Home » Archived » Test and Performance Tools Platform (TPTP) » Test with JUnit4 in an EMF project
Test with JUnit4 in an EMF project [message #479249] Mon, 10 August 2009 08:48 Go to next message
Originally posted by: aurelien.pupier.esial.net
I post in the two newsgroup because I hope that both can bring me the solution.
I tried to test some creation of EObject.
But in my JUnit test, the XXXFactory.eINSTANCE return the generated instance although the extended factory that I use and declared in another plugin via o.e.emf.ecore.factory_override.
How can I set JUnit test aware of this?
I already try with adding the plugin with extended factory User entries classpath of the JUnit test launch configuration but with no change.
Thanks for any hints.
Aurelien Pupier
Re: Test with JUnit4 in an EMF project [message #479272 is a reply to message #479249] Mon, 10 August 2009 09:48 Go to previous messageGo to next message
--------------030107040108030309080905
Aurelien,
You need to run as an Eclipse/OSGi application for plugin registrations
to be taken into account. Running as an ordinary Java application won't
do the trick, at least not until this is supported:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=271253
Aurelien Pupier wrote:
> solution.
> change.
> Aurelien Pupier
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Aurelien,<br>
<br>
to be taken into account.&nbsp; Running as an ordinary Java application
won't do the trick, at least not until this is supported:<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=271253">https://bugs.eclipse.org/bugs/show_bug.cgi?id=271253</a><br>
</blockquote>
<br>
<blockquote cite="mid:h5p4vi$pa2$1@build.eclipse.org" type="cite">Hi,
<br>
<br>
solution.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Aurelien Pupier
<br>
</blockquote>
</body>
</html>
--------------030107040108030309080905--
Re: Test with JUnit4 in an EMF project [message #479280 is a reply to message #479272] Mon, 10 August 2009 10:01 Go to previous message
thanks for your reply.
I will test it via an Eclipse application ;)
Ed Merks a écrit :
> Aurelien,
>> Hi,
>> solution.
>> change.
>> Aurelien Pupier
Previous Topic:Instance Name field is always blank if the jdk version is 1.5
Next Topic:Problem with AGR
Current Time: Wed Jul 23 04:19:52 EDT 2025
Powered by FUDForum. Page generated in 0.05766 seconds
