
at org.eclipse.team.internal.ccvs.core.resources.EclipseSynchro nizer.run(EclipseSynchronizer.java:1481)
at org.eclipse.team.internal.ccvs.core.resources.EclipseResourc e$2.run(EclipseResource.java:262)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1800)
at org.eclipse.team.internal.ccvs.core.resources.EclipseResourc e.run(EclipseResource.java:259)
at org.eclipse.team.internal.ccvs.core.client.Command.execute(C ommand.java:338)
at org.eclipse.team.internal.ccvs.core.client.Command.execute(C ommand.java:804)
at org.eclipse.team.internal.ccvs.ui.operations.CommitOperation .executeCommand(CommitOperation.java:39)
at org.eclipse.team.internal.ccvs.ui.operations.SingleCommandOp eration.execute(SingleCommandOperation.java:42)
at org.eclipse.team.internal.ccvs.ui.operations.RepositoryProvi derOperation.execute(RepositoryProviderOperation.java:282)
at org.eclipse.team.internal.ccvs.ui.operations.SingleCommandOp eration.execute(SingleCommandOperation.java:66)
at org.eclipse.team.internal.ccvs.ui.operations.RepositoryProvi derOperation.execute(RepositoryProviderOperation.java:256)
at org.eclipse.team.internal.ccvs.ui.operations.RepositoryProvi derOperation.execute(RepositoryProviderOperation.java:210)
at org.eclipse.team.internal.ccvs.ui.operations.CVSOperation.ru n(CVSOperation.java:81)
at org.eclipse.team.internal.ccvs.ui.wizards.CommitWizard$AddAn dCommitOperation.execute(CommitWizard.java:110)
at org.eclipse.team.internal.ui.actions.JobRunnableContext.run( JobRunnableContext.java:144)
at org.eclipse.team.internal.ui.actions.JobRunnableContext$Reso urceJob.runInWorkspace(JobRunnableContext.java:72)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run (InternalWorkspaceJob.java:38)
Thank you.
Guillaume Le Priol
Re: CVS checkout to remote project folder fails [message #516950 is a reply to message #17738] Thu, 25 February 2010 10:12 Go to previous message
Bump.
I'm using:
Windows XP
Eclipse 3.6M5
RSE 3.1.1
CDT 7M5
Remote c++ project with files are on a remote linux host. Using cvs with pserver. My project has CVS folders already.
CVS commands generate a 'The file store does not exist' error. If I keep retrying, the command eventually works, but with the error.
Has anyone found a workaround?
Thank you,
Eli
Re: CVS checkout to remote project folder fails [message #582117 is a reply to message #17738] Fri, 14 August 2009 06:07 Go to previous message
no answer.
problems.
without this error.
Thank you.
Guillaume Le Priol
Re: CVS checkout to remote project folder fails [message #582140 is a reply to message #480187] Fri, 14 August 2009 09:53 Go to previous message
!STACK 1
Thank you.
Guillaume Le Priol
Re: CVS checkout to remote project folder fails [message #583121 is a reply to message #17738] Thu, 25 February 2010 10:12 Go to previous message
Bump.
I'm using:
Windows XP
Eclipse 3.6M5
RSE 3.1.1
CDT 7M5
Thank you,
Eli
Previous Topic:[solved] FTP Connection problem
Next Topic:can't debug remotely
Current Time: Tue Nov 04 17:40:46 EST 2025
Powered by FUDForum. Page generated in 0.06154 seconds
