Home » Modeling » UML2 » Re: Getting the source code for eclipse uml2
Re: Getting the source code for eclipse uml2 [message #478028] Wed, 26 November 2008 09:08 Go to next message
Originally posted by: cdamus.zeligsoft.com
Hi, David,
This is a question for the UML2 newsgroup, which I have included in this
reply.
If you downloaded the UML2 SDK distribution ZIP, then it includes source
attachments that allow the PDE to show the source code in the Eclipse
workbench. It works just the same as for the Eclipse Platform source.
Christian
David Jaiyeola wrote:
> Hello everyone, please how can I get to extract the source code of uml2. I
> want to make some study about it. I have downloaded the uml2 zip folder but
> cannot see the source code. Thank for replies.
Re: Getting the source code for eclipse uml2 [message #478034 is a reply to message #478028] Thu, 27 November 2008 13:28 Go to previous messageGo to next message
Thanks for your reply Christian..... I have no idea of how to even get to
the PDE not to even talk of extracting the source. Please can you tell me
the steps to take. I will be happy if you can assist me on this. I am still
a basic learner when it comes to using eclipse. Thanks
On 26/11/2008 15:08, in article ggjl87$pn6$1@build.eclipse.org, "Christian
W. Damus" <cdamus@zeligsoft.com> wrote:
> Hi, David,
> reply.
> Cheers,
> Christian
Re: Getting the source code for eclipse uml2 [message #478035 is a reply to message #478034] Thu, 27 November 2008 14:33 Go to previous message
Hi, David,
For newbie Eclipse questions, there is a dedicated newsgroup:
eclipse.newcomer.
Assuming that you downloaded and installed a ZIP file named something
like mdt-uml2-SDK-2.2.1.zip, then it already includes the sources for
all of the UML2 code. If you didn't download the "SDK" ZIP, then get it
and install it. Look for the "SDK (Runtime, Source, Examples)" item:
http://www.eclipse.org/modeling/mdt/downloads/index.php?proj ect=uml2&showAll=0&showMax=5
If you're developing Eclipse plug-ins, then you are already using the
PDE. It's a bunch of plug-ins to Eclipse that (among much else) know
how to show the source code for the features you have installed. It
isn't a separate tool.
With the UML2 SDK installed, you should automatically see the source for
any *.class files from the UML2 project when you open them with, for
example, the Strl+Shift+T dialog.
If you have further questions, I'm sure that the newcomer mewsgroup will
be able to help. You can also search for "source attachment" in the
on-line help for more details.
Christian
>> Hi, David,
>> reply.
>> Cheers,
>> Christian
Re: Getting the source code for eclipse uml2 [message #627251 is a reply to message #478028] Thu, 27 November 2008 13:28 Go to previous message
> Hi, David,
> reply.
> Cheers,
> Christian
Re: Getting the source code for eclipse uml2 [message #627252 is a reply to message #478034] Thu, 27 November 2008 14:33 Go to previous message
Hi, David,
eclipse.newcomer.
Christian
>> Hi, David,
>> reply.
>> Cheers,
>> Christian
Previous Topic:Reflective feature delegation works incorrectly
Next Topic:Reflective feature delegation works incorrectly
Current Time: Fri Sep 19 09:35:38 EDT 2025
Powered by FUDForum. Page generated in 0.03187 seconds
