Home » Modeling » EMF » EMF References using Generics, Proxy are created
EMF References using Generics, Proxy are created [message #468346] Wed, 05 August 2009 04:05 Go to next message
I'm exploring the support for generics in EMF and facing a problem when
having a generic reference in a class and using the generated editor.
Basically what I want to have is a generic class with an attribute to
attach a certain object by reference.
The generated interface, which is exactly what I want to have, looks
like this:
public interface LTSStateTransitionAttached<E> extends LTSStateTransition {
E getAttached();
void setAttached(E value);
The corresponging ecore snippet:
<eClassifiers xsi:type="ecore:EClass" name="LTSStateTransitionAttached"
eSuperTypes="#//lts/LTSStateTransition">
<eTypeParameters name="E"/>
<eStructuralFeatures xsi:type="ecore:EReference"
name="attached" resolveProxies="false">
<eGenericType
eTypeParameter="#//lts/profiles/LTSStateTransitionAttached/E "/>
</eStructuralFeatures>
</eClassifiers>
So far so good.
When I use the generated editor I'm following the common approach of
loading a resource and being able to use the property view to reference
arbitrary objects to set the field, "attached" in this case.
However, when I close the editor and re-open it the reference are proxies.
Am I right, that those references should be resolved, and if not
possible proxies are created?
As far as I can tell this problem is related to attributes with a
generic type. I already compared the way the references are serialized
to attributes with a fixed type. Since those attributes are supposed to
implement references hrefs are used, in both cases.
Any help would be appreciated.
Maik
Re: EMF References using Generics, Proxy are created [message #468413 is a reply to message #468346] Wed, 05 August 2009 09:22 Go to previous messageGo to next message
Maik,
Comments below.
Maik Wurdel wrote:
> when having a generic reference in a class and using the generated
> editor.
> like this:
> E getAttached();
So cross document references will not be supported.
> <eGenericType
> </eClassifiers>
> So far so good.
> reference arbitrary objects to set the field, "attached" in this case.
> proxies.
Are they in other resources?
Cross document references are always created as proxies and then there
is an attempt to resolve them when first they are access (which you've
disabled).
> to implement references hrefs are used, in both cases.
Try changing resolveProxies to true.
> Maik
Re: EMF References using Generics, Proxy are created [message #468436 is a reply to message #468413] Wed, 05 August 2009 10:23 Go to previous messageGo to next message
Ed,
thanks for your fast response and comments.
Ed Merks schrieb:
> Maik,
> Comments below.
> Maik Wurdel wrote:
>> Hi,
>> editor.
>> like this:
>> E getAttached();
>> <eGenericType
>> </eClassifiers>
>> So far so good.
>> proxies.
Yes they are.
> disabled).
What is the purpose of a not resolving proxy? When I'm trying to access
an attribute of the object the proxy should always be resolved or at
least the corresponding attribute. Otherwise null is returned.
For me the only question for a proxies is when it is resolved not if. :)
Well, how can I? ;) Still using Rational Rose.
Okay, I think I found the general issue. I thought that modeling a field
by reference results in the same ecore model as modeling an
association, but this is apparently not the case, since the ecore
specific attribute for a field and a reference differ (as in this case:
a reference has the resolveProxies field, an attribute not).
Therefore my problem results from modeling generics in Rational Rose
(since a generic reference is modeled as attribute <<reference>> E:
attached). Thus, I can't set or use the default value of the ecore
propertues. :(
I know, from my last post, that you are not involved in Rational Rose
anymore.
Is there a comparable tool to Rational Rose for free?
Thanks again!
Maik
>> Maik
Re: EMF References using Generics, Proxy are created [message #468464 is a reply to message #468436] Wed, 05 August 2009 11:34 Go to previous messageGo to next message
--------------020609080404000302090002
Maik,
Comments below.
Maik Wurdel wrote:
> Ed,
> Ed Merks schrieb:
>> Maik,
>> Comments below.
>> Maik Wurdel wrote:
>>> Hi,
>>> editor.
>>> to attach a certain object by reference.
>>> like this:
>>> E getAttached();
>>> <eGenericType
>>> </eClassifiers>
>>> So far so good.
>>> proxies.
> Yes they are.
>> there is an attempt to resolve them when first they are access (which
>> you've disabled).
There are cases where the reference is assumed to be in the same
resource. An example in Ecore is references to type parameters. In XML
Schema, IDREFs are a good example.
> When I'm trying to access an attribute of the object the proxy should
> always be resolved or at least the corresponding attribute.
No doubt.
>>> serialized to attributes with a fixed type. Since those attributes
>>> are supposed to implement references hrefs are used, in both cases.
There are Rose properties.
> field by reference results in the same ecore model as modeling an
> case: a reference has the resolveProxies field, an attribute not).
Yes.
> propertues. :(
I see now.
> anymore.
I could use it for free while at IBM.
The Ecore Tools project supports a very nice graphical editor that I use
instead of Rose. Look at all the nice diagrams I used it for:
< http://ed-merks.blogspot.com/2008/06/was-gany-good-to-you.ht ml>
> Thanks again!
> Maik
>>> Maik
<html>
<head>
http-equiv="Content-Type">
</head>
Maik,<br>
<br>
Comments below.<br>
<br>
<br>
Maik Wurdel wrote:
<blockquote cite="mid:h5c4le$m5s$1@build.eclipse.org" type="cite">Ed,
<br>
<br>
<br>
<br>
<br>
Ed Merks schrieb:
<br>
<blockquote type="cite">Maik,
<br>
<br>
Comments below.
<br>
<br>
Maik Wurdel wrote:
<br>
<blockquote type="cite">Hi,
<br>
<br>
<br>
<br>
<br>
<br>
like this:
<br>
<br>
public interface LTSStateTransitionAttached&lt;E&gt; extends
<br>
<br>
E getAttached();
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
&lt;eClassifiers xsi:type="ecore:EClass"
eSuperTypes="#//lts/LTSStateTransition"&gt;
<br>
Re: EMF References using Generics, Proxy are created [message #478406 is a reply to message #468464] Thu, 06 August 2009 05:23 Go to previous messageGo to next message
Thanks Ed.
I tried the Ecore Diagram of the Ecore Tools. Look really mature.
However, it is inconvenient to have a diagra for each package.
Otherwise I'd take for sure.
Maik
Ed Merks schrieb:
> Maik,
> Comments below.
> Maik Wurdel wrote:
>> Ed,
>> Ed Merks schrieb:
>>> Maik,
>>> Comments below.
>>> Maik Wurdel wrote:
>>>> Hi,
>>>> editor.
>>>> like this:
>>>> E getAttached();
>>>> <eGenericType
>>>> </eClassifiers>
>>>> So far so good.
>>>> proxies.
>> Yes they are.
>>> you've disabled).
> No doubt.
> Yes.
>> propertues. :(
> I see now.
>> anymore.
>> Thanks again!
>> Maik
>>>> Maik
Re: EMF References using Generics, Proxy are created [message #478690 is a reply to message #478406] Thu, 06 August 2009 08:28 Go to previous message
Maik,
You can drag things from other models onto the diagram surface. You
load them into additional resources and then can use them the Change
model's diagram makes use of this to use EObject...
Maik Wurdel wrote:
> Thanks Ed.
> Maik
> Ed Merks schrieb:
>> Maik,
>> Comments below.
>> Maik Wurdel wrote:
>>> Ed,
>>> Ed Merks schrieb:
>>>> Maik,
>>>> Comments below.
>>>> Maik Wurdel wrote:
>>>>> Hi,
>>>>> editor.
>>>>> looks like this:
>>>>> E getAttached();
>>>>> <eGenericType
>>>>> </eClassifiers>
>>>>> So far so good.
>>>>> of loading a resource and being able to use the property view to
>>>>> case.
>>>>> proxies.
>>> Yes they are.
>>>> (which you've disabled).
>> XML Schema, IDREFs are a good example.
>>> should always be resolved or at least the corresponding attribute.
>> No doubt.
>>> if. :)
>> Yes.
>>> propertues. :(
>> I see now.
>>> Rose anymore.
>> use instead of Rose. Look at all the nice diagrams I used it for:
>>> Thanks again!
>>> Maik
>>>>> Maik
Previous Topic:[Transaction] IllegalArgumentException when collecting notifications
Next Topic:Load and save a model with references
Current Time: Sun Jul 27 09:09:48 EDT 2025
Powered by FUDForum. Page generated in 0.04398 seconds
