Home » Eclipse Projects » EclipseLink » Unknown entity type
Unknown entity type [message #478702] Thu, 06 August 2009 08:53 Go to next message
I have an application with added derby.jar, added eclipselink.jar and
javax.persistence.jar from eclipse eclipselink-2.0.0.v20090731-r4765
installtion zip.
I have entity class and some usage of this class and got different ind
of message when try to use it like:
Exception in thread "main" java.lang.IllegalArgumentException: An
exception occurred while creating a query in EntityManager:
Exception Description: Error compiling the query [select object(o) from
DiscountCode as o]. Unknown entity type [DiscountCode].
Caused by: Exception [EclipseLink-8034] (Eclipse Persistence Services -
2.0.0.v20090731-r4765): org.eclipse.persistence.exceptions.JPQLException
sometimes (may be with different version of eclipselink I have also
message about missed "@Entity annotation"
What may be wrong?
my persistence.xml:
<persistence version="2.0"
xmlns="http://java.sun.com/xml/ns/persistence"
xsi:schemaLocation="http://java.sun.com/xml/ns/persistence
http://java.sun.com/xml/ns/persistence/persistence_2_0.xsd">
<persistence-unit name="JavaApplication8PU"
transaction-type="RESOURCE_LOCAL">
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider >
<class>javaapplication8.DiscountCode</class>
<properties>
<property name="javax.persistence.jdbc.url"
value="jdbc:derby://localhost:1527/sample"/>
<property name="javax.persistence.jdbc.password" value="app"/>
<property name="javax.persistence.jdbc.driver"
value="org.apache.derby.jdbc.ClientDriver"/>
<property name="javax.persistence.jdbc.user" value="app"/>
</properties>
</persistence-unit>
</persistence>
my entity:
* To change this template, choose Tools | Templates
* and open the template in the editor.
package javaapplication8;
import java.io.Serializable;
import java.math.BigDecimal;
import javax.persistence.Basic;
import javax.persistence.Column;
import javax.persistence.Entity;
import javax.persistence.Id;
import javax.persistence.NamedQueries;
import javax.persistence.NamedQuery;
import javax.persistence.Table;
* @author sp153251
@Entity
@Table(name = "DISCOUNT_CODE")
@NamedQueries({@NamedQuery(name = "DiscountCode.findAll", query =
"SELECT d FROM DiscountCode d"), @NamedQuery(name =
"DiscountCode.findByDiscountCode", query = "SELECT d FROM DiscountCode d
WHERE d.discountCode = :discountCode"), @NamedQuery(name =
"DiscountCode.findByRate", query = "SELECT d FROM DiscountCode d WHERE
d.rate = :rate")})
public class DiscountCode implements Serializable {
private static final long serialVersionUID = 1L;
@Id
@Basic(optional = false)
@Column(name = "DISCOUNT_CODE")
private Character discountCode;
@Column(name = "RATE")
private BigDecimal rate;
public DiscountCode() {
public DiscountCode(Character discountCode) {
this.discountCode = discountCode;
public Character getDiscountCode() {
return discountCode;
public void setDiscountCode(Character discountCode) {
public BigDecimal getRate() {
return rate;
public void setRate(BigDecimal rate) {
this.rate = rate;
public int hashCode() {
int hash = 0;
hash += (discountCode != null ? discountCode.hashCode() : 0);
return hash;
public boolean equals(Object object) {
// TODO: Warning - this method won't work in the case the id
fields are not set
if (!(object instanceof DiscountCode)) {
return false;
DiscountCode other = (DiscountCode) object;
if ((this.discountCode == null && other.discountCode != null)
|| (this.discountCode != null &&
!this.discountCode.equals(other.discountCode))) {
return false;
return true;
public String toString() {
return "javaapplication8.DiscountCode[discountCode=" +
discountCode + "]";
Unknown entity type - addl details [message #478741 is a reply to message #478702] Thu, 06 August 2009 11:44 Go to previous messageGo to next message
- javax.persisten.jar is for jpa 2.0
- if I replace eclipselink with either toplink or hibernate(not sure
with version) all works. i.e. add toplink/hibernate libraries and
replace provider/properties in persistence.xml.
Re: Unknown entity type - addl details [message #478819 is a reply to message #478741] Fri, 07 August 2009 02:47 Go to previous messageGo to next message
Did you try listing your entity classes in persistence xml?
To do that you need to add a "class" child to your persistnce xml before
the <properties> child like this.
<persistence-unit name="some_pu" transaction-type="RESOURCE_LOCAL">
<class>org.package.[...].DiscountCode</class>
<class>org.package.SomeOtherClass</class>
<properties>
<property name="eclipselink.jdbc.driver"
value="oracle.jdbc.driver.OracleDriver" />
I remember that when I switched to EL from Hibernate that I had to list
my classes as EL whas complaining about not knowing my entites. That
helped. EL seems to be more strict concerning unlisted entites as other
ORM's.
Later,
Tom
Re: Unknown entity type - addl details [message #478820 is a reply to message #478819] Fri, 07 August 2009 02:59 Go to previous messageGo to next message
Thomas Haskes пишет:
see my persistence.xml in first message, it contain
I tried also to add <exclude-unlisted-classes> and still no success.
Wonder if it's an issue in eclipselink 2.0 m6, may be usage of jpa 2.0
javax (from eclipselink bundle) affect this too.
> <properties>
> ORM's.
> Later,
> Tom
Re: Unknown entity type - addl details [message #478844 is a reply to message #478820] Fri, 07 August 2009 03:39 Go to previous messageGo to next message
Sorry didn't see that.
eclipse link 2.0.0 + j2se + derby [message #478891 is a reply to message #478844] Fri, 07 August 2009 07:27 Go to previous messageGo to next message
It's ok.
but may be another question have anybody tried to use eclipse link 2.0.0
with j2se applications?
eclipse link 2.0.0 + j2se + derby - issue? [message #480659 is a reply to message #478891] Tue, 18 August 2009 03:08 Go to previous messageGo to next message
for reference: next issue was filed
https://bugs.eclipse.org/bugs/show_bug.cgi?id=286087
Re: Unknown entity type [message #480868 is a reply to message #478702] Tue, 18 August 2009 13:54 Go to previous messageGo to next message
This is an odd error, it seems your classpath may be corrupt, or have
issues. Are you in a basic JSE environment, or are you using something
like Spring or OSGI?
EclipseLink 2.0 has been extensively tested in a JSE environment, so there
is something wrong with your configuration. Is your persistence unit in a
jar? It should be deployed in a jar with the persistence.xml in the
META-INF directory and the entity classes inside their correct packages in
the jar.
Your error says, "select object(o) from DiscountCode as o"
But your code has, "SELECT d FROM DiscountCode d"
So it seems your have your classes on the classpath twice, or something is
corrupt in your environment.
Perhaps try one of the EclipseLink examples first.
James
Re: Unknown entity type [message #480893 is a reply to message #480868] Tue, 18 August 2009 15:21 Go to previous messageGo to next message
--------------000006040606040108020304
Content-Type: text/plain; charset=KOI8-R; format=flowed
James
Re: Unknown entity type [message #481110 is a reply to message #480868] Wed, 19 August 2009 12:14 Go to previous messageGo to next message
James пишет:
Can you point me to some examples with complete configuration steps?
For example
1. I found some config on
http://wiki.eclipse.org/Configuring_a_EclipseLink_JPA_Applic ation_(ELUG)
but it says only about eclipse.jar but this one jar do not contain
jpa2.0 api.
2. there are eclipselink.jar and persistence.jar on
http://wiki.eclipse.org/EclipseLink/Examples/JPA/JSF_Tutoria l
and
http://wiki.eclipse.org/EclipseLink/Examples/JPA/RCP
but eclpselink.zip (2.0.0 M6) (installation archive) do not contain
persistence.jar, I'm using javax.persistence_2.0_preview.jar instead.
Sergey
> James
issue for packages like "javasomething" [message #488002 is a reply to message #480659] Fri, 25 September 2009 05:25 Go to previous message
Serge пишет:
>> 2.0.0 with j2se applications?
some details from issue in subj, hope will be fixed in 2.0
Previous Topic:criteria API: select count(*) from ..
Next Topic:not support executeThreadRuntime
Current Time: Thu Nov 06 19:41:26 EST 2025
Powered by FUDForum. Page generated in 0.07598 seconds
