Home » Archived » BIRT » Trigger problem with BIRT 2.5.0
Trigger problem with BIRT 2.5.0 [message #479393] |
Mon, 10 August 2009 16:44  |
Hi everybody,
I updated my Eclipse IDE to 3.5 and also updated to BIRT 2.5.0.
After this update my "Trigger" dose not work correctly.
I have a pie chart and i add a trigger with the ONMOUSEOVER_LITERAL
condition and a SHOW_TOOLTIP_LITERAL action type.
Trigger is associated with a series type as follows:
sePie = (PieSeries) PieSeriesImpl.create();
ActionValue actionValue = TooltipValueImpl.create(0, null);
Action action = ActionImpl.create(ActionType.SHOW_TOOLTIP_LITERAL,
actionValue);
Trigger mouseOver =
TriggerImpl.create(TriggerCondition.ONMOUSEOVER_LITERAL,acti on);
sePie.getTriggers().add(mouseOver);
The co-ordinates for MouseOver are not determined properly.
This results that the wrong information are shown.
Any idea is welcome.
Thanks in advance.
Re: Trigger problem with BIRT 2.5.0 [message #480040 is a reply to message #479875] |
Thu, 13 August 2009 10:41   |
Farideh,
I can not reproduce the error. How are you rendering (output format and
location)?
Take a look at the attached example.
Jason
import java.awt.Graphics;
import java.awt.Graphics2D;
import java.awt.image.BufferedImage;
import java.io.BufferedWriter;
import java.io.FileWriter;
import java.util.ArrayList;
import java.util.Vector;
import org.eclipse.birt.chart.api.ChartEngine;
import org.eclipse.birt.chart.device.EmptyUpdateNotifier;
import org.eclipse.birt.chart.device.IDeviceRenderer;
import org.eclipse.birt.chart.device.IDisplayServer;
import org.eclipse.birt.chart.device.IImageMapEmitter;
import org.eclipse.birt.chart.factory.GeneratedChartState;
import org.eclipse.birt.chart.factory.IGenerator;
import org.eclipse.birt.chart.model.Chart;
import org.eclipse.birt.chart.model.ChartWithAxes;
import org.eclipse.birt.chart.model.attribute.ActionType;
import org.eclipse.birt.chart.model.attribute.ActionValue;
import org.eclipse.birt.chart.model.attribute.Anchor;
import org.eclipse.birt.chart.model.attribute.AxisType;
import org.eclipse.birt.chart.model.attribute.Bounds;
import org.eclipse.birt.chart.model.attribute.ChartDimension;
import org.eclipse.birt.chart.model.attribute.DataType;
import org.eclipse.birt.chart.model.attribute.IntersectionType;
import org.eclipse.birt.chart.model.attribute.LeaderLineStyle;
import org.eclipse.birt.chart.model.attribute.LegendItemType;
import org.eclipse.birt.chart.model.attribute.LineStyle;
import org.eclipse.birt.chart.model.attribute.Position;
import org.eclipse.birt.chart.model.attribute.SortOption;
import org.eclipse.birt.chart.model.attribute.TickStyle;
import org.eclipse.birt.chart.model.attribute.TriggerCondition;
import org.eclipse.birt.chart.model.attribute.impl.BoundsImpl;
import org.eclipse.birt.chart.model.attribute.impl.ColorDefinitionI mpl;
import org.eclipse.birt.chart.model.attribute.impl.GradientImpl;
import org.eclipse.birt.chart.model.attribute.impl.LineAttributesIm pl;
import org.eclipse.birt.chart.model.attribute.impl.TooltipValueImpl ;
import org.eclipse.birt.chart.model.attribute.impl.URLValueImpl;
import org.eclipse.birt.chart.model.component.Axis;
import org.eclipse.birt.chart.model.component.Series;
import org.eclipse.birt.chart.model.component.impl.SeriesImpl;
import org.eclipse.birt.chart.model.data.Action;
import org.eclipse.birt.chart.model.data.BaseSampleData;
import org.eclipse.birt.chart.model.data.DataFactory;
import org.eclipse.birt.chart.model.data.NumberDataSet;
import org.eclipse.birt.chart.model.data.OrthogonalSampleData;
import org.eclipse.birt.chart.model.data.Query;
import org.eclipse.birt.chart.model.data.SampleData;
import org.eclipse.birt.chart.model.data.SeriesDefinition;
import org.eclipse.birt.chart.model.data.TextDataSet;
import org.eclipse.birt.chart.model.data.Trigger;
import org.eclipse.birt.chart.model.data.impl.ActionImpl;
import org.eclipse.birt.chart.model.data.impl.NumberDataSetImpl;
import org.eclipse.birt.chart.model.data.impl.QueryImpl;
import org.eclipse.birt.chart.model.data.impl.SeriesDefinitionImpl;
import org.eclipse.birt.chart.model.data.impl.TextDataSetImpl;
import org.eclipse.birt.chart.model.data.impl.TriggerImpl;
import org.eclipse.birt.chart.model.impl.ChartWithAxesImpl;
import org.eclipse.birt.chart.model.impl.ChartWithoutAxesImpl;
import org.eclipse.birt.chart.model.layout.Legend;
import org.eclipse.birt.chart.model.layout.Plot;
import org.eclipse.birt.chart.model.type.BarSeries;
import org.eclipse.birt.chart.model.type.LineSeries;
import org.eclipse.birt.chart.model.type.PieSeries;
import org.eclipse.birt.chart.model.type.impl.LineSeriesImpl;
import org.eclipse.birt.chart.model.type.impl.BarSeriesImpl;
import org.eclipse.birt.chart.model.type.impl.PieSeriesImpl;
import org.eclipse.birt.core.framework.PlatformConfig;
import org.eclipse.emf.ecore.util.EcoreUtil;
* Test decription:
* </p>
* Chart script: BeforeDrawLegendItem()
* </p>
public class StandaloneChart {
private static String OUTPUT = "output/Standalone.png"; //$NON-NLS-1$
private static String OUTPUT_HTML = "output/Standalone.html"; //$NON-NLS-1$
* Comment for <code>serialVersionUID</code>
private static final long serialVersionUID = 1L;
* A chart model instance
private Chart cm = null;
* The swing rendering device
private IDeviceRenderer dRenderer = null;
private IDisplayServer dServer = null;
private GeneratedChartState gcs = null;
* execute application
* @param args
new StandaloneChart();
System.out.println("Finished");
* Constructor
public StandaloneChart() {
PlatformConfig pf = new PlatformConfig();
pf.setProperty("STANDALONE", true);
//Returns a singleton instance of the Chart Engine
ChartEngine ce = ChartEngine.instance(pf);
//Returns a singleton instance of the Generator
IGenerator gr = ce.getGenerator();
try {
//device renderers for dv.SWT, dv.PNG, dv.JPG
//dv.PDF, dv.SVG, dv.SWING, dv.PNG24, div.BMP
dRenderer = ce.getRenderer("dv.PNG");
dServer = dRenderer.getDisplayServer();
} catch (Exception ex) {
ex.printStackTrace();
//cm = new AfterDatasetFilled().GetChartModel();
//cm = StandaloneChart.createStackedBar();
//cm = StandaloneChart.createGrouponY();
//cm = StandaloneChart.createStockChart();
//cm = StandaloneChart.createTest();
cm = StandaloneChart.showTooltip_PieChart();
BufferedImage img = new BufferedImage(600, 600,
BufferedImage.TYPE_INT_ARGB);
Graphics g = img.getGraphics();
Graphics2D g2d = (Graphics2D) g;
//Look at IDeviceRenderer.java for all properties
//like DPI_RESOLUTION
//FILE_IDENTIFIER
//FORMAT_IDENTIFIER
//UPDATE_NOTIFIER
dRenderer.setProperty(IDeviceRenderer.GRAPHICS_CONTEXT, g2d);
dRenderer.setProperty(IDeviceRenderer.FILE_IDENTIFIER, OUTPUT);
//$NON-NLS-1$
//Set the bounds for the entire chart
Bounds bo = BoundsImpl.create(0, 0, 600, 600);
bo.scale(72d / dRenderer.getDisplayServer().getDpiResolution());
try {
gcs = gr.build(dServer, cm, bo, null, null, null);
//gcs.getRunTimeContext().setActionRenderer( new MyActionRenderer());
dRenderer.setProperty(IDeviceRenderer.UPDATE_NOTIFIER,
new EmptyUpdateNotifier(cm, gcs.getChartModel()));
gr.render(dRenderer, gcs);
String im = ((IImageMapEmitter) dRenderer).getImageMap();
BufferedWriter out = new BufferedWriter(new FileWriter(OUTPUT_HTML));
out.write("<html>");
out.newLine();
out.write("<body>");
out.newLine();
out.write("<div>");
out.newLine();
out.write("<map name='testmap'>");
out.write(im);
out.write("</map>");
out.newLine();
out
.write("<img id=myimage src='standalone.png'
usemap='#testmap'></img>");
out.newLine();
out.write("</div>");
out.newLine();
out.write("</body>");
out.newLine();
out.write("</html>");
out.newLine();
out.close();
System.out.println(im);
} catch (Exception e) {
e.printStackTrace();
public static final Chart showTooltip_PieChart( )
ChartWithoutAxesImpl cwoaPie =
(ChartWithoutAxesImpl)ChartWithoutAxesImpl.create( );
// Chart Type
cwoaPie.setType( "Pie Chart" );
cwoaPie
.setDimension( ChartDimension.TWO_DIMENSIONAL_WITH_DEPTH_LITERAL );
// Title
cwoaPie.getTitle( ).getLabel( ).getCaption( ).setValue(
"Sample Pie Chart" );
cwoaPie.getBlock( ).setBounds( BoundsImpl.create( 0, 0, 252, 288 ) );
cwoaPie.getBlock( ).getOutline( ).setVisible( true );
// Plot
cwoaPie.getPlot( ).getClientArea( ).getOutline( ).setVisible( false );
cwoaPie.getPlot( ).getClientArea( ).setBackground(
ColorDefinitionImpl.create( 255, 255, 225 ) );
// Legend
Legend lg = cwoaPie.getLegend( );
lg.getText( ).getFont( ).setSize( 16 );
lg.getInsets( ).set( 10, 5, 0, 0 );
lg.getOutline( ).setStyle( LineStyle.DASH_DOTTED_LITERAL );
lg.getOutline( ).setColor( ColorDefinitionImpl.create( 214, 100, 12 ) );
lg.getOutline( ).setVisible( true );
lg
.setBackground( GradientImpl.create( ColorDefinitionImpl
.create( 225, 225, 255 ), ColorDefinitionImpl.create(
255,
255,
225 ), -35, false ) );
lg.setAnchor( Anchor.EAST_LITERAL );
lg.setItemType( LegendItemType.CATEGORIES_LITERAL );
lg.getClientArea( ).setBackground( ColorDefinitionImpl.ORANGE( ) );
lg.setPosition( Position.LEFT_LITERAL );
//lg.setOrientation( Orientation.VERTICAL_LITERAL );
// Data Set
TextDataSet dsStringValue = TextDataSetImpl.create( new String[]{
"Keyboards", "Moritors", "Printers", "Mortherboards"} );
NumberDataSet dsNumericValues1 = NumberDataSetImpl
.create( new double[]{143.26, 156.55, 95.25, 47.56} );
// Series
Series seCategory = SeriesImpl.create( );
seCategory.setDataSet( dsStringValue );
SeriesDefinition series = SeriesDefinitionImpl.create( );
cwoaPie.getSeriesDefinitions( ).add( series );
series.getSeries( ).add( seCategory );
PieSeries ps = (PieSeries) PieSeriesImpl.create( );
ps.getLabel( ).getCaption( ).setColor( ColorDefinitionImpl.RED( ) );
ps.getLabel( ).setBackground( ColorDefinitionImpl.CYAN( ) );
ps.getLabel( ).setVisible( true );
ps.setSeriesIdentifier( "Actuate" );
ps.setDataSet( dsNumericValues1 );
ps.setLeaderLineAttributes( LineAttributesImpl.create(
ColorDefinitionImpl.create( 239, 33, 3 ),
LineStyle.DASH_DOTTED_LITERAL,
3 ) );
ps.setLeaderLineStyle( LeaderLineStyle.FIXED_LENGTH_LITERAL );
ps.setExplosion( 5 );
ps.setSliceOutline( ColorDefinitionImpl.BLACK( ) );
//ps.getTriggers( ).add(
// TriggerImpl.create(
// TriggerCondition.ONMOUSEOVER_LITERAL,
// ActionImpl.create(
// ActionType.SHOW_TOOLTIP_LITERAL,
// TooltipValueImpl.create( 500, null ) ) ) );
//sePie = (PieSeries) PieSeriesImpl.create();
actionValue);
Trigger mouseOver =
ps.getTriggers().add(mouseOver);
SeriesDefinition seGroup1 = SeriesDefinitionImpl.create( );
series.getSeriesPalette( ).update( -2 );
series.getSeriesDefinitions( ).add( seGroup1 );
seGroup1.getSeries( ).add( ps );
return cwoaPie;
farideh wrote:
> Hi Jason,
> In this case I get no Error but wrong value is shown when I move the
> mouse over a slice.
> For example the pie chart contains 4 different slices:
> Label Value
> A 10
> B 30
> C 40
> D 20
> i add a trigger with the ONMOUSEOVER_LITERAL condition and a
> Now if I position the mouse over first slice (Label A), the value 10
> shall be shown, but the value of the next neighbours slice is shown.
> I hope it is now clear what I exactly mine, if not I can send you a
> screenshot of my chart in which the problem can be easily seen.
> Farideh
Re: Trigger problem with BIRT 2.5.0 [message #480255 is a reply to message #480170] |
Fri, 14 August 2009 10:58   |
Farideh,
I did both and could not reproduce the issue. What libs are you using
to build. Take a look at the attached modified example.
Jason
* Copyright (c) 2004, 2007 Actuate Corporation.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Actuate Corporation - initial API and implementation
package my.swt.live.viewer;
import org.eclipse.birt.chart.device.ICallBackNotifier;
import org.eclipse.birt.chart.exception.ChartException;
import org.eclipse.birt.chart.factory.Generator;
import org.eclipse.birt.chart.model.attribute.CallBackValue;
import org.eclipse.birt.chart.util.PluginSettings;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.PaintEvent;
import org.eclipse.swt.events.PaintListener;
import org.eclipse.swt.graphics.GC;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.graphics.Rectangle;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Shell;
public class SwtChart extends Composite implements
PaintListener,
ICallBackNotifier
private boolean bNeedsGeneration = true;
private IDeviceRenderer idr = null;
public static SwtChart c3dViewer;
* Used in building the chart for the first time
private boolean bFirstPaint = true;
public Chart getDesignTimeModel( )
return cm;
public void regenerateChart( )
redraw( );
public Chart getRunTimeModel( )
return gcs.getChartModel( );
public void repaintChart( )
redraw( );
public Object peerInstance()
return this;
public void callback( Object event, Object source, CallBackValue value )
public static void main( String[] args )
Display display = Display.getDefault( );
Shell shell = new Shell( display );
shell.setSize( 600, 400 );
shell.setLayout( new GridLayout( ) );
c3dViewer = new SwtChart( shell, SWT.NO_BACKGROUND );
c3dViewer.setLayoutData( new GridData( GridData.FILL_BOTH ) );
c3dViewer.addPaintListener( c3dViewer );
shell.open( );
while ( !shell.isDisposed( ) )
if ( !display.readAndDispatch( ) )
display.sleep( );
display.dispose( );
* Constructor
SwtChart( Composite parent, int style )
super( parent, style );
PlatformConfig config = new PlatformConfig();
config.setProperty( "STANDALONE", "true" ); //$NON-NLS-1$//$NON-NLS-2$
final PluginSettings ps = PluginSettings.instance( config );
try
idr = ps.getDevice( "dv.SWT" );//$NON-NLS-1$
idr.setProperty( IDeviceRenderer.UPDATE_NOTIFIER, this );
catch ( ChartException ex )
ex.printStackTrace( );
cm = showTooltip_PieChart();
// Chart Type
cwoaPie
// Title
// Plot
// Legend
lg
255,
255,
// Data Set
// Series
3 ) );
ps.setExplosion( 0 );
actionValue);
Trigger mouseOver =
return cwoaPie;
private static final String[] sa = {
"One", "Two", "Three", "Four",
"Five" ,//$NON-NLS-1$//$NON-NLS-2$//$NON-NLS-3$//$NON-NLS-4$//$NON- NLS-5$
"Six", "Seven", "Eight", "Nine",
"Ten" };//$NON-NLS-1$//$NON-NLS-2$//$NON-NLS-3$//$NON-NLS-4$//$NON -NLS-5$
private static final double[] da1 = {
56.99,
352.95,
-201.95,
299.95,
-95.95,
25.45,
129.33,
-26.5,
43.5,
122
private static final double[] da2 = {
20, 35, 59, 105, 150, -37, -65, -99, -145, -185
public final void paintControl( PaintEvent e )
Rectangle d = this.getClientArea( );
Image imgChart = new Image( this.getDisplay( ), d );
GC gcImage = new GC( imgChart );
//FILE_IDENTIFIER
//FORMAT_IDENTIFIER
//UPDATE_NOTIFIER
idr.setProperty( IDeviceRenderer.GRAPHICS_CONTEXT, gcImage );
//idr.setProperty(IDeviceRenderer.UPDATE_NOTIFIER, this);
Bounds bo = BoundsImpl.create( 0, 0, d.width, d.height );
bo.scale( 72d / idr.getDisplayServer( ).getDpiResolution( ) );
Generator gr = Generator.instance( );
if ( bNeedsGeneration )
bNeedsGeneration = false;
try
gcs = gr.build( idr.getDisplayServer( ),
cm,
bo,
null,
null,
null );
catch ( ChartException ce )
ce.printStackTrace( );
try
gr.render( idr, gcs );
GC gc = e.gc;
gc.drawImage( imgChart, d.x, d.y );
farideh wrote:
> I am using the BIRT Chart Engine 2.5 in an swt app.
> IDeviceRenderer idr = ps.getDevice("dv.SWT");
> but just disable the chart Explode in Your source code (ps.setExplosion(
> 0 );). You can show the false value of the chart when the mouse move on
> the slice-chart.
> However i have ascertained that you can reproduce the error if you have
> device renderer "dv.SWT".
> farideh
Re: Trigger problem with BIRT 2.5.0 [message #480489 is a reply to message #480255] |
Mon, 17 August 2009 07:46   |
Jason,
i did it and i still have the problem.
My configuration follows.
farideh
*** Date: Monday, August 17, 2009 1:21:08 PM Germany Time
*** Platform Details:
*** System properties:
MaxCubeColumnLevels=50
MaxCubeRowLevels=50
MaxDataSetRows=500
RUN_UNDER_ECLIPSE=false
awt.toolkit=sun.awt.windows.WToolkit
birt.designer=true
birt.viewer.root.path=/D:/AixBOMS/eclipse-3.5.0/eclipse/plug ins/org.eclipse.birt.report.viewer_2.5.0.v20090520/birt/
birt.viewer.working.path=D:\AixBOMS\svn\navigator\trunk-3.5\ .metadata\.plugins\org.eclipse.birt.report.viewer
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=I20090611-1540
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
D:\AixBOMS\eclipse-3.5.0\eclipse\\plugins\org.eclipse.platfo rm_3.3.200.v200906111540\splash.bmp
-launcher
D:\AixBOMS\eclipse-3.5.0\eclipse\eclipse.exe
-name
Eclipse
--launcher.library
D:\AixBOMS\eclipse-3.5.0\eclipse\plugins/org.eclipse.equinox .launcher.win32.win32.x86_1.0.200.v20090519\eclipse_1206.dll
-startup
D:\AixBOMS\eclipse-3.5.0\eclipse\plugins/org.eclipse.equinox .launcher_1.0.200.v20090520.jar
-showlocation
-nl
en
-data
-vm
D:\AixBOMS\SUN\jre1.5.0_14\bin\client\jvm.dll
eclipse.home.location=file:/D:/AixBOMS/eclipse-3.5.0/eclipse /
eclipse.launcher=D:\AixBOMS\eclipse-3.5.0\eclipse\eclipse.ex e
eclipse.p2.data.area=@config.dir/../p2/
eclipse.p2.profile=SDKProfile
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1250493034743
eclipse.vm=D:\AixBOMS\SUN\jre1.5.0_14\bin\client\jvm.dll
eclipse.vmargs=-Xms40m
-Xmx768m
-XX:MaxPermSize=256m
-Djava.class.path=D:\AixBOMS\eclipse-3.5.0\eclipse\plugins/o rg.eclipse.equinox.launcher_1.0.200.v20090520.jar
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
http.nonProxyHosts=localhost| 127.0.0.1|vmaso072|aso239|<local>
http.proxyHost=fwcoco
http.proxyPort=8080
http.proxySet=true
https.nonProxyHosts=localhost| 127.0.0.1|vmaso072|aso239|<local>
https.proxyHost=fwcoco
https.proxyPort=8080
https.proxySet=true
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=D:\AixBOMS\eclipse-3.5.0\eclipse\plugins/org .eclipse.equinox.launcher_1.0.200.v20090520.jar
java.class.version=49.0
java.endorsed.dirs=D:\AixBOMS\SUN\jre1.5.0_14\lib\endorsed
java.ext.dirs=D:\AixBOMS\SUN\jre1.5.0_14\lib\ext
java.home=D:\AixBOMS\SUN\jre1.5.0_14
java.io.tmpdir=C:\DOKUME~1\Zahra\LOKALE~1\Temp\
java.library.path=D:\AixBOMS\eclipse-3.5.0\eclipse;.;C:\WIND OWS\system32;C:\WINDOWS;D:\oracle\product\10.2.0\db_1\bin;C: \WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Pro gramme\IDM
Computer Solutions\UltraEdit-32
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_14-b03
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_14
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_14-b03
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.NoOpLog
org.eclipse.birt.report.script.debug.launching.debuggerActiv e=false
org.eclipse.debug.ui.breakpoints.toggleFactoriesUsed=false
org.eclipse.equinox.launcher.splash.location=D:\AixBOMS\ecli pse-3.5.0\eclipse\\plugins\org.eclipse.platform_3.3.200.v200 906111540\splash.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.ec lipse.equinox.simpleconfigurator/bundles.info
org.eclipse.update.reconcile=false
org.eclipse.update.resolution_url=
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,OSGi/Minimum-1.2,JRE-1.1,J2SE-1.2,J2SE-1.3,J2S E-1.4,J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1.0
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,j avax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.plaf.synth,javax.swing.table,javax.swing.te xt,javax.swing.text.html,javax.swing.text.html.parser,javax. swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.trans action,javax.transaction.xa,javax.xml,javax.xml.datatype,jav ax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax .xml.transform.dom,javax.xml.transform.sax,javax.xml.transfo rm.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss ,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable, org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg .CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNam ing,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNam ing.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny, org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.D ynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org .omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInte rceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.o mg.PortableServer,org.omg.PortableServer.CurrentPackage,org. omg.PortableServer.POAManagerPackage,org.omg.PortableServer. POAPackage,org.omg.PortableServer.portable,org.omg.PortableS erver.ServantLocatorPackage,org.omg.SendingContext,org.omg.s tub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.c ss,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.ls,org.w3 c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.traversal,o rg.w3c.dom.views
,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.5.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=reference:file:javax.transaction_1.1.1.v2009061 61300.jar,reference:file:org.eclipse.osgi.nl_de_3.5.0.v20090 620043401.jar,reference:file: org.eclipse.equinox.simpleconfigurator_1.0.100.v20090520-190 5.jar @1:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=D:\AixBOMS\eclipse-3.5.0\eclipse\configurat ion\org.eclipse.osgi\bundles
osgi.configuration.area=file:/D:/AixBOMS/eclipse-3.5.0/eclip se/configuration/
osgi.framework=file:/d:/AixBOMS/eclipse-3.5.0/eclipse/plugin s/org.eclipse.osgi_3.5.0.v20090520.jar
osgi.framework.extensions=reference:file:javax.transaction_1 .1.1.v200906161300.jar,reference:file:org.eclipse.osgi.nl_de _3.5.0.v20090620043401.jar
osgi.framework.shape=jar
osgi.framework.version=3.5.0.v20090520
osgi.frameworkClassPath=.,
file:d:/AixBOMS/eclipse-3.5.0/eclipse/plugins/javax.transact ion_1.1.1.v200906161300.jar,
file:d:/AixBOMS/eclipse-3.5.0/eclipse/plugins/org.eclipse.os gi.nl_de_3.5.0.v20090620043401.jar
osgi.install.area=file:/D:/AixBOMS/eclipse-3.5.0/eclipse/
osgi.instance.area=file:/D:/AixBOMS/svn/navigator/trunk-3.5/
osgi.instance.area.default=file:/C:/Dokumente und
Einstellungen/Zahra/workspace/
osgi.logfile=D:\AixBOMS\svn\navigator\trunk-3.5\.metadata\.l og
osgi.manifest.cache=D:\AixBOMS\eclipse-3.5.0\eclipse\configu ration\org.eclipse.osgi\manifests
osgi.nl=en
osgi.nl.user=en
osgi.os=win32
osgi.splashLocation=D:\AixBOMS\eclipse-3.5.0\eclipse\\plugin s\org.eclipse.platform_3.3.200.v200906111540\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=d:\AixBOMS\eclipse-3.5.0\eclipse\plugins
osgi.tracefile=D:\AixBOMS\svn\navigator\trunk-3.5\.metadata\ trace.log
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=D:\AixBOMS\SUN\jre1.5.0_14\lib\rt.jar;D: \AixBOMS\SUN\jre1.5.0_14\lib\i18n.jar;D:\AixBOMS\SUN\jre1.5. 0_14\lib\sunrsasign.jar;D:\AixBOMS\SUN\jre1.5.0_14\lib\jsse. jar;D:\AixBOMS\SUN\jre1.5.0_14\lib\jce.jar;D:\AixBOMS\SUN\jr e1.5.0_14\lib\charsets.jar;D:\AixBOMS\SUN\jre1.5.0_14\classe s
sun.boot.library.path=D:\AixBOMS\SUN\jre1.5.0_14\bin
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 3
user.country=DE
user.dir=D:\AixBOMS\eclipse-3.5.0\eclipse
user.home=C:\Dokumente und Einstellungen\Zahra
user.language=de
user.name=zahra
user.timezone=Europe/Berlin
user.variant=
*** Features:
ca.ecliptical.emf.xpath (2.0.1.20071218052038) "XPath Support for EMF"
ca.ecliptical.emf.xpath.source (2.0.1.20071218052038) "XPath Support for
EMF Source"
net.entropysoft.jmx.feature (2.0.14) "JmxEntropy"
net.sf.eclipsensis (0.9.7.2) "EclipseNSIS"
net.sf.eclipsensis.installoptions (0.9.7) "EclipseNSIS InstallOptions
Editor"
net.sf.eclipsensis.utilities (0.9.2.2) "EclipseNSIS Utilities"
org.eclipse.acceleo (0.8.0.v200906161003) "Acceleo Common Utility Classes"
org.eclipse.acceleo.doc (0.8.0.v200906161003) "Acceleo Documentation"
org.eclipse.acceleo.examples (0.8.0.v200906161003) "Acceleo Examples"
org.eclipse.acceleo.sdk (0.8.0.v200906161003) "Acceleo Common Utility
Classes"
org.eclipse.acceleo.source (0.8.0.v200906161003) "Acceleo Runtime Source"
org.eclipse.acceleo.ui.capabilities (0.8.0.v200906161003) "Acceleo UI
capability definitions"
org.eclipse.birt (2.5.0.v20090607-9ODS6GD7wmMtz-DbWuHKMt_6VlSF) "Business
Intelligence and Reporting Tools"
org.eclipse.birt.chart.cshelp (2.5.0.v20090402-34-7w311A1728) "BIRT Chart
Context-sensitive Help"
org.eclipse.birt.cshelp (2.5.0.v20090402-34-7w311A1728) "BIRT
org.eclipse.birt.doc (2.5.0.v20090521-34-7w311A1726) "BIRT Documentation"
org.eclipse.birt.example (2.5.0.v20090611-7F7Y-DZRDEBDrGg) "BIRT Example"
org.eclipse.birt.report.designer.editor.xml.wtp
(2.5.0.v20090611-7m9a4FTy215N3qZ5UkRE) "BIRT Advanced XML Editor Plug-in"
org.eclipse.cdt.mylyn (5.1.0.200906161748) "Mylyn Bridge: C/C++
Development"
org.eclipse.cvs (1.1.100.v20090514-7E79FEc9BJ99r9YFR6JOEF) "Eclipse CVS
Client"
org.eclipse.datatools.common.doc.user
(1.7.0.v200906111100-26-311A16321A3557) "Data Tools Platform User
Documentation"
org.eclipse.datatools.connectivity.doc.user
(1.7.0.v200906111100-37D-7733L3D753L7BBF) "Data Tools Platform
Connectivity User Documentation"
org.eclipse.datatools.connectivity.feature
(1.7.0.v200906050400-7B7OAGEn1XeXjC4wj6KETrSOP8) "Data Tools Platform
Connectivity Plug-in"
org.eclipse.datatools.connectivity.oda.designer.feature
(1.7.0.v200906050400-7E7C6DZRDEBDsDSDijc) "DTP ODA Designer UI Framework
Plug-in"
org.eclipse.datatools.connectivity.oda.feature
(1.7.0.v200906050400-7H791CcNBC0BjDNBddV) "DTP Open Data Access"
org.eclipse.datatools.doc.user (1.7.0.v200906111100-47C-8w95ENAJ69EHJF7)
"Data Tool Platform User Documentation"
org.eclipse.datatools.enablement.apache.derby.feature
(1.7.0.v200906050400-7768bBmKDLfMjGqHEHL7PAB) "High-level Sybase
Enablement Plug-in"
org.eclipse.datatools.enablement.feature
(1.7.0.v200906050400-7J8i0BWwPJNaz-Fe15qs9q203H-b) "Eclipse Data Tools
Platform Enablement"
org.eclipse.datatools.enablement.hsqldb.feature
(1.7.0.v200906050400-67B0AqGBJVKbEmF3FJ7PAB) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.ibm.feature
(1.7.0.v200906050400-7F47HFC7sRTNSjRsTNRR) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.ingres.feature
(1.7.0.v200906050400-540AkF77g7VACAJJM) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.jdbc.feature
(1.7.0.v200906050400-4-29oB55W5N6A6O9A) "High-level Sybase Enablement
Plug-in"
org.eclipse.datatools.enablement.jdt.feature
(1.7.0.v200906050400-2-07w311A17131A11) "Data Tools Platform Connectivity
JDT Extension Plug-in"
org.eclipse.datatools.enablement.msft.feature
(1.7.0.v200906050400-542AkF77g7V7F7g77) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.mysql.feature
(1.7.0.v200906050400-546AkF77g7V7F7g77) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.oda.designer.feature
(1.7.0.v200906050400-33-8s733L3D6C47AG) "Eclipse Data Tools Platform XML
ODA Designer"
org.eclipse.datatools.enablement.oda.feature
(1.7.0.v200906050400-7A7T5DZRDEADiKjEbOs) "Eclipse Data Tools Platform XML
ODA Runtime Driver"
org.eclipse.datatools.enablement.oracle.feature
(1.7.0.v200906050400-548aAkF77g7V7F7g77) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.postgresql.feature
Enablement"
org.eclipse.datatools.enablement.sap.feature
(1.7.0.v200906050400-540AkF77g7V7F7g77) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.sdk.feature
(1.7.0.v200906050400-7I8r-FE9JfFkjWT8qt6UI5jX2laJ) "Eclipse Data Tools
org.eclipse.datatools.enablement.sqlite.feature
(1.7.0.v200906050400-541AkF77g7V7F7g77) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.sybase.feature
(1.7.0.v200906050400-7E45F9NiNWvOOVpNfUR) "High-level Sybase Enablement
Plug-in"
org.eclipse.datatools.intro (1.7.0.v200906050400-26-7w311A17142212)
"Eclipse Data Tools Platform Intro Plug-in"
org.eclipse.datatools.modelbase.feature
(1.7.0.v200906050400-77-3CcNBC0BkBNNN_0) "Eclipse Data Tools Platform
SQLModel Plug-in"
org.eclipse.datatools.sdk.feature
(1.7.0.v200906050400-7O9H-FD0IVEH6AsdTaISiFGNkk6p) "DTP SDK Plug-in"
org.eclipse.datatools.sqldevtools.ddlgen.feature
(1.7.0.v200906050400-7A-0F7RZHIXI6HZXnHX) "Eclipse Data Tools Platform FE
UI Plug-in"
org.eclipse.datatools.sqldevtools.feature
(1.7.0.v200906050400-7N7q-FDr_gSWLQCJJODUlz-1btbZ) "Eclipse Data Tools
Platform SQL Tools Common UI Plug-in"
org.eclipse.datatools.sqldevtools.parsers.feature
(1.7.0.v200906050400-602BgJ99q9_9OGXFJ) "Eclipse Data Tools Platform SQL
Parser Plugin"
org.eclipse.datatools.sqltools.doc.user
(1.7.0.v200906111100-37D-7733L3D753L7BBF) "Data Tools Platform SQL Tools
User Documentation"
org.eclipse.dltk.core (1.0.0.v20090610-1638-7C--EAAoOQBPbbrBcPz0b)
"Eclipse Dynamic Languages Toolkit"
org.eclipse.dltk.core.source (1.0.0.v20090610-1638-7C--EAAoOQBPbbrBcPz0b)
"Dynamic Languages Toolkit Core Source"
org.eclipse.dltk.itcl (1.0.0.v20090613-1432-3--9oA55V5L9K28LC_) "iTcl
Extension Support for TCL language"
org.eclipse.dltk.itcl.source (1.0.0.v20090613-1432-3--9oA55V5L9K28LC_)
"Dynamic Languages Toolkit (DLTK) iTcl IDE Source"
org.eclipse.dltk.javascript.source
(1.0.0.v20090610-1638-7A--E9IgKLsLFbY9UAo0) "Dynamic Languages Toolkit
(DLTK) TCL IDE Source"
org.eclipse.dltk.mylyn (1.0.0.v20090610-1638-1--7w311_17261119) "Mylyn
DLTK Bridge"
org.eclipse.dltk.mylyn.source (1.0.0.v20090610-1638-1--7w311_17261119)
"Dynamic Languages Toolkit (DLTK) Mylyn Integration Source"
org.eclipse.dltk.python.source (1.0.0.v20090610-1638-6--BcMAB0AiHf4DeLQ)
"Dynamic Languages Toolkit (DLTK) TCL IDE Source"
org.eclipse.dltk.rse.source (1.0.0.v20090610-1638-2--8s733K3E5615C9C)
"Dynamic Languages Toolkit (DLTK) RSE Environment Source"
org.eclipse.dltk.ruby (1.0.0.v20090610-1638-7B--E_EkMO1NTYtAZCz-9) "Ruby
Development Tools"
org.eclipse.dltk.ruby.source (1.0.0.v20090610-1638-7B--E_EkMO1NTYtAZCz-9)
"Dynamic Languages Toolkit (DLTK) Ryby IDE Source"
org.eclipse.dltk.tcl (1.0.0.v20090610-1638-7D--EB7sQSMRjetCfT7W) "Tcl
Development Tools"
org.eclipse.dltk.tcl.source (1.0.0.v20090610-1638-7D--EB7sQSMRjetCfT7W)
org.eclipse.dltk.xotcl (1.0.0.v20090610-1638-4--_kE77g7TAS28NCF) "XOTcl
org.eclipse.dltk.xotcl.source (1.0.0.v20090610-1638-4--_kE77g7TAS28NCF)
"Dynamic Languages Toolkit (DLTK) XOTcl IDE Source"
org.eclipse.draw2d (3.5.0.v20090422-2346-44-7w311A163902622) "Graphical
Editing Framework Draw2d"
org.eclipse.ecf.core (3.0.0.v20090616-0832) "Eclipse Communication
Framework (ECF)"
org.eclipse.emf (2.5.0.v200906151043) "EMF - Eclipse Modeling Framework
Runtime and Tools"
org.eclipse.emf.cdo (2.0.0.v200906160459) "CDO Model Repository Client"
org.eclipse.emf.cdo.defs (2.0.0.v200906160459) "CDO Model Repository
Definitions "
org.eclipse.emf.cdo.doc (2.0.0.v200906160459) "CDO Model Repository
Documentation"
org.eclipse.emf.cdo.examples (2.0.0.v200906160459) "CDO Model Repository
Examples"
org.eclipse.emf.cdo.server (2.0.0.v200906160459) "CDO Model Repository
Server"
org.eclipse.emf.codegen (2.5.0.v200906151043) "EMF Code Generation"
org.eclipse.emf.codegen.ecore (2.5.0.v200906151043) "EMF Ecore Code
Generator"
org.eclipse.emf.codegen.ecore.ui (2.5.0.v200906151043) "EMF Ecore Code
Generator UI"
org.eclipse.emf.codegen.ui (2.4.0.v200906151043) "EMF Code Generation UI"
org.eclipse.emf.common (2.5.0.v200906151043) "EMF Common"
org.eclipse.emf.common.ui (2.5.0.v200906151043) "EMF Common UI"
org.eclipse.emf.compare (1.0.0.v200906160908) "EMF Compare core"
org.eclipse.emf.compare.doc (1.0.0.v200906160908) "EMF Compare
Documentation"
org.eclipse.emf.compare.sdk (1.0.0.v200906160908) "EMF Compare core"
org.eclipse.emf.compare.source (1.0.0.v200906160908) "EMF Compare Source"
org.eclipse.emf.converter (2.5.0.v200906151043) "EMF Model Converter"
org.eclipse.emf.databinding (1.1.0.v200906151043) "EMF Data Binding"
org.eclipse.emf.databinding.edit (1.1.0.v200906151043) "EMF Edit Data
Binding"
org.eclipse.emf.doc (2.5.0.v200906151043) "EMF Documentation"
org.eclipse.emf.ecore (2.5.0.v200906151043) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.5.0.v200906151043) "EMF Ecore Edit"
org.eclipse.emf.ecore.editor (2.5.0.v200906151043) "EMF Sample Ecore
Editor"
org.eclipse.emf.ecoretools (0.9.0.v200906031210) "Ecore Tools (Incubation)"
org.eclipse.emf.ecoretools.doc (0.8.0.v200906031210) "Ecore Tools
Documentation (Incubation)"
org.eclipse.emf.ecoretools.source (0.9.0.v200906031210) "Ecore Tools
Source (Incubation)"
org.eclipse.emf.edit (2.5.0.v200906151043) "EMF Edit"
org.eclipse.emf.edit.ui (2.5.0.v200906151043) "EMF Edit UI"
org.eclipse.emf.index.source (0.7.0.v200906161042) "EMF Index Source
(Incubation)"
org.eclipse.emf.mapping (2.5.0.v200906151043) "EMF Mapping"
org.eclipse.emf.mapping.ecore (2.5.0.v200906151043) "EMF Ecore Mapping"
org.eclipse.emf.mapping.ecore.editor (2.5.0.v200906151043) "EMF Ecore
Mapping Editor"
org.eclipse.emf.mapping.ui (2.5.0.v200906151043) "EMF Mapping UI"
org.eclipse.emf.mint (0.8.0.v200906110922) "Mint Runtime (Incubation)"
org.eclipse.emf.mint.doc (0.8.0.v200906110922) "Mint Developer Guide
(Incubation)"
org.eclipse.emf.mwe.core (0.7.0.v200906160748) "MWE Core (Incubation)"
org.eclipse.emf.mwe.core.source (0.7.0.v200906160748) "MWE Core Source
(Incubation)"
org.eclipse.emf.mwe.doc (0.7.0.v200906160748) "MWE Documentation
(Incubation)"
org.eclipse.emf.mwe.examples (0.7.0.v200906160748) "MWE Examples
(Incubation)"
org.eclipse.emf.mwe.examples.source (0.7.0.v200906160748) "MWE Examples
org.eclipse.emf.mwe.ui (0.7.0.v200906160748) "MWE UI (Incubation)"
org.eclipse.emf.mwe.ui.source (0.7.0.v200906160748) "MWE Core UI Source
(Incubation)"
org.eclipse.emf.ocl (1.1.101.v200901271800-208_7w311A12382911) "Object
Constraint Language (OCL) 2.0 Compatibility API"
org.eclipse.emf.ocl.doc (1.2.1.v200901271800-208_7w311A17262341) "Object
Constraint Language (OCL) 2.0 Compatibility API Documentation"
org.eclipse.emf.query (1.2.100.v200901271643-218Z7w311A142A1142) "EMF
Model Query"
org.eclipse.emf.query.doc (1.2.100.v200901271543-33-8s733L357H5FB9) "EMF
Model Query Documentation"
org.eclipse.emf.query.ocl (1.2.100.v200901271643-21-7w311A142A1142) "EMF
Model Query OCL Integration"
org.eclipse.emf.teneo (1.1.0.v200906180911-786-DZRDEBDsL4EBKK) "EMF Teneo"
org.eclipse.emf.teneo.doc (1.1.0.v200906180911-20-7w311A17291A22) "EMF
Teneo Documentation"
org.eclipse.emf.teneo.eclipselink
(1.0.0.v200906180911-7A1-F7RZHIXI6ROIXQQ) "EMF Teneo EclipseLink Plug-in"
org.eclipse.emf.transaction (1.3.0.v200901271819-35-8s733L365B4D6D) "EMF
Model Transaction Core"
org.eclipse.emf.transaction.doc (1.3.0.v200901271819-348Z8s733L357H5J5L)
"EMF Model Transaction Documentation"
org.eclipse.emf.validation (1.3.0.v200902052232-478-9oB55W58BQ8QBB) "EMF
Validation Framework Core"
org.eclipse.emf.validation.doc (1.3.0.v200901271722-35-8s733L357H5H77)
"EMF Validation Framework Documentation"
org.eclipse.emf.validation.ocl (1.2.0.v200901271722-22-7w311A12382833)
"EMF Validation Framework OCL Integration"
org.eclipse.emf.workspace (1.3.0.v200901271819-35-8s733L366A4F6E) "EMF
Model Transaction Workbench Integration Core"
org.eclipse.emf.workspace.doc (1.3.0.v200901271819-22-7w311A1238292A) "EMF
Model Transaction Workbench Integration Documentation"
org.eclipse.gef (3.5.0.v20090422-2346-7779-8192B6696L3ABD43733) "Graphical
Editing Framework GEF"
org.eclipse.gmf (1.1.1.v20090114-0940-7d8B0FXwnKwGb15VuKFF0ELpPk0b)
"Graphical Modeling Framework"
org.eclipse.gmf.doc (1.2.1.v20090114-0940-3218s733L3A5C13J73) "Graphical
Modeling Framework Documentation"
org.eclipse.gmf.examples.pde (1.2.0.v20090114-0940-318Z8s733L3D4B14H53)
"Graphical Modeling Framework Examples"
org.eclipse.gmf.runtime.notation (1.1.1.v20090114-0940-33-8s733L3C5715J78)
"GMF Notation Model Support"
org.eclipse.gmf.sdk (2.2.0.v20090114-0940-7C7B3BLund3tnivqKNVdZqeqJTs5)
"Graphical Modeling Framework SDK"
org.eclipse.gmf.tooling (2.2.0.v20090317-0630-7c7GFBVFLWUko2mBGJQ9Bgq)
"Graphical Modeling Framework Tooling"
org.eclipse.help (1.1.0.v20090602-7e7eFAlFEx2XZoYqwI68e2F) "Help System
Base"
org.eclipse.jdt (3.5.0.v20090527-2000-7r88FEeFJePyvYeA33DjZ_c1) "Eclipse
Java Development Tools"
org.eclipse.jet (1.0.0.v200906120945-508ZAkF77g7VBF7g77) "Java Emitter
Templates (JET)"
org.eclipse.jet.doc (1.0.0.v200906120945-2--7w311A17231A11) "Java Emitter
Templates (JET) Documentation"
org.eclipse.jet.source (1.0.0.v200906120945) "Eclipse Model to Text - JET
SDK"
org.eclipse.m2m.atl (3.0.0.v200906160347) "ATL - ATLAS Transformation
Language"
org.eclipse.m2m.atl.doc (3.0.0.v200906160347) "ATL Documentation"
org.eclipse.m2m.atl.examples (3.0.0.v200906160347) "ATL Examples"
org.eclipse.m2m.atl.source (3.0.0.v200906160347) "ATL Source"
org.eclipse.m2m.qvt.oml (2.0.0.v20090316-1930-78--AkF77g7SCW3BeM7) "QVT
Operational Compiler and Interpreter"
org.eclipse.m2m.qvt.oml.common (2.0.0.v20090410-1820-79--AkF77g7SDX3BfM7)
"QVT Operational Common"
org.eclipse.m2m.qvt.oml.doc (2.0.0.v20090316-1930-3--7w311A172702611) "QVT
Operational Documentation"
org.eclipse.m2m.qvt.oml.editor (2.0.0.v20090316-1930-3--7w311A163702A51)
"QVT Operational Editor"
org.eclipse.m2m.qvt.oml.examples (2.0.0.v20090616-1500-3--7w311A171902941)
"QVT Operational Samples"
org.eclipse.m2m.qvt.oml.runtime (2.0.0.v20090410-1820-79--AkF77g7RCR3BeK7)
"QVT Operational Runtime"
org.eclipse.m2m.qvt.oml.sdk
(2.0.0.v20090316-1930-7N--CLrFgFfNpRJ4OVlVbmHcXLqT) "QVT Operational
org.eclipse.mylyn_feature (3.2.0.v20090617-0100-e3x) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (3.2.0.v20090617-0100-e3x) "Mylyn"
org.eclipse.mylyn.context_feature (3.2.0.v20090617-0100-e3x) "Mylyn"
org.eclipse.mylyn.ide_feature (3.2.0.v20090617-0100-e3x) "Mylyn"
org.eclipse.mylyn.java_feature (3.2.0.v20090617-0100-e3x) "Mylyn"
org.eclipse.mylyn.pde_feature (3.2.0.v20090617-0100-e3x) "Mylyn"
org.eclipse.mylyn.team_feature (3.2.0.v20090617-0100-e3x) "Mylyn"
org.eclipse.mylyn.wikitext_feature (1.1.0.v20090617-0100-e3x) "Mylyn"
org.eclipse.net4j (2.0.0.v200906160348) "Net4j Signalling Platform Runtime"
org.eclipse.net4j.db (2.0.0.v200906160348) "Net4j DB Framework"
org.eclipse.net4j.defs (2.0.0.v200906160348) "Net4j Signalling Platform
Definitions"
org.eclipse.net4j.doc (2.0.0.v200906160348) "Net4j Signalling Platform
Documentation"
org.eclipse.net4j.examples (2.0.0.v200906160348) "Net4j Signalling
Platform Examples"
org.eclipse.net4j.ui (2.0.0.v200906160348) "Net4j Signalling Platform UI"
org.eclipse.ocl (1.3.0.v200901271800-46-9oB55V5I9P8M65) "Object Constraint
Language (OCL) 2.0 Parser/Interpreter"
org.eclipse.ocl.doc (1.3.0.v200901271800-35-8s733L3A6F5D63) "Object
Constraint Language (OCL) 2.0 Documentation"
org.eclipse.ocl.uml (2.0.0.v200901271800-3--7w311A16382511) "OCL 2.0
Binding for UML"
org.eclipse.pde (3.5.0.v20090123-7Z7_F8NFE-z0VXhWiu-8Qb95) "PDE"
org.eclipse.platform (3.5.0.v20090611a-9gEeG1HFtQcmRThO4O3aR_fqSMvJR2sJ)
"Eclipse Platform"
org.eclipse.rcp (3.5.0.v20090519-9SA0FwxFv6x089WEf-TWh11) "Eclipse RCP"
org.eclipse.rse (3.1.0.v200905272300-7L5A78wqaCHMdrOqK3DvjpYKCnp3) "Remote
System Explorer End-User Runtime"
org.eclipse.rse.core (3.1.0.v200905272300-7a7CEoFC7sRTNS_oZt3fk) "RSE Core"
org.eclipse.rse.dstore (3.1.0.v200905272300-7L6EoEVVFGMFvQtVaPU) "RSE
DStore Services"
org.eclipse.rse.ftp (3.0.100.v200905272300-780A79oB55W5KBQBD9D) "RSE FTP
Service"
org.eclipse.rse.local (2.1.100.v200905272300-7B4EoBgJ99r9YJhJO99) "RSE
Local Services"
org.eclipse.rse.ssh (3.0.0.v200905272300-7A2BgAkF77g7RFZFJ77) "RSE SSH
Services"
org.eclipse.rse.telnet (2.2.0.v200905272300-773-AkF77g7RFZFIBF) "RSE
Telnet Service"
org.eclipse.rse.terminals (1.0.0.v200905272300-77--9uC6FSANEbEMAF4522)
"RSE Terminals UI"
org.eclipse.rse.useractions (1.1.100.v200905272300-31A78s733L3D7H7933)
"Remote System Explorer User Actions"
org.eclipse.sdk
(3.5.0.v20090423-7Q7bA7DPQ1SM6OYQ7wKYJhI-z-xZJCmLTBRhtZ0o61b 1z) "Eclipse
Project SDK"
org.eclipse.team.svn (0.7.8.I20090506-1500) "Subversive SVN Team Provider
(Incubation)"
org.eclipse.team.svn.mylyn (0.7.8.I20090506-1500) "Subversive Integration
for the Mylyn Project (Incubation)"
org.eclipse.tm.terminal (3.0.0.v200905272300-4--7w311A16383411) "Target
Management Terminal Widget"
org.eclipse.uml2 (3.0.0.v200906011111) "UML2"
org.eclipse.uml2.diagram (0.9.0.v200906031456) "UML2 Diagramming Plug-in
(Incubation)"
org.eclipse.uml2.doc (3.0.0.v200905041045) "UML2 Documentation"
org.eclipse.uml2.examples (3.0.0.v200905041045) "UML2 Examples"
org.eclipse.uml2tools (0.9.0.v200906031456) "UML2 Tools Plug-in
(Incubation)"
org.eclipse.wst.xml_ui.feature
(3.1.0.v200905240756-7H6FMVDxtkM-5OgPGKK4xQocS5AL) "Eclipse XML Editors
and Tools"
org.eclipse.xpand (0.7.0.v200906160952) "Xpand core (Incubation)"
org.eclipse.xpand.doc (0.7.0.v200906160952) "M2T Xpand Documentation
(Incubation)"
org.eclipse.xpand.examples (0.7.0.v200906160952) "Xpand Examples
(Incubation)"
org.eclipse.xpand.source (0.7.0.v200906160952) "Xpand SDK (Incubation)"
org.eclipse.xpand.ui (0.7.0.v200906160952) "Xpand editor (Incubation)"
org.eclipse.xpand.ui.source (0.7.0.v200906160952) "Xpand UI Developer
Resources (Incubation)"
org.eclipse.xsd (2.5.0.v200906151043) "XSD Model"
org.eclipse.xsd.doc (2.5.0.v200906151043) "XSD Documentation"
org.eclipse.xsd.ecore.converter (2.5.0.v200906151043) "XSD Ecore Converter"
org.eclipse.xsd.edit (2.5.0.v200906151043) "XSD Edit"
org.eclipse.xsd.editor (2.5.0.v200906151043) "XSD Sample Editor"
org.eclipse.xsd.mapping (2.5.0.v200906151043) "XSD Mapping"
org.eclipse.xsd.mapping.editor (2.5.0.v200906151043) "XSD Mapping Editor"
org.eclipse.xtend (0.7.0.v200906160952) "Xtend core (Incubation)"
org.eclipse.xtend.source (0.7.0.v200906160952) "Xtend Source (Incubation)"
org.eclipse.xtend.typesystem.emf (0.7.0.v200906160952) "Xtend emf
typesystem (Incubation)"
org.eclipse.xtend.typesystem.uml2 (0.7.0.v200906160952) "Xtend UML2
org.eclipse.xtend.typesystem.uml2.source (0.7.0.v200906160952) "Xtend UML2
typesystem Source (Incubation)"
org.eclipse.xtend.typesystem.xsd (0.7.0.v200906160952) "Xtend XSD
org.eclipse.xtend.typesystem.xsd.source (0.7.0.v200906160952) "Xtend XSD
org.eclipse.xtend.ui (0.7.0.v200906160952) "Xtend UI (Incubation)"
org.eclipse.xtend.ui.source (0.7.0.v200906160952) "Xtend UI Developer
org.eclipse.xtext.examples.source (0.7.0.v200906161042) "Xtext Examples
org.eclipse.xtext.runtime.source (0.7.0.v200906161042) "Xtext Runtime
org.eclipse.xtext.sdk (0.7.0.v200906161042) "Xtext (Incubation)"
org.eclipse.xtext.sdk.source (0.7.0.v200906161042) "Xtext SDK Source
(Incubation)"
org.eclipse.xtext.ui.source (0.7.0.v200906161042) "Xtext UI Source
(Incubation)"
org.polarion.eclipse.team.svn.connector (2.2.0.I20090505-1500) "Subversive
SVN Connectors"
org.polarion.eclipse.team.svn.connector.javahl16 (2.2.0.I20090505-1500)
"Subversive SVN 1.6 JavaHL Connector"
org.polarion.eclipse.team.svn.connector.javahl16.win32
(2.2.0.I20090505-1500) "JavaHL 1.6.0 Win32 Binaries"
org.polarion.eclipse.team.svn.connector.svnkit16 (2.2.0.I20090505-1500)
"Subversive SVN 1.6 SVN Kit Connector"
*** Plug-in Registry:
[Resolved]
EMF Source" [Resolved]
ca.ecliptical.emf.xpath.tests (2.0.1.20071218052038) "XPath Support for
EMF Tests" [Active]
ch.ethz.iks.r_osgi.remote (1.0.0.RC4_v20090616-0832) "R_OSGi Remote
Service" [Active]
ch.ethz.iks.slp (1.1.0.v20090616-0832) "jslp-osgi" [Active]
com.caucho.hessian (3.1.3) "Caucho Hessian Plug-in" [Resolved]
com.google.collect (0.8.0.v200906161042) "bundleName" [Resolved]
com.google.guice (1.0.1.v200906161042) "Guice Plug-in" [Resolved]
com.ibm.icu (4.0.1.v20090415) "International Components for Unicode for
Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.41.v200903070017) "JSch" [Resolved]
com.lowagie.itext (1.5.4.v20090608) "Lowagie Itext" [Resolved]
com.lowagie.itext.nl_de (3.5.0.v20090620043401) "com.lowagie.itext German
NLS Support" [Resolved]
de.kupzog.ktable (2.1.3) "KTable Plug-in" [Resolved]
javax.activation (1.1.0.v200905021805) "Apache Geronimo Activation
Plug-in" [Resolved]
javax.activation.nl_de (3.5.0.v20090620043401) "javax.activation German
javax.mail (1.4.0.v200905040518) "Javax Mail Plug-in" [Resolved]
javax.mail.nl_de (3.5.0.v20090620043401) "javax.mail German NLS Support"
[Resolved]
javax.persistence (1.99.0.v200906021518) "JPA 1.0 - Extended for OSGi
(1.99)" [Resolved]
javax.persistence.nl_de (3.5.0.v20090620043401) "javax.persistence German
javax.servlet (2.5.0.v200806031605) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200806031607) "Java Server Pages API Bundle"
[Resolved]
javax.servlet.jsp.nl_de (3.5.0.v20090620043401) "javax.servlet.jsp German
javax.servlet.nl_de (3.5.0.v20090620043401) "javax.servlet German NLS
Support" [Resolved]
javax.transaction (1.1.1.v200906161300) "jta 1.1 spec" [Resolved]
javax.wsdl (1.5.1.v200806030408) "WSDL4J" [Resolved]
javax.wsdl.nl_de (3.5.0.v20090620043401) "javax.wsdl German NLS Support"
[Resolved]
javax.xml (1.3.4.v200902170245) "JAXP XML" [Resolved]
javax.xml.nl_de (3.5.0.v20090620043401) "javax.xml German NLS Support"
[Resolved]
javax.xml.rpc (1.1.0.v200905122109) "JAX-RPC" [Resolved]
javax.xml.rpc.nl_de (3.5.0.v20090620043401) "javax.xml.rpc German NLS
Support" [Resolved]
javax.xml.soap (1.2.0.v200905122109) "SAAJ" [Resolved]
javax.xml.soap.nl_de (3.5.0.v20090620043401) "javax.xml.soap German NLS
Support" [Resolved]
net.entropysoft.dashboard.plugin (2.0.14) "dashboard plugin" [Starting]
net.entropysoft.jmx.plugin (2.0.14) "JmxEntropy" [Starting]
net.sf.eclipsensis (0.9.7.2) "EclipseNSIS" [Active]
Editor" [Active]
net.sf.eclipsensis.startup (0.9.7) "EclipseNSIS Startup" [Active]
net.sf.eclipsensis.update (0.9.7) "EclipseNSIS Update" [Active]
net.sf.eclipsensis.utilities (0.9.2.2) "EclipseNSIS Utilities" [Starting]
net.sf.jarsigner (0.9.2.2) "JARSigner Plug-in" [Starting]
net.sf.jnigen (0.9.2.2) "JNIGen Plug-in" [Starting]
net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200803061910) "SourceForge LPG"
[Resolved]
net.sourceforge.lpg.lpgjavaruntime.nl_de (3.5.0.v20090620043401)
"net.sourceforge.lpg.lpgjavaruntime German NLS Support" [Resolved]
org.antlr.runtime (3.0.0.v200803061811) "ANTLR Runtime" [Resolved]
org.antlr.runtime.nl_de (3.5.0.v20090620043401) "org.antlr.runtime German
org.apache.ant (1.7.1.v20090120-1145) "Apache Ant" [Resolved]
org.apache.axis (1.4.0.v200905122109) "Apache Web Services" [Resolved]
org.apache.axis.nl_de (3.5.0.v20090620043401) "org.apache.axis German NLS
Support" [Resolved]
org.apache.batik.bridge (1.6.0.v200805290154) "Apache Batik
Bridge/GVT/Scripting" [Resolved]
org.apache.batik.bridge.nl_de (3.5.0.v20090620043401)
"org.apache.batik.bridge German NLS Support" [Resolved]
org.apache.batik.css (1.6.0.v200805290154) "Apache Batik CSS" [Resolved]
org.apache.batik.css.nl_de (3.5.0.v20090620043401) "org.apache.batik.css
org.apache.batik.dom (1.6.0.v200805290154) "Apache Batik DOM" [Resolved]
org.apache.batik.dom.nl_de (3.5.0.v20090620043401) "org.apache.batik.dom
org.apache.batik.dom.svg (1.6.0.v200805290154) "Apache Batik SVG DOM"
[Resolved]
org.apache.batik.dom.svg.nl_de (3.5.0.v20090620043401)
"org.apache.batik.dom.svg German NLS Support" [Resolved]
org.apache.batik.ext.awt (1.6.0.v200805290154) "Apache Batik AWT
Utilities" [Resolved]
org.apache.batik.ext.awt.nl_de (3.5.0.v20090620043401)
"org.apache.batik.ext.awt German NLS Support" [Resolved]
org.apache.batik.extension (1.6.0.v200805290154) "Apache Batik Extension"
[Resolved]
org.apache.batik.extension.nl_de (3.5.0.v20090620043401)
"org.apache.batik.extension German NLS Support" [Resolved]
org.apache.batik.parser (1.6.0.v200805290154) "Apache Batik Parser"
[Resolved]
org.apache.batik.parser.nl_de (3.5.0.v20090620043401)
"org.apache.batik.parser German NLS Support" [Resolved]
org.apache.batik.pdf (1.6.0.v200806031500) "Apache Batik PDF" [Resolved]
org.apache.batik.pdf.nl_de (3.5.0.v20090620043401) "org.apache.batik.pdf
org.apache.batik.svggen (1.6.0.v200805290154) "Apache Batik SVG
Generation" [Resolved]
org.apache.batik.svggen.nl_de (3.5.0.v20090620043401)
"org.apache.batik.svggen German NLS Support" [Resolved]
org.apache.batik.swing (1.6.0.v200805290154) "Apache Batik Swing"
[Resolved]
org.apache.batik.swing.nl_de (3.5.0.v20090620043401)
"org.apache.batik.swing German NLS Support" [Resolved]
org.apache.batik.transcoder (1.6.0.v200805290154) "Apache Batik
Transcoder" [Resolved]
org.apache.batik.transcoder.nl_de (3.5.0.v20090620043401)
"org.apache.batik.transcoder German NLS Support" [Resolved]
org.apache.batik.util (1.6.0.v200805290154) "Apache Batik Utilities"
[Resolved]
org.apache.batik.util.gui (1.6.0.v200805290154) "Apache Batik GUI
org.apache.batik.util.gui.nl_de (3.5.0.v20090620043401)
"org.apache.batik.util.gui German NLS Support" [Resolved]
org.apache.batik.util.nl_de (3.5.0.v20090620043401) "org.apache.batik.util
org.apache.batik.xml (1.6.0.v200805290154) "Apache Batik XML" [Resolved]
org.apache.batik.xml.nl_de (3.5.0.v20090620043401) "org.apache.batik.xml
org.apache.commons.beanutils (1.7.0.v200902170505) "Apache Commons
BeanUtils" [Resolved]
org.apache.commons.beanutils.nl_de (3.5.0.v20090620043401)
"org.apache.commons.beanutils German NLS Support" [Resolved]
org.apache.commons.cli (1.0.0.v20080604-1500) "pluginName" [Resolved]
org.apache.commons.codec (1.3.0.v20080530-1600) "Apache Commons Codec
Plug-in" [Resolved]
org.apache.commons.collections (3.2.0.v200803061811) "Apache Commons
Collections" [Resolved]
org.apache.commons.collections.nl_de (3.5.0.v20090620043401)
"org.apache.commons.collections German NLS Support" [Resolved]
org.apache.commons.discovery (0.2.0.v200905122109) "Jakarta-Commons
Discovery" [Resolved]
org.apache.commons.discovery.nl_de (3.5.0.v20090620043401)
"org.apache.commons.discovery German NLS Support" [Resolved]
org.apache.commons.el (1.0.0.v200806031608) "Apache Commons JSP 2.0
Expression Language Interpreter" [Resolved]
org.apache.commons.el.nl_de (3.5.0.v20090620043401) "org.apache.commons.el
org.apache.commons.httpclient (3.1.0.v20080605-1935) "Apache Commons
Httpclient" [Resolved]
org.apache.commons.lang (2.3.0.v200803061910) "Apache Jakarta Commons
Lang" [Resolved]
org.apache.commons.lang (2.4.0.v20081016-1030) "Apache Jakarta Commons
Lang" [Resolved]
org.apache.commons.lang.nl_de (3.5.0.v20090620043401)
"org.apache.commons.lang German NLS Support" [Resolved]
org.apache.commons.logging (1.0.4.v200904062259) "Apache Commons Logging
Plug-in" [Resolved]
org.apache.commons.logging.nl_de (3.5.0.v20090620043401)
"org.apache.commons.logging German NLS Support" [Resolved]
org.apache.commons.net (2.0.0.v200905272248) "Apache Commons Net"
[Resolved]
org.apache.commons.net.nl_de (3.5.0.v20090620043401)
"org.apache.commons.net German NLS Support" [Resolved]
org.apache.derby (10.1.2.1_v200803061811) "Apache Derby Plug-in" [Resolved]
org.apache.derby.core (10.3.1.4) "Apache Derby Core Plug-in for Eclipse"
[Starting]
org.apache.derby.core.nl_de (3.5.0.v20090620043401) "org.apache.derby.core
org.apache.derby.nl_de (3.5.0.v20090620043401) "org.apache.derby German
org.apache.jasper (5.5.17.v200903231320) "Apache Jasper 2 Plug-in"
[Resolved]
org.apache.jasper.nl_de (3.5.0.v20090620043401) "org.apache.jasper German
org.apache.log4j (1.2.13.v200903072027) "Apache Jakarta log4j Plug-in"
[Resolved]
org.apache.log4j.nl_de (3.5.0.v20090620043401) "org.apache.log4j German
org.apache.lucene (1.9.1.v20080530-1600) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v20080530-1600) "Apache Lucene Analysis"
[Resolved]
org.apache.xerces (2.9.0.v200909240008) "Apache Xerces-J" [Resolved]
org.apache.xerces.nl_de (3.5.0.v20090620043401) "org.apache.xerces German
org.apache.xml.resolver (1.2.0.v200902170519) "Apache XmlResolver"
[Resolved]
org.apache.xml.resolver.nl_de (3.5.0.v20090620043401)
"org.apache.xml.resolver German NLS Support" [Resolved]
org.apache.xml.serializer (2.7.1.v200902170519) "Apache XML Commons
Serializer" [Resolved]
org.apache.xml.serializer.nl_de (3.5.0.v20090620043401)
"org.apache.xml.serializer German NLS Support" [Resolved]
org.codehaus.groovy (1.6.1.200905091951) "Groovy Runtime Plug-in" [Active]
org.codehaus.groovy.eclipse (1.6.1.200905091951) "Groovy Core" [Active]
org.codehaus.groovy.eclipse.astviews (1.6.1.200905091951) "Groovy AST
Views" [Starting]
org.codehaus.groovy.eclipse.codeassist (1.6.1.200905091951) "Code Assist
Core" [Starting]
org.codehaus.groovy.eclipse.codeassist.completion (1.6.1.200905091951)
"Code Completion Plug-in" [Starting]
org.codehaus.groovy.eclipse.codebrowsing (1.6.1.200905091951) "Groovy Code
Browsing" [Starting]
org.codehaus.groovy.eclipse.collections (1.6.1.200905091951) "Collections
Plug-in" [Resolved]
org.codehaus.groovy.eclipse.core.help (1.6.1.200905091951) "GroovyEclipse
Core Help" [Resolved]
org.codehaus.groovy.eclipse.cstviewer (1.6.1.200905091951) "Groovy CST
Viewer" [Starting]
org.codehaus.groovy.eclipse.junit (1.6.1.200905091951) "Java Development
Tools JUnit support" [Starting]
org.codehaus.groovy.eclipse.refactoring (1.6.1.200905091951) "Refactoring
Plug-in" [Starting]
org.codehaus.groovy.eclipse.ui (1.6.1.200905091951) "Groovy UI" [Active]
org.easymock (2.4.0.v20090202-0900) "EasyMock" [Resolved]
org.eclipse.acceleo.common (0.8.0.v200906161003) "Acceleo Common Utility
Classes" [Starting]
org.eclipse.acceleo.common.nl_de (3.5.0.v20090620043401)
"org.eclipse.acceleo.common German NLS Support" [Resolved]
[Starting]
org.eclipse.acceleo.engine (0.8.0.v200906161003) "Acceleo evaluation
engine" [Starting]
org.eclipse.acceleo.engine.nl_de (3.5.0.v20090620043401)
"org.eclipse.acceleo.engine German NLS Support" [Resolved]
[Starting]
org.eclipse.acceleo.ide.ui (0.8.0.v200906161003) "Acceleo Eclipse User
Interface" [Active]
org.eclipse.acceleo.ide.ui.nl_de (3.5.0.v20090620043401)
"org.eclipse.acceleo.ide.ui German NLS Support" [Resolved]
org.eclipse.acceleo.model (0.8.0.v200906161003) "Acceleo Model" [Active]
org.eclipse.acceleo.model.nl_de (3.5.0.v20090620043401)
"org.eclipse.acceleo.model German NLS Support" [Resolved]
org.eclipse.acceleo.parser (0.8.0.v200906161003) "Acceleo Parser" [Active]
org.eclipse.acceleo.parser.nl_de (3.5.0.v20090620043401)
"org.eclipse.acceleo.parser German NLS Support" [Resolved]
[Resolved]
capability definitions" [Resolved]
org.eclipse.ant.core (3.2.100.v20090520) "Ant Build Tool Core" [Starting]
org.eclipse.ant.core.nl_de (3.5.0.v20090620043401) "org.eclipse.ant.core
org.eclipse.ant.ui (3.4.0.v20090520) "Ant UI" [Starting]
org.eclipse.ant.ui.nl_de (3.5.0.v20090620043401) "org.eclipse.ant.ui
org.eclipse.birt (2.5.0.v20090615) "Business Intelligence and Reporting
Tools" [Resolved]
org.eclipse.birt.chart.cshelp (2.5.0.v20090617) "BIRT Chart
Context-sensitive Help" [Starting]
org.eclipse.birt.chart.cshelp.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.chart.cshelp German NLS Support" [Resolved]
org.eclipse.birt.chart.device.extension (2.5.0.v20090514) "BIRT Chart
Device Extension(s)" [Starting]
org.eclipse.birt.chart.device.extension.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.chart.device.extension German NLS Support" [Resolved]
org.eclipse.birt.chart.device.pdf (2.5.0.v20090326) "BIRT Chart Device PDF
Extension" [Starting]
org.eclipse.birt.chart.device.svg (2.5.0.v20090423) "BIRT Chart Device SVG
org.eclipse.birt.chart.device.svg.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.chart.device.svg German NLS Support" [Resolved]
org.eclipse.birt.chart.device.swt (2.5.0.v20090514) "BIRT Chart Device SWT
Extension" [Active]
org.eclipse.birt.chart.device.swt.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.chart.device.swt German NLS Support" [Resolved]
org.eclipse.birt.chart.engine (2.5.0.v20090604) "BIRT Chart Engine"
[Active]
org.eclipse.birt.chart.engine.extension (2.5.0.v20090527) "BIRT Chart
Engine Extension" [Active]
org.eclipse.birt.chart.engine.extension.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.chart.engine.extension German NLS Support" [Resolved]
org.eclipse.birt.chart.engine.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.chart.engine German NLS Support" [Resolved]
org.eclipse.birt.chart.examples (2.5.0.v20090514) "BIRT Chart Examples
Plug-in" [Starting]
org.eclipse.birt.chart.examples.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.chart.examples German NLS Support" [Resolved]
org.eclipse.birt.chart.reportitem (2.5.0.v20090514) "BIRT Chart-Report
Integration" [Active]
org.eclipse.birt.chart.reportitem.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.chart.reportitem German NLS Support" [Resolved]
org.eclipse.birt.chart.reportitem.ui (2.5.0.v20090531) "BIRT Chart-Report
UI Integration Plug-in" [Active]
org.eclipse.birt.chart.reportitem.ui.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.chart.reportitem.ui German NLS Support" [Resolved]
org.eclipse.birt.chart.ui (2.5.0.v20090604) "BIRT Chart Library UI
Plug-in" [Active]
org.eclipse.birt.chart.ui.extension (2.5.0.v20090604) "BIRT Chart UI
Extension" [Active]
org.eclipse.birt.chart.ui.extension.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.chart.ui.extension German NLS Support" [Resolved]
org.eclipse.birt.chart.ui.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.chart.ui German NLS Support" [Resolved]
org.eclipse.birt.core (2.5.0.v20090601) "BIRT Core Package" [Active]
org.eclipse.birt.core.nl_de (3.5.0.v20090620043401) "org.eclipse.birt.core
org.eclipse.birt.core.script.function (2.5.0.v20090611) "Function Plug-in"
[Active]
org.eclipse.birt.core.script.function.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.core.script.function German NLS Support" [Resolved]
org.eclipse.birt.core.ui (2.5.0.v20090326) "BIRT Core UI" [Active]
org.eclipse.birt.core.ui.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.core.ui German NLS Support" [Resolved]
org.eclipse.birt.cshelp (2.5.0.v20090617) "BIRT Context-sensitive Help"
[Starting]
org.eclipse.birt.cshelp.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.cshelp German NLS Support" [Resolved]
org.eclipse.birt.data (2.5.0.v20090605) "BIRT Data Engine" [Active]
org.eclipse.birt.data.aggregation (2.5.0.v20090605) "Build-in Aggregation
Plug-in" [Starting]
org.eclipse.birt.data.aggregation.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.data.aggregation German NLS Support" [Resolved]
org.eclipse.birt.data.nl_de (3.5.0.v20090620043401) "org.eclipse.birt.data
org.eclipse.birt.doc (2.5.0.v20090615) "BIRT Documentation" [Starting]
org.eclipse.birt.doc.nl_de (3.5.0.v20090620043401) "org.eclipse.birt.doc
org.eclipse.birt.example (2.5.0.v20090615) "BIRT Example" [Resolved]
org.eclipse.birt.example.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.example German NLS Support" [Resolved]
org.eclipse.birt.nl_de (3.5.0.v20090620043401) "org.eclipse.birt German
org.eclipse.birt.report.data.adapter (2.5.0.v20090605) "BIRT Data Adapter"
[Active]
org.eclipse.birt.report.data.adapter.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.report.data.adapter German NLS Support" [Resolved]
org.eclipse.birt.report.data.oda.jdbc (2.5.0.v20090605) "BIRT ODA-JDBC
Bridge Driver" [Starting]
org.eclipse.birt.report.data.oda.jdbc.dbprofile (2.5.0.v20090605) "JDBC
Databases Profile Data Source ODA Runtime Driver" [Starting]
org.eclipse.birt.report.data.oda.jdbc.dbprofile.nl_de
(3.5.0.v20090620043401) "org.eclipse.birt.report.data.oda.jdbc.dbprofile
org.eclipse.birt.report.data.oda.jdbc.dbprofile.sampledb (2.5.0.v20090605)
"BIRT Sample Database Connection Profile Plug-in" [Starting]
org.eclipse.birt.report.data.oda.jdbc.dbprofile.sampledb.nl_ de
"org.eclipse.birt.report.data.oda.jdbc.dbprofile.sampledb German NLS
Support" [Resolved]
org.eclipse.birt.report.data.oda.jdbc.dbprofile.ui (2.5.0.v20090605) "JDBC
Databases Profile Data Source ODA Designer" [Starting]
org.eclipse.birt.report.data.oda.jdbc.dbprofile.ui.nl_de
"org.eclipse.birt.report.data.oda.jdbc.dbprofile.ui German NLS Support"
[Resolved]
org.eclipse.birt.report.data.oda.jdbc.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.report.data.oda.jdbc German NLS Support" [Resolved]
org.eclipse.birt.report.data.oda.jdbc.ui (2.5.0.v20090605) "BIRT JDBC UI
Plug-in" [Starting]
org.eclipse.birt.report.data.oda.jdbc.ui.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.report.data.oda.jdbc.ui German NLS Support" [Resolved]
org.eclipse.birt.report.data.oda.sampledb (2.5.0.v20090605) "BIRT Sample
Database" [Starting]
org.eclipse.birt.report.data.oda.sampledb.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.report.data.oda.sampledb German NLS Support" [Resolved]
org.eclipse.birt.report.data.oda.sampledb.ui (2.5.0.v20090605) "BIRT
Sample Database UI Plug-in" [Starting]
org.eclipse.birt.report.data.oda.sampledb.ui.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.report.data.oda.sampledb.ui German NLS Support"
[Resolved]
org.eclipse.birt.report.data.oda.xml (2.5.0.v20090605) "BIRT ODA-XML
Driver" [Starting]
org.eclipse.birt.report.data.oda.xml.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.report.data.oda.xml German NLS Support" [Resolved]
org.eclipse.birt.report.data.oda.xml.ui (2.5.0.v20090615) "BIRT ODA XML
org.eclipse.birt.report.data.oda.xml.ui.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.report.data.oda.xml.ui German NLS Support" [Resolved]
org.eclipse.birt.report.debug.core (2.5.0.v20090603) "BIRT Debug Core
Plug-in" [Resolved]
org.eclipse.birt.report.debug.core.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.report.debug.core German NLS Support" [Resolved]
org.eclipse.birt.report.debug.ui (2.5.0.v20090603) "BIRT Debug UI Plug-in"
[Active]
org.eclipse.birt.report.debug.ui.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.report.debug.ui German NLS Support" [Resolved]
org.eclipse.birt.report.designer.core (2.5.0.v20090603) "BIRT Designer
Core" [Active]
org.eclipse.birt.report.designer.core.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.report.designer.core German NLS Support" [Resolved]
org.eclipse.birt.report.designer.samplereports (2.5.0.v20090615) "BIRT
Samplereports Plug-in" [Starting]
org.eclipse.birt.report.designer.ui (2.5.0.v20090603) "BIRT Designer UI"
[Active]
org.eclipse.birt.report.designer.ui.cubebuilder (2.5.0.v20090603) "BIRT
Cube Builder Plug-in" [Active]
org.eclipse.birt.report.designer.ui.cubebuilder.nl_de
(3.5.0.v20090620043401) "org.eclipse.birt.report.designer.ui.cubebuilder
org.eclipse.birt.report.designer.ui.data (2.5.0.v20090603) "BIRT Designer
Data Plug-in" [Active]
org.eclipse.birt.report.designer.ui.editor.script (2.5.0.v20090603) "BIRT
Enhanced Script Editor Plug-in" [Active]
org.eclipse.birt.report.designer.ui.editor.script.nl_de
(3.5.0.v20090620043401) "org.eclipse.birt.report.designer.ui.editor.script
org.eclipse.birt.report.designer.ui.editor.xml.wtp (2.5.0.v20090603) "BIRT
Advanced XML Editor Plug-in" [Active]
org.eclipse.birt.report.designer.ui.editor.xml.wtp.nl_de
"org.eclipse.birt.report.designer.ui.editor.xml.wtp German NLS Support"
[Resolved]
org.eclipse.birt.report.designer.ui.editors (2.5.0.v20090603) "BIRT
MultipageEditor Extension Point Plug-in" [Active]
org.eclipse.birt.report.designer.ui.editors.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.report.designer.ui.editors German NLS Support" [Resolved]
org.eclipse.birt.report.designer.ui.editors.schematic (2.5.0.v20090603)
"BIRT Editors Plug-in" [Active]
org.eclipse.birt.report.designer.ui.editors.schematic.nl_de
"org.eclipse.birt.report.designer.ui.editors.schematic German NLS Support"
[Resolved]
org.eclipse.birt.report.designer.ui.ide (2.5.0.v20090603) "BIRT Designer
UI for IDE" [Active]
org.eclipse.birt.report.designer.ui.ide.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.report.designer.ui.ide German NLS Support" [Resolved]
org.eclipse.birt.report.designer.ui.lib (2.5.0.v20090603) "BIRT Designer
UI for Library" [Starting]
org.eclipse.birt.report.designer.ui.lib.explorer (2.5.0.v20090603) "BIRT
Library Explorer Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.lib.explorer.nl_de
(3.5.0.v20090620043401) "org.eclipse.birt.report.designer.ui.lib.explorer
org.eclipse.birt.report.designer.ui.lib.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.report.designer.ui.lib German NLS Support" [Resolved]
org.eclipse.birt.report.designer.ui.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.report.designer.ui German NLS Support" [Resolved]
org.eclipse.birt.report.designer.ui.preview.web (2.5.0.v20090603) "BIRT
Preview Plug-in" [Active]
org.eclipse.birt.report.designer.ui.preview.web.nl_de
(3.5.0.v20090620043401) "org.eclipse.birt.report.designer.ui.preview.web
org.eclipse.birt.report.designer.ui.samples.ide (2.5.0.v20090603) "Report
Samples IDE Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.samples.ide.nl_de
(3.5.0.v20090620043401) "org.eclipse.birt.report.designer.ui.samples.ide
org.eclipse.birt.report.designer.ui.samplesview (2.5.0.v20090603) "BIRT
Report Samples View Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.samplesview.nl_de
(3.5.0.v20090620043401) "org.eclipse.birt.report.designer.ui.samplesview
org.eclipse.birt.report.designer.ui.views (2.5.0.v20090603) "BIRT UI Views
Plug-in" [Active]
org.eclipse.birt.report.designer.ui.views.nl_de (3.5.0.v20090620043401)
"org.eclipse.birt.report.designer.ui.views German NLS Support" [Resolved]
org.eclipse.birt.report.engine (2.5.0.v20090616) "BIRT Engine" [Active]
org.eclipse.birt.report.engine.dataextraction (2.5.0.v20090611)
"Dataextraction Plug-in" [Starting]
org.eclip
Re: Trigger problem with BIRT 2.5.0 [message #480802 is a reply to message #480489] |
Tue, 18 August 2009 10:33   |
Farideh,
Any chance you could download the allinone build to a separate directory
and try your code in it?
Jason
farideh wrote:
> Jason,
> farideh
> MaxCubeRowLevels=50
> MaxDataSetRows=500
> birt.designer=true
> win32
> -ws
> win32
> -arch
> x86
> -showsplash
> -launcher
> -name
> Eclipse
> --launcher.library
> -startup
> -showlocation
> -nl
> en
> -data
> -vm
> -Xmx768m
> file.separator=\
> http.proxyPort=8080
> http.proxySet=true
> https.proxySet=true
> line.separator=
vax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.r owset.serial,javax.sql.rowset.spi,javax.swing,javax.swing.bo rder,javax.swing.colorchooser,javax.swing.event,javax.swing. filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.sw ing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.synth ,javax.swing.table,javax.swing.text,javax.swing.text.html,ja vax.swing.text.html.parser,javax.swing.text.rtf,javax.swing. tree,javax.swing.undo,javax.transaction,javax.transaction.xa ,javax.xml,javax.xml.datatype,javax.xml.namespace,javax.xml. parsers,javax.xml.transform,javax.xml.transform.dom,javax.xm l.transform.sax,javax.xml.transform.stream,javax.xml.validat ion,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORB A_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage ,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.COR BA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.Namin gContextExtPackage,org.omg.CosNaming.NamingContextPackage,or g.omg.Dynamic,org.omg.DynamicA
ny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAn y.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage, org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableI nterceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,or g.omg.PortableServer,org.omg.PortableServer.CurrentPackage,o rg.omg.PortableServer.POAManagerPackage,org.omg.PortableServ er.POAPackage,org.omg.PortableServer.portable,org.omg.Portab leServer.ServantLocatorPackage,org.omg.SendingContext,org.om g.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.do m.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.ls,org .w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.traversa l,org.w3c.dom.views
> os.arch=x86
> os.name=Windows XP
> os.version=5.1
> osgi.arch=x86
> osgi.nl=en
> osgi.nl.user=en
> osgi.os=win32
> osgi.ws=win32
> path.separator=;
> sun.cpu.isalist=
> sun.desktop=windows
> user.country=DE
> user.language=de
> user.name=zahra
> user.variant=
> *** Features:
> EMF Source"
> Editor"
> Classes"
> "Business Intelligence and Reporting Tools"
> Chart Context-sensitive Help"
> Development"
> Client"
> Documentation"
> Plug-in"
> Enablement Plug-in"
> Enablement"
> Enablement"
> Plug-in"
> Connectivity JDT Extension Plug-in"
> Enablement"
> Enablement"
> ODA Designer"
> XML ODA Runtime Driver"
> Enablement"
> Enablement"
> Enablement"
> Enablement"
> Plug-in"
> SQLModel Plug-in"
> FE UI Plug-in"
> Parser Plugin"
> User Documentation"
> (1.0.0.v20090610-1638-7C--EAAoOQBPbbrBcPz0b) "Dynamic Languages Toolkit
> Core Source"
> DLTK Bridge"
> Development Tools"
> (1.0.0.v20090610-1638-7B--E_EkMO1NTYtAZCz-9) "Dynamic Languages Toolkit
> Development Tools"
> Framework (ECF)"
> Runtime and Tools"
> Definitions "
> Documentation"
> Examples"
> Server"
> Generator"
> Generator UI"
> Documentation"
> Binding"
> Editor"
> (Incubation)"
> Mapping Editor"
> (Incubation)"
> (Incubation)"
> (Incubation)"
> (Incubation)"
> (Incubation)"
> Model Query"
> "EMF Model Transaction Workbench Integration Documentation"
> "Graphical Editing Framework GEF"
> (1.1.1.v20090114-0940-33-8s733L3C5715J78) "GMF Notation Model Support"
> Base"
> Templates (JET)"
> Emitter Templates (JET) Documentation"
> JET SDK"
> Language"
> (2.0.0.v20090410-1820-79--AkF77g7SDX3BfM7) "QVT Operational Common"
> "QVT Operational Documentation"
> (2.0.0.v20090616-1500-3--7w311A171902941) "QVT Operational Samples"
> (2.0.0.v20090410-1820-79--AkF77g7RCR3BeK7) "QVT Operational Runtime"
> Definitions"
> Documentation"
> Platform Examples"
> Constraint Language (OCL) 2.0 Parser/Interpreter"
> Binding for UML"
> "Eclipse Platform"
> "Remote System Explorer End-User Runtime"
> DStore Services"
> Service"
> Local Services"
> Services"
> Telnet Service"
> "RSE Terminals UI"
> org.eclipse.sdk
> Project SDK"
> Provider (Incubation)"
> Integration for the Mylyn Project (Incubation)"
> (Incubation)"
> (Incubation)"
> and Tools"
> (Incubation)"
> (Incubation)"
> UML2 typesystem Source (Incubation)"
> (Incubation)"
> (Incubation)"
> "Subversive SVN Connectors"
> [Resolved]
> EMF Tests" [Active]
> Service" [Active]
> Plug-in" [Resolved]
> [Resolved]
> (1.99)" [Resolved]
> [Resolved]
> Support" [Resolved]
> [Resolved]
> [Resolved]
> Support" [Resolved]
> Support" [Resolved]
> Editor" [Active]
> LPG" [Resolved]
> [Resolved]
> Extension" [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> "org.apache.batik.util German NLS Support" [Resolved]
> Plug-in" [Resolved]
> "org.apache.commons.el German NLS Support" [Resolved]
> Lang" [Resolved]
> Lang" [Resolved]
> Plug-in" [Resolved]
> [Resolved]
> [Starting]
> "org.apache.derby.core German NLS Support" [Resolved]
> [Resolved]
> [Resolved]
> Analysis" [Resolved]
> [Resolved]
> Views" [Starting]
> Core" [Starting]
> Code Browsing" [Starting]
> "Collections Plug-in" [Resolved]
> "GroovyEclipse Core Help" [Resolved]
> Viewer" [Starting]
> "Refactoring Plug-in" [Starting]
> Classes" [Starting]
> [Starting]
> engine" [Starting]
> [Starting]
> Interface" [Active]
> Source" [Resolved]
> Tools" [Resolved]
> PDF Extension" [Starting]
> SVG Extension" [Starting]
> SWT Extension" [Active]
> [Active]
> Plug-in" [Starting]
> Chart-Report UI Integration Plug-in" [Active]
> Plug-in" [Active]
> Extension" [Active]
> "org.eclipse.birt.core German NLS Support" [Resolved]
> Plug-in" [Active]
> [Starting]
> Aggregation Plug-in" [Starting]
> "org.eclipse.birt.data German NLS Support" [Resolved]
> Adapter" [Active]
> (2.5.0.v20090605) "BIRT Sample Database Connection Profile Plug-in"
> [Starting]
> Support" [Resolved]
> "JDBC Databases Profile Data Source ODA Designer" [Starting]
> [Resolved]
> Plug-in" [Starting]
> (3.5.0.v20090620043401) "org.eclipse.birt.report.data.oda.sampledb.ui
> Driver" [Starting]
> Plug-in" [Resolved]
Re: Trigger problem with BIRT 2.5.0 [message #669284 is a reply to message #481039] |
Mon, 09 May 2011 14:19  |
Hi, Did you ever get a resolution for this problem?
We are seeing similar problems.
They only occur when we have more than one BIRT report open in a single page of our application. The problem seems to be that the map ids not being unique.
Current Time: Sun Jul 27 03:58:06 EDT 2025
Powered by FUDForum. Page generated in 0.10455 seconds
