Home » Modeling » TMF (Xtext) » Lexical syntax highlighting
Lexical syntax highlighting [message #479001] Fri, 07 August 2009 18:21 Go to next message
Originally posted by: c.krause.cwi.nl
sorry I know this is covered in the docu, but I do not fully understand
how I can hook up my own custom lexical highlighter. Is there any
example that shows how exactly I should hook up the
ILexicalHighlightingConfiguration and the AbstractTokenScanner +
AbstractAntlrTokenToAttributeIdMapper?
The token scanner I should hook up via bindITokenScanner() in my
XXXUIModule, right? And then I override getTokenIdMapper() in there?
How about the ILexicalHighlightingConfiguration?
Christian
Re: Lexical syntax highlighting [message #479020 is a reply to message #479001] Sat, 08 August 2009 04:21 Go to previous messageGo to next message
The documentation is not really helpful for beginners. But once you get
the hang of guice injection and how it is used within XText, everything
should look simple.
If you bind a ITokenScanner you need to implement all the stuff. In XText,
you just need to bind a AbstractAntlrTokenToAttributeIdMapper.
In detail:
1. Create a LexicalHighlightingConfiguration class that extends either
DefaultLexicalHighlightingConfiguration or implements
ILexicalHighlightingConfiguration. You need to override
configure(IHighlightingConfigurationAcceptor acceptor) method and call
acceptor.acceptDefaultHighlighting to register textstyles.
2. Create a AntlrTokenToAttributeIdMapper class that extends either
DefaultAntlrTokenToAttributeIdMapper or
AbstractAntlrTokenToAttributeIdMapper. You need to override the
calculateId(String tokenName, int tokenType) method and return the ID
defined in the LexicalHighlightingConfiguration for the tokens.
3. Update your <grammar>UIModule.java and add these two functions:
public Class<? extends ILexicalHighlightingConfiguration>
bindILexicalHighlightingConfiguration() {
return LexicalHighlightingConfiguration.class;
public Class<? extends AbstractAntlrTokenToAttributeIdMapper>
bindAbstractAntlrTokenToAttributeIdMapper() {
return AntlrTokenToAttributeIdMapper.class ;
XText uses reflection to find all bind* methods and injects the
appropriate objects.
Done.
HTH.
-- KD
Re: Lexical syntax highlighting [message #479067 is a reply to message #479020] Sat, 08 August 2009 14:55 Go to previous messageGo to next message
Originally posted by: christian.krause.cwi.nl
Thanks a lot. That worked like a charm.
Christian
Am 08.08.2009 10:21, schrieb KD:
>> understand how I can hook up my own custom lexical highlighter. Is
>> there any example that shows how exactly I should hook up the
> should look simple.
> XText, you just need to bind a AbstractAntlrTokenToAttributeIdMapper.
> In detail:
> Done.
> HTH.
> -- KD
Re: Lexical syntax highlighting [message #552723 is a reply to message #479001] Fri, 13 August 2010 05:29 Go to previous messageGo to next message
Hi, this thread is helpful, but I cannot see how to achieve the following.
I want a subset of the keywords in my language to have a different color than the default keyword color. I don't understand how to adapt the lexical highlighting to achieve this.
-- Jos
Re: Lexical syntax highlighting [message #552731 is a reply to message #552723] Fri, 13 August 2010 05:41 Go to previous messageGo to next message
in the highlighting configuration you only state which styles are
available. Which style is in fact used (for lexical highlighting) is
determined in the DefaultAntlrTokenToAttributeIdMapper. You will have to
bind your own implementation and determine the style based on the token
name/type.
Alex
Re: Lexical syntax highlighting [message #552736 is a reply to message #552731] Fri, 13 August 2010 06:31 Go to previous messageGo to next message
Alex, this is what I am trying to do. IOn the Lexical highlighting I define a new style:
public class MyHighLightingConfiguration extends DefaultHighlightingConfiguration{
	public static final String LAYOUT_ID = "layout";
	public void configure(IHighlightingConfigurationAcceptor acceptor) {
		super.configure(acceptor);
		acceptor.acceptDefaultHighlighting(LAYOUT_ID, "Layout",	layoutTextStyle());
	public TextStyle layoutTextStyle() {
		TextStyle textStyle = new TextStyle();
		textStyle.setColor(new RGB(0, 0, 255));
		textStyle.setStyle(SWT.ITALIC);
		return textStyle;
And in the token id scanner I try to use it:
public class MyAntlrTokenToAttributeIdMapper extends DefaultAntlrTokenToAttributeIdMapper {
	protected String calculateId(String tokenName, int tokenType) {
		if( "container".equals(tokenName)) {
			return MyHighLightingConfiguration.LAYOUT_ID;
		return super.calculateId(tokenName, tokenType);
And in the module I bind them:
	public Class<? extends IHighlightingConfiguration> bindILexicalHighlightingConfiguration() {
		return MyHighLightingConfiguration.class;
	public Class<? extends AbstractAntlrTokenToAttributeIdMapper> bindAbstractAntlrTokenToAttributeIdMapper() {
		return MyAntlrTokenToAttributeIdMapper.class ;
Nothing happens, I still get the default keyword color for the "container" keyword.
If I take out the call to 'super' in MyHighlightingConfiguration all keyword syntax coloring dissappears, so the binding works ok.
-- Jos
Re: Lexical syntax highlighting [message #552740 is a reply to message #552736] Fri, 13 August 2010 06:42 Go to previous messageGo to next message
have you checked whether the token name is indeed "container"? Have you
tried returing your LAYOUT_ID for all elements, to see whether then all
keywords get your new style?
Alex
Re: Lexical syntax highlighting [message #552742 is a reply to message #552740] Fri, 13 August 2010 07:00 Go to previous messageGo to next message
Alex,
Good point! I print the tokenName and it prints as 'container'. Looks ok, but after rereading it several times I realized that the single quotes are part of the tokenName. I now check for equality with 'container' including the quotes (read carefully) it works ok:
	protected String calculateId(String tokenName, int tokenType)kenName + "] type [" + tokenType + "]");
		if( "'container'".equals(tokenName)) {
Surprising behavior at least because tehre are no quotes in the input anywhere, maybe even a bug.
-- Thanks, Jos
Re: Lexical syntax highlighting [message #552744 is a reply to message #552740] Fri, 13 August 2010 06:56 Go to previous messageGo to next message
ps:
I am almost prepared to bet that it is "'container'".
Alex
Re: Lexical syntax highlighting [message #552746 is a reply to message #552742] Fri, 13 August 2010 07:09 Go to previous messageGo to next message
I don't think it is a bug. I believe it is intended in order to
distinguish keywords from rule names. After all, nobody prevents you
from having a grammar containing
SomeRule: 'ID' id=ID;
in which case the token names could be identical if keywords did not get
the single quotes (don't hit me if the name for the ID rule is ID_RULE,
in this case there could be a keyword ID_RULE as well).
Alex
Re: Lexical syntax highlighting [message #552761 is a reply to message #552746] Fri, 13 August 2010 08:20 Go to previous messageGo to next message
Alex,
Ok, then it is just me who didn't expect this.
-- Jos
Re: Lexical syntax highlighting [message #727588 is a reply to message #552761] Wed, 21 September 2011 11:20 Go to previous messageGo to next message
Is it possible to highlight also hidden parts?
In my DSL everything that start with % is hidden, but i want to be able to change the color of this tokens. Is it possible?
Thank you
Andrey
Re: Lexical syntax highlighting [message #727630 is a reply to message #727588] Wed, 21 September 2011 13:27 Go to previous messageGo to next message
Yes,
That is how comments get highlighted. This is all in the documentation.
- henrik
On 9/21/11 5:20 PM, Andrey wrote:
> Thank you
> Regards,
> Andrey
Re: Lexical syntax highlighting [message #1782138 is a reply to message #727630] Mon, 19 February 2018 06:47 Go to previous message
I can't find neither bindILexicalHighlightingConfiguration(), nor bindAbstractAntlrTokenToAttributeIdMapper() in my <grammar>UIModule.java.
Also I can't find any information on how to register custom highlighters here: https://www.eclipse.org/Xtext/documentation/310_eclipse_support.html#highlighting
Could you suggest how to register them?
Previous Topic:Creating hyperlinks in Xtext editor
Next Topic:Problem with ID Terminal Rule
Current Time: Wed Jul 23 22:57:27 EDT 2025
Powered by FUDForum. Page generated in 0.06294 seconds
