Home » Modeling » UML2 » Stereotypes parameters
Stereotypes parameters [message #477972] |
Sat, 15 November 2008 05:58  |
I defined a stereotype with a parameter of type uml::Operation
The problem is that when I apply the stereotype it seems impossible to fill
the parameter value in the property view...
Is this feature supported by the uml editor?
thanks
Mauro
Re: Stereotypes parameters [message #477980 is a reply to message #477979] |
Mon, 17 November 2008 06:04   |
Kenn Hussey wrote:
> Do you have a large number of operations in your resource set? We have
> received similar complaints in the past, but have been unable to reproduce
> the problem (since the list should simply be scrollable)...
yes the list is very very long, some resources have a very long name and I
think that the size of the menu is based on the longest wich are
<Operation> Create Association (End 1 Is Navigable : Boolean, End 1
Aggregation : Aggregation Kind, End 1 Name : String, End 1 Lower : Integer,
End 1 Upper : Unlimited Natural, End 1 Type : Type, End 2 Is Navigable :
Boolean, End 2 Aggregation : Aggregation Kind, End 2 Name : String, End 2
Lower : Integer, End 2 Upper : Unlimited Natural) : Association
<Operation> Create Communication Path (End 1 Is Navigable : Boolean, End 1
End 1 Upper : Unlimited Natural, End 1 Node : Node, End 2 Is Navigable :
Lower : Integer, End 2 Upper : Unlimited Natural) : Communication Path
Mauro
Re: Stereotypes parameters [message #477982 is a reply to message #477980] |
Mon, 17 November 2008 09:35   |
Hi Mauro,
Please raise a defect on that with a small example to reproduce the issue
and it will be addressed.
- James.
"Mauro" <mauro@bglug.it> wrote in message
news:gfrfn2$mnv$1@build.eclipse.org...
>> reproduce
> Integer,
> Integer,
> Mauro
Re: Stereotypes parameters [message #477990 is a reply to message #477988] |
Wed, 19 November 2008 12:00   |
James Bruck wrote:
> Below when you ask ".. is it normal to have *those* operations ..."
> which operations are you referring to exactly?
the very long 2 I mentioned before:
I think they are the cause of the wide menu!!
Mauro
Re: Stereotypes parameters [message #627190 is a reply to message #477972] |
Sat, 15 November 2008 10:15  |
Originally posted by: cdamus.zeligsoft.com
Hi, Mauro,
By "parameter" do you mean that the stereotype has a *property* of type
uml::Operation? (i.e., an association to the Operation metaclass)
This feature is supported by the UML editor. You should get a drop-down
list from which to select any existing operation in the resource set (if
it is a single-valued property) or a dialog from which to select
existing operations (if it is a multi-valued property).
Perhaps you can share details of the stereotype definition in your
profile (a snippet of the XMI would be most handy)? Likely we would be
able to see what the problem is ...
Christian
> thanks
> Mauro
Re: Stereotypes parameters [message #627191 is a reply to message #477973] |
Sun, 16 November 2008 13:32  |
I see... the dialog is there but it is so much larger than the screen that I
can't see anything!
It's the same under Windows and Linux...
Mauro
Re: Stereotypes parameters [message #627196 is a reply to message #477974] |
Mon, 17 November 2008 04:00  |
Mauro,
Kenn
news:gfpli1$oil$1@build.eclipse.org...
> I
> can't see anything!
> Mauro
Re: Stereotypes parameters [message #627197 is a reply to message #477979] |
Mauro
Re: Stereotypes parameters [message #627199 is a reply to message #477980] |
Hi Mauro,
- James.
>> reproduce
> Integer,
> Integer,
> Mauro
Re: Stereotypes parameters [message #627200 is a reply to message #477982] |
Mon, 17 November 2008 14:44  |
I did it
Is it normal to have those operations in the resource set?
I installed just the default packages...
do you see any workaround (filtering the data somewhere?)
Mauro
Re: Stereotypes parameters [message #627205 is a reply to message #477983] |
Wed, 19 November 2008 10:33  |
Thanks for raising the defect.
I can see the problem now... very wacky.
Below when you ask ".. is it normal to have *those* operations ..." which
operations are you referring to exactly? You can explicitly load other
resources into your resource set.
Filtering the data would be one possibility, but I really can't see why the
dialog is so large. Perhaps popping up a dialog with some filtering
criteria would be more helpful.
This is definitely an issue.
- James.
news:gfse5d$324$1@build.eclipse.org...
> I did it
> Mauro
Re: Stereotypes parameters [message #627207 is a reply to message #477988] |
Mauro
Current Time: Thu Jul 24 02:38:02 EDT 2025
Powered by FUDForum. Page generated in 0.08972 seconds
