Home » Modeling » UML2 » problem with load value of property of object stereotyped
problem with load value of property of object stereotyped [message #478226] Mon, 09 March 2009 04:00 Go to next message
How can I get the value of property of object stereotyped?
If I use getStereotypePropertyValue() this return IllegalArgument
Exception.
So, i have implemented a method with first parameter a metaclass of object
but I don't know how call this method in the class main.
The method is:
public static String loadREAccessProb(org.eclipse.uml2.uml.Actor
actor,Stereotype stereotipo)
String risultato=null;
String appliedStereotype=stereotipo.getQualifiedName();
risultato=(String) ((Element) actor).getValue(((Element)
actor).getAppliedStereotype(appliedStereotype), "REaccessProb");
return risultato;
the model is:
<<REUser>><Actor>Elevator user
and REUser has as property REAccessprob
I must get the value of REAccessProb on object Elevator user.
How can i do?
Re: problem with load value of property of object stereotyped [message #478229 is a reply to message #478226] Mon, 09 March 2009 09:54 Go to previous messageGo to next message
Fiorella,
If this code is not working, I'd suggest debugging it to see why the illegal
argument exception is occurring...
Kenn
"fiorella " <fiorellaepablo@hotmail.it> wrote in message
news:9f47b6b7285bf7e14b7393fff51f3850$1@www.eclipse.org...
> Hello,
> Exception.
> The method is:
> return risultato;
> the model is:
> How can i do?
Re: problem with load value of property of object stereotyped [message #478233 is a reply to message #478229] Mon, 09 March 2009 12:40 Go to previous message
The method return nothing,no an illegal exception, but the problem is how
call the method in the main class.
Re: problem with load value of property of object stereotyped [message #627426 is a reply to message #478226] Mon, 09 March 2009 09:54 Go to previous message
Fiorella,
Kenn
> Hello,
> Exception.
> The method is:
> return risultato;
> the model is:
> How can i do?
Re: problem with load value of property of object stereotyped [message #627429 is a reply to message #478229] Mon, 09 March 2009 12:40 Go to previous message
Previous Topic:Re: get property'value of stereotype
Next Topic:How read uml model in java?
Current Time: Sat Jul 19 04:49:59 EDT 2025
Powered by FUDForum. Page generated in 0.09560 seconds
