Home » Eclipse Projects » Eclipse Platform » Converting an Action path into command path
Converting an Action path into command path [message #479273] Mon, 10 August 2009 09:59 Go to next message
I'm sure this should be simple, can someone please point out where I'm going
wrong... I'm migrating actions to be commands.
One action had a path of "/navigateGroup". I found that when I created a
menu contribution using org.eclipse.ui.menus and specified
locationURI=" popup:org.eclipse.gmf.runtime.diagram.ui.DiagramEditorContex tMenu?after=navigateGroup ">
it worked.
Now I have another action but its found with the action path:
"/navigateMenu/groupX" (which actually is a contribution to a menu found
within the same group as above)
I'm not sure how this converts into the command/handler framework...
I've tried:
locationURI=" popup:org.eclipse.gmf.runtime.diagram.ui.DiagramEditorContex tMenu?after=navigateMenu/groupX ">
And:
locationURI=" popup:org.eclipse.gmf.runtime.diagram.ui.DiagramEditorContex tMenu?after=groupX ">
And
<menu id="navigateMenu"...> <command ... /> </menu>
I also found in the IIDEActionConstants an id for the start of the
navigation menu: navStart. So I tried this as well:
locationURI=" popup:org.eclipse.gmf.runtime.diagram.ui.DiagramEditorContex tMenu?after=navStart ">
But none seem to contribute my command into the navigate menu.
Any help please?
Adam
Re: Converting an Action path into command path [message #479354 is a reply to message #479273] Mon, 10 August 2009 14:23 Go to previous messageGo to next message
The syntax for the location URI is popup:<menu.id>?after=<contained.id>
navigateMenu is probably the menu id ... but where is it coming from? menuContributions cannot see objectContributions or viewerContributions. They can only see programmatic contributions and other menuContributions.
PW
Re: Converting an Action path into command path [message #479359 is a reply to message #479273] Mon, 10 August 2009 14:20 Go to previous messageGo to next message
Could it be that my issue is I need to specify the navigate menu id rather
then the diagram context menu id? If this is the case, how do I get the
proper navigateMenu id?
I tried using just locationURI="popup:navigateMenu?after=groupX"
and
locationURI=" popup:org.eclipse.gmf.runtime.diagram.ui.navigateMenu?after= groupX ">
But this also didn't work. Do I need to specify the navigate menu id? or do
I need to use the default context menu, and then re-create the menu
structure (I believe I read to do this else where, but it is also not
working for me).
Thanks again,
Adam
Re: Converting an Action path into command path [message #479372 is a reply to message #479354] Mon, 10 August 2009 14:43 Go to previous messageGo to next message
Looks like its contributed through GMF's DiagramContributionItemProvider as
a popupmenu
<popupmenu path="/navigateGroup" id="navigateMenu"/>
Does this mean that its not accessible via the org.eclipse.ui.menus
infrastructure?
-Adam
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:h5pojp$ut5$1@build.eclipse.org...
> PW
Re: Converting an Action path into command path [message #479530 is a reply to message #479372] Tue, 11 August 2009 09:14 Go to previous messageGo to next message
Adam Neal wrote on Mon, 10 August 2009 14:43
a popupmenu
infrastructure?
I'm not familiar with how GMF is creating its submenu, but it might not be available to o.e.ui.menus.
When you try and add the submenu using:
It doesn't work? Or does it produce 2 submenus? You said that using locationURI=" popup:org.eclipse.gmf.runtime.diagram.ui.DiagramEditorContex tMenu?after=navigateGroup " to place a command worked, right?
PW
Re: Converting an Action path into command path [message #479636 is a reply to message #479530] Tue, 11 August 2009 15:46 Go to previous messageGo to next message
It seems that the GMF navigate menu is being created first, before the
PopupMenuExtender gets its chance to add contributions. Therefore the
navigateMenu already exists by the time I try to add to it (as I have other
actions which have already been added to it).
I am again trying to re-create the Navigate menu via:
locationURI="
If I change the id to be navigateMenu1,then I get two menus showing up. But
if I use the GMF id, my command seems to get wiped out.
Here's what I found by debugging.
In the WorkbenchMenuService::processAdditions, the idx value is found to 9
(index when using the cache...). The safe runnable is then used to add my
menu item...The expressions return true for visiblity. It gets the
ManagerPopulationRecord from the ContributionManager, and from this I can
see the menu URI is popup:navigateMenu. Eventually we find ourselves at line
599 in the SafeRunnable of the WorkbenchMenuService::processAdditions trying
to insert the command: mgr.insert(insertionIndex, ici);
At this point, the mgr has an empty contributions list!?! So this method
throws an ArrayIndexOutOfBoundsException since its asking to add at index 9
and therefore I never get added to the menu.
Does this ring a bell for you as to what might be wrong?
Thanks again,
Adam
P.S you asked: locationURI="
Yes, this works since its an action in the root menu.
news:h5rqrg$jg5$1@build.eclipse.org...
>> as a popupmenu
>> infrastructure?
> locationURI="
> locationURI="
> PW
Re: Converting an Action path into command path [message #479776 is a reply to message #479636] Wed, 12 August 2009 09:40 Go to previous messageGo to next message
So the index==9, is that for the command element based on the programmatically added navigateMenu? And then it's using the empty one it created to actually do the insert?
It sounds like there's a bug in there, one way or the other. Please open a bug at https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=UI and post the number back here and we'll have a look.
if the navigateMenu MenuManager is being added to the context menu programmatically then it should be available to your menuContributions simply using popup:navigateMenu (you don't need to add the <menu/> element yourself).
PW
Re: Converting an Action path into command path [message #479883 is a reply to message #479776] Wed, 12 August 2009 17:33 Go to previous message
Thanks Paul,
This bug is tracking the issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=286393
Note: I did try using simply the URI popup:navigateMenu as well, but I get
the exact same issue...
Adam
news:h5ugo7$7te$1@build.eclipse.org...
> a bug at
> yourself).
> PW
Previous Topic:Delta lost when breakpoint change merged with breakpoint add?
Next Topic:How to override Boolean settings using ScopedPreferenceStore?
Current Time: Wed Jul 23 12:17:04 EDT 2025
Powered by FUDForum. Page generated in 0.33249 seconds
