Load and save a model with references [message #478428] |
Thu, 06 August 2009 05:41  |
I have two UML2-models:
- "main.uml"
- contains package "foo" which contains class "SimpleClass" which
contains property "age" which is of PrimitiveType "int" (which is not
contained in "main.uml")
- "references.uml"
- contains only the PrimitiveType "int"
Now I want to load these models and save them in a different folder. The
way I do it now messes up the reference from "main.uml" to
"references.uml", because "main.uml" contains still the old path to the
old "references.uml".
Here is how I load the models in a List of Model:
protected List<Model> createModels() throws Exception
List<Model> models = new Vector<Model>();
ResourceSet rSet = new ResourceSetImpl();
// load the models
Model model = loadModel(rSet, "main.uml");
models.add(model);
Model refmodel = loadModel(rSet, "references.uml");
models.add(refmodel);
// return the models
return models;
private Model loadModel( ResourceSet rSet, String name ) throws Exception
XMIResourceFactoryImpl _xmiFac = new XMIResourceFactoryImpl();
EObject sourceModel = null;
rSet.getResourceFactoryRegistry().getExtensionToFactoryMap() .put( "*",
_xmiFac);
URL modelURL = FileLocator.find(Activator.getDefault().getBundle(),
new Path("completeTestTestData/model/" + name), null);
modelURL = FileLocator.toFileURL(modelURL);
String absolutePath = modelURL.getPath();
URI uri = URI.createFileURI(absolutePath);
// register meta-model
rSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
rSet.getPackageRegistry().put(OtmlPackage.eNS_URI,
OtmlPackage.eINSTANCE);
Resource resource = rSet.getResource(uri, true);
if( resource != null )
if( resource.getContents().size() > 0 )
sourceModel = (EObject) resource.getContents().get(0);
return (Model) sourceModel;
Here is how I save them (without changing anything) in a different folder:
public void saveModels( List<Model> models, IFolder modelFolder )
throws Exception
ResourceSet resourceSet = new ResourceSetImpl();
List<Resource> resources = new Vector<Resource>();
for( Model model : models )
String fileName = model.getName() + ".uml";
IFile file = modelFolder.getFile(fileName);
String path = file.getLocation().toFile().getAbsolutePath();
URI fileURI = URI.createFileURI(path);
Resource aResource = resourceSet.createResource(fileURI);
aResource.getContents().add(model);
resources.add(aResource);
for( Resource resource : resources )
resource.save(Collections.EMPTY_MAP);
One thing I stumbled upon: If I navigate to the reference in the loaded
EMF-model (after loading, before saving), then the saving works. So if I
give the "main-"model to the following method, then the saving is OK:
private void forDebugging( Model model )
for( org.eclipse.uml2.uml.Package pack : model.getNestedPackages() )
String name = pack.getName();
for( Type type : pack.getOwnedTypes() )
String typeName = type.getName();
if( type instanceof Classifier )
Classifier classifier = (Classifier) type;
for( Property prop : classifier.getAllAttributes() )
String propName = prop.getName();
Type propType = prop.getType();
String propTypeName = propType.getName();
So how can I save the models, so that the reference is "updated" ?
thank you
Re: Load and save a model with references [message #478699 is a reply to message #478428] |
Thu, 06 August 2009 08:37  |
Usul
Maybe I should wait for a never mind? :-P
More comments below.
Usul wrote:
> - "main.uml"
> - "references.uml"
> The way I do it now messes up the reference from "main.uml" to
> the old "references.uml".
You might need to ensure all proxies are resolved. EcoreUtil.resolveAll
is useful for that.
> @Override
Vector. Yuck.
> // load the models
> models.add(model);
> return models;
> Exception
> _xmiFac);
> URL modelURL =
EMF should be able to process any URL directly.
> folder:
> throws Exception
Yes, be sure all the proxies are resolved. You can just change the URI
of the resources you've already loaded and save those...
> loaded EMF-model (after loading, before saving), then the saving works.
Indeed, unresolved proxies are an issue then. They record the original
resource location and saving does not resolve proxies.
> So if I give the "main-"model to the following method, then the saving
> is OK:
> thank you
FUDForum. Page generated in 0.13490 seconds
