Home » Modeling » UML2 » Missing property in UML::Class::Kernel::PackageableElement
Missing property in UML::Class::Kernel::PackageableElement [message #477891] Mon, 27 October 2008 05:32 Go to next message
Originally posted by: florianwendland.freenet.de
Hi all,
i've found out, that the relationship between Package and PackageableElement
isn't realized with respect to the UML Superstructure (or may be it is
wanted).
In the spec, there is a containent relationship between Package and
PackageableElement with both ends being navigable. See:
Package:
+ packagedElement : PackageableElement [0..*]
PackageableElement : NamedElement
+ owningPackage : Package [0..1]
The first accessor was generated in the code, but the second one in class
PackageableElementImpl wasn't. Instead of, there is getOwner() : Element
method, which returns of course the owningPackage, but it is not very
precisly defined.
Is this a bug or a feature :)
Marc-Florian
Re: Missing property in UML::Class::Kernel::PackageableElement [message #477907 is a reply to message #477891] Wed, 29 October 2008 15:06 Go to previous messageGo to next message
Hi Marc-Florian,
I think you are referring to figure 7.14 in the spec. Other than that one
figure, I can't see owning package in the description of PackageableElement
or mentioned anywhere else in the spec. This may be some oversight. I'll
dig into this a bit more and raise an issue with the OMG.
-James.
"Marc-Florian Wendland" <florianwendland@freenet.de> wrote in message
news:ge41nt$ifi$1@build.eclipse.org...
> Hi all,
> PackageableElement isn't realized with respect to the UML Superstructure
> (or may be it is wanted).
> Package:
> precisly defined.
> Marc-Florian
Re: Missing property in UML::Class::Kernel::PackageableElement [message #477913 is a reply to message #477891] Thu, 30 October 2008 14:52 Go to previous messageGo to next message
Marc-Florian,
Which version of the specification are you referencing, and which figure?
Figure 7.14 (also mentioned by James) shows the
PackageableElement::owningPackage property as being non-navigable; when this
is mapped to Java, the property is lost (as are all non-navigable
properties)...
Kenn
> Hi all,
> Package:
> precisly defined.
> Marc-Florian
Re: Missing property in UML::Class::Kernel::PackageableElement [message #477919 is a reply to message #477913] Mon, 03 November 2008 04:16 Go to previous messageGo to next message
Kenn and James,
indeed, i'm referencing the figure 7.14 in the uml 2.1 spec. But why is the
owningPackage-end non-navigable? See the association between Package and
Type. There are no differences on the ends at Package-side, so how do you
see, that it is non-navigable? Or depends this on the arrow at the
packagedElement-end? Does that mean, that you can navigate from Package only
to PackageableElement but not vice versa? Because this arrow is the only
difference, i can recognize...
Surely, if it is non-navigable, than it won't be translated into code.
Thanks a lot
Marc-Florian
"Kenn Hussey" <Kenn.Hussey@embarcadero.com> schrieb im Newsbeitrag
news:gecvps$968$1@build.eclipse.org...
> Marc-Florian,
> this is mapped to Java, the property is lost (as are all non-navigable
> properties)...
> Kenn
>> Hi all,
>> Package:
>> precisly defined.
>> Marc-Florian
Re: Missing property in UML::Class::Kernel::PackageableElement [message #477920 is a reply to message #477919] Mon, 03 November 2008 09:08 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, Marc-Florian,
If it helps, OCL expressions are able to navigate the non-navigable
association ends, and even unnamed ends where they are not ambiguous
(though there are few). The MDT OCL implementation uses the UML
CacheAdapter's inverse-reference tracking to implement this campability.
Christian
Marc-Florian Wendland wrote:
> Kenn and James,
> Thanks a lot
> Marc-Florian
>> Marc-Florian,
>> properties)...
>> Kenn
>>> Hi all,
>>> Package:
>>> precisly defined.
>>> Marc-Florian
Re: Missing property in UML::Class::Kernel::PackageableElement [message #477924 is a reply to message #477919] Mon, 03 November 2008 12:57 Go to previous message
Marc-Florian,
Yes, it's the absence of the arrowhead that indicates that the property is
non-navigable.
Kenn
news:gemfct$h38$1@build.eclipse.org...
> Kenn and James,
> the owningPackage-end non-navigable? See the association between Package
> and Type. There are no differences on the ends at Package-side, so how do
> you see, that it is non-navigable? Or depends this on the arrow at the
> only to PackageableElement but not vice versa? Because this arrow is the
> only difference, i can recognize...
> Thanks a lot
> Marc-Florian
>> Marc-Florian,
>> properties)...
>> Kenn
>>> Hi all,
>>> Package:
>>> class PackageableElementImpl wasn't. Instead of, there is getOwner() :
>>> Element method, which returns of course the owningPackage, but it is not
>>> very precisly defined.
>>> Marc-Florian
Re: Missing property in UML::Class::Kernel::PackageableElement [message #627116 is a reply to message #477891] Wed, 29 October 2008 15:06 Go to previous message
Hi Marc-Florian,
-James.
> Hi all,
> Package:
> precisly defined.
> Marc-Florian
Re: Missing property in UML::Class::Kernel::PackageableElement [message #627122 is a reply to message #477891] Thu, 30 October 2008 14:52 Go to previous message
Marc-Florian,
properties)...
Kenn
> Hi all,
> Package:
> precisly defined.
> Marc-Florian
Re: Missing property in UML::Class::Kernel::PackageableElement [message #627128 is a reply to message #477913] Mon, 03 November 2008 04:16 Go to previous message
Kenn and James,
Thanks a lot
Marc-Florian
> Marc-Florian,
> properties)...
> Kenn
>> Hi all,
>> Package:
>> precisly defined.
>> Marc-Florian
Re: Missing property in UML::Class::Kernel::PackageableElement [message #627129 is a reply to message #477919] Mon, 03 November 2008 09:08 Go to previous message
Hi, Marc-Florian,
Christian
> Kenn and James,
> Thanks a lot
> Marc-Florian
>> Marc-Florian,
>> properties)...
>> Kenn
>>> Hi all,
>>> Package:
>>> precisly defined.
>>> Marc-Florian
Re: Missing property in UML::Class::Kernel::PackageableElement [message #627133 is a reply to message #477919] Mon, 03 November 2008 12:57 Go to previous message
Marc-Florian,
non-navigable.
Kenn
> Kenn and James,
> Thanks a lot
> Marc-Florian
>> Marc-Florian,
>> properties)...
>> Kenn
>>> Hi all,
>>> Package:
>>> Marc-Florian
Previous Topic:Constraint Attachments
Next Topic:Importing Superstructure.uml to Rational Software Architect
Current Time: Sat Jul 26 08:06:08 EDT 2025
Powered by FUDForum. Page generated in 0.13532 seconds
