Home » Modeling » UML2 » Re: genmodel for state machine diagram
Re: genmodel for state machine diagram [message #478628] Thu, 23 July 2009 08:34 Go to next message
Hello Eban,
Thank you for the warm words.
You generate Java code using an approach described here - http://wiki.eclipse.org/MDT/UML2/FAQ#Can_I_generate_code_fro m_my_UML_.28.uml.29_model.3F
, don't you?
In that case the most relevant answer will be gotten in UML2 newsgroup. I
redirect your question there.
There are other approaches to generate code from UML diagrams. Some of them
are described here - news://news.eclipse.org/31c6fe66a4cc61648c68aef19f1af8ae$1@w ww.eclipse.org
Best wishes,
Tanya.
> Hello,
> First up, thanks guys for putting this great software together and the
> potential is awesome!
> I am trying to "Generate Model Code" from a .genmodel based on a
> "State Machine Diagram" from the "UML 2.1 Diagrams" wizard. I am able
> to complete this with code popping out in the src directory but it is
> incomplete, i.e. the only .java file is the StateMachine name and none
> of the initial states, transitions or simple state and final state can
> be found anywhere in the generate model code.
> Am I missing something or is there a simple example I can follow to
> get me going? Or, is this one of those incubation features I need to
> be patient on?
> I have just downloaded the "Eclipse Modeling Tools" version of Eclipse
> so I should have all the latest code and I know this includes
> incubation projects and hence is not complete yet.
> Thanks in advance Eban
Re: genmodel for state machine diagram [message #478632 is a reply to message #478628] Fri, 24 July 2009 03:19 Go to previous messageGo to next message
When I look at the .uml file it looks like:
<packagedElement xmi:type="uml:StateMachine"
xmi:id="_4QV5AHTSEd6tw7FQB0T26Q" name="Product">
<region xmi:id="_4QlwoHTSEd6tw7FQB0T26Q" name="Region">
<subvertex xmi:type="uml:Pseudostate"
xmi:id="_-7aC0HTSEd6tw7FQB0T26Q"/>
<subvertex xmi:type="uml:FinalState"
xmi:id="__kusoHTSEd6tw7FQB0T26Q"/>
<subvertex xmi:type="uml:State" xmi:id="_AdpRoHTTEd6tw7FQB0T26Q"
name="ProductList"/>
<transition xmi:id="_CciAMHTTEd6tw7FQB0T26Q"
source="_-7aC0HTSEd6tw7FQB0T26Q" target="_AdpRoHTTEd6tw7FQB0T26Q"/>
<transition xmi:id="_C9WOQHTTEd6tw7FQB0T26Q"
source="_AdpRoHTTEd6tw7FQB0T26Q" target="__kusoHTSEd6tw7FQB0T26Q"/>
</region>
</packagedElement>
</uml:Package>
So, the statemachine has a region and some states. All good until I create
an ecore model or genmodel from it but it seems to be missing everything
except the packageElement. Here is the .ecore file:
<ecore:EPackage xmi:version="2.0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="InputC"
nsURI="http:///InputC.ecore" nsPrefix="InputC">
<eClassifiers xsi:type="ecore:EClass" name="Product"/>
</ecore:EPackage>
Please help! :)
Re: genmodel for state machine diagram [message #478633 is a reply to message #478632] Fri, 24 July 2009 04:45 Go to previous messageGo to next message
Hi Eban,
I've not been keeping updated on what's happing in the UML2 project for a
little while but I don't beleive generation of code from StateMachines has
been implemented. I beleive the conversion from UML2 to Ecore is only for
the class modelling parts of UML where equivalent EMF metaclasses exists. I
think the only reason you are getting the "Product" come through is becuase
in UML a StateMachine is a type of Class and it's getting picked up by the
translater.
Implementing this type of generation isn't too hard once you are familar
with both UML2 and EMF and you can achieve a lot of control. I've done it
before so if you explain alittle more about what you are trying to achieve I
might be able to give you some ideas.
Tas
"Eban Escott" <eban.escott@uqconnect.edu.au> wrote in message
news:6f020c2cc5047138d4e51d4ac89073da$1@www.eclipse.org...
> </region>
> </packagedElement>
> </uml:Package>
> xmlns:xmi="http://www.omg.org/XMI"
> </ecore:EPackage>
> Please help! :)
Re: genmodel for state machine diagram [message #478634 is a reply to message #478633] Fri, 24 July 2009 09:43 Go to previous messageGo to next message
Hey Tas, thanks for the heads up. I am trying to do some reflective
programming on a ecore model, or as it turns out now on a uml2 model? So,
i have been reading the EMF, 2nd edition book and I have got this working
on an ecore model fine:
InputCPackage inputCPackage = InputCPackage.eINSTANCE;
System.out.println(inputCPackage);
classifiers = inputCPackage.getEClassifiers();
for(EClassifier classifier: classifiers) {
System.out.println(classifier);
And from here I can reflectively traverse a meta-model combine that with
JET and out pops some code ... sweet. Having a guess, is this how
generators work?
Now, I want to do something similar again but on a state machine not a
class diagram. I have tried converting to ecore as you know but ran into
problems. How can I use reflection on a UML2 model?
Thanks, Eban
Re: genmodel for state machine diagram [message #478635 is a reply to message #478634] Fri, 24 July 2009 11:17 Go to previous messageGo to next message
Eban,
UML2 is implemented as instance of an ecore model, so you can instanciate
and manipulate it using the UML2 API. It's API is not as easy to understand
and EMF but that's just the way the UMl2 Spec is. You mgiht find the OMG
specification useful as the UML2 API is pretty much a mirror of it plus some
convenience methods.
You can do soemting allong the lines of
import org.eclipse.uml2.uml.Class;
import org.eclipse.uml2.uml.Model;
import org.eclipse.uml2.uml.NamedElement;
import org.eclipse.uml2.uml.UMLFactory;
import org.eclipse.uml2.uml.UMLPackage;
Model model = UMLFactory.eINSTANCE.createModel();
Class personClass = model.createOwnedClass("Person", false);
Class addressClass = model.createOwnedClass("Address", false);
personClass.createOwnedAttribute("address", addressClass);
for (NamedElement namedElement: model.getOwnedMembers()) {
if (UMLPackage.Literals.CLASS.equals(namedElement.eClass())) {
Class umlClass = (Class) namedElement;
System.out.println(umlClass.getName());
In terms of going from a UML Statemachine I would approach it in a number of
steps which make it easier to build and test your generators
1. Using EMF define a simple StateMachine meta-model that describes the
semantics you are really interested in.
2. Develop a generators for generating code from instances of this simple
meta-model
3. Develop a transformation from UML2 StateMachine to your own StateMachine
To achieve step 2 you may find transforming to an ecore model and
customising the emf code generation tamplates helpful
The pure "modeling" approach to the transformations would be to use a proper
model transformation language but I have also found SwithUtil classes
pragmatic and easy to test.
Hope that helps,
Tas
news:1db3d97061ef7dcbb69e6494d701ad4a$1@www.eclipse.org...
> generators work?
> Thanks, Eban
Re: genmodel for state machine diagram [message #478643 is a reply to message #478635] Sun, 26 July 2009 23:08 Go to previous messageGo to next message
Hi Tas, I got the example code going that you included and I intend to
look at model transformational languages soon, thanks heaps for the tips!
For the moment, I am still trying to de-serialise the uml model as per:
http://wiki.eclipse.org/MDT/UML2/FAQ#What.27s_required_to_lo ad_a_UML_.28.uml.29_resource_from_a_standalone_application.3 F
I am getting an empty set and I have double checked the .uml file has in
it a statemachine and other elements. The code I have written is:
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI,
UMLPackage.eINSTANCE); resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(UMLResource.FILE_EXTENSION,
UMLResource.Factory.INSTANCE);
File file = new File("InputC.uml");
if(!file.exists()) {
System.out.println("Cannot find file.");
} else {
System.out.println("Found " + file.getCanonicalPath());
//URI uri = URI.createFileURI(file.getCanonicalPath());
//Resource resource = resourceSet.createResource(uri);
//System.out.println(resource.getContents().get(0));
Map uriMap = resourceSet.getURIConverter().getURIMap();
uriMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP),
uri.appendSegment("libraries").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP),
uri.appendSegment("metamodels").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP),
uri.appendSegment("profiles").appendSegment(""));
System.out.println(resource.getContents());
I know I am close but can't seem to get it loading. Any ideas? Thanks, Eban
Re: genmodel for state machine diagram [message #478644 is a reply to message #478643] Mon, 27 July 2009 02:27 Go to previous messageGo to next message
Right got it. You have to
Resource resource = resourceSet.getResource(uri, true);
not create it. Thanks for the help :)
Re: genmodel for state machine diagram [message #627811 is a reply to message #478628] Fri, 24 July 2009 03:19 Go to previous messageGo to next message
</region>
</packagedElement>
</uml:Package>
</ecore:EPackage>
Please help! :)
Re: genmodel for state machine diagram [message #627812 is a reply to message #478632] Fri, 24 July 2009 04:45 Go to previous messageGo to next message
Hi Eban,
translater.
Tas
> </region>
> </packagedElement>
> </uml:Package>
> </ecore:EPackage>
> Please help! :)
Re: genmodel for state machine diagram [message #627813 is a reply to message #478633] Fri, 24 July 2009 09:43 Go to previous messageGo to next message
generators work?
Thanks, Eban
Re: genmodel for state machine diagram [message #627814 is a reply to message #478634] Fri, 24 July 2009 11:17 Go to previous messageGo to next message
Eban,
meta-model
Hope that helps,
Tas
> generators work?
> Thanks, Eban
Re: genmodel for state machine diagram [message #627822 is a reply to message #478635] Sun, 26 July 2009 23:08 Go to previous messageGo to next message
} else {
Re: genmodel for state machine diagram [message #627823 is a reply to message #478643] Mon, 27 July 2009 02:27 Go to previous messageGo to next message
Re: genmodel for state machine diagram [message #653181 is a reply to message #478628] Tue, 08 February 2011 13:40 Go to previous message
Hello everybody
i want just to ask you about rules of transformation of an activity diagramm to a state machine
where can i find them ?
please if you have any thing about this transformation it will be helpful for me
thanks a lot
have fun
Previous Topic:Additional Operation for uml::Classifier (meta model)
Next Topic:UML2 Instance Diagram
Current Time: Tue Jul 22 22:55:59 EDT 2025
Powered by FUDForum. Page generated in 0.10092 seconds
