Home » Eclipse Projects » Eclipse Platform » Search issue
Search issue [message #45813] Fri, 23 May 2003 10:28 Go to next message
Hello everyone.
I'm having some issues when extending eclipse's search functionality:
As far as i can understand, this is the way to do it:
Implement a search page by subclassing a DialogPage that implements
ISearchPage.
in the ISearchPage.performAction(), do the following:
public boolean performAction(){
SearchUI.activateSearchResultView();
ISearchResultView view=SearchUI.getSearchResultView();
view.searchStarted(...);
/* do the actual search by filling up with calls to:*/
view.addMatch(...);
view.searchFinished();
return true;
However, when running my code, the result does not get displayed in the
Search Result View, unless I close and open the view (thus forcing a refresh
of some kind).
I have tried miscellaneous ways embedding the actual search in a
RunnableWithProgress that is run in the container.getRunnableContext, but
the results remain the same.
Weird? I appreciate all help.
Emil Einarsson
Re: Search issue [message #46724 is a reply to message #45813] Fri, 23 May 2003 14:57 Go to previous messageGo to next message
Yeah, it's harder than that (I was trying to do something simpler than what it
seems like you are doing); see just-entered bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=38062 for a partial description of
what I had to do; then take a look at how the TextSearchEngine/Operation/Visitor
stuff works (which has the operations correctly wrapped in the WorkspaceRunnable
and all). That may well tell you more about what you need to do (I don't know
that you will have to copy all dozen classes the way I did).
HTH,
Paul K
Emil Einarsson wrote:
> Hello everyone.
> ISearchPage.
> view.addMatch(...);
> return true;
> of some kind).
> Emil Einarsson
Re: Search issue [message #47827 is a reply to message #45813] Mon, 26 May 2003 05:02 Go to previous messageGo to next message
>Hello everyone.
>ISearchPage.
> view.addMatch(...);
> return true;
>of some kind).
Try running it in a WorkspaceModifyOperation. This is the suggested way
because you will end up with only one resource delta instead of 1 per
marker that you create.
You should also write a bug report: assuming you did everything right,
there should be no need to close and reopen the Search view to see the
results. Also check your .log for possible exceptions.
HTH
Dani
Re: Search issue [message #48291 is a reply to message #47827] Mon, 26 May 2003 10:09 Go to previous message
Problem solved:
The marker type used in addMatch MUST be a subtype of
org.eclipse.search.searchmarker for results to be discovered by the search
result viewer.
I had not registered my search marker properly, but the marker type was
still accepted by the platform, no indication of what was wrong. Tricky
thing, this...
Thanks for the help
Emil
"Daniel Megert" <daniel.megert@gmx.net> skrev i meddelandet
news:basl6o$miu$1@rogue.oti.com...
> >Hello everyone.
> >ISearchPage.
> > view.addMatch(...);
> > return true;
refresh
> >of some kind).
> HTH
> Dani
Previous Topic:[ANN] metrics release 1.2.0 available
Next Topic:Eclipse Issues: Parameter Hints not functioning correctly
Current Time: Fri Oct 31 21:47:34 EDT 2025
Powered by FUDForum. Page generated in 0.06547 seconds
