Home » Eclipse Projects » Plugin Development Environment (PDE) » Re: Modifying plugin.xml
Re: Modifying plugin.xml [message #69055] Fri, 24 July 2009 11:28 Go to next message
Originally posted by: eclipse-news.rizzoweb.com
Copying this to the PDE (eclipse.platform.pde) newsgroup where it might
get more attention.
Markus wrote:
> Hi all,
> I just switched from Eclipse 3.2.2 to Eclipse 3.4.2 and I have noticed
> that everytime I modify an existing plugin.xml my Eclipse hangs for a
> few seconds. Using tools like ProcessExplorer shows me that Eclipse is
> scanning all files in my target runtime folder during that time. After
> that, Eclipse decides to perform a full workspace build.
> Is this a common behaviour or is this something I can change in the
> preferences? I never had this issue using 3.2.2. Could someone help me?
> Thanks in advance,
> Cheers!
Re: Modifying plugin.xml [message #479380 is a reply to message #69055] Mon, 10 August 2009 15:47 Go to previous messageGo to next message
If the plug-in dependencies change, the PDE state must be updated and a build is likely to happen. However, this shouldn't hang Eclipse and it shouldn't happen each time the plugin.xml is modified.
Re: Modifying plugin.xml [message #600464 is a reply to message #69055] Mon, 10 August 2009 15:48 Go to previous message
Previous Topic:Eclipse Extension Point Schema Definition Change from Eclipse 3.4 to 3.5
Next Topic:Eclipse 3.5 Update Site / p2 issues
Current Time: Sun Aug 31 22:44:31 EDT 2025
Powered by FUDForum. Page generated in 0.05102 seconds
