Home » Modeling » UML2 » Using UML2 mechanism
Using UML2 mechanism [message #477852] Tue, 21 October 2008 01:45 Go to next message
Originally posted by: florianwendland.freenet.de
Salute,
i've a similar question as Timothy. I followed his discussions, and it seems
that we want to do exactly the same at the same time... sometimes it is very
mystical :)
Back to business:
I have an UML2 model with some union/subsets relationships and i want to
realize these mechanisms in the resulting Ecore, like it is done in the
wonderful UML2 project. I've introspected the uml2 sources but didn't found
an hint how to include the UML2 generator instead of the ordinary EMF one,
which doesn't care about union/subsets. Is there somewhere an article
outthere, how to integrate this code generator?
Any help would be appreciated.
Marc-Florian
Re: Using UML2 mechanism [message #477853 is a reply to message #477852] Tue, 21 October 2008 05:03 Go to previous messageGo to next message
Marc-Florian,
Here's what I would try as a simple "hack". Open the *.genmodel,
change the xmlns:genmodel's namespace to
http://www.eclipse.org/uml2/2.2.0/GenModel and then see how it goes.
"Reloading..." this model will continue to create the UML2 derived GenModel.
Marc-Florian Wendland wrote:
> Salute,
> mystical :)
> Back to business:
> Marc-Florian
Re: Using UML2 mechanism [message #477854 is a reply to message #477853] Tue, 21 October 2008 06:25 Go to previous messageGo to next message
Dear Ed,
i've done this instincly by myself before. And i've explored the same
phenomenon like Timothy. It is possible to construct a model hierarchy with
the generated editor, but once you have serialized it and try to reopen it,
it fails with the exception:
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException:
org.eclipse.emf.ecore.xmi.IllegalValueException: Value
'subset.test.impl.AImpl@192322e' is not legal.
(platform:/resource/de/My2.test, -1, -1)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:315)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:274)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
at subset.test.presentation.TestEditor.createModel(TestEditor.j ava:952)
at subset.test.presentation.TestEditor.createPages(TestEditor.j ava:1009)
at
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:310)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:428)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:30 6)
at
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:180)
at
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:270)
at
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:473)
at
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 08)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
at
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
at
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:217)
at
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:207)
at
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:779)
at
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:678)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:639)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2817)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2729)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2721)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2673)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2668)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2652)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2643)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:646)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:605)
at
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:318)
at
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:160)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:22 8)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:20 7)
at
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:274)
at
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:250)
at
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:363)
at
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 5.open(PackageExplorerPart.java:603)
at
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:820)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:818)
at
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1079)
at
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1183)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Caused by: org.eclipse.emf.ecore.xmi.IllegalValueException: Value
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XM LHandler.java:2647)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleForwardRefer ences(XMLHandler.java:1135)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.endDocument(XMLHan dler.java:1214)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .endDocument(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
Source)
at
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
Source)
at
com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown
Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1445)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1241)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
... 79 more
Caused by: java.lang.UnsupportedOperationException
at
org.eclipse.uml2.common.util.DerivedEObjectEList$DerivedList Iterator.add(DerivedEObjectEList.java:278)
//cannot resolve the subsets?
at java.util.AbstractSequentialList.add(Unknown Source)
at
org.eclipse.uml2.common.util.DerivedEObjectEList.addUnique(D erivedEObjectEList.java:636)
at
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHel perImpl.java:1192)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XM LHandler.java:2642)
... 95 more
All the DerivedUnion-List are generated, but the genmodel didn't produce the
SupersetSupset-Lists. Instead of, ordinary EMF-Lists are used. I think,
that's the problem, because all the elements, which are participating in the
Union-Relationship of the root element (like UML::Element) couldn't be
computed, since the wrong List-type was selected.
May be it is possible to send one member of the UML2 project this simple
model, because i have to solve this problem for my masterthesis... does
anyone of this project has the interest to solve this problem with me?
Thanks for answering
Marc-Florian
"Ed Merks" <Ed.Merks@gmail.com> schrieb im Newsbeitrag
news:gdk5sb$3b2$1@build.eclipse.org...
> Marc-Florian,
> Here's what I would try as a simple "hack". Open the *.genmodel, change
> GenModel.
>> Salute,
>> seems that we want to do exactly the same at the same time... sometimes
>> it is very mystical :)
>> Back to business:
>> found an hint how to include the UML2 generator instead of the ordinary
>> EMF one, which doesn't care about union/subsets. Is there somewhere an
>> article outthere, how to integrate this code generator?
>> Marc-Florian
Re: Using UML2 mechanism [message #477855 is a reply to message #477854] Tue, 21 October 2008 06:46 Go to previous messageGo to next message
--------------030107000009080307050307
Marc-Florian,
It's likely that folks will want to be able to reproduce this problem.
Could you share a test case?
> Dear Ed,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> ... 79 more
> at
> at
> at
> at
> ... 95 more
> Marc-Florian
>> Marc-Florian,
>> GenModel.
>>> Salute,
>>> Back to business:
>>> Marc-Florian
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Marc-Florian,<br>
<br>
It's likely that folks will want to be able to reproduce this problem.&nbsp;
Could you share a test case?<br>
<br>
<br>
<blockquote cite="mid:gdkajc$kq1$1@build.eclipse.org" type="cite">
<pre wrap="">Dear Ed,
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
Source)
at
at
at
at
at
... 79 more
at
at
at
at
... 95 more
Marc-Florian
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:Ed.Merks@gmail.com">&lt;Ed.Merks@gmail.com&gt;</a> schrieb im Newsbeitrag
<a class="moz-txt-link-freetext" href="news:gdk5sb$3b2$1@build.eclipse.org">news:gdk5sb$3b2$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Marc-Florian,
<a class="moz-txt-link-freetext" href="http://www.eclipse.org/uml2/2.2.0/GenModel">http://www.eclipse.org/uml2/2.2.0/GenModel</a> and then see how it goes.
GenModel.
</pre>
<pre wrap="">Salute,
Back to business:
Marc-Florian
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------030107000009080307050307--
Re: Using UML2 mechanism [message #477856 is a reply to message #477855] Tue, 21 October 2008 06:54 Go to previous messageGo to next message
------=_NextPart_000_00D6_01C9337C.249F49F0
Content-Type: multipart/alternative;
boundary="----=_NextPart_001_00D7_01C9337C.249F49F0"
------=_NextPart_001_00D7_01C9337C.249F49F0
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Ed,
what kind of test case. I think th easiest way to reproduce this is to =
propagate the genmodel and ecore files, isn't it? I've attached them.
Marc-Florian
"Ed Merks" <Ed.Merks@gmail.com> schrieb im Newsbeitrag =
news:gdkbtd$vqh$1@build.eclipse.org...
Marc-Florian,
It's likely that folks will want to be able to reproduce this problem. =
Marc-Florian Wendland wrote:=20
Dear Ed,
i've done this instincly by myself before. And i've explored the same=20
phenomenon like Timothy. It is possible to construct a model hierarchy =
with=20
the generated editor, but once you have serialized it and try to reopen =
it,=20
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedExc=
eption:=20
org.eclipse.emf.ecore.xmi.IllegalValueException: Value=20
'subset.test.impl.AImpl@192322e' is not legal.=20
at=20
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadExcep=
at=20
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(Reso=
at=20
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceS=
etImpl.java:397)
at =
at=20
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditor=
Part.java:310)
at=20
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.=
java:661)
at=20
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:4=
28)
at=20
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartRefer=
ence.java:594)
at=20
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(Presenta=
blePart.java:180)
at=20
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(P=
at=20
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(Lef=
at=20
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.select=
at=20
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.=
java:1256)
at=20
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer=
..java:63)
at=20
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.jav=
a:217)
at=20
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:=
207)
at=20
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:=
779)
at=20
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorMana=
ger.java:678)
at =
at=20
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage=
..java:2817)
at=20
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2=
729)
at =
at =
at =
at=20
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2668)=
at=20
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2652)=
at=20
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2643)=
at=20
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorU=
tility.java:318)
at=20
tility.java:160)
at=20
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionD=
at=20
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchA=
ction.java:250)
at=20
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handle=
at=20
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 5.open(Packag=
at=20
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:82=
0)
at=20
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java=
:818)
at=20
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.ja=
va:1079)
at=20
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.=
java:1183)
at =
at =
at=20
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:2=
88)
at=20
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:48=
8)
at=20
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplicati=
on.java:113)
at=20
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.ja=
va:193)
at=20
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplicati=
at=20
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(Eclips=
at=20
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:3=
82)
at=20
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:1=
79)
Caused by: org.eclipse.emf.ecore.xmi.IllegalValueException: Value=20
at=20
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XM LHandler.java=
:2647)
at=20
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleForwardRefer ences(XMLHand=
ler.java:1135)
at=20
org.eclipse.emf.ecore.xmi.impl.XMLHandler.endDocument(XMLHan dler.java:121=
4)
at=20
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .endDocument(=
Unknown=20
Source)
at=20
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.sc=
anDocument(Unknown=20
Source)
at=20
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unkno=
wn=20
Source)
at=20
wn=20
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown=20
Source)
at=20
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknow=
n=20
Source)
at=20
com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse=
(Unknown=20
Source)
at =
at=20
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.jav=
a:180)
at=20
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1=
445)
at=20
241)
at=20
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSe=
tImpl.java:255)
at=20
... 79 more
at=20
org.eclipse.uml2.common.util.DerivedEObjectEList$DerivedList Iterator.add(=
DerivedEObjectEList.java:278)=20
at=20
org.eclipse.uml2.common.util.DerivedEObjectEList.addUnique(D erivedEObject=
EList.java:636)
at=20
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHel perImpl.java:=
1192)
at=20
:2642)
... 95 more
All the DerivedUnion-List are generated, but the genmodel didn't produce =
the=20
SupersetSupset-Lists. Instead of, ordinary EMF-Lists are used. I think,=20
that's the problem, because all the elements, which are participating in =
the=20
Union-Relationship of the root element (like UML::Element) couldn't be=20
May be it is possible to send one member of the UML2 project this simple =
model, because i have to solve this problem for my masterthesis... does=20
Marc-Florian
"Ed Merks" <Ed.Merks@gmail.com> schrieb im Newsbeitrag=20
Marc-Florian,
Here's what I would try as a simple "hack". Open the *.genmodel, =
change=20
the xmlns:genmodel's namespace to=20
http://www.eclipse.org/uml2/2.2.0/GenModel and then see how it goes.=20
"Reloading..." this model will continue to create the UML2 derived=20
GenModel.
Salute,
i've a similar question as Timothy. I followed his discussions, and it=20
seems that we want to do exactly the same at the same time... sometimes=20
Back to business:
I have an UML2 model with some union/subsets relationships and i want to =
realize these mechanisms in the resulting Ecore, like it is done in the=20
wonderful UML2 project. I've introspected the uml2 sources but didn't=20
found an hint how to include the UML2 generator instead of the ordinary=20
EMF one, which doesn't care about union/subsets. Is there somewhere an=20
Marc-Florian
=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.2900.5659" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>what kind of test case. I think th =
easiest way to=20
reproduce this is to propagate the genmodel and ecore files, isn't it? =
I've=20
attached them.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Marc-Florian</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" &lt;<A=20
href=3D"mailto:Ed.Merks@gmail.com">Ed.Merks@gmail.com</A>&gt; schrieb =
im=20
Newsbeitrag <A=20
href=3D"news:gdkbtd$vqh$1@build.eclipse.org">news:gdkbtd$vqh$1@build.ecli=
pse.org</A>...</DIV>Marc-Florian,<BR><BR>It's=20
likely that folks will want to be able to reproduce this =
problem.&nbsp; Could=20
you share a test case?<BR><BR><BR>Marc-Florian Wendland wrote:=20
<BLOCKQUOTE cite=3Dmid:gdkajc$kq1$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Dear Ed,
with=20
it,=20
eption:=20
at=20
at=20
at=20
etImpl.java:397)
at =
at=20
Part.java:310)
at=20
java:661)
at=20
28)
at=20
ence.java:594)
at=20
blePart.java:180)
at=20
at=20
at=20
at=20
java:1256)
at=20
..java:63)
at=20
a:217)
at=20
207)
at=20
779)
at=20
ger.java:678)
at =
at=20
..java:2817)
at=20
729)
at =
at =
at =
at=20
at=20
at=20
at=20
tility.java:318)
at=20
tility.java:160)
at=20
at=20
ction.java:250)
at=20
at=20
at=20
0)
at=20
:818)
at=20
va:1079)
at=20
java:1183)
at =
at =
at=20
88)
at=20
8)
at=20
on.java:113)
at=20
va:193)
at=20
at=20
at=20
82)
at=20
79)
at=20
:2647)
at=20
ler.java:1135)
at=20
4)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at =
at=20
a:180)
at=20
445)
at=20
241)
at=20
tImpl.java:255)
at=20
... 79 more
at=20
at=20
EList.java:636)
at=20
1192)
at=20
:2642)
... 95 more
the=20
the=20
Marc-Florian
"Ed Merks" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:Ed.Merks@gmail.com">&lt;Ed.Merks@gmail.com&gt;</A> =
<A class=3Dmoz-txt-link-freetext =
href=3D"news:gdk5sb$3b2$1@build.eclipse.org">news:gdk5sb$3b2$1@build.ecli=
pse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Marc-Florian,
change=20
href=3D"http://www.eclipse.org/uml2/2.2.0/GenModel">http://www.eclipse.or=
g/uml2/2.2.0/GenModel</A> and then see how it goes.=20
GenModel.
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Salute,
Back to business:
Marc-Florian
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->
</PRE></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_001_00D7_01C9337C.249F49F0--
Content-Type: application/octet-stream;
name="Ohne_Titel1.genmodel"
filename="Ohne_Titel1.genmodel"
<?xml version=3D"1.0" encoding=3D"UTF-8"?>
<genmodel:GenModel xmi:version=3D"2.0"
xmlns:xmi=3D"http://www.omg.org/XMI" =
xmlns:xsi=3D"http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore=3D"http://www.eclipse.org/emf/2002/Ecore" =
xmlns:genmodel=3D"http://www.eclipse.org/uml2/2.2.0/GenModel" =
modelDirectory=3D"/x/src"
modelPluginID=3D"x" modelName=3D"Ohne_Titel1" =
importerID=3D"org.eclipse.uml2.uml.ecore.importer"
complianceLevel=3D"6.0" suppressGenModelAnnotations=3D"false" =
copyrightFields=3D"false"
factoryMethods=3D"true" pluralizedGetters=3D"true" =
cacheAdapterSupport=3D"true" invariantPrefix=3D"validate">
<genAnnotations =
source=3D" http://www.eclipse.org/emf/2002/GenModel/importer/org.eclips e.u=
ml2.uml.ecore.importer">
<details key=3D"ECORE_TAGGED_VALUES" value=3D"PROCESS"/>
<details key=3D"UNION_PROPERTIES" value=3D"PROCESS"/>
<details key=3D"DUPLICATE_FEATURES" value=3D"DISCARD"/>
<details key=3D"SUBSETTING_PROPERTIES" value=3D"PROCESS"/>
<details key=3D"COMMENTS" value=3D"PROCESS"/>
<details key=3D"DUPLICATE_FEATURE_INHERITANCE" value=3D"DISCARD"/>
<details key=3D"DUPLICATE_OPERATIONS" value=3D"DISCARD"/>
<details key=3D"INVARIANT_CONSTRAINTS" value=3D"PROCESS"/>
<details key=3D"REDEFINING_PROPERTIES" value=3D"PROCESS"/>
<details key=3D"ANNOTATION_DETAILS" value=3D"PROCESS"/>
<details key=3D"DUPLICATE_OPERATION_INHERITANCE" value=3D"DISCARD"/>
<details key=3D"REDEFINING_OPERATIONS" value=3D"PROCESS"/>
<details key=3D"DERIVED_FEATURES" value=3D"PROCESS"/>
<details key=3D"OPERATION_BODIES" value=3D"PROCESS"/>
<details key=3D"CAMEL_CASE_NAMES" value=3D"PROCESS"/>
<details key=3D"SUPER_CLASS_ORDER" value=3D"PROCESS"/>
</genAnnotations>
<foreignModel>../../t/model/x/Ohne_Titel1.uml</foreignModel >
<genPackages xsi:type=3D"genmodel:GenPackage" prefix=3D"Subset" =
disposableProviderFactory=3D"true"
ecorePackage=3D"subset.ecore#/">
<nestedGenPackages xsi:type=3D"genmodel:GenPackage" =
prefix=3D"UmlStandardProfile"
basePackage=3D"subset" disposableProviderFactory=3D"true" =
ecorePackage=3D"subset.ecore#//umlStandardProfile"/>
<nestedGenPackages xsi:type=3D"genmodel:GenPackage" prefix=3D"Test" =
ecorePackage=3D"subset.ecore#//test">
<genClasses xsi:type=3D"genmodel:GenClass" =
ecoreClass=3D"subset.ecore#//test/ModelElement">
<genFeatures xsi:type=3D"genmodel:GenFeature" =
property=3D"Readonly" notify=3D"false"
createChild=3D"false" ecoreFeature=3D"ecore:EReference =
subset.ecore#//test/ModelElement/ownedElements"/>
subset.ecore#//test/ModelElement/owner"/>
</genClasses>
ecoreClass=3D"subset.ecore#//test/A">
<genFeatures xsi:type=3D"genmodel:GenFeature" property=3D"None" =
children=3D"true"
createChild=3D"true" ecoreFeature=3D"ecore:EReference =
subset.ecore#//test/A/theB"/>
</genClasses>
ecoreClass=3D"subset.ecore#//test/B">
notify=3D"false"
subset.ecore#//test/B/theA"/>
</genClasses>
ecoreClass=3D"subset.ecore#//test/C"/>
</nestedGenPackages>
</genPackages>
</genmodel:GenModel>
name="subset.ecore"
filename="subset.ecore"
<ecore:EPackage xmi:version=3D"2.0"
name=3D"subset"
nsURI=3D"http:///subset.ecore" nsPrefix=3D"subset">
<eAnnotations source=3D"http://www.eclipse.org/emf/2002/GenModel">
<details key=3D"documentation" =
value=3D"Author:mfw.&#xA;Created:19.10.08 =
22:22.&#xA;Title:.&#xA;Comment:.&#xA;"/>
</eAnnotations>
<eSubpackages name=3D"umlStandardProfile" =
nsURI=3D"http:///subset/umlStandardProfile.ecore"
nsPrefix=3D"subset.umlStandardProfile">
<details key=3D"documentation" value=3D"UML Standard Profile =
contains several popular stereotypes, tag definitions and constraints =
described in UML 1.4 and UML 2.0 Specifications."/>
</eAnnotations>
</eSubpackages>
<eSubpackages name=3D"test" nsURI=3D"http:///subset/test.ecore" =
nsPrefix=3D"subset.test">
<eClassifiers xsi:type=3D"ecore:EClass" name=3D"ModelElement">
<eStructuralFeatures xsi:type=3D"ecore:EReference" =
name=3D"ownedElements" ordered=3D"false"
upperBound=3D"-1" eType=3D"#//test/ModelElement" =
changeable=3D"false" volatile=3D"true"
derived=3D"true" eOpposite=3D"#//test/ModelElement/owner">
<eAnnotations source=3D"union"/>
</eStructuralFeatures>
<eStructuralFeatures xsi:type=3D"ecore:EReference" name=3D"owner" =
ordered=3D"false"
eType=3D"#//test/ModelElement" changeable=3D"false" =
volatile=3D"true" derived=3D"true"
eOpposite=3D"#//test/ModelElement/ownedElements">
</eClassifiers>
<eClassifiers xsi:type=3D"ecore:EClass" name=3D"A2" =
eSuperTypes=3D"#//test/ModelElement">
<eStructuralFeatures xsi:type=3D"ecore:EReference" name=3D"theC2" =
eType=3D"#//test/C"
containment=3D"true">
<eAnnotations source=3D"subsets" =
references=3D"#//test/ModelElement/ownedElements"/>
</eClassifiers>
<eClassifiers xsi:type=3D"ecore:EClass" name=3D"A" =
<eStructuralFeatures xsi:type=3D"ecore:EReference" name=3D"theB" =
ordered=3D"false"
upperBound=3D"-1" eType=3D"#//test/B" derived=3D"true" =
containment=3D"true" eOpposite=3D"#//test/B/theA">
<eStructuralFeatures xsi:type=3D"ecore:EReference" name=3D"theC" =
upperBound=3D"-1"
eType=3D"#//test/C" containment=3D"true">
</eClassifiers>
<eClassifiers xsi:type=3D"ecore:EClass" name=3D"B" =
<eStructuralFeatures xsi:type=3D"ecore:EReference" name=3D"theA" =
ordered=3D"false"
eType=3D"#//test/A" eOpposite=3D"#//test/A/theB">
references=3D"#//test/ModelElement/owner"/>
</eClassifiers>
<eClassifiers xsi:type=3D"ecore:EClass" name=3D"C" =
eSuperTypes=3D"#//test/ModelElement"/>
<eClassifiers xsi:type=3D"ecore:EClass" name=3D"Model" =
name=3D"modeableElements" upperBound=3D"-1"
eType=3D"#//test/ModelElement" containment=3D"true">
</eClassifiers>
</eSubpackages>
</ecore:EPackage>
------=_NextPart_000_00D6_01C9337C.249F49F0--
Re: Using UML2 mechanism [message #477857 is a reply to message #477856] Tue, 21 October 2008 07:29 Go to previous messageGo to next message
--------------000400060400000206070308
Marc-Florian,
Probably a union should be transient. Looking at the example, it seems
redundant to serialize a union. Worse than that in fact. I.e., given
these union features aren't changeable, serializing them seems like a
really bad idea...
> Ed,
> Marc-Florian
> "Ed Merks" <Ed.Merks@gmail.com <mailto:Ed.Merks@gmail.com>>
> schrieb im Newsbeitrag news:gdkbtd$vqh$1@build.eclipse.org...
> Marc-Florian,
> problem. Could you share a test case?
>> Dear Ed,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> ... 79 more
>> at
>> at
>> at
>> at
>> ... 95 more
>> Marc-Florian
>>> Marc-Florian,
>>> GenModel.
>>>> Salute,
>>>> Back to business:
>>>> Marc-Florian
<html>
<head>
</head>
Marc-Florian,<br>
<br>
Probably a union should be transient.&nbsp; Looking at the example, it seems
redundant to serialize a union.&nbsp; Worse than that in fact.&nbsp; I.e., given
really bad idea...<br>
<br>
<br>
<blockquote cite="mid:gdkc94$4qa$1@build.eclipse.org" type="cite">
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.2900.5659" name="GENERATOR">
<style></style>
<div><font face="Arial" size="2">Ed,</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">what kind of test case. I think th
easiest way to reproduce this is to propagate the genmodel and ecore
files, isn't it? I've attached them.</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">Marc-Florian</font></div>
<blockquote dir="ltr"
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Ed Merks" &lt;<a moz-do-not-send="true"
href="mailto:Ed.Merks@gmail.com">Ed.Merks@gmail.com</a>&gt; schrieb im
Newsbeitrag <a moz-do-not-send="true"
href="news:gdkbtd$vqh$1@build.eclipse.org">news:gdkbtd$vqh$1@build.eclipse.org</a>...</div>
Marc-Florian,<br>
<br>
<br>
<br>
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
Source)
at
at
at
at
at
... 79 more
at
at
at
at
... 95 more
Marc-Florian
"Ed Merks" <a moz-do-not-send="true" class="moz-txt-link-rfc2396E"
<a moz-do-not-send="true" class="moz-txt-link-freetext"
</pre>
GenModel.
</pre>
Back to business:
Marc-Florian
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
</blockquote>
</blockquote>
</body>
</html>
--------------000400060400000206070308--
Re: Using UML2 mechanism [message #477858 is a reply to message #477857] Tue, 21 October 2008 08:06 Go to previous messageGo to next message
------=_NextPart_000_0105_01C93386.32386240
boundary="----=_NextPart_001_0106_01C93386.32386240"
------=_NextPart_001_0106_01C93386.32386240
Dear Ed,
okay, that was a good point. 1-0 for you, as we say in Germany. But, my =
point was also very good, because the elements, which i wanted to be =
participating in the union, aren't be computed correctly. Only the top =
level children of the root element are computed as "ownedElements". And =
i really think, that this missbehaviour is a result of using the wrong =
List for computing the subsets. I've attached a simple model, which =
illustrates this missbehaviour. Here it is with no overhead:
Root
A
B
B
A2
C
while metamodel defines the references as follows:
Element
ownedElements (union)
owner (union)
owningModel(subsets owner)
Root : Element
modeableElements(subsets ownedElements)
A:Element
theB (subsets ownedElements)
B:Element
theA(subsets owner)
A2:Element
theC (subsets ownedElements)
C:Element
theA2 (subsets owner)
When i call getOwnedElements in the Root model, the result is 2. In uml2 =
philosophie, this should be 5, because every containment reference is =
defined as a subset of the ownedElements reference, hence, the =
references should contribute themself into the derived union =
relationship. But this isn't done... and again, i think this relates to =
the choice of the generated lists. But i'm really not sure. If i would =
know, why this approach fails, i wouldn't post here :-)
Marc-Florian
news:gdkedv$trt$1@build.eclipse.org...
Marc-Florian,
Probably a union should be transient. Looking at the example, it =
seems redundant to serialize a union. Worse than that in fact. I.e., =
given these union features aren't changeable, serializing them seems =
like a really bad idea...
Ed,
what kind of test case. I think th easiest way to reproduce this is =
to propagate the genmodel and ecore files, isn't it? I've attached them.
Marc-Florian
Marc-Florian,
It's likely that folks will want to be able to reproduce this =
Dear Ed,
with=20
it,=20
eption:=20
at=20
at=20
at=20
etImpl.java:397)
at =
at=20
Part.java:310)
at=20
java:661)
at=20
28)
at=20
ence.java:594)
at=20
blePart.java:180)
at=20
at=20
at=20
at=20
java:1256)
at=20
..java:63)
at=20
a:217)
at=20
207)
at=20
779)
at=20
ger.java:678)
at =
at=20
..java:2817)
at=20
729)
at =
at =
at =
at=20
at=20
at=20
at=20
tility.java:318)
at=20
tility.java:160)
at=20
at=20
ction.java:250)
at=20
at=20
at=20
0)
at=20
:818)
at=20
va:1079)
at=20
java:1183)
at =
at =
at=20
88)
at=20
8)
at=20
on.java:113)
at=20
va:193)
at=20
at=20
at=20
82)
at=20
79)
at=20
:2647)
at=20
ler.java:1135)
at=20
4)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at =
at=20
a:180)
at=20
445)
at=20
241)
at=20
tImpl.java:255)
at=20
... 79 more
at=20
at=20
EList.java:636)
at=20
1192)
at=20
:2642)
... 95 more
the=20
the=20
Marc-Florian
Marc-Florian,
change=20
GenModel.
Salute,
Back to business:
Marc-Florian
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.5659" name=3DGENERATOR></HEAD>
<DIV><FONT face=3DArial size=3D2>Dear Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>okay, that was a good point. 1-0 for =
you, as we say=20
in Germany. But, my point was also very good, because the elements, =
which i=20
wanted to be participating in the union, aren't be computed correctly. =
Only the=20
top level children of the root element are computed as "ownedElements". =
And i=20
List for=20
computing the subsets. I've attached a simple model, which illustrates =
this=20
missbehaviour. Here it is with no overhead:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Root</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; A</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;=20
B</FONT></DIV>
B</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; A2</FONT></DIV>
C</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>while metamodel defines the references =
as=20
follows:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Element</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; ownedElements=20
(union)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; owner =
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; owningModel(subsets=20
owner)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Root : Element</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; =
modeableElements(subsets=20
ownedElements)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>A:Element</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; theB (subsets=20
<DIV><FONT face=3DArial size=3D2>B:Element</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; theA(subsets =
owner)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>A2:Element</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; theC (subsets=20
<DIV><FONT face=3DArial size=3D2>C:Element</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; theA2 (subsets=20
owner)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>When i call getOwnedElements in the =
Root model, the=20
result is 2. In uml2 philosophie, this should be 5, because every =
containment=20
reference is defined as a subset of the ownedElements reference, hence, =
the=20
relationship. But=20
this isn't done... and again, i think this relates to the choice of the=20
generated lists. But i'm really not sure. If i would know, why this =
approach=20
fails, i wouldn't post here :-)</FONT></DIV>
im=20
Newsbeitrag <A=20
href=3D"news:gdkedv$trt$1@build.eclipse.org">news:gdkedv$trt$1@build.ecli=
pse.org</A>...</DIV>Marc-Florian,<BR><BR>Probably=20
a union should be transient.&nbsp; Looking at the example, it seems =
redundant=20
to serialize a union.&nbsp; Worse than that in fact.&nbsp; I.e., given =
these=20
union features aren't changeable, serializing them seems like a really =
bad=20
idea...<BR><BR><BR>Marc-Florian Wendland wrote:=20
<BLOCKQUOTE cite=3Dmid:gdkc94$4qa$1@build.eclipse.org type=3D"cite">
<STYLE></STYLE>
<DIV>&nbsp;</DIV>
easiest way=20
to reproduce this is to propagate the genmodel and ecore files, =
isn't it?=20
I've attached them.</FONT></DIV>
<DIV>&nbsp;</DIV>
BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" &lt;<A href=3D"mailto:Ed.Merks@gmail.com"=20
moz-do-not-send=3D"true">Ed.Merks@gmail.com</A>&gt; schrieb im =
Newsbeitrag=20
<A href=3D"news:gdkbtd$vqh$1@build.eclipse.org"=20
moz-do-not-send=3D"true">news:gdkbtd$vqh$1@build.eclipse.org</A>...</DIV>=
problem.&nbsp;=20
Could you share a test case?<BR><BR><BR>Marc-Florian Wendland =
wrote:=20
with=20
it,=20
eption:=20
at=20
at=20
at=20
etImpl.java:397)
at =
at=20
Part.java:310)
at=20
java:661)
at=20
28)
at=20
ence.java:594)
at=20
blePart.java:180)
at=20
at=20
at=20
at=20
java:1256)
at=20
..java:63)
at=20
a:217)
at=20
207)
at=20
779)
at=20
ger.java:678)
at =
at=20
..java:2817)
at=20
729)
at =
at =
at =
at=20
at=20
at=20
at=20
tility.java:318)
at=20
tility.java:160)
at=20
at=20
ction.java:250)
at=20
at=20
at=20
0)
at=20
:818)
at=20
va:1079)
at=20
java:1183)
at =
at =
at=20
88)
at=20
8)
at=20
on.java:113)
at=20
va:193)
at=20
at=20
at=20
82)
at=20
79)
at=20
:2647)
at=20
ler.java:1135)
at=20
4)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at =
at=20
a:180)
at=20
445)
at=20
241)
at=20
tImpl.java:255)
at=20
... 79 more
at=20
at=20
EList.java:636)
at=20
1192)
at=20
:2642)
... 95 more
the=20
the=20
Marc-Florian
href=3D"mailto:Ed.Merks@gmail.com" =
moz-do-not-send=3D"true">&lt;Ed.Merks@gmail.com&gt;</A> schrieb im =
Newsbeitrag=20
href=3D"news:gdk5sb$3b2$1@build.eclipse.org" =
moz-do-not-send=3D"true">news:gdk5sb$3b2$1@build.eclipse.org</A>...
</PRE>
change=20
href=3D"http://www.eclipse.org/uml2/2.2.0/GenModel" =
moz-do-not-send=3D"true">http://www.eclipse.org/uml2/2.2.0/GenModel</A> =
GenModel.
</PRE>
Back to business:
Marc-Florian
</PRE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE ></BODY></HTML>
------=_NextPart_001_0106_01C93386.32386240--
name="My3.test"
filename="My3.test"
<subset.test:Model xmi:version=3D"2.0" =
xmlns:xsi=3D"http://www.w3.org/2001/XMLSchema-instance" =
xmlns:subset.test=3D"http:///subset/test.ecore">
<modeableElements xsi:type=3D"subset.test:A">
<theB/>
<theB/>
</modeableElements>
<modeableElements xsi:type=3D"subset.test:A2">
<theC2/>
</modeableElements>
</subset.test:Model>
------=_NextPart_000_0105_01C93386.32386240--
Re: Using UML2 mechanism [message #477859 is a reply to message #477858] Tue, 21 October 2008 08:13 Go to previous messageGo to next message
--------------080309010204070903070403
Marc-Florian,
Comments below.
> Dear Ed,
Darned, we're keeping score!
> But, my point was also very good, because the elements, which i wanted
I wouldn't know correct if I saw it. :-P
> Only the top level children of the root element are computed as
> "ownedElements". And i really think, that this missbehaviour is a
> result of using the wrong List for computing the subsets. I've
> attached a simple model, which illustrates this missbehaviour. Here it
> Root
> A
> B
> B
> A2
> C
> Element
> owner (union)
> Root : Element
> A:Element
> B:Element
> theA(subsets owner)
> A2:Element
> C:Element
> uml2 philosophie, this should be 5, because every containment
> hence, the references should contribute themself into the derived
> union relationship. But this isn't done... and again, i think this
> relates to the choice of the generated lists. But i'm really not sure.
> If i would know, why this approach fails, i wouldn't post here :-)
I think this require Kenn's attention because I've never learned these
concepts. I was hoping to live in ignorant bliss a little longer. :-P
> Marc-Florian
> schrieb im Newsbeitrag news:gdkedv$trt$1@build.eclipse.org...
> Marc-Florian,
> I.e., given these union features aren't changeable, serializing
> them seems like a really bad idea...
>> Ed,
>> is to propagate the genmodel and ecore files, isn't it? I've
>> attached them.
>> Marc-Florian
>> Marc-Florian,
>>> Dear Ed,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 79 more
>>> at
>>> at
>>> at
>>> at
>>> ... 95 more
>>> Marc-Florian
>>>> Marc-Florian,
>>>> GenModel.
>>>>> Salute,
>>>>> Back to business:
>>>>> Marc-Florian
<html>
<head>
</head>
Marc-Florian,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:gdkgfp$i3d$1@build.eclipse.org" type="cite">
<div><font face="Arial" size="2">Dear Ed,</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">okay, that was a good point. 1-0 for
you, as we say in Germany. </font></div>
</blockquote>
Darned, we're keeping score!<br>
<div><font face="Arial" size="2">But, my point was also very good,
because the elements, which i wanted to be participating in the union,
aren't be computed correctly.</font></div>
</blockquote>
I wouldn't know correct if I saw it. :-P<br>
<div><font face="Arial" size="2"> Only the top level children of the
root element are computed as "ownedElements". And i really think, that
this missbehaviour is a result of using the wrong List for computing
the subsets. I've attached a simple model, which illustrates this
missbehaviour. Here it is with no overhead:</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">Root</font></div>
<div><font face="Arial" size="2">&nbsp;&nbsp;&nbsp; A</font></div>
<div><font face="Arial" size="2">&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; B</font></div>
<div><font face="Arial" size="2">&nbsp;&nbsp;&nbsp; A2</font></div>
<div><font face="Arial" size="2">&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; C</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">while metamodel defines the
references as follows:</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">Element</font></div>
<div><font face="Arial" size="2">&nbsp;&nbsp;&nbsp; ownedElements (union)</font></div>
<div><font face="Arial" size="2">&nbsp;&nbsp;&nbsp; owner (union)</font></div>
<div><font face="Arial" size="2">&nbsp;&nbsp;&nbsp; owningModel(subsets owner)</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">Root : Element</font></div>
<div><font face="Arial" size="2">&nbsp;&nbsp;&nbsp; modeableElements(subsets
ownedElements)</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">A:Element</font></div>
<div><font face="Arial" size="2">&nbsp;&nbsp;&nbsp; theB (subsets ownedElements)</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">B:Element</font></div>
<div><font face="Arial" size="2">&nbsp;&nbsp;&nbsp; theA(subsets owner)</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">A2:Element</font></div>
<div><font face="Arial" size="2">&nbsp;&nbsp;&nbsp; theC (subsets ownedElements)</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">C:Element</font></div>
<div><font face="Arial" size="2">&nbsp;&nbsp;&nbsp; theA2 (subsets owner)</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">When i call getOwnedElements in the
Root model, the result is 2. In uml2 philosophie, this should be 5,
because every containment reference is defined as a subset of the
ownedElements reference, hence, the references should contribute
themself into the derived union relationship. But this isn't done...
and again, i think this relates to the choice of the generated lists.
But i'm really not sure. If i would know, why this approach fails, i
wouldn't post here :-)</font></div>
</blockquote>
concepts.&nbsp; I was hoping to live in ignorant bliss a little longer. :-P<br>
<div>&nbsp;</div>
href="news:gdkedv$trt$1@build.eclipse.org">news:gdkedv$trt$1@build.eclipse.org</a>...</div>
Marc-Florian,<br>
<br>
<br>
<br>
<style></style>
<div>&nbsp;</div>
th easiest way to reproduce this is to propagate the genmodel and ecore
<div>&nbsp;</div>
<div>"Ed Merks" &lt;<a href="mailto:Ed.Merks@gmail.com"
moz-do-not-send="true">Ed.Merks@gmail.com</a>&gt; schrieb im
Newsbeitrag <a href="news:gdkbtd$vqh$1@build.eclipse.org"
moz-do-not-send="true">news:gdkbtd$vqh$1@build.eclipse.org</a>...</div>
Marc-Florian,<br>
<br>
<br>
<br>
type="cite">
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
Source)
at
at
at
at
at
... 79 more
at
at
at
at
... 95 more
Marc-Florian
href="mailto:Ed.Merks@gmail.com" moz-do-not-send="true">&lt;Ed.Merks@gmail.com&gt;</a> schrieb im Newsbeitrag
href="news:gdk5sb$3b2$1@build.eclipse.org" moz-do-not-send="true">news:gdk5sb$3b2$1@build.eclipse.org</a>...
</pre>
moz-do-not-send="true">http://www.eclipse.org/uml2/2.2.0/GenModel</a> and then see how it goes.
GenModel.
</pre>
Back to business:
Marc-Florian
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</body>
</html>
--------------080309010204070903070403--
Re: Using UML2 mechanism [message #477860 is a reply to message #477859] Tue, 21 October 2008 10:54 Go to previous messageGo to next message
------=_NextPart_000_003B_01C9336B.57CFE750
... comments below ...
"Ed Merks" <Ed.Merks@gmail.com> wrote in message =
news:gdkh14$ms1$1@build.eclipse.org...
Marc-Florian,
Comments below.
Dear Ed,
okay, that was a good point. 1-0 for you, as we say in Germany.=20
But, my point was also very good, because the elements, which i =
Only the top level children of the root element are computed as =
"ownedElements". And i really think, that this missbehaviour is a result =
of using the wrong List for computing the subsets. I've attached a =
simple model, which illustrates this missbehaviour. Here it is with no =
overhead:
Root
A
B
B
A2
C
Element
owner (union)
Root : Element
A:Element
B:Element
theA(subsets owner)
A2:Element
C:Element
When i call getOwnedElements in the Root model, the result is 2. In =
uml2 philosophie, this should be 5, because every containment reference =
is defined as a subset of the ownedElements reference, hence, the =
I think this require Kenn's attention because I've never learned these =
[James] Without a doubt, Kenn is the master of subsets and derived =
unions but in my humble opinion, calling getOwnedElements in the root =
model and retrieving 2 elements is fine. This can be considered all the =
"direct" owned elements. If you want all the direct and indirect =
elements a special query, allOwnedElements, is defined in the spec. =
see section 7.3.14 in the "Additional Operations" section.
Marc-Florian
Marc-Florian,
Ed,
what kind of test case. I think th easiest way to reproduce this =
is to propagate the genmodel and ecore files, isn't it? I've attached =
them.
Marc-Florian
Marc-Florian,
Dear Ed,
with=20
it,=20
eption:=20
at=20
at=20
at=20
etImpl.java:397)
at =
at=20
Part.java:310)
at=20
java:661)
at=20
28)
at=20
ence.java:594)
at=20
blePart.java:180)
at=20
at=20
at=20
at=20
java:1256)
at=20
..java:63)
at=20
a:217)
at=20
207)
at=20
779)
at=20
ger.java:678)
at =
at=20
..java:2817)
at=20
729)
at =
at =
at =
at=20
at=20
at=20
at=20
tility.java:318)
at=20
tility.java:160)
at=20
at=20
ction.java:250)
at=20
at=20
at=20
0)
at=20
:818)
at=20
va:1079)
at=20
java:1183)
at =
at =
at=20
88)
at=20
8)
at=20
on.java:113)
at=20
va:193)
at=20
at=20
at=20
82)
at=20
79)
at=20
:2647)
at=20
ler.java:1135)
at=20
4)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at =
at=20
a:180)
at=20
445)
at=20
241)
at=20
tImpl.java:255)
at=20
... 79 more
at=20
at=20
EList.java:636)
at=20
1192)
at=20
:2642)
... 95 more
the=20
the=20
Marc-Florian
Marc-Florian,
change=20
GenModel.
Salute,
Back to business:
Marc-Florian
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.3395" name=3DGENERATOR></HEAD>
<DIV><FONT face=3DArial size=3D2>.. comments below ...</FONT></DIV>
href=3D"mailto:Ed.Merks@gmail.com">Ed.Merks@gmail.com</A>&gt; wrote in =
message=20
<A=20
href=3D"news:gdkh14$ms1$1@build.eclipse.org">news:gdkh14$ms1$1@build.ecli=
pse.org</A>...</DIV>Marc-Florian,<BR><BR>Comments=20
below.<BR><BR>Marc-Florian Wendland wrote:=20
<BLOCKQUOTE cite=3Dmid:gdkgfp$i3d$1@build.eclipse.org type=3D"cite">
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>okay, that was a good point. 1-0 =
for you, as we=20
say in Germany. </FONT></DIV></BLOCKQUOTE>Darned, we're keeping =
score!<BR>
<DIV><FONT face=3DArial size=3D2>But, my point was also very good, =
because the=20
elements, which i wanted to be participating in the union, aren't be =
computed correctly.</FONT></DIV></BLOCKQUOTE>I wouldn't know correct =
if I saw=20
it. :-P<BR>
<DIV><FONT face=3DArial size=3D2>Only the top level children of the =
root element=20
are computed as "ownedElements". And i really think, that this =
missbehaviour=20
is a result of using the wrong List for computing the subsets. I've =
attached=20
a simple model, which illustrates this missbehaviour. Here it is =
with no=20
<DIV>&nbsp;</DIV>
B</FONT></DIV>
B</FONT></DIV>
C</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>while metamodel defines the =
references as=20
<DIV>&nbsp;</DIV>
owner)</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; theA(subsets=20
owner)</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
owner)</FONT></DIV>
<DIV>&nbsp;</DIV>
Root model,=20
the result is 2. In uml2 philosophie, this should be 5, because =
every=20
containment reference is defined as a subset of the ownedElements =
reference,=20
hence, the references should contribute themself into the derived =
union=20
relationship. But this isn't done... and again, i think this relates =
to the=20
know, why=20
this approach fails, i wouldn't post here =
:-)</FONT></DIV></BLOCKQUOTE>
<DIV>I think this require Kenn's attention because I've never learned =
these=20
concepts.&nbsp; I was hoping to live in ignorant bliss a little =
longer.=20
:-P</DIV>
<DIV><BR>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>[James]&nbsp;&nbsp; =
Witho</FONT><FONT=20
face=3DArial size=3D2>ut a doubt, Kenn is the master of subsets and =
derived=20
unions but in my humble opinion, calling getOwnedElements in the =
root model=20
and retrieving 2 elements is fine.&nbsp; This can be considered all =
the=20
"direct" owned elements. &nbsp;&nbsp;&nbsp;If you want all the =
direct and=20
indirect elements a special query, <EM>allOwnedElements, =
</EM>&nbsp;is=20
defined in the spec.&nbsp; see section 7.3.14 in the "Additional =
Operations"=20
section.</FONT></DIV>
Newsbeitrag=20
<A href=3D"news:gdkedv$trt$1@build.eclipse.org"=20
moz-do-not-send=3D"true">news:gdkedv$trt$1@build.eclipse.org</A>...</DIV>=
a union should be transient.&nbsp; Looking at the example, it =
seems=20
redundant to serialize a union.&nbsp; Worse than that in =
fact.&nbsp; I.e.,=20
given these union features aren't changeable, serializing them =
seems like=20
a really bad idea...<BR><BR><BR>Marc-Florian Wendland wrote:=20
<BLOCKQUOTE cite=3Dmid:gdkc94$4qa$1@build.eclipse.org =
type=3D"cite">
<STYLE></STYLE>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>what kind of test case. I think =
th easiest=20
way to reproduce this is to propagate the genmodel and ecore =
files,=20
isn't it? I've attached them.</FONT></DIV>
<DIV>&nbsp;</DIV>
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: =
5px; BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
Newsbeitrag <A href=3D"news:gdkbtd$vqh$1@build.eclipse.org"=20
likely that folks will want to be able to reproduce this=20
problem.&nbsp; Could you share a test =
case?<BR><BR><BR>Marc-Florian=20
Wendland wrote:=20
with=20
it,=20
eption:=20
at=20
at=20
at=20
etImpl.java:397)
at =
at=20
Part.java:310)
at=20
java:661)
at=20
28)
at=20
ence.java:594)
at=20
blePart.java:180)
at=20
at=20
at=20
at=20
java:1256)
at=20
..java:63)
at=20
a:217)
at=20
207)
at=20
779)
at=20
ger.java:678)
at =
at=20
..java:2817)
at=20
729)
at =
at =
at =
at=20
at=20
at=20
at=20
tility.java:318)
at=20
tility.java:160)
at=20
at=20
ction.java:250)
at=20
at=20
at=20
0)
at=20
:818)
at=20
va:1079)
at=20
java:1183)
at =
at =
at=20
88)
at=20
8)
at=20
on.java:113)
at=20
va:193)
at=20
at=20
at=20
82)
at=20
79)
at=20
:2647)
at=20
ler.java:1135)
at=20
4)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at =
at=20
a:180)
at=20
445)
at=20
241)
at=20
tImpl.java:255)
at=20
... 79 more
at=20
at=20
EList.java:636)
at=20
1192)
at=20
:2642)
... 95 more
the=20
the=20
Marc-Florian
Newsbeitrag=20
</PRE>
change=20
GenModel.
</PRE>
Back to business:
Marc-Florian
</PRE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE ></BLOCKQUOTE></=
------=_NextPart_000_003B_01C9336B.57CFE750--
Re: Using UML2 mechanism [message #477862 is a reply to message #477860] Tue, 21 October 2008 14:28 Go to previous messageGo to next message
------=_NextPart_000_0052_01C933BB.994819F0
Dear James,
dear Ed,
the allOwnedElements is an option, that's right.=20
I just thought, that the content of the union ownedElements would =
include any element, that participate in that relationship via subset =
mechanism, in whatever hierarchy level they are defined. But the way it =
now works isn't so far from that, what i've expected. I've tried to add =
a containment relationship that doesn't participate in the ownedElement =
relationship and it wasn't selected, when i call getOwnedElements(). So =
far so good.
May be, i got a wrong imagination from the union/subsets mechanism.=20
Thanks=20
Marc-Florian
"James Bruck" <jbruck@ca.ibm.com> schrieb im Newsbeitrag =
news:gdkqbh$tk3$1@build.eclipse.org...
Marc-Florian,
Comments below.
Dear Ed,
overhead:
Root
A
B
B
A2
C
Element
owner (union)
Root : Element
A:Element
B:Element
theA(subsets owner)
A2:Element
C:Element
When i call getOwnedElements in the Root model, the result is 2. =
In uml2 philosophie, this should be 5, because every containment =
the references should contribute themself into the derived union =
these concepts. I was hoping to live in ignorant bliss a little longer. =
:-P
=20
[James] Without a doubt, Kenn is the master of subsets and =
derived unions but in my humble opinion, calling getOwnedElements in the =
root model and retrieving 2 elements is fine. This can be considered =
all the "direct" owned elements. If you want all the direct and =
indirect elements a special query, allOwnedElements, is defined in the =
spec. see section 7.3.14 in the "Additional Operations" section.
Marc-Florian
Marc-Florian,
Probably a union should be transient. Looking at the example, =
it seems redundant to serialize a union. Worse than that in fact. =
I.e., given these union features aren't changeable, serializing them =
Ed,
what kind of test case. I think th easiest way to reproduce =
this is to propagate the genmodel and ecore files, isn't it? I've =
attached them.
Marc-Florian
Marc-Florian,
It's likely that folks will want to be able to reproduce =
this problem. Could you share a test case?
Dear Ed,
with=20
it,=20
eption:=20
at=20
at=20
at=20
etImpl.java:397)
at =
at=20
Part.java:310)
at=20
java:661)
at=20
28)
at=20
ence.java:594)
at=20
blePart.java:180)
at=20
at=20
at=20
at=20
java:1256)
at=20
..java:63)
at=20
a:217)
at=20
207)
at=20
779)
at=20
ger.java:678)
at =
at=20
..java:2817)
at=20
729)
at =
at =
at =
at=20
at=20
at=20
at=20
tility.java:318)
at=20
tility.java:160)
at=20
at=20
ction.java:250)
at=20
at=20
at=20
0)
at=20
:818)
at=20
va:1079)
at=20
java:1183)
at =
at =
at=20
88)
at=20
8)
at=20
on.java:113)
at=20
va:193)
at=20
at=20
at=20
82)
at=20
79)
at=20
:2647)
at=20
ler.java:1135)
at=20
4)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at =
at=20
a:180)
at=20
445)
at=20
241)
at=20
tImpl.java:255)
at=20
... 79 more
at=20
at=20
EList.java:636)
at=20
1192)
at=20
:2642)
... 95 more
the=20
the=20
Marc-Florian
Marc-Florian,
change=20
GenModel.
Salute,
Back to business:
Marc-Florian
=20
<HTML><HEAD>
<DIV><FONT face=3DArial size=3D2>Dear James,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>dear&nbsp;Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>the allOwnedElements is an option, =
that's=20
right.&nbsp;</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I just thought, that the content of the =
union=20
ownedElements would include any element, that participate in that =
relationship=20
via subset mechanism, in whatever hierarchy level they are defined. But =
the way=20
it now works isn't so far from that, what i've expected. I've tried to =
add a=20
containment relationship that doesn't participate in the ownedElement=20
far so=20
good.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>May be, i got a wrong imagination from =
the=20
union/subsets&nbsp;mechanism. </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks </FONT></DIV>
<DIV>"James Bruck" &lt;<A=20
href=3D"mailto:jbruck@ca.ibm.com">jbruck@ca.ibm.com</A>&gt; schrieb im =
Newsbeitrag <A=20
href=3D"news:gdkqbh$tk3$1@build.eclipse.org">news:gdkqbh$tk3$1@build.ecli=
href=3D"mailto:Ed.Merks@gmail.com">Ed.Merks@gmail.com</A>&gt; wrote =
in message=20
<A=20
<DIV>&nbsp;</DIV>
for you, as=20
we say in Germany. </FONT></DIV></BLOCKQUOTE>Darned, we're keeping =
score!<BR>
because the=20
elements, which i wanted to be participating in the union, aren't =
be=20
computed correctly.</FONT></DIV></BLOCKQUOTE>I wouldn't know =
correct if I=20
saw it. :-P<BR>
<DIV><FONT face=3DArial size=3D2>Only the top level children of =
the root=20
element are computed as "ownedElements". And i really think, that =
this=20
missbehaviour is a result of using the wrong List for computing =
the=20
subsets. I've attached a simple model, which illustrates this=20
<DIV>&nbsp;</DIV>
B</FONT></DIV>
B</FONT></DIV>
A2</FONT></DIV>
C</FONT></DIV>
<DIV>&nbsp;</DIV>
references as=20
<DIV>&nbsp;</DIV>
owner)</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
owner)</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; theA2 (subsets =
owner)</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>When i call getOwnedElements in =
the Root=20
model, the result is 2. In uml2 philosophie, this should be 5, =
because=20
every containment reference is defined as a subset of the =
ownedElements=20
reference, hence, the references should contribute themself into =
the=20
derived union relationship. But this isn't done... and again, i =
think this=20
relates to the choice of the generated lists. But i'm really not =
sure. If=20
i would know, why this approach fails, i wouldn't post here=20
<DIV>I think this require Kenn's attention because I've never =
learned these=20
longer.=20
:-P</DIV>
face=3DArial size=3D2>ut a doubt, Kenn is the master of subsets =
and derived=20
root=20
model and retrieving 2 elements is fine.&nbsp; This can be =
considered all=20
the "direct" owned elements. &nbsp;&nbsp;&nbsp;If you want all the =
direct=20
and indirect elements a special query, <EM>allOwnedElements, =
</EM>&nbsp;is=20
defined in the spec.&nbsp; see section 7.3.14 in the "Additional=20
Operations" section.</FONT></DIV>
Newsbeitrag=20
seems=20
fact.&nbsp;=20
I.e., given these union features aren't changeable, serializing =
them=20
seems like a really bad idea...<BR><BR><BR>Marc-Florian Wendland =
wrote:=20
type=3D"cite">
<STYLE></STYLE>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>what kind of test case. I =
think th=20
easiest way to reproduce this is to propagate the genmodel and =
ecore=20
files, isn't it? I've attached them.</FONT></DIV>
<DIV>&nbsp;</DIV>
moz-do-not-send=3D"true">Ed.Merks@gmail.com</A>&gt; schrieb =
im=20
Wendland wrote:=20
with=20
it,=20
it fails with the exception:
eption:=20
(platform:/resource/de/My2.test, -1, -1)
at=20
tion(ResourceSetImpl.java:315)
at=20
urceSetImpl.java:274)
at=20
etImpl.java:397)
at subset.test.presentation.TestEditor.createModel(TestEditor.j ava:952)
at =
subset.test.presentation.TestEditor.createPages(TestEditor.j ava:1009)
at=20
Part.java:310)
at=20
java:661)
at=20
28)
at=20
ence.java:594)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:30 6)
at=20
blePart.java:180)
at=20
at=20
at=20
at=20
java:1256)
at=20
..java:63)
at=20
a:217)
at=20
207)
at=20
779)
at=20
ger.java:678)
at =
at=20
..java:2817)
at=20
729)
at =
at =
at =
at=20
at=20
at=20
at=20
tility.java:318)
at=20
tility.java:160)
at=20
at=20
ction.java:250)
at=20
at=20
at=20
0)
at=20
:818)
at=20
va:1079)
at=20
java:1183)
at =
at =
at=20
88)
at=20
8)
at=20
on.java:113)
at=20
va:193)
at=20
at=20
at=20
82)
at=20
79)
at=20
:2647)
at=20
ler.java:1135)
at=20
4)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at =
at=20
a:180)
at=20
445)
at=20
241)
at=20
tImpl.java:255)
at=20
... 79 more
at=20
at=20
EList.java:636)
at=20
1192)
at=20
:2642)
... 95 more
the=20
the=20
Marc-Florian
Newsbeitrag=20
</PRE>
change=20
GenModel.
</PRE>
Back to business:
Any help would be appreciated.
Marc-Florian
------=_NextPart_000_0052_01C933BB.994819F0--
Re: Using UML2 mechanism [message #477875 is a reply to message #477862] Thu, 23 October 2008 12:42 Go to previous messageGo to next message
------=_NextPart_000_00A6_01C9350C.CD769470
It's a well-established convention (for better or worse) in the UML =
specification to use "foo" to refer to directly associated elements and =
"allFoo" to refer to a greater set of associated elements which takes a =
hierarchy (such as composition or generalization) into consideration...
In terms of subsets and unions, the semantics are (not surprisingly) =
vague on whether inclusion in the set is recursive, but given the above =
mentioned convention, we made the assumption that it shouldn't be =
(otherwise the definition of the allOwnedElements() operation would be =
redundant)...
Kenn
"Marc-Florian Wendland" <florianwendland@freenet.de> wrote in message =
news:gdl6si$47m$1@build.eclipse.org...
Dear James,
dear Ed,
far so good.
Thanks=20
Marc-Florian
Marc-Florian,
Comments below.
Dear Ed,
overhead:
Root
A
B
B
A2
C
Element
owner (union)
Root : Element
A:Element
B:Element
theA(subsets owner)
A2:Element
C:Element
:-P
=20
Marc-Florian
Marc-Florian,
Ed,
attached them.
Marc-Florian
Marc-Florian,
Dear Ed,
with=20
it,=20
eption:=20
at=20
at=20
at=20
etImpl.java:397)
at =
at=20
Part.java:310)
at=20
java:661)
at=20
28)
at=20
ence.java:594)
at=20
blePart.java:180)
at=20
resentablePartFolder.java:270)
at=20
tToRightTabOrder.java:65)
at=20
Part(TabbedStackPresentation.java:473)
at=20
java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 08)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
at=20
..java:63)
at=20
a:217)
at=20
207)
at=20
779)
at=20
ger.java:678)
at =
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:639)
at=20
..java:2817)
at=20
729)
at =
org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2721)
at =
org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2673)
at =
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at=20
at=20
at=20
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:646)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:605)
at=20
tility.java:318)
at=20
tility.java:160)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:22 8)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:20 7)
at=20
ispatchAction.java:274)
at=20
ction.java:250)
at=20
Open(PackageExplorerActionGroup.java:363)
at=20
eExplorerPart.java:603)
at=20
0)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at=20
:818)
at=20
va:1079)
at=20
java:1183)
at =
org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
at =
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at=20
88)
at=20
8)
at=20
on.java:113)
at=20
va:193)
at=20
on(EclipseAppLauncher.java:110)
at=20
eAppLauncher.java:79)
at=20
82)
at=20
79)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
at=20
:2647)
at=20
ler.java:1135)
at=20
4)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at =
at=20
a:180)
at=20
445)
at=20
241)
at=20
tImpl.java:255)
at=20
... 79 more
at=20
at=20
EList.java:636)
at=20
1192)
at=20
:2642)
... 95 more
the=20
the=20
Marc-Florian
Marc-Florian,
change=20
GenModel.
Salute,
Back to business:
Marc-Florian
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.6000.16705" name=3DGENERATOR></HEAD>
<DIV><FONT face=3DArial size=3D2>It's a well-established convention (for =
better or=20
worse) in the UML specification to use "foo" to refer to directly =
associated=20
elements and "allFoo" to refer to a greater set of associated elements =
which=20
takes a hierarchy (such as composition or generalization) into=20
consideration...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>In terms of subsets and unions, the =
semantics are=20
(not surprisingly) vague on whether inclusion in the set is recursive, =
but given=20
the above mentioned convention, we made the assumption that it shouldn't =
be=20
(otherwise the definition of the allOwnedElements() operation would be=20
redundant)...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Kenn</FONT></DIV>
<DIV>"Marc-Florian Wendland" &lt;<A=20
href=3D"mailto:florianwendland@freenet.de">florianwendland@freenet.de</A>=
&gt;=20
wrote in message <A=20
href=3D"news:gdl6si$47m$1@build.eclipse.org">news:gdl6si$47m$1@build.ecli=
that's=20
<DIV><FONT face=3DArial size=3D2>I just thought, that the content of =
the union=20
relationship=20
via subset mechanism, in whatever hierarchy level they are defined. =
But the=20
way it now works isn't so far from that, what i've expected. I've =
tried to add=20
a containment relationship that doesn't participate in the =
ownedElement=20
relationship and it wasn't selected, when i call getOwnedElements(). =
So far so=20
good.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>May be, i got a wrong imagination =
from the=20
href=3D"mailto:jbruck@ca.ibm.com">jbruck@ca.ibm.com</A>&gt; schrieb =
im=20
Newsbeitrag <A=20
href=3D"mailto:Ed.Merks@gmail.com">Ed.Merks@gmail.com</A>&gt; =
wrote in=20
message <A=20
<BLOCKQUOTE cite=3Dmid:gdkgfp$i3d$1@build.eclipse.org =
type=3D"cite">
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>okay, that was a good point. =
1-0 for you,=20
as we say in Germany. </FONT></DIV></BLOCKQUOTE>Darned, we're =
keeping=20
score!<BR>
type=3D"cite">
<DIV><FONT face=3DArial size=3D2>But, my point was also very =
good, because=20
the elements, which i wanted to be participating in the union, =
aren't be=20
correct if I=20
saw it. :-P<BR>
type=3D"cite">
the root=20
element are computed as "ownedElements". And i really think, =
that this=20
the=20
<DIV>&nbsp;</DIV>
A</FONT></DIV>
B</FONT></DIV>
B</FONT></DIV>
A2</FONT></DIV>
C</FONT></DIV>
<DIV>&nbsp;</DIV>
references as=20
<DIV>&nbsp;</DIV>
ownedElements=20
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; owner=20
owner)</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; theB =
(subsets=20
<DIV>&nbsp;</DIV>
owner)</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; theC =
(subsets=20
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; theA2 =
(subsets=20
owner)</FONT></DIV>
<DIV>&nbsp;</DIV>
the Root=20
because=20
ownedElements=20
the=20
think=20
this relates to the choice of the generated lists. But i'm =
really not=20
sure. If i would know, why this approach fails, i wouldn't post =
here=20
learned=20
these concepts.&nbsp; I was hoping to live in ignorant bliss a =
little=20
longer. :-P</DIV>
type=3D"cite">
and derived=20
root=20
considered=20
all the "direct" owned elements. &nbsp;&nbsp;&nbsp;If you want =
all the=20
direct and indirect elements a special query, =
<EM>allOwnedElements,=20
</EM>&nbsp;is defined in the spec.&nbsp; see section 7.3.14 in =
the=20
"Additional Operations" section.</FONT></DIV>
Newsbeitrag <A href=3D"news:gdkedv$trt$1@build.eclipse.org"=20
seems=20
fact.&nbsp;=20
I.e., given these union features aren't changeable, =
serializing them=20
seems like a really bad idea...<BR><BR><BR>Marc-Florian =
Wendland=20
wrote:=20
type=3D"cite">
<STYLE></STYLE>
<DIV>&nbsp;</DIV>
think th=20
easiest way to reproduce this is to propagate the genmodel =
and ecore=20
<DIV>&nbsp;</DIV>
moz-do-not-send=3D"true">Ed.Merks@gmail.com</A>&gt; =
schrieb im=20
Newsbeitrag <A =
problem.&nbsp; Could you share a test=20
with=20
it,=20
eption:=20
at=20
at=20
at=20
etImpl.java:397)
at =
at=20
Part.java:310)
at=20
java:661)
at=20
28)
at=20
ence.java:594)
at=20
blePart.java:180)
at=20
at=20
at=20
at=20
java:1256)
at=20
..java:63)
at=20
a:217)
at=20
207)
at=20
779)
at=20
ger.java:678)
at =
at=20
..java:2817)
at=20
729)
at =
at =
at =
at=20
at=20
at=20
at=20
tility.java:318)
at=20
tility.java:160)
at=20
at=20
ction.java:250)
at=20
at=20
at=20
0)
at=20
:818)
at=20
va:1079)
at=20
java:1183)
at =
at =
at=20
88)
at=20
8)
at=20
on.java:113)
at=20
va:193)
at=20
at=20
at=20
82)
at=20
79)
at=20
:2647)
at=20
ler.java:1135)
at=20
4)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at =
org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
at=20
a:180)
at=20
445)
at=20
241)
at=20
tImpl.java:255)
at=20
urceSetImpl.java:270)
... 79 more
Caused by: java.lang.UnsupportedOperationException
at=20
//cannot resolve the subsets?
at java.util.AbstractSequentialList.add(Unknown Source)
at=20
EList.java:636)
at=20
1192)
at=20
:2642)
... 95 more
the=20
the=20
computed, since the wrong List-type was selected.
anyone of this project has the interest to solve this problem with me?
Thanks for answering
Marc-Florian
Newsbeitrag=20
</PRE>
change=20
GenModel.
</PRE>
it is very mystical :)
Back to business:
article outthere, how to integrate this code generator?
Marc-Florian
BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_00A6_01C9350C.CD769470--
Re: Using UML2 mechanism [message #477880 is a reply to message #477875] Fri, 24 October 2008 06:19 Go to previous message
Originally posted by: florianwendland.freenet.de
------=_NextPart_000_01F4_01C935D2.CCEC43D0
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Dear Kenn,
thank you for your detailled answer. I agree with your definition =
totally and will realize the allOwnedElements() method for the case, =
that anyone needs access to all directly or indirectly owned elements.
Have a nice day.
Marc-Florian
"Kenn Hussey" <Kenn.Hussey@embarcadero.com> schrieb im Newsbeitrag =
news:gdq9hj$dam$1@build.eclipse.org...
redundant)...
Kenn
"Marc-Florian Wendland" <florianwendland@freenet.de> wrote in =
message news:gdl6si$47m$1@build.eclipse.org...
Dear James,
dear Ed,
far so good.
Thanks=20
Marc-Florian
Marc-Florian,
Comments below.
Dear Ed,
okay, that was a good point. 1-0 for you, as we say in =
Germany.=20
But, my point was also very good, because the elements, which =
i wanted to be participating in the union, aren't be computed correctly.
Only the top level children of the root element are computed =
as "ownedElements". And i really think, that this missbehaviour is a =
result of using the wrong List for computing the subsets. I've attached =
a simple model, which illustrates this missbehaviour. Here it is with no =
overhead:
Root
A
B
B
A2
C
Element
owner (union)
Root : Element
A:Element
B:Element
theA(subsets owner)
A2:Element
C:Element
When i call getOwnedElements in the Root model, the result is =
2. In uml2 philosophie, this should be 5, because every containment =
:-P
=20
Marc-Florian
"Ed Merks" <Ed.Merks@gmail.com> schrieb im Newsbeitrag =
Marc-Florian,
Probably a union should be transient. Looking at the =
example, it seems redundant to serialize a union. Worse than that in =
fact. I.e., given these union features aren't changeable, serializing =
Ed,
what kind of test case. I think th easiest way to =
I've attached them.
Marc-Florian
Marc-Florian,
Dear Ed,
i've done this instincly by myself before. And i've explored the same=20
phenomenon like Timothy. It is possible to construct a model hierarchy =
with=20
the generated editor, but once you have serialized it and try to reopen =
it,=20
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedExc=
eption:=20
'subset.test.impl.AImpl@192322e' is not legal.=20
at=20
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadExcep=
at=20
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(Reso=
at=20
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceS=
etImpl.java:397)
at =
at=20
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditor=
Part.java:310)
at=20
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.=
java:661)
at=20
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:4=
28)
at=20
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartRefer=
ence.java:594)
at=20
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(Presenta=
blePart.java:180)
at=20
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(P=
at=20
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(Lef=
at=20
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.select=
at=20
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.=
java:1256)
at=20
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer=
..java:63)
at=20
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.jav=
a:217)
at=20
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:=
207)
at=20
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:=
779)
at=20
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorMana=
ger.java:678)
at =
at=20
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage=
..java:2817)
at=20
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2=
729)
at =
at =
at =
at=20
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2668)=
at=20
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2652)=
at=20
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2643)=
at=20
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorU=
tility.java:318)
at=20
tility.java:160)
at=20
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionD=
at=20
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchA=
ction.java:250)
at=20
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handle=
at=20
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 5.open(Packag=
at=20
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:82=
0)
at=20
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java=
:818)
at=20
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.ja=
va:1079)
at=20
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.=
java:1183)
at =
at =
at=20
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:2=
88)
at=20
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:48=
8)
at=20
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplicati=
on.java:113)
at=20
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.ja=
va:193)
at=20
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplicati=
at=20
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(Eclips=
at=20
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:3=
82)
at=20
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:1=
79)
Caused by: org.eclipse.emf.ecore.xmi.IllegalValueException: Value=20
at=20
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XM LHandler.java=
:2647)
at=20
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleForwardRefer ences(XMLHand=
ler.java:1135)
at=20
org.eclipse.emf.ecore.xmi.impl.XMLHandler.endDocument(XMLHan dler.java:121=
4)
at=20
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .endDocument(=
Unknown=20
Source)
at=20
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.sc=
anDocument(Unknown=20
Source)
at=20
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unkno=
wn=20
Source)
at=20
wn=20
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown=20
Source)
at=20
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknow=
n=20
Source)
at=20
com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse=
(Unknown=20
Source)
at =
at=20
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.jav=
a:180)
at=20
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1=
445)
at=20
241)
at=20
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSe=
tImpl.java:255)
at=20
... 79 more
at=20
org.eclipse.uml2.common.util.DerivedEObjectEList$DerivedList Iterator.add(=
DerivedEObjectEList.java:278)=20
at=20
org.eclipse.uml2.common.util.DerivedEObjectEList.addUnique(D erivedEObject=
EList.java:636)
at=20
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHel perImpl.java:=
1192)
at=20
:2642)
... 95 more
All the DerivedUnion-List are generated, but the genmodel didn't produce =
the=20
SupersetSupset-Lists. Instead of, ordinary EMF-Lists are used. I think,=20
that's the problem, because all the elements, which are participating in =
the=20
Union-Relationship of the root element (like UML::Element) couldn't be=20
May be it is possible to send one member of the UML2 project this simple =
model, because i have to solve this problem for my masterthesis... does=20
Marc-Florian
"Ed Merks" <Ed.Merks@gmail.com> schrieb im Newsbeitrag=20
news:gdk5sb$3b2$1@build.eclipse.org...
Marc-Florian,
Here's what I would try as a simple "hack". Open the *.genmodel, =
change=20
the xmlns:genmodel's namespace to=20
http://www.eclipse.org/uml2/2.2.0/GenModel and then see how it goes.=20
"Reloading..." this model will continue to create the UML2 derived=20
GenModel.
Salute,
i've a similar question as Timothy. I followed his discussions, and it=20
seems that we want to do exactly the same at the same time... sometimes=20
Back to business:
I have an UML2 model with some union/subsets relationships and i want to =
realize these mechanisms in the resulting Ecore, like it is done in the=20
wonderful UML2 project. I've introspected the uml2 sources but didn't=20
found an hint how to include the UML2 generator instead of the ordinary=20
EMF one, which doesn't care about union/subsets. Is there somewhere an=20
Marc-Florian
=20
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Dear Kenn,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>thank you for your detailled answer. I =
agree with=20
your definition totally and will realize the allOwnedElements() method =
for the=20
case, that anyone needs access to all directly or indirectly owned=20
elements.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Have a nice day.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Marc-Florian</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Kenn Hussey" &lt;<A=20
href=3D"mailto:Kenn.Hussey@embarcadero.com">Kenn.Hussey@embarcadero.com</=
A>&gt;=20
schrieb im Newsbeitrag <A=20
href=3D"news:gdq9hj$dam$1@build.eclipse.org">news:gdq9hj$dam$1@build.ecli=
<DIV><FONT face=3DArial size=3D2>It's a well-established convention =
(for better or=20
associated=20
which=20
semantics are=20
but=20
given the above mentioned convention, we made the assumption that it =
shouldn't=20
be (otherwise the definition of the allOwnedElements() operation would =
be=20
&gt;=20
that's=20
the union=20
ownedElements would include any element, that participate in that=20
relationship via subset mechanism, in whatever hierarchy level they =
are=20
defined. But the way it now works isn't so far from that, what i've=20
expected. I've tried to add a containment relationship that doesn't=20
participate in the ownedElement relationship and it wasn't selected, =
when i=20
call getOwnedElements(). So far so good.</FONT></DIV>
from the=20
href=3D"mailto:jbruck@ca.ibm.com">jbruck@ca.ibm.com</A>&gt; =
schrieb im=20
Newsbeitrag <A=20
<DIV><FONT face=3DArial size=3D2>.. comments below =
....</FONT></DIV>
<DIV>"Ed Merks" &lt;<A=20
wrote in=20
message <A=20
type=3D"cite">
<DIV>&nbsp;</DIV>
1-0 for you,=20
keeping=20
score!<BR>
type=3D"cite">
good, because=20
aren't=20
be computed correctly.</FONT></DIV></BLOCKQUOTE>I wouldn't =
know correct=20
if I saw it. :-P<BR>
type=3D"cite">
<DIV><FONT face=3DArial size=3D2>Only the top level children =
of the root=20
that this=20
missbehaviour is a result of using the wrong List for =
computing the=20
<DIV>&nbsp;</DIV>
A</FONT></DIV>
B</FONT></DIV>
B</FONT></DIV>
A2</FONT></DIV>
C</FONT></DIV>
<DIV>&nbsp;</DIV>
references as=20
<DIV>&nbsp;</DIV>
ownedElements=20
owner)</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp;=20
modeableElements(subsets ownedElements)</FONT></DIV>
<DIV>&nbsp;</DIV>
(subsets=20
<DIV>&nbsp;</DIV>
theA(subsets=20
owner)</FONT></DIV>
<DIV>&nbsp;</DIV>
(subsets=20
<DIV>&nbsp;</DIV>
(subsets=20
owner)</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>When i call getOwnedElements =
in the Root=20
because=20
every containment reference is defined as a subset of the=20
ownedElements reference, hence, the references should =
contribute=20
themself into the derived union relationship. But this isn't =
done...=20
and again, i think this relates to the choice of the generated =
lists.=20
But i'm really not sure. If i would know, why this approach =
fails, i=20
wouldn't post here :-)</FONT></DIV></BLOCKQUOTE>
learned=20
little=20
longer. :-P</DIV>
type=3D"cite">
face=3DArial size=3D2>ut a doubt, Kenn is the master of =
subsets and=20
derived unions but in my humble opinion, calling =
getOwnedElements in=20
the root model and retrieving 2 elements is fine.&nbsp; This =
can be=20
considered all the "direct" owned elements. =
&nbsp;&nbsp;&nbsp;If you=20
want all the direct and indirect elements a special query,=20
<EM>allOwnedElements, </EM>&nbsp;is defined in the spec.&nbsp; =
see=20
section 7.3.14 in the "Additional Operations" =
im=20
a union should be transient.&nbsp; Looking at the example, =
it seems=20
fact.&nbsp;=20
serializing them=20
Wendland=20
wrote:=20
type=3D"cite">
<STYLE></STYLE>
<DIV><FONT face=3DArial size=3D2>Ed,</FONT></DIV>
<DIV>&nbsp;</DIV>
think th=20
and=20
ecore files, isn't it? I've attached them.</FONT></DIV>
<DIV>&nbsp;</DIV>
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; =
MARGIN-LEFT: 5px; BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" &lt;<A =
schrieb im=20
Newsbeitrag <A =
Marc-Florian,<BR><BR>It's=20
case?<BR><BR><BR>Marc-Florian Wendland wrote:=20
<BLOCKQUOTE cite=3Dmid:gdkajc$kq1$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Dear Ed,
with=20
it,=20
eption:=20
at=20
at=20
at=20
etImpl.java:397)
at =
at=20
Part.java:310)
at=20
java:661)
at=20
28)
at=20
ence.java:594)
at=20
blePart.java:180)
at=20
at=20
at=20
at=20
java:1256)
at=20
..java:63)
at=20
a:217)
at=20
207)
at=20
779)
at=20
ger.java:678)
at =
at=20
..java:2817)
at=20
729)
at =
at =
at =
at=20
at=20
at=20
at=20
tility.java:318)
at=20
tility.java:160)
at=20
at=20
ction.java:250)
at=20
at=20
at=20
0)
at=20
:818)
at=20
va:1079)
at=20
java:1183)
at =
at =
at=20
88)
at=20
8)
at=20
on.java:113)
at=20
va:193)
at=20
at=20
at=20
82)
at=20
79)
at=20
:2647)
at=20
ler.java:1135)
at=20
4)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at =
at=20
a:180)
at=20
445)
at=20
241)
at=20
tImpl.java:255)
at=20
... 79 more
at=20
at=20
EList.java:636)
at=20
1192)
at=20
:2642)
... 95 more
the=20
the=20
Marc-Florian
"Ed Merks" <A class=3Dmoz-txt-link-rfc2396E =
Newsbeitrag=20
<A class=3Dmoz-txt-link-freetext =
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Marc-Florian,
change=20
GenModel.
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Salute,
Back to business:
Marc-Florian
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->
BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE></BODY ></HTML>
------=_NextPart_000_01F4_01C935D2.CCEC43D0--
Re: Using UML2 mechanism [message #627056 is a reply to message #477852] Tue, 21 October 2008 05:03 Go to previous message
Marc-Florian,
change the xmlns:genmodel's namespace to
"Reloading..." this model will continue to create the UML2 derived GenModel.
> Salute,
> i've a similar question as Timothy. I followed his discussions, and it seems
> that we want to do exactly the same at the same time... sometimes it is very
> mystical :)
> Back to business:
> wonderful UML2 project. I've introspected the uml2 sources but didn't found
> an hint how to include the UML2 generator instead of the ordinary EMF one,
> which doesn't care about union/subsets. Is there somewhere an article
> Marc-Florian
Re: Using UML2 mechanism [message #627057 is a reply to message #477853] Tue, 21 October 2008 06:25 Go to previous message
Dear Ed,
phenomenon like Timothy. It is possible to construct a model hierarchy with
the generated editor, but once you have serialized it and try to reopen it,
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException:
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:315)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:274)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
at subset.test.presentation.TestEditor.createPages(TestEditor.j ava:1009)
at
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:310)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:428)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
at
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:180)
at
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:270)
at
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:473)
at
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
at
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:217)
at
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:207)
at
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:779)
at
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:678)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:639)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2817)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2729)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2721)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2673)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at
at
at
at
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:318)
at
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:160)
at
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:274)
at
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:250)
at
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:363)
at
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 5.open(PackageExplorerPart.java:603)
at
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:820)
at
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:818)
at
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1079)
at
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1183)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XM LHandler.java:2647)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleForwardRefer ences(XMLHandler.java:1135)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.endDocument(XMLHan dler.java:1214)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .endDocument(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
Source)
at
Source)
Source)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
Source)
at
com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown
Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1445)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1241)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
... 79 more
at
org.eclipse.uml2.common.util.DerivedEObjectEList$DerivedList Iterator.add(DerivedEObjectEList.java:278)
at
org.eclipse.uml2.common.util.DerivedEObjectEList.addUnique(D erivedEObjectEList.java:636)
at
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHel perImpl.java:1192)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XM LHandler.java:2642)
... 95 more
All the DerivedUnion-List are generated, but the genmodel didn't produce the
that's the problem, because all the elements, which are participating in the
Marc-Florian
> Marc-Florian,
> Here's what I would try as a simple "hack". Open the *.genmodel, change
> GenModel.
>> Salute,
>> Back to business:
>> Marc-Florian
Re: Using UML2 mechanism [message #627058 is a reply to message #477854] Tue, 21 October 2008 06:46 Go to previous message
--------------030107000009080307050307
Marc-Florian,
It's likely that folks will want to be able to reproduce this problem.
> Dear Ed,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> ... 79 more
> at
> at
> at
> at
> ... 95 more
> Marc-Florian
>> Marc-Florian,
>> GenModel.
>>> Salute,
>>> Back to business:
>>> Marc-Florian
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Marc-Florian,<br>
<br>
It's likely that folks will want to be able to reproduce this problem.&nbsp;
Could you share a test case?<br>
<br>
<br>
<blockquote cite="mid:gdkajc$kq1$1@build.eclipse.org" type="cite">
<pre wrap="">Dear Ed,
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
Source)
at
at
at
at
at
... 79 more
at
at
at
at
... 95 more
Marc-Florian
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:Ed.Merks@gmail.com">&lt;Ed.Merks@gmail.com&gt;</a> schrieb im Newsbeitrag
<a class="moz-txt-link-freetext" href="news:gdk5sb$3b2$1@build.eclipse.org">news:gdk5sb$3b2$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Marc-Florian,
<a class="moz-txt-link-freetext" href="http://www.eclipse.org/uml2/2.2.0/GenModel">http://www.eclipse.org/uml2/2.2.0/GenModel</a> and then see how it goes.
GenModel.
</pre>
<pre wrap="">Salute,
Back to business:
Marc-Florian
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------030107000009080307050307--
Re: Using UML2 mechanism [message #627059 is a reply to message #477855] Tue, 21 October 2008 06:54 Go to previous message
------=_NextPart_000_00D6_01C9337C.249F49F0
Content-Type: multipart/alternative;
boundary="----=_NextPart_001_00D7_01C9337C.249F49F0"
------=_NextPart_001_00D7_01C9337C.249F49F0
Ed,
what kind of test case. I think th easiest way to reproduce this is to =
propagate the genmodel and ecore files, isn't it? I've attached them.
Marc-Florian
news:gdkbtd$vqh$1@build.eclipse.org...
Marc-Florian,
It's likely that folks will want to be able to reproduce this problem. =
Dear Ed,
with=20
it,=20
eption:=20
at=20
at=20
at=20
etImpl.java:397)
at =
at=20
Part.java:310)
at=20
java:661)
at=20
28)
at=20
ence.java:594)
at=20
blePart.java:180)
at=20
at=20
at=20
at=20
java:1256)
at=20
..java:63)
at=20
a:217)
at=20
207)
at=20
779)
at=20
ger.java:678)
at =
at=20
..java:2817)
at=20
729)
at =
at =
at =
at=20
at=20
at=20
at=20
tility.java:318)
at=20
tility.java:160)
at=20
at=20
ction.java:250)
at=20
at=20
at=20
0)
at=20
:818)
at=20
va:1079)
at=20
java:1183)
at =
at =
at=20
88)
at=20
8)
at=20
on.java:113)
at=20
va:193)
at=20
at=20
at=20
82)
at=20
79)
at=20
:2647)
at=20
ler.java:1135)
at=20
4)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at =
at=20
a:180)
at=20
445)
at=20
241)
at=20
tImpl.java:255)
at=20
... 79 more
at=20
at=20
EList.java:636)
at=20
1192)
at=20
:2642)
... 95 more
the=20
the=20
Marc-Florian
Marc-Florian,
change=20
GenModel.
Salute,
Back to business:
Marc-Florian
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.5659" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>what kind of test case. I think th =
easiest way to=20
reproduce this is to propagate the genmodel and ecore files, isn't it? =
I've=20
href=3D"mailto:Ed.Merks@gmail.com">Ed.Merks@gmail.com</A>&gt; schrieb =
im=20
Newsbeitrag <A=20
href=3D"news:gdkbtd$vqh$1@build.eclipse.org">news:gdkbtd$vqh$1@build.ecli=
pse.org</A>...</DIV>Marc-Florian,<BR><BR>It's=20
likely that folks will want to be able to reproduce this =
problem.&nbsp; Could=20
you share a test case?<BR><BR><BR>Marc-Florian Wendland wrote:=20
with=20
it,=20
eption:=20
at=20
at=20
at=20
etImpl.java:397)
at =
at=20
Part.java:310)
at=20
java:661)
at=20
28)
at=20
ence.java:594)
at=20
blePart.java:180)
at=20
at=20
at=20
at=20
java:1256)
at=20
..java:63)
at=20
a:217)
at=20
207)
at=20
779)
at=20
ger.java:678)
at =
at=20
..java:2817)
at=20
729)
at =
at =
at =
at=20
at=20
at=20
at=20
tility.java:318)
at=20
tility.java:160)
at=20
at=20
ction.java:250)
at=20
at=20
at=20
0)
at=20
:818)
at=20
va:1079)
at=20
java:1183)
at =
at =
at=20
88)
at=20
8)
at=20
on.java:113)
at=20
va:193)
at=20
at=20
at=20
82)
at=20
79)
at=20
:2647)
at=20
ler.java:1135)
at=20
4)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at =
at=20
a:180)
at=20
445)
at=20
241)
at=20
tImpl.java:255)
at=20
... 79 more
at=20
at=20
EList.java:636)
at=20
1192)
at=20
:2642)
... 95 more
the=20
the=20
Marc-Florian
href=3D"mailto:Ed.Merks@gmail.com">&lt;Ed.Merks@gmail.com&gt;</A> =
href=3D"news:gdk5sb$3b2$1@build.eclipse.org">news:gdk5sb$3b2$1@build.ecli=
pse.org</A>...
</PRE>
change=20
href=3D"http://www.eclipse.org/uml2/2.2.0/GenModel">http://www.eclipse.or=
g/uml2/2.2.0/GenModel</A> and then see how it goes.=20
GenModel.
</PRE>
Back to business:
Marc-Florian
</PRE></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_001_00D7_01C9337C.249F49F0--
Content-Type: application/octet-stream;
name="Ohne_Titel1.genmodel"
filename="Ohne_Titel1.genmodel"
<?xml version=3D"1.0" encoding=3D"UTF-8"?>
<genmodel:GenModel xmi:version=3D"2.0"
xmlns:xmi=3D"http://www.omg.org/XMI" =
xmlns:xsi=3D"http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore=3D"http://www.eclipse.org/emf/2002/Ecore" =
xmlns:genmodel=3D"http://www.eclipse.org/uml2/2.2.0/GenModel" =
modelDirectory=3D"/x/src"
modelPluginID=3D"x" modelName=3D"Ohne_Titel1" =
importerID=3D"org.eclipse.uml2.uml.ecore.importer"
complianceLevel=3D"6.0" suppressGenModelAnnotations=3D"false" =
copyrightFields=3D"false"
factoryMethods=3D"true" pluralizedGetters=3D"true" =
cacheAdapterSupport=3D"true" invariantPrefix=3D"validate">
<genAnnotations =
source=3D" http://www.eclipse.org/emf/2002/GenModel/importer/org.eclips e.u=
ml2.uml.ecore.importer">
<details key=3D"ECORE_TAGGED_VALUES" value=3D"PROCESS"/>
<details key=3D"UNION_PROPERTIES" value=3D"PROCESS"/>
<details key=3D"DUPLICATE_FEATURES" value=3D"DISCARD"/>
<details key=3D"SUBSETTING_PROPERTIES" value=3D"PROCESS"/>
<details key=3D"COMMENTS" value=3D"PROCESS"/>
<details key=3D"DUPLICATE_FEATURE_INHERITANCE" value=3D"DISCARD"/>
<details key=3D"DUPLICATE_OPERATIONS" value=3D"DISCARD"/>
<details key=3D"INVARIANT_CONSTRAINTS" value=3D"PROCESS"/>
<details key=3D"REDEFINING_PROPERTIES" value=3D"PROCESS"/>
<details key=3D"ANNOTATION_DETAILS" value=3D"PROCESS"/>
<details key=3D"DUPLICATE_OPERATION_INHERITANCE" value=3D"DISCARD"/>
<details key=3D"REDEFINING_OPERATIONS" value=3D"PROCESS"/>
<details key=3D"DERIVED_FEATURES" value=3D"PROCESS"/>
<details key=3D"OPERATION_BODIES" value=3D"PROCESS"/>
<details key=3D"CAMEL_CASE_NAMES" value=3D"PROCESS"/>
<details key=3D"SUPER_CLASS_ORDER" value=3D"PROCESS"/>
</genAnnotations>
<foreignModel>../../t/model/x/Ohne_Titel1.uml</foreignModel >
<genPackages xsi:type=3D"genmodel:GenPackage" prefix=3D"Subset" =
disposableProviderFactory=3D"true"
ecorePackage=3D"subset.ecore#/">
<nestedGenPackages xsi:type=3D"genmodel:GenPackage" =
prefix=3D"UmlStandardProfile"
basePackage=3D"subset" disposableProviderFactory=3D"true" =
ecorePackage=3D"subset.ecore#//umlStandardProfile"/>
<nestedGenPackages xsi:type=3D"genmodel:GenPackage" prefix=3D"Test" =
ecorePackage=3D"subset.ecore#//test">
<genClasses xsi:type=3D"genmodel:GenClass" =
ecoreClass=3D"subset.ecore#//test/ModelElement">
<genFeatures xsi:type=3D"genmodel:GenFeature" =
property=3D"Readonly" notify=3D"false"
createChild=3D"false" ecoreFeature=3D"ecore:EReference =
subset.ecore#//test/ModelElement/ownedElements"/>
subset.ecore#//test/ModelElement/owner"/>
</genClasses>
ecoreClass=3D"subset.ecore#//test/A">
<genFeatures xsi:type=3D"genmodel:GenFeature" property=3D"None" =
children=3D"true"
createChild=3D"true" ecoreFeature=3D"ecore:EReference =
subset.ecore#//test/A/theB"/>
</genClasses>
ecoreClass=3D"subset.ecore#//test/B">
notify=3D"false"
subset.ecore#//test/B/theA"/>
</genClasses>
ecoreClass=3D"subset.ecore#//test/C"/>
</nestedGenPackages>
</genPackages>
</genmodel:GenModel>
name="subset.ecore"
filename="subset.ecore"
<ecore:EPackage xmi:version=3D"2.0"
name=3D"subset"
nsURI=3D"http:///subset.ecore" nsPrefix=3D"subset">
<eAnnotations source=3D"http://www.eclipse.org/emf/2002/GenModel">
<details key=3D"documentation" =
value=3D"Author:mfw.&#xA;Created:19.10.08 =
22:22.&#xA;Title:.&#xA;Comment:.&#xA;"/>
</eAnnotations>
<eSubpackages name=3D"umlStandardProfile" =
nsURI=3D"http:///subset/umlStandardProfile.ecore"
nsPrefix=3D"subset.umlStandardProfile">
<details key=3D"documentation" value=3D"UML Standard Profile =
contains several popular stereotypes, tag definitions and constraints =
described in UML 1.4 and UML 2.0 Specifications."/>
</eAnnotations>
</eSubpackages>
<eSubpackages name=3D"test" nsURI=3D"http:///subset/test.ecore" =
nsPrefix=3D"subset.test">
<eClassifiers xsi:type=3D"ecore:EClass" name=3D"ModelElement">
<eStructuralFeatures xsi:type=3D"ecore:EReference" =
name=3D"ownedElements" ordered=3D"false"
upperBound=3D"-1" eType=3D"#//test/ModelElement" =
changeable=3D"false" volatile=3D"true"
derived=3D"true" eOpposite=3D"#//test/ModelElement/owner">
<eAnnotations source=3D"union"/>
</eStructuralFeatures>
<eStructuralFeatures xsi:type=3D"ecore:EReference" name=3D"owner" =
ordered=3D"false"
eType=3D"#//test/ModelElement" changeable=3D"false" =
volatile=3D"true" derived=3D"true"
eOpposite=3D"#//test/ModelElement/ownedElements">
</eClassifiers>
<eClassifiers xsi:type=3D"ecore:EClass" name=3D"A2" =
eSuperTypes=3D"#//test/ModelElement">
<eStructuralFeatures xsi:type=3D"ecore:EReference" name=3D"theC2" =
eType=3D"#//test/C"
containment=3D"true">
<eAnnotations source=3D"subsets" =
references=3D"#//test/ModelElement/ownedElements"/>
</eClassifiers>
<eClassifiers xsi:type=3D"ecore:EClass" name=3D"A" =
<eStructuralFeatures xsi:type=3D"ecore:EReference" name=3D"theB" =
ordered=3D"false"
upperBound=3D"-1" eType=3D"#//test/B" derived=3D"true" =
containment=3D"true" eOpposite=3D"#//test/B/theA">
<eStructuralFeatures xsi:type=3D"ecore:EReference" name=3D"theC" =
upperBound=3D"-1"
eType=3D"#//test/C" containment=3D"true">
</eClassifiers>
<eClassifiers xsi:type=3D"ecore:EClass" name=3D"B" =
<eStructuralFeatures xsi:type=3D"ecore:EReference" name=3D"theA" =
ordered=3D"false"
eType=3D"#//test/A" eOpposite=3D"#//test/A/theB">
references=3D"#//test/ModelElement/owner"/>
</eClassifiers>
<eClassifiers xsi:type=3D"ecore:EClass" name=3D"C" =
eSuperTypes=3D"#//test/ModelElement"/>
<eClassifiers xsi:type=3D"ecore:EClass" name=3D"Model" =
name=3D"modeableElements" upperBound=3D"-1"
eType=3D"#//test/ModelElement" containment=3D"true">
</eClassifiers>
</eSubpackages>
</ecore:EPackage>
------=_NextPart_000_00D6_01C9337C.249F49F0--
Re: Using UML2 mechanism [message #627060 is a reply to message #477856] Tue, 21 October 2008 07:29 Go to previous message
--------------000400060400000206070308
Marc-Florian,
Probably a union should be transient. Looking at the example, it seems
redundant to serialize a union. Worse than that in fact. I.e., given
these union features aren't changeable, serializing them seems like a
really bad idea...
> Ed,
> Marc-Florian
> "Ed Merks" <Ed.Merks@gmail.com <mailto:Ed.Merks@gmail.com>>
> schrieb im Newsbeitrag news:gdkbtd$vqh$1@build.eclipse.org...
> Marc-Florian,
>> Dear Ed,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> ... 79 more
>> at
>> at
>> at
>> at
>> ... 95 more
>> Marc-Florian
>>> Marc-Florian,
>>> GenModel.
>>>> Salute,
>>>> Back to business:
>>>> Marc-Florian
<html>
<head>
</head>
Marc-Florian,<br>
<br>
Probably a union should be transient.&nbsp; Looking at the example, it seems
redundant to serialize a union.&nbsp; Worse than that in fact.&nbsp; I.e., given
really bad idea...<br>
<br>
<br>
<blockquote cite="mid:gdkc94$4qa$1@build.eclipse.org" type="cite">
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.2900.5659" name="GENERATOR">
<style></style>
<div><font face="Arial" size="2">Ed,</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">what kind of test case. I think th
easiest way to reproduce this is to propagate the genmodel and ecore
files, isn't it? I've attached them.</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">Marc-Florian</font></div>
<blockquote dir="ltr"
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Ed Merks" &lt;<a moz-do-not-send="true"
href="mailto:Ed.Merks@gmail.com">Ed.Merks@gmail.com</a>&gt; schrieb im
Newsbeitrag <a moz-do-not-send="true"
href="news:gdkbtd$vqh$1@build.eclipse.org">news:gdkbtd$vqh$1@build.eclipse.org</a>...</div>
Marc-Florian,<br>
<br>
<br>
<br>
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
Source)
at
at
at
at
at
... 79 more
at
at
at
at
... 95 more
Marc-Florian
"Ed Merks" <a moz-do-not-send="true" class="moz-txt-link-rfc2396E"
<a moz-do-not-send="true" class="moz-txt-link-freetext"
</pre>
GenModel.
</pre>
Back to business:
Marc-Florian
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
</blockquote>
</blockquote>
</body>
</html>
--------------000400060400000206070308--
Re: Using UML2 mechanism [message #627061 is a reply to message #477857] Tue, 21 October 2008 08:06 Go to previous message
------=_NextPart_000_0105_01C93386.32386240
boundary="----=_NextPart_001_0106_01C93386.32386240"
------=_NextPart_001_0106_01C93386.32386240
Dear Ed,
okay, that was a good point. 1-0 for you, as we say in Germany. But, my =
point was also very good, because the elements, which i wanted to be =
participating in the union, aren't be computed correctly. Only the top =
level children of the root element are computed as "ownedElements". And =
i really think, that this missbehaviour is a result of using the wrong =
List for computing the subsets. I've attached a simple model, which =
illustrates this missbehaviour. Here it is with no overhead:
Root
A
B
B
A2
C
while metamodel defines the references as follows:
Element
ownedElements (union)
owner (union)
owningModel(subsets owner)
Root : Element
A:Element
theB (subsets ownedElements)
B:Element
theA(subsets owner)
A2:Element
theC (subsets ownedElements)
C:Element
theA2 (subsets owner)
When i call getOwnedElements in the Root model, the result is 2. In uml2 =
philosophie, this should be 5, because every containment reference is =
defined as a subset of the ownedElements reference, hence, the =
relationship. But this isn't done... and again, i think this relates to =
the choice of the generated lists. But i'm really not sure. If i would =
know, why this approach fails, i wouldn't post here :-)
Marc-Florian
news:gdkedv$trt$1@build.eclipse.org...
Marc-Florian,
Probably a union should be transient. Looking at the example, it =
seems redundant to serialize a union. Worse than that in fact. I.e., =
given these union features aren't changeable, serializing them seems =
Ed,
what kind of test case. I think th easiest way to reproduce this is =
to propagate the genmodel and ecore files, isn't it? I've attached them.
Marc-Florian
Marc-Florian,
It's likely that folks will want to be able to reproduce this =
Dear Ed,
with=20
it,=20
eption:=20
at=20
at=20
at=20
etImpl.java:397)
at =
at=20
Part.java:310)
at=20
java:661)
at=20
28)
at=20
ence.java:594)
at=20
blePart.java:180)
at=20
at=20
at=20
at=20
java:1256)
at=20
..java:63)
at=20
a:217)
at=20
207)
at=20
779)
at=20
ger.java:678)
at =
at=20
..java:2817)
at=20
729)
at =
at =
at =
at=20
at=20
at=20
at=20
tility.java:318)
at=20
tility.java:160)
at=20
at=20
ction.java:250)
at=20
at=20
at=20
0)
at=20
:818)
at=20
va:1079)
at=20
java:1183)
at =
at =
at=20
88)
at=20
8)
at=20
on.java:113)
at=20
va:193)
at=20
at=20
at=20
82)
at=20
79)
at=20
:2647)
at=20
ler.java:1135)
at=20
4)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at =
at=20
a:180)
at=20
445)
at=20
241)
at=20
tImpl.java:255)
at=20
... 79 more
at=20
at=20
EList.java:636)
at=20
1192)
at=20
:2642)
... 95 more
the=20
the=20
Marc-Florian
Marc-Florian,
change=20
GenModel.
Salute,
Back to business:
Marc-Florian
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.5659" name=3DGENERATOR></HEAD>
<DIV><FONT face=3DArial size=3D2>Dear Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>okay, that was a good point. 1-0 for =
you, as we say=20
in Germany. But, my point was also very good, because the elements, =
which i=20
wanted to be participating in the union, aren't be computed correctly. =
Only the=20
top level children of the root element are computed as "ownedElements". =
And i=20
List for=20
computing the subsets. I've attached a simple model, which illustrates =
this=20
missbehaviour. Here it is with no overhead:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Root</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; A</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;=20
B</FONT></DIV>
B</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; A2</FONT></DIV>
C</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>while metamodel defines the references =
as=20
follows:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Element</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; ownedElements=20
(union)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; owner =
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; owningModel(subsets=20
owner)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Root : Element</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; =
modeableElements(subsets=20
<DIV><FONT face=3DArial size=3D2>A:Element</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; theB (subsets=20
<DIV><FONT face=3DArial size=3D2>B:Element</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; theA(subsets =
owner)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>A2:Element</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; theC (subsets=20
<DIV><FONT face=3DArial size=3D2>C:Element</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; theA2 (subsets=20
owner)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>When i call getOwnedElements in the =
Root model, the=20
result is 2. In uml2 philosophie, this should be 5, because every =
containment=20
reference is defined as a subset of the ownedElements reference, hence, =
the=20
relationship. But=20
this isn't done... and again, i think this relates to the choice of the=20
generated lists. But i'm really not sure. If i would know, why this =
approach=20
fails, i wouldn't post here :-)</FONT></DIV>
im=20
Newsbeitrag <A=20
href=3D"news:gdkedv$trt$1@build.eclipse.org">news:gdkedv$trt$1@build.ecli=
pse.org</A>...</DIV>Marc-Florian,<BR><BR>Probably=20
a union should be transient.&nbsp; Looking at the example, it seems =
redundant=20
to serialize a union.&nbsp; Worse than that in fact.&nbsp; I.e., given =
these=20
union features aren't changeable, serializing them seems like a really =
bad=20
idea...<BR><BR><BR>Marc-Florian Wendland wrote:=20
<BLOCKQUOTE cite=3Dmid:gdkc94$4qa$1@build.eclipse.org type=3D"cite">
<STYLE></STYLE>
<DIV>&nbsp;</DIV>
easiest way=20
to reproduce this is to propagate the genmodel and ecore files, =
isn't it?=20
<DIV>&nbsp;</DIV>
<DIV>"Ed Merks" &lt;<A href=3D"mailto:Ed.Merks@gmail.com"=20
moz-do-not-send=3D"true">Ed.Merks@gmail.com</A>&gt; schrieb im =
Newsbeitrag=20
<A href=3D"news:gdkbtd$vqh$1@build.eclipse.org"=20
moz-do-not-send=3D"true">news:gdkbtd$vqh$1@build.eclipse.org</A>...</DIV>=
problem.&nbsp;=20
Could you share a test case?<BR><BR><BR>Marc-Florian Wendland =
wrote:=20
with=20
it,=20
eption:=20
at=20
at=20
at=20
etImpl.java:397)
at =
at=20
Part.java:310)
at=20
java:661)
at=20
28)
at=20
ence.java:594)
at=20
blePart.java:180)
at=20
at=20
at=20
at=20
java:1256)
at=20
..java:63)
at=20
a:217)
at=20
207)
at=20
779)
at=20
ger.java:678)
at =
at=20
..java:2817)
at=20
729)
at =
at =
at =
at=20
at=20
at=20
at=20
tility.java:318)
at=20
tility.java:160)
at=20
at=20
ction.java:250)
at=20
at=20
at=20
0)
at=20
:818)
at=20
va:1079)
at=20
java:1183)
at =
at =
at=20
88)
at=20
8)
at=20
on.java:113)
at=20
va:193)
at=20
at=20
at=20
82)
at=20
79)
at=20
:2647)
at=20
ler.java:1135)
at=20
4)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at =
at=20
a:180)
at=20
445)
at=20
241)
at=20
tImpl.java:255)
at=20
... 79 more
at=20
at=20
EList.java:636)
at=20
1192)
at=20
:2642)
... 95 more
the=20
the=20
Marc-Florian
href=3D"mailto:Ed.Merks@gmail.com" =
moz-do-not-send=3D"true">&lt;Ed.Merks@gmail.com&gt;</A> schrieb im =
Newsbeitrag=20
href=3D"news:gdk5sb$3b2$1@build.eclipse.org" =
moz-do-not-send=3D"true">news:gdk5sb$3b2$1@build.eclipse.org</A>...
</PRE>
change=20
href=3D"http://www.eclipse.org/uml2/2.2.0/GenModel" =
moz-do-not-send=3D"true">http://www.eclipse.org/uml2/2.2.0/GenModel</A> =
GenModel.
</PRE>
Back to business:
Marc-Florian
</PRE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE ></BODY></HTML>
------=_NextPart_001_0106_01C93386.32386240--
name="My3.test"
filename="My3.test"
<subset.test:Model xmi:version=3D"2.0" =
xmlns:xsi=3D"http://www.w3.org/2001/XMLSchema-instance" =
xmlns:subset.test=3D"http:///subset/test.ecore">
<modeableElements xsi:type=3D"subset.test:A">
<theB/>
<theB/>
</modeableElements>
<modeableElements xsi:type=3D"subset.test:A2">
<theC2/>
</modeableElements>
</subset.test:Model>
------=_NextPart_000_0105_01C93386.32386240--
Re: Using UML2 mechanism [message #627062 is a reply to message #477858] Tue, 21 October 2008 08:13 Go to previous message
--------------080309010204070903070403
Marc-Florian,
Comments below.
> Dear Ed,
Darned, we're keeping score!
> But, my point was also very good, because the elements, which i wanted
I wouldn't know correct if I saw it. :-P
> Only the top level children of the root element are computed as
> attached a simple model, which illustrates this missbehaviour. Here it
> Root
> A
> B
> B
> A2
> C
> Element
> owner (union)
> Root : Element
> A:Element
> B:Element
> theA(subsets owner)
> A2:Element
> C:Element
> hence, the references should contribute themself into the derived
> union relationship. But this isn't done... and again, i think this
> relates to the choice of the generated lists. But i'm really not sure.
> If i would know, why this approach fails, i wouldn't post here :-)
I think this require Kenn's attention because I've never learned these
concepts. I was hoping to live in ignorant bliss a little longer. :-P
> Marc-Florian
> schrieb im Newsbeitrag news:gdkedv$trt$1@build.eclipse.org...
> Marc-Florian,
> them seems like a really bad idea...
>> Ed,
>> is to propagate the genmodel and ecore files, isn't it? I've
>> attached them.
>> Marc-Florian
>> Marc-Florian,
>> problem. Could you share a test case?
>>> Dear Ed,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 79 more
>>> at
>>> at
>>> at
>>> at
>>> ... 95 more
>>> Marc-Florian
>>>> Marc-Florian,
>>>> GenModel.
>>>>> Salute,
>>>>> Back to business:
>>>>> Marc-Florian
<html>
<head>
</head>
Marc-Florian,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:gdkgfp$i3d$1@build.eclipse.org" type="cite">
<div><font face="Arial" size="2">Dear Ed,</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">okay, that was a good point. 1-0 for
you, as we say in Germany. </font></div>
</blockquote>
Darned, we're keeping score!<br>
<div><font face="Arial" size="2">But, my point was also very good,
because the elements, which i wanted to be participating in the union,
aren't be computed correctly.</font></div>
</blockquote>
I wouldn't know correct if I saw it. :-P<br>
<div><font face="Arial" size="2"> Only the top level children of the
root element are computed as "ownedElements". And i really think, that
this missbehaviour is a result of using the wrong List for computing
the subsets. I've attached a simple model, which illustrates this
missbehaviour. Here it is with no overhead:</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">Root</font></div>
<div><font face="Arial" size="2">&nbsp;&nbsp;&nbsp; A</font></div>
<div><font face="Arial" size="2">&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; B</font></div>
<div><font face="Arial" size="2">&nbsp;&nbsp;&nbsp; A2</font></div>
<div><font face="Arial" size="2">&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; C</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">while metamodel defines the
references as follows:</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">Element</font></div>
<div><font face="Arial" size="2">&nbsp;&nbsp;&nbsp; ownedElements (union)</font></div>
<div><font face="Arial" size="2">&nbsp;&nbsp;&nbsp; owner (union)</font></div>
<div><font face="Arial" size="2">&nbsp;&nbsp;&nbsp; owningModel(subsets owner)</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">Root : Element</font></div>
<div><font face="Arial" size="2">&nbsp;&nbsp;&nbsp; modeableElements(subsets
ownedElements)</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">A:Element</font></div>
<div><font face="Arial" size="2">&nbsp;&nbsp;&nbsp; theB (subsets ownedElements)</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">B:Element</font></div>
<div><font face="Arial" size="2">&nbsp;&nbsp;&nbsp; theA(subsets owner)</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">A2:Element</font></div>
<div><font face="Arial" size="2">&nbsp;&nbsp;&nbsp; theC (subsets ownedElements)</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">C:Element</font></div>
<div><font face="Arial" size="2">&nbsp;&nbsp;&nbsp; theA2 (subsets owner)</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">When i call getOwnedElements in the
Root model, the result is 2. In uml2 philosophie, this should be 5,
because every containment reference is defined as a subset of the
ownedElements reference, hence, the references should contribute
themself into the derived union relationship. But this isn't done...
and again, i think this relates to the choice of the generated lists.
But i'm really not sure. If i would know, why this approach fails, i
wouldn't post here :-)</font></div>
</blockquote>
concepts.&nbsp; I was hoping to live in ignorant bliss a little longer. :-P<br>
<div>&nbsp;</div>
href="news:gdkedv$trt$1@build.eclipse.org">news:gdkedv$trt$1@build.eclipse.org</a>...</div>
Marc-Florian,<br>
<br>
<br>
<br>
<style></style>
<div>&nbsp;</div>
th easiest way to reproduce this is to propagate the genmodel and ecore
<div>&nbsp;</div>
<div>"Ed Merks" &lt;<a href="mailto:Ed.Merks@gmail.com"
moz-do-not-send="true">Ed.Merks@gmail.com</a>&gt; schrieb im
Newsbeitrag <a href="news:gdkbtd$vqh$1@build.eclipse.org"
moz-do-not-send="true">news:gdkbtd$vqh$1@build.eclipse.org</a>...</div>
Marc-Florian,<br>
<br>
<br>
<br>
type="cite">
it fails with the exception:
(platform:/resource/de/My2.test, -1, -1)
at
at
at
at subset.test.presentation.TestEditor.createModel(TestEditor.j ava:952)
at
at
at
at
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:30 6)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
Source)
at
at
at
at
at
... 79 more
at
at
at
at
... 95 more
Marc-Florian
href="mailto:Ed.Merks@gmail.com" moz-do-not-send="true">&lt;Ed.Merks@gmail.com&gt;</a> schrieb im Newsbeitrag
href="news:gdk5sb$3b2$1@build.eclipse.org" moz-do-not-send="true">news:gdk5sb$3b2$1@build.eclipse.org</a>...
</pre>
moz-do-not-send="true">http://www.eclipse.org/uml2/2.2.0/GenModel</a> and then see how it goes.
GenModel.
</pre>
Back to business:
Any help would be appreciated.
Marc-Florian
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</body>
</html>
--------------080309010204070903070403--
Re: Using UML2 mechanism [message #627063 is a reply to message #477859] Tue, 21 October 2008 10:54 Go to previous message
------=_NextPart_000_003B_01C9336B.57CFE750
... comments below ...
"Ed Merks" <Ed.Merks@gmail.com> wrote in message =
news:gdkh14$ms1$1@build.eclipse.org...
Marc-Florian,
Comments below.
Dear Ed,
okay, that was a good point. 1-0 for you, as we say in Germany.=20
But, my point was also very good, because the elements, which i =
Only the top level children of the root element are computed as =
"ownedElements". And i really think, that this missbehaviour is a result =
of using the wrong List for computing the subsets. I've attached a =
overhead:
Root
A
B
B
A2
C
Element
owner (union)
Root : Element
A:Element
B:Element
theA(subsets owner)
A2:Element
C:Element
When i call getOwnedElements in the Root model, the result is 2. In =
uml2 philosophie, this should be 5, because every containment reference =
is defined as a subset of the ownedElements reference, hence, the =
references should contribute themself into the derived union =
I think this require Kenn's attention because I've never learned these =
[James] Without a doubt, Kenn is the master of subsets and derived =
unions but in my humble opinion, calling getOwnedElements in the root =
model and retrieving 2 elements is fine. This can be considered all the =
"direct" owned elements. If you want all the direct and indirect =
elements a special query, allOwnedElements, is defined in the spec. =
see section 7.3.14 in the "Additional Operations" section.
Marc-Florian
Marc-Florian,
Ed,
what kind of test case. I think th easiest way to reproduce this =
is to propagate the genmodel and ecore files, isn't it? I've attached =
them.
Marc-Florian
Marc-Florian,
Dear Ed,
with=20
it,=20
eption:=20
at=20
at=20
at=20
etImpl.java:397)
at =
at=20
Part.java:310)
at=20
java:661)
at=20
28)
at=20
ence.java:594)
at=20
blePart.java:180)
at=20
at=20
at=20
at=20
java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 08)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
at=20
..java:63)
at=20
a:217)
at=20
207)
at=20
779)
at=20
ger.java:678)
at =
at=20
..java:2817)
at=20
729)
at =
at =
at =
at=20
at=20
at=20
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:646)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:605)
at=20
tility.java:318)
at=20
tility.java:160)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:22 8)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:20 7)
at=20
at=20
ction.java:250)
at=20
at=20
at=20
0)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at=20
:818)
at=20
va:1079)
at=20
java:1183)
at =
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
at =
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at=20
88)
at=20
8)
at=20
on.java:113)
at=20
va:193)
at=20
at=20
at=20
82)
at=20
79)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
at=20
:2647)
at=20
ler.java:1135)
at=20
4)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at =
at=20
a:180)
at=20
445)
at=20
241)
at=20
tImpl.java:255)
at=20
... 79 more
at=20
at=20
EList.java:636)
at=20
1192)
at=20
:2642)
... 95 more
the=20
the=20
Marc-Florian
Marc-Florian,
change=20
GenModel.
Salute,
Back to business:
Marc-Florian
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.3395" name=3DGENERATOR></HEAD>
<DIV><FONT face=3DArial size=3D2>.. comments below ...</FONT></DIV>
href=3D"mailto:Ed.Merks@gmail.com">Ed.Merks@gmail.com</A>&gt; wrote in =
message=20
<A=20
href=3D"news:gdkh14$ms1$1@build.eclipse.org">news:gdkh14$ms1$1@build.ecli=
pse.org</A>...</DIV>Marc-Florian,<BR><BR>Comments=20
below.<BR><BR>Marc-Florian Wendland wrote:=20
<BLOCKQUOTE cite=3Dmid:gdkgfp$i3d$1@build.eclipse.org type=3D"cite">
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>okay, that was a good point. 1-0 =
for you, as we=20
say in Germany. </FONT></DIV></BLOCKQUOTE>Darned, we're keeping =
score!<BR>
<DIV><FONT face=3DArial size=3D2>But, my point was also very good, =
because the=20
elements, which i wanted to be participating in the union, aren't be =
computed correctly.</FONT></DIV></BLOCKQUOTE>I wouldn't know correct =
if I saw=20
it. :-P<BR>
<DIV><FONT face=3DArial size=3D2>Only the top level children of the =
root element=20
are computed as "ownedElements". And i really think, that this =
missbehaviour=20
is a result of using the wrong List for computing the subsets. I've =
attached=20
a simple model, which illustrates this missbehaviour. Here it is =
with no=20
<DIV>&nbsp;</DIV>
B</FONT></DIV>
B</FONT></DIV>
C</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>while metamodel defines the =
references as=20
<DIV>&nbsp;</DIV>
owner)</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; theA(subsets=20
owner)</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
owner)</FONT></DIV>
<DIV>&nbsp;</DIV>
Root model,=20
the result is 2. In uml2 philosophie, this should be 5, because =
every=20
containment reference is defined as a subset of the ownedElements =
reference,=20
hence, the references should contribute themself into the derived =
union=20
relationship. But this isn't done... and again, i think this relates =
to the=20
know, why=20
this approach fails, i wouldn't post here =
<DIV>I think this require Kenn's attention because I've never learned =
these=20
concepts.&nbsp; I was hoping to live in ignorant bliss a little =
longer.=20
:-P</DIV>
<DIV><BR>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>[James]&nbsp;&nbsp; =
Witho</FONT><FONT=20
face=3DArial size=3D2>ut a doubt, Kenn is the master of subsets and =
derived=20
unions but in my humble opinion, calling getOwnedElements in the =
root model=20
and retrieving 2 elements is fine.&nbsp; This can be considered all =
the=20
"direct" owned elements. &nbsp;&nbsp;&nbsp;If you want all the =
direct and=20
indirect elements a special query, <EM>allOwnedElements, =
</EM>&nbsp;is=20
defined in the spec.&nbsp; see section 7.3.14 in the "Additional =
Operations"=20
section.</FONT></DIV>
Newsbeitrag=20
<A href=3D"news:gdkedv$trt$1@build.eclipse.org"=20
moz-do-not-send=3D"true">news:gdkedv$trt$1@build.eclipse.org</A>...</DIV>=
a union should be transient.&nbsp; Looking at the example, it =
seems=20
redundant to serialize a union.&nbsp; Worse than that in =
fact.&nbsp; I.e.,=20
given these union features aren't changeable, serializing them =
seems like=20
a really bad idea...<BR><BR><BR>Marc-Florian Wendland wrote:=20
<BLOCKQUOTE cite=3Dmid:gdkc94$4qa$1@build.eclipse.org =
type=3D"cite">
<STYLE></STYLE>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>what kind of test case. I think =
th easiest=20
way to reproduce this is to propagate the genmodel and ecore =
files,=20
<DIV>&nbsp;</DIV>
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: =
Newsbeitrag <A href=3D"news:gdkbtd$vqh$1@build.eclipse.org"=20
likely that folks will want to be able to reproduce this=20
problem.&nbsp; Could you share a test =
case?<BR><BR><BR>Marc-Florian=20
Wendland wrote:=20
with=20
it,=20
eption:=20
at=20
at=20
at=20
etImpl.java:397)
at =
at=20
Part.java:310)
at=20
java:661)
at=20
28)
at=20
ence.java:594)
at=20
blePart.java:180)
at=20
at=20
at=20
at=20
java:1256)
at=20
..java:63)
at=20
a:217)
at=20
207)
at=20
779)
at=20
ger.java:678)
at =
at=20
..java:2817)
at=20
729)
at =
at =
at =
at=20
at=20
at=20
at=20
tility.java:318)
at=20
tility.java:160)
at=20
at=20
ction.java:250)
at=20
at=20
at=20
0)
at=20
:818)
at=20
va:1079)
at=20
java:1183)
at =
at =
at=20
88)
at=20
8)
at=20
on.java:113)
at=20
va:193)
at=20
at=20
at=20
82)
at=20
79)
at=20
:2647)
at=20
ler.java:1135)
at=20
4)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at =
at=20
a:180)
at=20
445)
at=20
241)
at=20
tImpl.java:255)
at=20
... 79 more
Caused by: java.lang.UnsupportedOperationException
at=20
//cannot resolve the subsets?
at java.util.AbstractSequentialList.add(Unknown Source)
at=20
EList.java:636)
at=20
1192)
at=20
:2642)
... 95 more
the=20
the=20
computed, since the wrong List-type was selected.
anyone of this project has the interest to solve this problem with me?
Thanks for answering
Marc-Florian
Newsbeitrag=20
</PRE>
change=20
GenModel.
</PRE>
it is very mystical :)
Back to business:
article outthere, how to integrate this code generator?
Marc-Florian
</PRE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE ></BLOCKQUOTE></=
------=_NextPart_000_003B_01C9336B.57CFE750--
Re: Using UML2 mechanism [message #627065 is a reply to message #477860] Tue, 21 October 2008 14:28 Go to previous message
Originally posted by: florianwendland.freenet.de
------=_NextPart_000_0052_01C933BB.994819F0
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Dear James,
dear Ed,
the allOwnedElements is an option, that's right.=20
I just thought, that the content of the union ownedElements would =
include any element, that participate in that relationship via subset =
mechanism, in whatever hierarchy level they are defined. But the way it =
now works isn't so far from that, what i've expected. I've tried to add =
a containment relationship that doesn't participate in the ownedElement =
relationship and it wasn't selected, when i call getOwnedElements(). So =
far so good.
May be, i got a wrong imagination from the union/subsets mechanism.=20
Thanks=20
Marc-Florian
"James Bruck" <jbruck@ca.ibm.com> schrieb im Newsbeitrag =
news:gdkqbh$tk3$1@build.eclipse.org...
Marc-Florian,
Comments below.
Dear Ed,
simple model, which illustrates this missbehaviour. Here it is with no =
overhead:
Root
A
B
B
A2
C
Element
owner (union)
Root : Element
A:Element
B:Element
theA(subsets owner)
A2:Element
C:Element
When i call getOwnedElements in the Root model, the result is 2. =
In uml2 philosophie, this should be 5, because every containment =
the references should contribute themself into the derived union =
these concepts. I was hoping to live in ignorant bliss a little longer. =
:-P
=20
[James] Without a doubt, Kenn is the master of subsets and =
derived unions but in my humble opinion, calling getOwnedElements in the =
root model and retrieving 2 elements is fine. This can be considered =
all the "direct" owned elements. If you want all the direct and =
indirect elements a special query, allOwnedElements, is defined in the =
spec. see section 7.3.14 in the "Additional Operations" section.
Marc-Florian
"Ed Merks" <Ed.Merks@gmail.com> schrieb im Newsbeitrag =
Marc-Florian,
Probably a union should be transient. Looking at the example, =
it seems redundant to serialize a union. Worse than that in fact. =
I.e., given these union features aren't changeable, serializing them =
Ed,
what kind of test case. I think th easiest way to reproduce =
this is to propagate the genmodel and ecore files, isn't it? I've =
attached them.
Marc-Florian
Marc-Florian,
It's likely that folks will want to be able to reproduce =
this problem. Could you share a test case?
Dear Ed,
i've done this instincly by myself before. And i've explored the same=20
phenomenon like Timothy. It is possible to construct a model hierarchy =
with=20
the generated editor, but once you have serialized it and try to reopen =
it,=20
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedExc=
eption:=20
'subset.test.impl.AImpl@192322e' is not legal.=20
at=20
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadExcep=
at=20
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(Reso=
at=20
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceS=
etImpl.java:397)
at =
at=20
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditor=
Part.java:310)
at=20
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.=
java:661)
at=20
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:4=
28)
at=20
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartRefer=
ence.java:594)
at=20
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(Presenta=
blePart.java:180)
at=20
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(P=
at=20
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(Lef=
at=20
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.select=
at=20
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.=
java:1256)
at=20
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer=
..java:63)
at=20
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.jav=
a:217)
at=20
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:=
207)
at=20
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:=
779)
at=20
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorMana=
ger.java:678)
at =
at=20
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage=
..java:2817)
at=20
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2=
729)
at =
at =
at =
at=20
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2668)=
at=20
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2652)=
at=20
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2643)=
at=20
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorU=
tility.java:318)
at=20
tility.java:160)
at=20
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionD=
at=20
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchA=
ction.java:250)
at=20
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handle=
at=20
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 5.open(Packag=
at=20
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:82=
0)
at=20
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java=
:818)
at=20
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.ja=
va:1079)
at=20
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.=
java:1183)
at =
at =
at=20
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:2=
88)
at=20
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:48=
8)
at=20
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplicati=
on.java:113)
at=20
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.ja=
va:193)
at=20
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplicati=
at=20
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(Eclips=
at=20
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:3=
82)
at=20
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:1=
79)
Caused by: org.eclipse.emf.ecore.xmi.IllegalValueException: Value=20
at=20
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XM LHandler.java=
:2647)
at=20
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleForwardRefer ences(XMLHand=
ler.java:1135)
at=20
org.eclipse.emf.ecore.xmi.impl.XMLHandler.endDocument(XMLHan dler.java:121=
4)
at=20
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .endDocument(=
Unknown=20
Source)
at=20
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.sc=
anDocument(Unknown=20
Source)
at=20
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unkno=
wn=20
Source)
at=20
wn=20
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown=20
Source)
at=20
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknow=
n=20
Source)
at=20
com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse=
(Unknown=20
Source)
at =
at=20
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.jav=
a:180)
at=20
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1=
445)
at=20
241)
at=20
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSe=
tImpl.java:255)
at=20
... 79 more
at=20
org.eclipse.uml2.common.util.DerivedEObjectEList$DerivedList Iterator.add(=
DerivedEObjectEList.java:278)=20
at=20
org.eclipse.uml2.common.util.DerivedEObjectEList.addUnique(D erivedEObject=
EList.java:636)
at=20
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHel perImpl.java:=
1192)
at=20
:2642)
... 95 more
All the DerivedUnion-List are generated, but the genmodel didn't produce =
the=20
SupersetSupset-Lists. Instead of, ordinary EMF-Lists are used. I think,=20
that's the problem, because all the elements, which are participating in =
the=20
Union-Relationship of the root element (like UML::Element) couldn't be=20
May be it is possible to send one member of the UML2 project this simple =
model, because i have to solve this problem for my masterthesis... does=20
Marc-Florian
"Ed Merks" <Ed.Merks@gmail.com> schrieb im Newsbeitrag=20
news:gdk5sb$3b2$1@build.eclipse.org...
Marc-Florian,
Here's what I would try as a simple "hack". Open the *.genmodel, =
change=20
the xmlns:genmodel's namespace to=20
http://www.eclipse.org/uml2/2.2.0/GenModel and then see how it goes.=20
"Reloading..." this model will continue to create the UML2 derived=20
GenModel.
Salute,
i've a similar question as Timothy. I followed his discussions, and it=20
seems that we want to do exactly the same at the same time... sometimes=20
Back to business:
I have an UML2 model with some union/subsets relationships and i want to =
realize these mechanisms in the resulting Ecore, like it is done in the=20
wonderful UML2 project. I've introspected the uml2 sources but didn't=20
found an hint how to include the UML2 generator instead of the ordinary=20
EMF one, which doesn't care about union/subsets. Is there somewhere an=20
Marc-Florian
=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Dear James,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>dear&nbsp;Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>the allOwnedElements is an option, =
that's=20
right.&nbsp;</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I just thought, that the content of the =
union=20
ownedElements would include any element, that participate in that =
relationship=20
via subset mechanism, in whatever hierarchy level they are defined. But =
the way=20
it now works isn't so far from that, what i've expected. I've tried to =
add a=20
containment relationship that doesn't participate in the ownedElement=20
far so=20
good.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>May be, i got a wrong imagination from =
the=20
union/subsets&nbsp;mechanism. </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Marc-Florian</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"James Bruck" &lt;<A=20
href=3D"mailto:jbruck@ca.ibm.com">jbruck@ca.ibm.com</A>&gt; schrieb im =
Newsbeitrag <A=20
href=3D"news:gdkqbh$tk3$1@build.eclipse.org">news:gdkqbh$tk3$1@build.ecli=
<DIV>"Ed Merks" &lt;<A=20
href=3D"mailto:Ed.Merks@gmail.com">Ed.Merks@gmail.com</A>&gt; wrote =
in message=20
<A=20
<DIV>&nbsp;</DIV>
for you, as=20
we say in Germany. </FONT></DIV></BLOCKQUOTE>Darned, we're keeping =
score!<BR>
because the=20
elements, which i wanted to be participating in the union, aren't =
be=20
computed correctly.</FONT></DIV></BLOCKQUOTE>I wouldn't know =
correct if I=20
saw it. :-P<BR>
<DIV><FONT face=3DArial size=3D2>Only the top level children of =
the root=20
element are computed as "ownedElements". And i really think, that =
this=20
missbehaviour is a result of using the wrong List for computing =
the=20
subsets. I've attached a simple model, which illustrates this=20
<DIV>&nbsp;</DIV>
B</FONT></DIV>
B</FONT></DIV>
A2</FONT></DIV>
C</FONT></DIV>
<DIV>&nbsp;</DIV>
references as=20
<DIV>&nbsp;</DIV>
owner)</FONT></DIV>
<DIV>&nbsp;</DIV>
ownedElements)</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
owner)</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; theA2 (subsets =
owner)</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>When i call getOwnedElements in =
the Root=20
model, the result is 2. In uml2 philosophie, this should be 5, =
because=20
every containment reference is defined as a subset of the =
ownedElements=20
reference, hence, the references should contribute themself into =
the=20
derived union relationship. But this isn't done... and again, i =
think this=20
relates to the choice of the generated lists. But i'm really not =
sure. If=20
i would know, why this approach fails, i wouldn't post here=20
:-)</FONT></DIV></BLOCKQUOTE>
<DIV>I think this require Kenn's attention because I've never =
learned these=20
longer.=20
:-P</DIV>
face=3DArial size=3D2>ut a doubt, Kenn is the master of subsets =
and derived=20
root=20
model and retrieving 2 elements is fine.&nbsp; This can be =
considered all=20
the "direct" owned elements. &nbsp;&nbsp;&nbsp;If you want all the =
direct=20
and indirect elements a special query, <EM>allOwnedElements, =
</EM>&nbsp;is=20
defined in the spec.&nbsp; see section 7.3.14 in the "Additional=20
Operations" section.</FONT></DIV>
BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
Newsbeitrag=20
seems=20
fact.&nbsp;=20
I.e., given these union features aren't changeable, serializing =
them=20
seems like a really bad idea...<BR><BR><BR>Marc-Florian Wendland =
wrote:=20
type=3D"cite">
<STYLE></STYLE>
<DIV><FONT face=3DArial size=3D2>Ed,</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>what kind of test case. I =
think th=20
easiest way to reproduce this is to propagate the genmodel and =
ecore=20
files, isn't it? I've attached them.</FONT></DIV>
<DIV>&nbsp;</DIV>
5px; BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
moz-do-not-send=3D"true">Ed.Merks@gmail.com</A>&gt; schrieb =
im=20
Wendland wrote:=20
<BLOCKQUOTE cite=3Dmid:gdkajc$kq1$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Dear Ed,
with=20
it,=20
eption:=20
at=20
at=20
at=20
etImpl.java:397)
at =
at=20
Part.java:310)
at=20
java:661)
at=20
28)
at=20
ence.java:594)
at=20
blePart.java:180)
at=20
at=20
at=20
at=20
java:1256)
at=20
..java:63)
at=20
a:217)
at=20
207)
at=20
779)
at=20
ger.java:678)
at =
at=20
..java:2817)
at=20
729)
at =
at =
at =
at=20
at=20
at=20
at=20
tility.java:318)
at=20
tility.java:160)
at=20
at=20
ction.java:250)
at=20
at=20
at=20
0)
at=20
:818)
at=20
va:1079)
at=20
java:1183)
at =
at =
at=20
88)
at=20
8)
at=20
on.java:113)
at=20
va:193)
at=20
at=20
at=20
82)
at=20
79)
at=20
:2647)
at=20
ler.java:1135)
at=20
4)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at =
at=20
a:180)
at=20
445)
at=20
241)
at=20
tImpl.java:255)
at=20
... 79 more
at=20
at=20
EList.java:636)
at=20
1192)
at=20
:2642)
... 95 more
the=20
the=20
Marc-Florian
"Ed Merks" <A class=3Dmoz-txt-link-rfc2396E =
Newsbeitrag=20
<A class=3Dmoz-txt-link-freetext =
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Marc-Florian,
change=20
GenModel.
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Salute,
Back to business:
Marc-Florian
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->
------=_NextPart_000_0052_01C933BB.994819F0--
Re: Using UML2 mechanism [message #627075 is a reply to message #477862] Thu, 23 October 2008 12:42 Go to previous message
------=_NextPart_000_00A6_01C9350C.CD769470
It's a well-established convention (for better or worse) in the UML =
specification to use "foo" to refer to directly associated elements and =
"allFoo" to refer to a greater set of associated elements which takes a =
hierarchy (such as composition or generalization) into consideration...
In terms of subsets and unions, the semantics are (not surprisingly) =
vague on whether inclusion in the set is recursive, but given the above =
mentioned convention, we made the assumption that it shouldn't be =
(otherwise the definition of the allOwnedElements() operation would be =
redundant)...
Kenn
"Marc-Florian Wendland" <florianwendland@freenet.de> wrote in message =
news:gdl6si$47m$1@build.eclipse.org...
Dear James,
dear Ed,
far so good.
Thanks=20
Marc-Florian
Marc-Florian,
Comments below.
Dear Ed,
overhead:
Root
A
B
B
A2
C
Element
owner (union)
Root : Element
modeableElements(subsets ownedElements)
A:Element
B:Element
theA(subsets owner)
A2:Element
C:Element
:-P
=20
Marc-Florian
Marc-Florian,
Ed,
attached them.
Marc-Florian
Marc-Florian,
Dear Ed,
with=20
it,=20
eption:=20
at=20
tion(ResourceSetImpl.java:315)
at=20
urceSetImpl.java:274)
at=20
etImpl.java:397)
at =
subset.test.presentation.TestEditor.createPages(TestEditor.j ava:1009)
at=20
Part.java:310)
at=20
java:661)
at=20
28)
at=20
ence.java:594)
at=20
blePart.java:180)
at=20
resentablePartFolder.java:270)
at=20
tToRightTabOrder.java:65)
at=20
Part(TabbedStackPresentation.java:473)
at=20
java:1256)
at=20
..java:63)
at=20
a:217)
at=20
207)
at=20
779)
at=20
ger.java:678)
at =
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:639)
at=20
..java:2817)
at=20
729)
at =
org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2721)
at =
org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2673)
at =
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at=20
at=20
at=20
at=20
tility.java:318)
at=20
tility.java:160)
at=20
at=20
ction.java:250)
at=20
at=20
at=20
0)
at=20
:818)
at=20
va:1079)
at=20
java:1183)
at =
at =
at=20
88)
at=20
8)
at=20
on.java:113)
at=20
va:193)
at=20
at=20
at=20
82)
at=20
79)
at=20
:2647)
at=20
ler.java:1135)
at=20
4)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at =
at=20
a:180)
at=20
445)
at=20
241)
at=20
tImpl.java:255)
at=20
... 79 more
at=20
at=20
EList.java:636)
at=20
1192)
at=20
:2642)
... 95 more
the=20
the=20
Marc-Florian
Marc-Florian,
change=20
GenModel.
Salute,
Back to business:
Marc-Florian
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.6000.16705" name=3DGENERATOR></HEAD>
<DIV><FONT face=3DArial size=3D2>It's a well-established convention (for =
better or=20
worse) in the UML specification to use "foo" to refer to directly =
associated=20
elements and "allFoo" to refer to a greater set of associated elements =
which=20
takes a hierarchy (such as composition or generalization) into=20
consideration...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>In terms of subsets and unions, the =
semantics are=20
(not surprisingly) vague on whether inclusion in the set is recursive, =
but given=20
the above mentioned convention, we made the assumption that it shouldn't =
be=20
(otherwise the definition of the allOwnedElements() operation would be=20
redundant)...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Kenn</FONT></DIV>
<DIV>"Marc-Florian Wendland" &lt;<A=20
href=3D"mailto:florianwendland@freenet.de">florianwendland@freenet.de</A>=
&gt;=20
wrote in message <A=20
href=3D"news:gdl6si$47m$1@build.eclipse.org">news:gdl6si$47m$1@build.ecli=
that's=20
<DIV><FONT face=3DArial size=3D2>I just thought, that the content of =
the union=20
relationship=20
via subset mechanism, in whatever hierarchy level they are defined. =
But the=20
way it now works isn't so far from that, what i've expected. I've =
tried to add=20
a containment relationship that doesn't participate in the =
ownedElement=20
relationship and it wasn't selected, when i call getOwnedElements(). =
So far so=20
good.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>May be, i got a wrong imagination =
from the=20
href=3D"mailto:jbruck@ca.ibm.com">jbruck@ca.ibm.com</A>&gt; schrieb =
im=20
Newsbeitrag <A=20
href=3D"mailto:Ed.Merks@gmail.com">Ed.Merks@gmail.com</A>&gt; =
wrote in=20
message <A=20
<BLOCKQUOTE cite=3Dmid:gdkgfp$i3d$1@build.eclipse.org =
type=3D"cite">
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>okay, that was a good point. =
1-0 for you,=20
as we say in Germany. </FONT></DIV></BLOCKQUOTE>Darned, we're =
keeping=20
score!<BR>
type=3D"cite">
<DIV><FONT face=3DArial size=3D2>But, my point was also very =
good, because=20
the elements, which i wanted to be participating in the union, =
aren't be=20
correct if I=20
saw it. :-P<BR>
type=3D"cite">
the root=20
element are computed as "ownedElements". And i really think, =
that this=20
the=20
<DIV>&nbsp;</DIV>
A</FONT></DIV>
B</FONT></DIV>
B</FONT></DIV>
A2</FONT></DIV>
C</FONT></DIV>
<DIV>&nbsp;</DIV>
references as=20
<DIV>&nbsp;</DIV>
ownedElements=20
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; owner=20
owner)</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; theB =
(subsets=20
<DIV>&nbsp;</DIV>
owner)</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; theC =
(subsets=20
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; theA2 =
(subsets=20
owner)</FONT></DIV>
<DIV>&nbsp;</DIV>
the Root=20
because=20
ownedElements=20
the=20
think=20
this relates to the choice of the generated lists. But i'm =
really not=20
sure. If i would know, why this approach fails, i wouldn't post =
here=20
learned=20
these concepts.&nbsp; I was hoping to live in ignorant bliss a =
little=20
longer. :-P</DIV>
type=3D"cite">
and derived=20
root=20
considered=20
all the "direct" owned elements. &nbsp;&nbsp;&nbsp;If you want =
all the=20
direct and indirect elements a special query, =
<EM>allOwnedElements,=20
</EM>&nbsp;is defined in the spec.&nbsp; see section 7.3.14 in =
the=20
"Additional Operations" section.</FONT></DIV>
Newsbeitrag <A href=3D"news:gdkedv$trt$1@build.eclipse.org"=20
seems=20
fact.&nbsp;=20
I.e., given these union features aren't changeable, =
serializing them=20
seems like a really bad idea...<BR><BR><BR>Marc-Florian =
Wendland=20
wrote:=20
type=3D"cite">
<STYLE></STYLE>
<DIV>&nbsp;</DIV>
think th=20
easiest way to reproduce this is to propagate the genmodel =
and ecore=20
<DIV>&nbsp;</DIV>
moz-do-not-send=3D"true">Ed.Merks@gmail.com</A>&gt; =
schrieb im=20
Newsbeitrag <A =
problem.&nbsp; Could you share a test=20
with=20
it,=20
eption:=20
at=20
at=20
at=20
etImpl.java:397)
at =
at=20
Part.java:310)
at=20
java:661)
at=20
28)
at=20
ence.java:594)
at=20
blePart.java:180)
at=20
at=20
at=20
at=20
java:1256)
at=20
..java:63)
at=20
a:217)
at=20
207)
at=20
779)
at=20
ger.java:678)
at =
at=20
..java:2817)
at=20
729)
at =
at =
at =
at=20
at=20
at=20
at=20
tility.java:318)
at=20
tility.java:160)
at=20
ispatchAction.java:274)
at=20
ction.java:250)
at=20
Open(PackageExplorerActionGroup.java:363)
at=20
eExplorerPart.java:603)
at=20
0)
at=20
:818)
at=20
va:1079)
at=20
java:1183)
at =
org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
at =
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
at=20
88)
at=20
8)
at=20
on.java:113)
at=20
va:193)
at=20
on(EclipseAppLauncher.java:110)
at=20
eAppLauncher.java:79)
at=20
82)
at=20
79)
at=20
:2647)
at=20
ler.java:1135)
at=20
4)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at =
org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
at=20
a:180)
at=20
445)
at=20
241)
at=20
tImpl.java:255)
at=20
urceSetImpl.java:270)
... 79 more
at=20
at=20
EList.java:636)
at=20
1192)
at=20
:2642)
... 95 more
the=20
the=20
Marc-Florian
Newsbeitrag=20
</PRE>
change=20
GenModel.
</PRE>
Back to business:
Marc-Florian
BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_00A6_01C9350C.CD769470--
Re: Using UML2 mechanism [message #627080 is a reply to message #477875] Fri, 24 October 2008 06:19 Go to previous message
------=_NextPart_000_01F4_01C935D2.CCEC43D0
Content-Type: text/plain;
Dear Kenn,
thank you for your detailled answer. I agree with your definition =
totally and will realize the allOwnedElements() method for the case, =
that anyone needs access to all directly or indirectly owned elements.
Have a nice day.
Marc-Florian
"Kenn Hussey" <Kenn.Hussey@embarcadero.com> schrieb im Newsbeitrag =
news:gdq9hj$dam$1@build.eclipse.org...
redundant)...
Kenn
"Marc-Florian Wendland" <florianwendland@freenet.de> wrote in =
message news:gdl6si$47m$1@build.eclipse.org...
Dear James,
dear Ed,
far so good.
Thanks=20
Marc-Florian
Marc-Florian,
Comments below.
Dear Ed,
okay, that was a good point. 1-0 for you, as we say in =
Germany.=20
But, my point was also very good, because the elements, which =
i wanted to be participating in the union, aren't be computed correctly.
Only the top level children of the root element are computed =
as "ownedElements". And i really think, that this missbehaviour is a =
result of using the wrong List for computing the subsets. I've attached =
a simple model, which illustrates this missbehaviour. Here it is with no =
overhead:
Root
A
B
B
A2
C
Element
owner (union)
Root : Element
A:Element
B:Element
theA(subsets owner)
A2:Element
C:Element
When i call getOwnedElements in the Root model, the result is =
2. In uml2 philosophie, this should be 5, because every containment =
:-P
=20
Marc-Florian
Marc-Florian,
Probably a union should be transient. Looking at the =
example, it seems redundant to serialize a union. Worse than that in =
fact. I.e., given these union features aren't changeable, serializing =
Ed,
what kind of test case. I think th easiest way to =
reproduce this is to propagate the genmodel and ecore files, isn't it? =
I've attached them.
Marc-Florian
Marc-Florian,
Dear Ed,
with=20
it,=20
eption:=20
at=20
at=20
at=20
etImpl.java:397)
at =
at=20
Part.java:310)
at=20
java:661)
at=20
28)
at=20
ence.java:594)
at=20
blePart.java:180)
at=20
at=20
at=20
at=20
java:1256)
at=20
..java:63)
at=20
a:217)
at=20
207)
at=20
779)
at=20
ger.java:678)
at =
at=20
..java:2817)
at=20
729)
at =
at =
at =
at=20
at=20
at=20
at=20
tility.java:318)
at=20
tility.java:160)
at=20
at=20
ction.java:250)
at=20
at=20
at=20
0)
at=20
:818)
at=20
va:1079)
at=20
java:1183)
at =
at =
at=20
88)
at=20
8)
at=20
on.java:113)
at=20
va:193)
at=20
at=20
at=20
82)
at=20
79)
at=20
:2647)
at=20
ler.java:1135)
at=20
4)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at =
at=20
a:180)
at=20
445)
at=20
241)
at=20
tImpl.java:255)
at=20
... 79 more
at=20
at=20
EList.java:636)
at=20
1192)
at=20
:2642)
... 95 more
the=20
the=20
Marc-Florian
Marc-Florian,
change=20
GenModel.
Salute,
Back to business:
Marc-Florian
=20
Content-Type: text/html;
<HTML><HEAD>
<DIV><FONT face=3DArial size=3D2>Dear Kenn,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>thank you for your detailled answer. I =
agree with=20
your definition totally and will realize the allOwnedElements() method =
for the=20
case, that anyone needs access to all directly or indirectly owned=20
elements.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Have a nice day.</FONT></DIV>
<DIV>"Kenn Hussey" &lt;<A=20
href=3D"mailto:Kenn.Hussey@embarcadero.com">Kenn.Hussey@embarcadero.com</=
A>&gt;=20
schrieb im Newsbeitrag <A=20
href=3D"news:gdq9hj$dam$1@build.eclipse.org">news:gdq9hj$dam$1@build.ecli=
<DIV><FONT face=3DArial size=3D2>It's a well-established convention =
(for better or=20
associated=20
which=20
semantics are=20
but=20
given the above mentioned convention, we made the assumption that it =
shouldn't=20
be (otherwise the definition of the allOwnedElements() operation would =
be=20
&gt;=20
that's=20
the union=20
ownedElements would include any element, that participate in that=20
relationship via subset mechanism, in whatever hierarchy level they =
are=20
defined. But the way it now works isn't so far from that, what i've=20
expected. I've tried to add a containment relationship that doesn't=20
participate in the ownedElement relationship and it wasn't selected, =
when i=20
call getOwnedElements(). So far so good.</FONT></DIV>
from the=20
href=3D"mailto:jbruck@ca.ibm.com">jbruck@ca.ibm.com</A>&gt; =
schrieb im=20
Newsbeitrag <A=20
<DIV><FONT face=3DArial size=3D2>.. comments below =
....</FONT></DIV>
wrote in=20
message <A=20
type=3D"cite">
<DIV>&nbsp;</DIV>
1-0 for you,=20
keeping=20
score!<BR>
type=3D"cite">
good, because=20
aren't=20
be computed correctly.</FONT></DIV></BLOCKQUOTE>I wouldn't =
know correct=20
if I saw it. :-P<BR>
type=3D"cite">
<DIV><FONT face=3DArial size=3D2>Only the top level children =
of the root=20
that this=20
missbehaviour is a result of using the wrong List for =
computing the=20
<DIV>&nbsp;</DIV>
A</FONT></DIV>
B</FONT></DIV>
B</FONT></DIV>
A2</FONT></DIV>
C</FONT></DIV>
<DIV>&nbsp;</DIV>
references as=20
<DIV>&nbsp;</DIV>
ownedElements=20
owner)</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp;=20
modeableElements(subsets ownedElements)</FONT></DIV>
<DIV>&nbsp;</DIV>
(subsets=20
<DIV>&nbsp;</DIV>
theA(subsets=20
owner)</FONT></DIV>
<DIV>&nbsp;</DIV>
(subsets=20
<DIV>&nbsp;</DIV>
(subsets=20
owner)</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>When i call getOwnedElements =
in the Root=20
because=20
every containment reference is defined as a subset of the=20
ownedElements reference, hence, the references should =
contribute=20
themself into the derived union relationship. But this isn't =
done...=20
and again, i think this relates to the choice of the generated =
lists.=20
But i'm really not sure. If i would know, why this approach =
fails, i=20
wouldn't post here :-)</FONT></DIV></BLOCKQUOTE>
learned=20
little=20
longer. :-P</DIV>
type=3D"cite">
face=3DArial size=3D2>ut a doubt, Kenn is the master of =
subsets and=20
derived unions but in my humble opinion, calling =
getOwnedElements in=20
the root model and retrieving 2 elements is fine.&nbsp; This =
can be=20
considered all the "direct" owned elements. =
&nbsp;&nbsp;&nbsp;If you=20
want all the direct and indirect elements a special query,=20
<EM>allOwnedElements, </EM>&nbsp;is defined in the spec.&nbsp; =
see=20
section 7.3.14 in the "Additional Operations" =
im=20
a union should be transient.&nbsp; Looking at the example, =
it seems=20
fact.&nbsp;=20
serializing them=20
Wendland=20
wrote:=20
type=3D"cite">
<STYLE></STYLE>
<DIV>&nbsp;</DIV>
think th=20
and=20
ecore files, isn't it? I've attached them.</FONT></DIV>
<DIV>&nbsp;</DIV>
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; =
MARGIN-LEFT: 5px; BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" &lt;<A =
schrieb im=20
Newsbeitrag <A =
Marc-Florian,<BR><BR>It's=20
case?<BR><BR><BR>Marc-Florian Wendland wrote:=20
with=20
it,=20
eption:=20
at=20
at=20
at=20
etImpl.java:397)
at =
at=20
Part.java:310)
at=20
java:661)
at=20
28)
at=20
ence.java:594)
at=20
blePart.java:180)
at=20
at=20
at=20
at=20
java:1256)
at=20
..java:63)
at=20
a:217)
at=20
207)
at=20
779)
at=20
ger.java:678)
at =
at=20
..java:2817)
at=20
729)
at =
at =
at =
at=20
at=20
at=20
at=20
tility.java:318)
at=20
tility.java:160)
at=20
at=20
ction.java:250)
at=20
at=20
at=20
0)
at=20
:818)
at=20
va:1079)
at=20
java:1183)
at =
at =
at=20
88)
at=20
8)
at=20
on.java:113)
at=20
va:193)
at=20
at=20
at=20
82)
at=20
79)
at=20
:2647)
at=20
ler.java:1135)
at=20
4)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at =
at=20
a:180)
at=20
445)
at=20
241)
at=20
tImpl.java:255)
at=20
... 79 more
at=20
at=20
EList.java:636)
at=20
1192)
at=20
:2642)
... 95 more
the=20
the=20
Marc-Florian
Newsbeitrag=20
</PRE>
change=20
GenModel.
</PRE>
Back to business:
Marc-Florian
BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE></BODY ></HTML>
------=_NextPart_000_01F4_01C935D2.CCEC43D0--
Previous Topic:EMF Code generation from UML2 model fails
Next Topic:Difference in treating redfinded properties
Current Time: Mon Jul 28 03:37:40 EDT 2025
Powered by FUDForum. Page generated in 0.41755 seconds
