Home » Modeling » UML2 » Preserving uuid to xmi:id mapping converting uml2 to eCore
Preserving uuid to xmi:id mapping converting uml2 to eCore [message #478444] Fri, 22 May 2009 11:45 Go to next message
I'm building an EMF based Eclipse application and I am currently using the
existing UML to EMF converter from the ide.
How can I preserve the uuids in the original uml file forcing them to be
the xmi:id of the generated EClasses, and EStructuralFeatures?
My UML tool assures to preserve the same uuid for the same element (even
if it is, let's say, moved to another package) across different exports,
so using uuids it is possible to perform more accurated comparisons of
generated eCore models that, i.e., do not exange a moving operation for
two unrelated operations (delete of the existing element and creation of a
new one).
Thank for any help
Re: Preserving uuid to xmi:id mapping converting uml2 to eCore [message #478447 is a reply to message #478444] Fri, 22 May 2009 14:14 Go to previous messageGo to next message
Piergiuseppe,
Given that UUIDs are supposed to be globally unique (that's why they're
useful), I'm not sure it would be a good idea to assign the IDs of UML
elements to the resulting Ecore elements (although it would be possible by
calling the conversion utility programmatically, using a custom resource to
load the Ecore model, and setting the XMI IDs of the Ecore elements based on
the UML element on which they were based). I would suggest producing a
mapping from UML element URI fragment (GUID) to Ecore element URI fragment
(name-based path) by processing the map that is returned after the
conversion and doing a reverse look-up to assign the desired IDs to UML
elements if/when the Ecore representation is ever converted back to UML...
Kenn
"Piergiuseppe Spinelli" <piergiuseppe.spinelli@tin.it> wrote in message
news:66dcd6dc89d0595eed9e551934c1185b$1@www.eclipse.org...
> new one).
> Thank for any help
Re: Preserving uuid to xmi:id mapping converting uml2 to eCore [message #478448 is a reply to message #478447] Sat, 23 May 2009 04:42 Go to previous messageGo to next message
Kenn Hussey wrote:
Kenn, many thanks for your answer
> Piergiuseppe,
Yes, I get your point. There could be different options here:
- setting in ecore alternative ids "generated" by the original ones in UML
(i.e. adding a prefix) (at the end it is sufficient for the xmi:id to be
unique in the document or in the context of use)
- do not use at all ids but URI fragments for mapping both the sides (as
you sugest, if I undertend) .
The 2d options would be the most confortable one, but it seems to me it is
a little sensible to some kinds of changes (i.e. how it behaves when e
Class or Property is renamed, or a Class is moved to another package?)
Could you address me to some doc or sample?
Many thanks, I will do some test in this direction
> Kenn
>> Hi,
>> new one).
>> Thank for any help
Re: Preserving uuid to xmi:id mapping converting uml2 to eCore [message #478449 is a reply to message #478447] Mon, 25 May 2009 05:44 Go to previous messageGo to next message
Hi Kenn,
I apologize if I return again on this point, just to ask one clarification
(not to argue, really just to better undertand)
You said: "Given that UUIDs are supposed to be globally unique (that's why
they're useful), I'm not sure it would be a good idea to assign the IDs of
UML elements to the resulting Ecore elements"
Now this made me wander a couple of things:
- does "UUIDs are globally unique" mean than every time you serialize the
same uml document to different files it is mandatory to generate new UUIDs?
In my opinion this is not required, since the role of UUIDs should be to
sign with an unique value, w/o any business meaning by itself, the unique
identity of an element (i.e. an UML Class or Property).
So, when the same element it is serialized again & again (and this means,
the same identity, even if some of its properties has been modified or its
position in the document has changed) it could be right to use the same
UUID since it is the only thing granting the identity of the element along
the time.
Using URI fragments, instead (in my opinion, but I ask for yours),
identify an elements just in a specific context and are not always able to
keep its identity along the time (i.e. when some other sibling is inserted
before it, or it is renamed or moved under onother package, and so on)
Finally, the unicity of an UUIDs shoud be granted just in the space of all
the UUIDs: this shoud not refrain to use the same value (or a derived one)
in the space of XMI:ID of its ecore translation, since (1) XMI:IDs are not
UUIDs (2) they need to be unique just inside a model.
At the end, a concrete example:
I've been involved in these last years, on the behalf of the bigger
italian Telco, in the processes for adopting the SID (the reference model
for the Telcos by the Tele Management Forum).
SID is a very (really very) large UML document that needs to be extended
in order to be adopted in the real word, and it can be used in a lot of
ways: one of them is as an hub in the semantic reconciliation among the
different models used in the enterprise. This task requires a map between
the SID entities and each matching element in the different data sources.
Now, every time the extended SID is modified (or a new version is released
by the TMF), all this huge mass of work should be revisited: this would
make the governance impossible in facts.
Now, if the impact analysis of a new SID version takes care of UUIDs and
they are preserved across the successive versions, the job becomes
possible!
As you see, this could be a very important and not "philosophical"
question.
Since I have choosed Eclipse and EMF as the best among the current
tecnologies to gring models and metadata, I look forward for opinions
about that from you and every other guy interested in this matter.
Piero
Kenn Hussey wrote:
> Piergiuseppe,
> Kenn
>> Hi,
>> new one).
>> Thank for any help
Re: Preserving uuid to xmi:id mapping converting uml2 to eCore [message #478450 is a reply to message #478448] Mon, 25 May 2009 09:21 Go to previous messageGo to next message
Piergiuseppe,
To be clear, you are dealing with URI fragments in both cases - the URI
fragment is the portion of the URI that identifies an object within a
resource. In the case of the (default) UML2 resource implementation, UUIDs
are used as URI fragments; in Ecore, path-based strings are used.
For an example of how to call the converter programmatically, take a look at
the ConvertToEcoreModelAction class in the UML2 examples plug-in or perhaps
even the define(*) methods on ProfileOperations in
org.eclipse.uml2.uml.internal.operations. Note that the converter can be
used to look up target objects after the conversion is done by calling
doSwitch(Object) again with the source object. In order to use XMI IDs for
your Ecore models, you'll need to use a resource implementation that makes
use of XMI IDs (or even UUIDs) instead of the default path-based convention
used by the default Ecore resource implementation; you could even use the
UML2 resource implementation, for that matter. An example of how to set the
IDs for elements can be found in the ConvertModelAction, also in the UML2
examples plug-in...
Kenn
news:aec33d4c1e1830630600b6f2487f8e99$1@www.eclipse.org...
>> Piergiuseppe,
>> to load the Ecore model, and setting the XMI IDs of the Ecore elements
>> based on the UML element on which they were based).
>> fragment (name-based path) by processing the map that is returned after
>> the conversion and doing a reverse look-up to assign the desired IDs to
>> UML elements if/when the Ecore representation is ever converted back to
>> UML...
>> Kenn
>>> Hi,
>>> the existing UML to EMF converter from the ide.
>>> a new one).
>>> Thank for any help
Re: Preserving uuid to xmi:id mapping converting uml2 to eCore [message #478451 is a reply to message #478449] Mon, 25 May 2009 09:24 Go to previous messageGo to next message
Piergiuseppe,
It isn't technically mandatory for UUIDs to be globally unique (and there's
no way to enforce that), but that's certainly the spirit with which support
for them was introduced. In fact, if you move an object between two resource
implementations for which UUIDs are enabled, the ID for that object is
preserved. The intent is that once an object has been assigned a UUID, it
keeps that UUID (regardless of which resource it's attached to) until it is
destroyed, regardless of how it changes over time.
Kenn
news:67ca18393826cdbe003eebf8851e0ebd$1@www.eclipse.org...
> Hi Kenn,
> UUIDs?
> the time.
> At the end, a concrete example: I've been involved in these last years, on
> the behalf of the bigger italian Telco, in the processes for adopting the
> SID (the reference model for the Telcos by the Tele Management Forum).
> possible!
> question.
> Piero
> Kenn Hussey wrote:
>> Piergiuseppe,
>> by calling the conversion utility programmatically, using a custom
>> resource to load the Ecore model, and setting the XMI IDs of the Ecore
>> elements based on the UML element on which they were based). I would
>> suggest producing a mapping from UML element URI fragment (GUID) to Ecore
>> element URI fragment (name-based path) by processing the map that is
>> returned after the conversion and doing a reverse look-up to assign the
>> desired IDs to UML elements if/when the Ecore representation is ever
>> Kenn
>>> Hi,
>>> a new one).
>>> Thank for any help
Re: Preserving uuid to xmi:id mapping converting uml2 to eCore [message #478452 is a reply to message #478451] Mon, 25 May 2009 10:22 Go to previous messageGo to next message
Kenn Hussey wrote:
> Piergiuseppe,
> Kenn
Many thanks Kenn: that's very clear and it confirms UUIDs were introduced
not as a simple technicality but as true universal identifiers keeping
their validity along time and versions.
So, in your opinion does it make sense to use them:
- In computing differences between two versions of a model (instead than
URI fragments)?
- Preserving them in different translations of the same model (i.e. the
case could be generating eCore XMI:IDs from UML UUIDs)?
And if it could make some sense (at least in some situation), what is
(here you are the expert and I am asking for help) the simplest way to get
that?
Again many thanks
Piero
>> Hi Kenn,
>> UUIDs?
>> the time.
>> possible!
>> question.
>> Thanks,
>> Piero
>> Kenn Hussey wrote:
>>> Piergiuseppe,
>>> Kenn
>>>> Hi,
>>>> a new one).
>>>> Thank for any help
Re: Preserving uuid to xmi:id mapping converting uml2 to eCore [message #478453 is a reply to message #478452] Mon, 25 May 2009 10:55 Go to previous messageGo to next message
Piergiuseppe,
I do think is makes sense to use UUIDs in computing differences between two
versions of a model (indeed that's in part why they were introduced). I
don't see a problem with using smilar (but not the same) IDs for different
representations (e.g. UML, Ecore) of the "same" element. See my response to
your other post regarding how to accomplish this. Basically, you need to use
a resource implementation for your Ecore models which supports UUIDs and
you'll need to do some post-processing once a UML model is converted to an
Ecore model (and before the target model is saved) to set the desired IDs.
Kenn
news:ef53ef1f0d4dc07897aaffcf7c389bd0$1@www.eclipse.org...
> Kenn Hussey wrote:
>> Piergiuseppe,
>> there's no way to enforce that), but that's certainly the spirit with
>> which support for them was introduced. In fact, if you move an object
>> between two resource implementations for which UUIDs are enabled, the ID
>> for that object is preserved. The intent is that once an object has been
>> assigned a UUID, it keeps that UUID (regardless of which resource it's
>> attached to) until it is destroyed, regardless of how it changes over
>> time.
>> Kenn
> URI fragments)?
> that?
> Again many thanks
> Piero
>>> Hi Kenn,
>>> clarification (not to argue, really just to better undertand)
>>> why they're useful), I'm not sure it would be a good idea to assign the
>>> IDs of UML elements to the resulting Ecore elements"
>>> the same uml document to different files it is mandatory to generate new
>>> UUIDs?
>>> unique identity of an element (i.e. an UML Class or Property).
>>> means, the same identity, even if some of its properties has been
>>> modified or its position in the document has changed) it could be right
>>> to use the same UUID since it is the only thing granting the identity of
>>> the element along the time.
>>> to keep its identity along the time (i.e. when some other sibling is
>>> inserted before it, or it is renamed or moved under onother package, and
>>> so on)
>>> all the UUIDs: this shoud not refrain to use the same value (or a
>>> derived one) in the space of XMI:ID of its ecore translation, since (1)
>>> XMI:IDs are not UUIDs (2) they need to be unique just inside a model.
>>> on the behalf of the bigger italian Telco, in the processes for adopting
>>> the SID (the reference model for the Telcos by the Tele Management
>>> Forum).
>>> between the SID entities and each matching element in the different data
>>> sources.
>>> released by the TMF), all this huge mass of work should be revisited:
>>> this would make the governance impossible in facts.
>>> possible!
>>> question.
>>> Thanks,
>>> Piero
>>> Kenn Hussey wrote:
>>>> Piergiuseppe,
>>>> Ecore element URI fragment (name-based path) by processing the map that
>>>> is returned after the conversion and doing a reverse look-up to assign
>>>> the desired IDs to UML elements if/when the Ecore representation is
>>>> Kenn
>>>>> Hi,
>>>>> be the xmi:id of the generated EClasses, and EStructuralFeatures?
>>>>> (even if it is, let's say, moved to another package) across different
>>>>> exports, so using uuids it is possible to perform more accurated
>>>>> comparisons of generated eCore models that, i.e., do not exange a
>>>>> moving operation for two unrelated operations (delete of the existing
>>>>> element and creation of a new one).
>>>>> Thank for any help
Re: Preserving uuid to xmi:id mapping converting uml2 to eCore [message #478454 is a reply to message #478453] Mon, 25 May 2009 16:47 Go to previous message
Kenn Hussey wrote:
Kenn,
Many thanks, I tried as you suggest and it seems to work fine, like in the
following code:
package test;
import java.io.IOException;
import java.util.Collection;
import java.util.Collections;
import java.util.HashMap;
import java.util.Map;
import org.eclipse.emf.common.util.BasicDiagnostic;
import org.eclipse.emf.common.util.DiagnosticChain;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EModelElement;
import org.eclipse.emf.ecore.ENamedElement;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.util.EcoreUtil;
import org.eclipse.emf.ecore.xmi.XMIResource;
import org.eclipse.uml2.uml.Element;
import org.eclipse.uml2.uml.UMLPackage;
import org.eclipse.uml2.uml.resource.UMLResource;
import org.eclipse.uml2.uml.util.UMLUtil;
import org.eclipse.uml2.uml.util.UMLUtil.UML2EcoreConverter;
import com.pjsoft.ecore.plus.ECorePlus.util.ECorePlusResourceFactor yImpl;
public class UML2ECorePlus {
private static String filePath = "/uml/test.uml";
protected static final ResourceSet RESOURCE_SET = new ResourceSetImpl();
public UML2ECorePlus() {}
class MyUML2EcoreConverter extends UML2EcoreConverter{
Map<Element, EModelElement> getElementToEModelElementMap(){
return elementToEModelElementMap;
protected static void registerResourceFactories()
{ RESOURCE_SET.getResourceFactoryRegistry().getExtensionToFact oryMap().put(
UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
RESOURCE_SET.getPackageRegistry().put(UMLPackage.eNS_URI,
UMLPackage.eINSTANCE);
"ecore", new ECorePlusResourceFactoryImpl());
private void mkSchema(URI umlUri, URI ecoreUri) throws IOException {
UMLResource umlRes = (UMLResource)RESOURCE_SET.getResource(umlUri, true);
XMIResource ecoreRes =
(XMIResource)RESOURCE_SET.createResource(ecoreUri);
org.eclipse.uml2.uml.Model umlPkg = (org.eclipse.uml2.uml.Model)
EcoreUtil
.getObjectByType(umlRes.getContents(), UMLPackage.Literals.MODEL);
DiagnosticChain dc=new BasicDiagnostic();
Map<String, String> options=new HashMap<String, String>();
Map<Object, Object> cache=new HashMap<Object, Object>();
options.put(UML2EcoreConverter.OPTION__ECORE_TAGGED_VALUES,
UMLUtil.OPTION__REPORT);
options.put(UML2EcoreConverter.OPTION__REDEFINING_OPERATIONS ,
options.put(UML2EcoreConverter.OPTION__REDEFINING_PROPERTIES ,
options.put(UML2EcoreConverter.OPTION__SUBSETTING_PROPERTIES ,
options.put(UML2EcoreConverter.OPTION__UNION_PROPERTIES,
options.put(UML2EcoreConverter.OPTION__DERIVED_FEATURES,
options.put(UML2EcoreConverter.OPTION__DUPLICATE_OPERATIONS,
options.put(UML2EcoreConverter.OPTION__DUPLICATE_OPERATION_I NHERITANCE,
options.put(UML2EcoreConverter.OPTION__DUPLICATE_FEATURES,
options.put(UML2EcoreConverter.OPTION__DUPLICATE_FEATURE_INH ERITANCE,
options.put(UML2EcoreConverter.OPTION__SUPER_CLASS_ORDER,
options.put(UML2EcoreConverter.OPTION__ANNOTATION_DETAILS,
options.put(UML2EcoreConverter.OPTION__INVARIANT_CONSTRAINTS ,
options.put(UML2EcoreConverter.OPTION__OPERATION_BODIES,
options.put(UML2EcoreConverter.OPTION__COMMENTS, UMLUtil.OPTION__REPORT);
MyUML2EcoreConverter conv=new MyUML2EcoreConverter();
Collection<? extends EObject>
ret=conv.convert(Collections.singleton(umlPkg), options, dc, cache);
System.out.println(cache);
for(Element el: conv.getElementToEModelElementMap().keySet()){
ENamedElement enel=(ENamedElement)
conv.getElementToEModelElementMap().get(el);
ecoreRes.setID(enel, "UML.UUID:"+umlRes.getID(el));
for(EObject obj: ret)
ecoreRes.getContents().add(obj);
ecoreRes.save(Collections.EMPTY_MAP);
public static void main(String[] args) throws IOException {
UML2ECorePlus reader = new UML2ECorePlus();
registerResourceFactories();
reader.mkSchema(URI.createFileURI(filePath),
URI.createFileURI(filePath).trimFileExtension().appendFileEx tension( "ecore"));
> Piergiuseppe,
> Kenn
>> Kenn Hussey wrote:
>>> Piergiuseppe,
>>> time.
>>> Kenn
>> URI fragments)?
>> that?
>> Again many thanks
>> Piero
>>>> Hi Kenn,
>>>> UUIDs?
>>>> so on)
>>>> Forum).
>>>> sources.
>>>> possible!
>>>> question.
>>>> Thanks,
>>>> Piero
>>>> Kenn Hussey wrote:
>>>>> Piergiuseppe,
>>>>> Kenn
>>>>>> Hi,
>>>>>> Thank for any help
Re: Preserving uuid to xmi:id mapping converting uml2 to eCore [message #627625 is a reply to message #478444] Fri, 22 May 2009 14:14 Go to previous message
Piergiuseppe,
Kenn
> new one).
> Thank for any help
Re: Preserving uuid to xmi:id mapping converting uml2 to eCore [message #627626 is a reply to message #478447] Sat, 23 May 2009 04:42 Go to previous message
> Piergiuseppe,
> Kenn
>> Hi,
>> new one).
>> Thank for any help
Re: Preserving uuid to xmi:id mapping converting uml2 to eCore [message #627627 is a reply to message #478447] Mon, 25 May 2009 05:44 Go to previous message
Hi Kenn,
the time.
possible!
question.
Piero
Kenn Hussey wrote:
> Piergiuseppe,
> Kenn
>> Hi,
>> new one).
>> Thank for any help
Re: Preserving uuid to xmi:id mapping converting uml2 to eCore [message #627628 is a reply to message #478448] Mon, 25 May 2009 09:21 Go to previous message
Piergiuseppe,
examples plug-in...
Kenn
>> Piergiuseppe,
>> UML...
>> Kenn
>>> Hi,
>>> a new one).
>>> Thank for any help
Re: Preserving uuid to xmi:id mapping converting uml2 to eCore [message #627629 is a reply to message #478449] Mon, 25 May 2009 09:24 Go to previous message
Piergiuseppe,
Kenn
> Hi Kenn,
> UUIDs?
> the time.
> possible!
> question.
> Piero
> Kenn Hussey wrote:
>> Piergiuseppe,
>> Kenn
>>> Hi,
>>> a new one).
>>> Thank for any help
Re: Preserving uuid to xmi:id mapping converting uml2 to eCore [message #627630 is a reply to message #478451] Mon, 25 May 2009 10:22 Go to previous message
Kenn Hussey wrote:
> Piergiuseppe,
> Kenn
URI fragments)?
that?
Again many thanks
Piero
>> Hi Kenn,
>> UUIDs?
>> the time.
>> possible!
>> question.
>> Thanks,
>> Piero
>> Kenn Hussey wrote:
>>> Piergiuseppe,
>>> Kenn
>>>> Hi,
>>>> a new one).
>>>> Thank for any help
Re: Preserving uuid to xmi:id mapping converting uml2 to eCore [message #627631 is a reply to message #478452] Mon, 25 May 2009 10:55 Go to previous message
Piergiuseppe,
Kenn
> Kenn Hussey wrote:
>> Piergiuseppe,
>> time.
>> Kenn
> URI fragments)?
> that?
> Again many thanks
> Piero
>>> Hi Kenn,
>>> UUIDs?
>>> so on)
>>> Forum).
>>> sources.
>>> possible!
>>> question.
>>> Thanks,
>>> Piero
>>> Kenn Hussey wrote:
>>>> Piergiuseppe,
>>>> Kenn
>>>>> Hi,
>>>>> Thank for any help
Re: Preserving uuid to xmi:id mapping converting uml2 to eCore [message #627632 is a reply to message #478453] Mon, 25 May 2009 16:47 Go to previous message
Kenn Hussey wrote:
Kenn,
following code:
package test;
EcoreUtil
> Piergiuseppe,
> Kenn
>> Kenn Hussey wrote:
>>> Piergiuseppe,
>>> time.
>>> Kenn
>> URI fragments)?
>> that?
>> Again many thanks
>> Piero
>>>> Hi Kenn,
>>>> UUIDs?
>>>> so on)
>>>> Forum).
>>>> sources.
>>>> possible!
>>>> question.
>>>> Thanks,
>>>> Piero
>>>> Kenn Hussey wrote:
>>>>> Piergiuseppe,
>>>>> Kenn
>>>>>> Hi,
>>>>>> Thank for any help
Previous Topic:Generating Java-classes?
Next Topic:UML2Ecore converter
Current Time: Sun Jul 27 04:00:50 EDT 2025
Powered by FUDForum. Page generated in 0.06272 seconds
