Home » Eclipse Projects » Buckminster dev » [buckminster-dev] question about rmap and mutable and anon
[buckminster-dev] question about rmap and mutable and anon [message #479903] Wed, 12 August 2009 20:58 Go to next message
Some of the examples I've seen of rmap files use mutable="true" with a
readerType="cvs" and a uri format=":pserver:anonymous@ ...."
Does it make sense to have mutable="true" if you are checking out
anonymously. The Bucky book tells me
"The attribute mutable is set to true because we want the projects
checked out from CVS (so we
can work on them and check in again)."
As an anon user, I'm clearly not going to check in files. Is it worng
to set mutable="false" in this case.
-Ted
Re: [buckminster-dev] question about rmap and mutable and anon [message #479916 is a reply to message #479903] Thu, 13 August 2009 01:28 Go to previous messageGo to next message
No, it's not wrong. Buckminster only uses the mutable attribute if you use it yourself in a CQUERY. If you don't care
about its setting, neither will Buckminster.
The intention is the same as with the source="false", i.e. to help selecting the right provider in case there are
several possible matches. A provider with a mutable status that matches your cquery has higher priority. And that's all
there's to it.
Thomas Hallgren
Re: [buckminster-dev] question about rmap and mutable and anon [message #479975 is a reply to message #479903] Thu, 13 August 2009 06:23 Go to previous messageGo to next message
I should rephrase that to explain that what is set up in the RMAP is
just the *capability* to get mutable access.
- henrik
Re: [buckminster-dev] question about rmap and mutable and anon [message #479979 is a reply to message #479975] Thu, 13 August 2009 06:43 Go to previous message
I changed the text to:
The attribute mutable is set to true because we want searches for
mutable source (i.e. projects checked out from CVS that can be worked on
and checked in again) to also use this search path. Note that in this
example we are using an anonymous user so in order to be
able to actually check things in again, someone with write access would
have to use the IDE’s team CVS functionality to relocate the projects
with their user id once they have been materialized to the workspace.
You will see later how to create entries using authentication — see the
section called, “Providers and authentication”.
> - henrik
Previous Topic:Tutorial for building an RCP from hudson
Next Topic:Check-in comments
Current Time: Sun Jul 27 22:28:20 EDT 2025
Powered by FUDForum. Page generated in 0.05512 seconds
