Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Spinner - Min, Max values
Spinner - Min, Max values [message #479581] Tue, 11 August 2009 11:46 Go to next message
I have a question concerning the min and max behaviour of the SWT Spinner
component.
In some cases, I have the same value for the min and max values. But this
is managed by the component as an error case :
Spinner.java => L 1090 : if (maximum <= minimum) return;
Does anyone knows why this has been done and if it is possible to allow
the min and max values to be equal in the next release of SWT ?
Thanks in advance,
Cédric
Re: Spinner - Min, Max values [message #479850 is a reply to message #479581] Wed, 12 August 2009 13:21 Go to previous messageGo to next message
Opfermann Cédric wrote:
> Spinner component.
> this is managed by the component as an error case :
Note: when referring to code, you should give more context, including
the version of SWT and the method you are referencing. In the current
(3.5) version of Spinner.java, there is no line 1090.
Hopefully someone will explain why that limitation exits; if you want to
request a change you should do so via Bugzilla:
https://bugs.eclipse.org/bugs
Hope this helps,
Eric
Re: Spinner - Min, Max values [message #479968 is a reply to message #479850] Thu, 13 August 2009 05:47 Go to previous messageGo to next message
OK, thanks for your help, I posted a bug report, let's see how it will be
corrected or not :)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=286489
Re: Spinner - Min, Max values [message #480026 is a reply to message #479968] Thu, 13 August 2009 09:39 Go to previous message
> be corrected or not :)
Good.
I see that it was marked as a duplicate of another (old) bug report. I
suggest you make an attempt at fixing the problem and submitting a
patch, since bugs or feature requests with code patches tend to get more
attention than those without. Plus, it is a wonderful feeling to see
some code you wrote make it into the platform!
Eric
Previous Topic:SWT Label with SWT.WRAP and SWT.CENTER is wrapped, but not centered (Mac OS X)
Next Topic:Preventing a shell from closing
Current Time: Sat Jul 26 15:24:16 EDT 2025
Powered by FUDForum. Page generated in 0.04080 seconds
