Home » Modeling » UML2 » Class templates and associations
Class templates and associations [message #478564] Mon, 29 June 2009 10:23 Go to next message
After bashing my head against UML templates for a while, I came across the tip of using the more familiar (for Java folks) EMF generics and
looking what the EMF to UML converter makes of it. While that helped a lot, I still have a couple of questions I couldn't solve for myself
that way and a couple of questions/comments about what the Converter generates.
I) Let's start with class templates in general. Say I have the following (in Java-like pseudo-notation):
class Foo;
class Bar<X extends Foo>
void doStuff ();
<Y extends Foo> Y calculate(Bar<Y> otherBar);
Using the EMF to UML converter I get the following UML model:
class Foo;
class Bar
TemplateSignature
Classifier Template Parameter X
Class X
operation doStuff ()
(Return Parameter)
class Bar_Y
Template Binding Bar<X->Y>
operation calculate(Bar_Y otherBar): Y
TemplateSignature
Classifier Template Parameter Y
Class Y
1) Not actually template related, but instead of a return parameter without a type, shouldn't the doStuff method have no return parameter at
all if the Ecore method did not have a return type?
2) For the type bounds "X extends Foo", ignoring that the converter uses an EMF-specific stereotype instead of constrainingClassifier, what
is the benefit of introducing the additional constrainingClassifier property at all, instead of just defining a Generalization from the
parameter class X to Foo?
3) The bound class Bar_Y is generated in Bar, obviously because an Operation is not a Namespace and cannot contain a Class. But strictly
speaking, isn't the template parameter Y, used as actual parameter in the binding of Bar_Y, out of scope at this point since the binding
does not happen inside of calculate(...)?
4) It can easily happen that I get multiple "synthetic" classes Bar_something binding Bar to the same actual parameters (i.e. in 2 different
packages and then seeing both types in a package that imports both). Is there any specification available about if/when such classes should
be considered compatible with each other?
II) Now for a slightly more complex example involving associations:
class Foo<X>
Bar<X> bar;//otherEnd=Bar.foo
class Bar<Y>
Foo<Y> foo;//otherEnd=Foo.bar
class StringFoo extends Foo<String>;
class StringBar extends Bar<String>;
So I basically have an association between two templates with the respective other side's parameter bound to my own. The abridged version in
UML looks like this:
class Foo<X>
class Bar_X (Bar<Y->X>)
property bar : Bar_X
class Bar<Y>
class Foo_Y (Foo<X->Y>)
property foo : Foo_X
association A_Foo_Bar
memberEnd Foo.bar, Bar.foo
class Foo_String (Foo<X->String>)
class Bar_String (Bar<Y->String>)
class StringFoo
generalization Foo_String
class StringBar
generalization Bar_String
According to the Superstructure specification, the semantics of this should be the same as if the template contents were copied into the
binding classes and the parameters replaced accordingly. However, attempting to manually perform such a copy operation on my example model
for Foo_String and Bar_String, I run into a couple of problems:
1) In a way, this is related to question I.4: Copying the contents of Foo<X> into Foo_String would entail copying the nested class Bar_X as
well. Then I would need to "merge" Bar_X which in turn would add an inner class Foo_Y to it, which in turn... StackOverflow... Of course in
reality I probably shouldn't perform this copying ad infinitum, but recognize that Bar_X should be equivalent to Bar_String under the
current binding. But how would I recognize that in general?
2) Strictly speaking, the association A_Foo_Bar is not part of either of the two template classes. But if I copy all contents of the
templates into the binding classes "as is", i.e. with Foo_String.bar.association=A_Foo_Bar, I'd end up with a 4-ary association. Obviously,
A_Foo_Bar also needs to be copied (into the namespace of Foo_String?). But how would I recognize in general what to copy (and where to) and
what not? Would this always be every element that is either contained in a template itself or references something contained in a template?
3) Changing the association into a uni-directional reference Foo.bar in EMF results in a UML association with an ownedEnd of type Foo
(without binding). Shouldn't that be Foo_X, with Foo_X being an inner class of Foo with binding Foo<X->X>?
As you can see by this soewhat longish post, I think that the template binding semantics section of the Superstructure could use a bit of
clarification ;P Meanwhile I'd greatly appreciate any help with any of these questions or any pointers to material beside the Superstructure
spec that sheds some light on this topic.
Carsten Reckord
Re: Class templates and associations [message #478569 is a reply to message #478564] Tue, 30 June 2009 16:10 Go to previous messageGo to next message
Hi Carsten,
While I'm making my way through your questions, you may want to have a look
at:
http://www.eclipse.org/modeling/mdt/uml2/docs/articles/Defin ing_Generics_with_UML_Templates/article.html
- James.
"Carsten Reckord" <creckord@uni-kassel.de> wrote in message
news:h2aiq0$os4$1@build.eclipse.org...
> tip of using the more familiar (for Java folks) EMF generics and looking
> still have a couple of questions I couldn't solve for myself that way and
> class Foo;
> void doStuff ();
> class Foo;
> class Bar
> TemplateSignature
> Class X
> (Return Parameter)
> class Bar_Y
> TemplateSignature
> Class Y
> an EMF-specific stereotype instead of constrainingClassifier, what is the
> all, instead of just defining a Generalization from the parameter class X
> to Foo?
> binding of Bar_Y, out of scope at this point since the binding does not
> different packages and then seeing both types in a package that imports
> should be considered compatible with each other?
> class Foo<X>
> class Bar<Y>
> class Foo<X>
> class Bar<Y>
> class StringFoo
> class StringBar
> class Foo_Y to it, which in turn... StackOverflow... Of course in reality
> Bar_X should be equivalent to Bar_String under the current binding. But
> the two template classes. But if I copy all contents of the templates into
> Obviously, A_Foo_Bar also needs to be copied (into the namespace of
> to) and what not? Would this always be every element that is either
> template?
> EMF results in a UML association with an ownedEnd of type Foo (without
> these questions or any pointers to material beside the Superstructure spec
> Best regards,
> Carsten Reckord
Re: Class templates and associations [message #478594 is a reply to message #478564] Tue, 07 July 2009 10:08 Go to previous message
Some of the questions responded to below ... I will respond to the rest a
bit later when I get a chance.
-James.
> class Foo;
> void doStuff ();
> class Foo;
> class Bar
> TemplateSignature
> Class X
> (Return Parameter)
> class Bar_Y
> TemplateSignature
> Class Y
Yes possibly, I believe this is a by-product of how we try to manufacture
types during the conversion process. Either way I don't think it should
cause a problem. If it is a problem please raise a bugzilla.
The stereotype is used since there is an issue in the spec where you can't
express X extends Foo & Bar & ... I believe you are restricted to 1 item.
We use the stereotype for consistency.
X might not directly extend Foo so creation a generalization may not be
appropriate. I believe we are correctly using the constraining classifier
the way it is intended by the spec.
I haven't reproduced your example but assuming that your example above is
correct, you may have a point here. I will have to look at this in more
detail. Please raise a bugzilla.
-------------------------- part 2 a bit later ----------------------
> class Foo<X>
> class Bar<Y>
> class Foo<X>
> class Bar<Y>
> class StringFoo
> class StringBar
> template?
> Best regards,
> Carsten Reckord
Re: Class templates and associations [message #627751 is a reply to message #478564] Tue, 30 June 2009 16:10 Go to previous message
Hi Carsten,
at:
- James.
> class Foo;
> void doStuff ();
> class Foo;
> class Bar
> TemplateSignature
> Class X
> (Return Parameter)
> class Bar_Y
> TemplateSignature
> Class Y
> to Foo?
> class Foo<X>
> class Bar<Y>
> class Foo<X>
> class Bar<Y>
> class StringFoo
> class StringBar
> template?
> Best regards,
> Carsten Reckord
Re: Class templates and associations [message #627775 is a reply to message #478564] Tue, 07 July 2009 10:08 Go to previous message
-James.
> class Foo;
> void doStuff ();
> class Foo;
> class Bar
> TemplateSignature
> Class X
> (Return Parameter)
> class Bar_Y
> TemplateSignature
> Class Y
> class Foo<X>
> class Bar<Y>
> class Foo<X>
> class Bar<Y>
> class StringFoo
> class StringBar
> template?
> Best regards,
> Carsten Reckord
Previous Topic:UML2 Context Menu
Next Topic:UML2 Context Menu
Current Time: Fri Jul 25 07:23:48 EDT 2025
Powered by FUDForum. Page generated in 0.05952 seconds
