Home » Modeling » UML2 » Unable to create 'ResourceSetImpl' instance in Eclipse 3.4.1
Unable to create 'ResourceSetImpl' instance in Eclipse 3.4.1 [message #478105] Tue, 06 January 2009 03:30 Go to next message
I have just started working on an UML project after studying the article
"Getting Started with UML2" from the following URL:
http://www.eclipse.org/modeling/mdt/uml2/docs/articles/Getti ng_Started_with_UML2/article.html
I have followed all steps given in this article, and its working except
these lines:
URI uri =
URI.createURI("file:///C:").appendSegment("Try-ExtendedPO2-Activity").appendFileExtension(UMLResource.FILE_EXTENSION);
save(model, uri);
protected static void save(org.eclipse.uml2.uml.Package package_, URI uri)
Resource resource = new ResourceSetImpl().createResource(uri);
resource.getContents().add(package_);
But the line "new ResourceSetImpl().createResource(uri);"
always returns a null object, even if the uri object is proper.
I am unable to understand the problem b'coz I have installed all required
plugins as given in article. (Also ResourceSetImpl class is also present
into workspace of eclipse 3.4.1)
Please tell me the cause of my problem.
Thanks in advance.
Kishore
Re: Unable to create 'ResourceSetImpl' instance in Eclipse 3.4.1 [message #478106 is a reply to message #478105] Tue, 06 January 2009 04:26 Go to previous messageGo to next message
Kishore,
Keep in mind that if you aren't running as an Eclipse application, which
I suppose the getting started guide assumes you are, then plugin.xml
registration of resource factories won't happen (nor any other
plugin.xml registrations). I don't really see where the required setup
for stand alone execution is documented...
> article "Getting Started with UML2" from the following URL:
> except these lines:
> URI uri =
> save(model, uri);
> uri)
> required plugins as given in article. (Also ResourceSetImpl class is
> also present into workspace of eclipse 3.4.1)
> Thanks in advance.
> Kishore
Re: Unable to create 'ResourceSetImpl' instance in Eclipse 3.4.1 [message #478107 is a reply to message #478106] Tue, 06 January 2009 05:14 Go to previous messageGo to next message
Thanks Ed Merks.
Yes I was running it as a Eclipse Application. After your reply, I
understand my silly mistake. Now its working fine.
Thanks again.
Kishore
Re: Unable to create 'ResourceSetImpl' instance in Eclipse 3.4.1 [message #627313 is a reply to message #478105] Tue, 06 January 2009 04:26 Go to previous messageGo to next message
Kishore,
> except these lines:
> URI uri =
> save(model, uri);
> uri)
> Thanks in advance.
> Kishore
Re: Unable to create 'ResourceSetImpl' instance in Eclipse 3.4.1 [message #627314 is a reply to message #478106] Tue, 06 January 2009 05:14 Go to previous messageGo to next message
Thanks Ed Merks.
Thanks again.
Kishore
Re: Unable to create 'ResourceSetImpl' instance in Eclipse 3.4.1 [message #643060 is a reply to message #478105] Fri, 03 December 2010 14:21 Go to previous message
Try this:
		Resource.Factory.Registry reg = Resource.Factory.Registry.INSTANCE;
		Map<String, Object> m = reg.getExtensionToFactoryMap();
		m.put(UMLResource.FILE_EXTENSION, new XMIResourceFactoryImpl());
Previous Topic:load correctly an UML profile
Next Topic:Problem in set property value
Current Time: Sat Jul 26 15:20:44 EDT 2025
Powered by FUDForum. Page generated in 0.58073 seconds
