Home » Modeling » UML2 » Add classes to my UML2 model via java code
Add classes to my UML2 model via java code [message #477696] Tue, 02 September 2008 09:15 Go to next message
I'm currently searching an EMF project which could enable me to add
"easily" classes to my UML2 project. A sort of algorithm like this :
Load UML Resource
Add Class 1
Add Class 2
Save UML Resource
Could you please tell me what is the best one for modifying my model
please ?
Thanks for your support.
P.
Re: Add classes to my UML2 model via java code [message #477697 is a reply to message #477696] Tue, 02 September 2008 11:48 Go to previous messageGo to next message
Hi Pierre,
Have you tried code similar to this example?
package org.search.jiem.uml.util;
import org.eclipse.emf.common.command.CompoundCommand;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.edit.command.AddCommand;
import org.eclipse.emf.edit.domain.EditingDomain;
import org.eclipse.uml2.uml.Class;
import org.eclipse.uml2.uml.Model;
import org.eclipse.uml2.uml.UMLFactory;
import org.eclipse.uml2.uml.UMLPackage;
import org.eclipse.uml2.uml.resource.UMLResource;
public class ClassAdder {
public static void addClassesToModel(final EditingDomain editingDomain) {
final URI uri = URI.createURI("path/to/uml/resource");
final UMLResource resource = (UMLResource)
editingDomain.getResourceSet().getResource(uri, true);
final Model model = (Model) resource.getContents().get(0);
final Class class1 = UMLFactory.eINSTANCE.createClass();
final Class class2 = UMLFactory.eINSTANCE.createClass();
final CompoundCommand command = new CompoundCommand();
command.append(AddCommand.create(editingDomain, model,
UMLPackage.PACKAGE__PACKAGED_ELEMENT, class1));
UMLPackage.PACKAGE__PACKAGED_ELEMENT, class2));
editingDomain.getCommandStack().execute(command);
Hope that helps,
-----Tim------
Pierre wrote:
> Hello,
> Load UML Resource
> Add Class 1
> Add Class 2
> Save UML Resource
> please ?
> Regards,
> P.
Re: Add classes to my UML2 model via java code [message #477698 is a reply to message #477697] Tue, 02 September 2008 11:50 Go to previous messageGo to next message
I left off these last lines for saving the resource after the commands
have been executed:
try {
resource.save(resource.getDefaultSaveOptions());
} catch (IOException e) {
e.printStackTrace();
Tim Myer wrote:
> Hi Pierre,
> editingDomain) {
> Hope that helps,
> -----Tim------
> Pierre wrote:
>> Hello,
>> Load UML Resource
>> Add Class 1
>> Add Class 2
>> Save UML Resource
>> please ?
>> Regards,
>> P.
Re: Add classes to my UML2 model via java code [message #477702 is a reply to message #477698] Wed, 03 September 2008 03:53 Go to previous messageGo to next message
Thanks a lot for your quick answer Tim. But I did not find how to launch
the addClassesToModel method ? How instanciating a classe extending
EditingDomain interface ?
P.
Re: Add classes to my UML2 model via java code [message #477703 is a reply to message #477702] Wed, 03 September 2008 11:35 Go to previous messageGo to next message
Ok I found this :
public class AddClasses {
	private static EditingDomain editingDomain;
	public static void initEditingDomain() {
		ComposedAdapterFactory adapterFactory = new ComposedAdapterFactory();
		BasicCommandStack commandStack = new BasicCommandStack();
		editingDomain = new UML2AdapterFactoryEditingDomain(adapterFactory,
				commandStack, new HashMap<Resource, Boolean>());
	public static void addClassesToModel() {
		initEditingDomain();
Re: Add classes to my UML2 model via java code [message #477705 is a reply to message #477696] Thu, 04 September 2008 05:06 Go to previous messageGo to next message
I assume you have seen this already?
http://www.eclipse.org/modeling/mdt/uml2/docs/articles/Getti ng_Started_with_UML2/article.html
That plus the javadoc for UML2 should get you going...
Rafael
Pierre wrote:
> Hello,
> Load UML Resource
> Add Class 1
> Add Class 2
> Save UML Resource
> please ?
> Regards,
> P.
Re: Add classes to my UML2 model via java code [message #477708 is a reply to message #477705] Fri, 05 September 2008 05:27 Go to previous messageGo to next message
Thanks Rafael. I used the example provided at the end of
http://www.eclipse.org/newsportal/thread.php?group=eclipse.m odeling.mdt.uml2
I want to do exactly the same thing but instead of creating a new model, I
want to load an existing one. So I created this method :
protected static org.eclipse.uml2.uml.Model loadModel(URI uri) {
org.eclipse.uml2.uml.Model model_ = null;
try {
Resource resource = RESOURCE_SET.getResource(uri, true);
model_ = (org.eclipse.uml2.uml.Model) EcoreUtil
.getObjectByType(resource.getContents(),
UMLPackage.Literals.MODEL);
} catch (WrappedException we) {
err(we.getMessage());
System.exit(1);
return model_;
And in my Main method, I do :
Model model =
loadModel(URI.createFileURI("D:/workspace/EMFP/model/modeltest.uml "));
But I get this exception :
Exception in thread "main" java.lang.NullPointerException
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFe atureType(XMLHandler.java:2132)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHa ndler.java:2010)
at
org.eclipse.emf.ecore.xmi.impl.XMIHandler.createObject(XMIHa ndler.java:131)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLH andler.java:1789)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1013)
at
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:87)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:991)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:711)
at
org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:167)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocume ntParser.emptyElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
Source)
at
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
Source)
at
com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown
Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1414)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X MLHandler.java:2516)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi x(XMLHandler.java:2397)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1275)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1444)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1009)
at
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
Source)
at
at
at
at
at
at
at
at
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
Source)
at
at
at
at
at
at
at
at
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
Source)
at
at
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1210)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
at UML2Article.loadModel(UML2Article.java:114)
at GettingStartedWithUML2.main(GettingStartedWithUML2.java:223)
Notice that the line "Resource resource = RESOURCE_SET.getResource(uri,
true);" is very long to execute in debug mode. And the exception is got at
this line.
Any hint would be very appreciated.
Thanks !
P.
Re: Add classes to my UML2 model via java code [message #477998 is a reply to message #477708] Fri, 21 November 2008 10:25 Go to previous message
Hi Pierre,
Did you manage to figure out the NullPointerException?
Some set-up code is needed for stand-alone projects, you may be missing some
mappings.
- James.
"Pierre " <p.tamisier@netfective.com> wrote in message
news:41c78135e2e7bb053d01cbfa42f406f8$1@www.eclipse.org...
> try {
> System.exit(1);
> return model_;
> Model model =
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> this line.
> Thanks !
> Regards,
> P.
Re: Add classes to my UML2 model via java code [message #626891 is a reply to message #477696] Tue, 02 September 2008 11:48 Go to previous message
Hi Pierre,
Hope that helps,
-----Tim------
Pierre wrote:
> Hello,
> Load UML Resource
> Add Class 1
> Add Class 2
> Save UML Resource
> please ?
> Regards,
> P.
Re: Add classes to my UML2 model via java code [message #626892 is a reply to message #477697] Tue, 02 September 2008 11:50 Go to previous message
have been executed:
try {
Tim Myer wrote:
> Hi Pierre,
> editingDomain) {
> Hope that helps,
> -----Tim------
> Pierre wrote:
>> Hello,
>> Load UML Resource
>> Add Class 1
>> Add Class 2
>> Save UML Resource
>> please ?
>> Regards,
>> P.
Re: Add classes to my UML2 model via java code [message #626896 is a reply to message #477698] Wed, 03 September 2008 03:53 Go to previous message
P.
Re: Add classes to my UML2 model via java code [message #626897 is a reply to message #477702] Wed, 03 September 2008 11:35 Go to previous message
Ok I found this :
Re: Add classes to my UML2 model via java code [message #626899 is a reply to message #477696] Thu, 04 September 2008 05:06 Go to previous message
Rafael
Pierre wrote:
> Hello,
> Load UML Resource
> Add Class 1
> Add Class 2
> Save UML Resource
> please ?
> Regards,
> P.
Re: Add classes to my UML2 model via java code [message #626902 is a reply to message #477705] Fri, 05 September 2008 05:27 Go to previous message
try {
System.exit(1);
return model_;
Model model =
at
at
at
at
at
at
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
Source)
at
at
at
at
at
at
at
at
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
Source)
at
at
at
at
at
at
at
at
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
Source)
at
at
at
at
at
at
at
at
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
Source)
at
at
at
at
at
at
this line.
Thanks !
P.
Re: Add classes to my UML2 model via java code [message #627215 is a reply to message #477708] Fri, 21 November 2008 10:25 Go to previous message
Hi Pierre,
mappings.
- James.
> try {
> System.exit(1);
> return model_;
> Model model =
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> this line.
> Thanks !
> Regards,
> P.
Previous Topic:Constructors and Parameters
Next Topic:UML2 migration
Current Time: Wed Jul 23 20:34:21 EDT 2025
Powered by FUDForum. Page generated in 0.07524 seconds
