Duplicate XMI id [message #478494] |
Thu, 04 June 2009 09:09  |
I have a model in Topcased, if I open it in TextModel, there are two
elements with the same XMI id(_0BovNkUVEd6RNpVxnEI7mg) but with different
content inside:
<ownedComment xmi:id="_0BovNkUVEd6RNpVxnEI7mg">
<eAnnotations xmi:id="_8dW29UxgEd6WS8fHSy3Udg"
source="http://www.topcased.org/documentation">
<details xmi:id="_8dW29kxgEd6WS8fHSy3Udg"
key="documentation"
value=" \\Kcopsrv2\Modelisation\specs_reqpro\cassiopee\bes\pro\prm\p qt\Creer_affaire.FCU "/>
</eAnnotations>
<body> \\Kcopsrv2\Modelisation\specs_reqpro\cassiopee\bes\pro\prm\p qt\Creer_affaire.FCU </body>
</ownedComment>
<packagedElement xmi:type="uml:Package" xmi:id="_0BovnUUVEd6RNpVxnEI7mg"
name="01 Saisie des X avec classement ab-initio">
<ownedComment xmi:id="_0BovnkUVEd6RNpVxnEI7mg">
<body>U:\_Maquette\doc\maquette\cassiopee\aff\saisirlesX.htm </body>
</ownedComment>
Has anybody an idea about the reason or even a possible solution?
I need a model without duplicated ids.
Thank you!
Laura.
Re: Duplicate XMI id [message #478503 is a reply to message #478494] |
Tue, 09 June 2009 09:21  |
Laura,
Have you tried contacting the Topcased folks about this? The duplicate
identifiers are likely being introduced by the application, not the UML2
framework itself...
Kenn
"hernandez " <lauhp09@gmail.com> wrote in message
news:fbfc83c14cf16643784198ea240294a5$1@www.eclipse.org...
>content inside:
> <details xmi:id="_8dW29kxgEd6WS8fHSy3Udg" key="documentation"
> </eAnnotations>
> </ownedComment>
> </ownedComment>
> Thank you!
> Laura.
Re: Duplicate XMI id [message #627680 is a reply to message #478494] |
Laura,
framework itself...
Kenn
>content inside:
> </eAnnotations>
> </ownedComment>
> </ownedComment>
> Thank you!
> Laura.
FUDForum. Page generated in 0.10355 seconds
