Home » Modeling » UML2 » problem with UML2.ecore file
problem with UML2.ecore file [message #477765] Mon, 29 September 2008 09:20 Go to next message
Originally posted by: jihed.touzi.enstimac.fr
Hi to all;
I'm working into a transformation that starts from a stereotyped UML2
model to genrate another DSL.
It works fine when in the metamodel field in the configuration panel i
specify it using NS URI: uri:http://www.eclipse.org/uml2/2.0.0/UML or
uri:http://www.eclipse.org/uml2/2.1.0/UML
The problem is when i use the physical UML2.ecore file of the same
version it doesn't works.
I obtain at first warnings like that:
ATTENTION: metamodel contains several classifiers with same name: EAttribute
ecore::EAttribute
EAnnotation
ecore::EAnnotation
ATTENTION: metamodel contains several classifiers with same name: EClass
ecore::EClass
and errors like that :
GRAVE: message: ERROR: could not find operation
getAppliedStereotypes on UML2!Class having supertypes:
[UML2!BehavioredClassifier, UML2!EncapsulatedClassifier, OclType,
OclAny] (including Java operations)
and
GRAVE: message: ERROR: could not find operation not on
Sequence(OclAny) having supertypes: [Collection(OclAny)]
Normally the UML2 file and the NsURI option have to do the same
tranformation.
Some one can help me ??
Thank you much.
Jihed
Re: problem with UML2.ecore file [message #477766 is a reply to message #477765] Mon, 29 September 2008 09:55 Go to previous messageGo to next message
Hi Jihed,
There may be issues in the original "stereotyped UML2 model". Where
exactly is this model coming from?
What version of UML2 are you using?
- James.
"jihed touzi" <jihed.touzi@enstimac.fr> wrote in message
news:gbqknv$t7p$2@build.eclipse.org...
> Hi to all;
> The problem is when i use the physical UML2.ecore file of the same version
> it doesn't works.
> EAttribute
> ecore::EAttribute
> EAnnotation
> ecore::EAnnotation
> ecore::EClass
> GRAVE: message: ERROR: could not find operation getAppliedStereotypes
> on UML2!Class having supertypes: [UML2!BehavioredClassifier,
> UML2!EncapsulatedClassifier, OclType, OclAny] (including Java operations)
> and
> tranformation.
> Thank you much.
> Jihed
Re: problem with UML2.ecore file [message #477771 is a reply to message #477766] Wed, 01 October 2008 07:21 Go to previous messageGo to next message
Hi james
the uml model is obtained using an atl transformation. the UML2
metamodel (specified using NS URI)is used.
The version is 2.0.0.
James Bruck a écrit :
> Hi Jihed,
> - James.
>> Hi to all;
>> it doesn't works.
>> EAttribute
>> ecore::EAttribute
>> EAnnotation
>> ecore::EAnnotation
>> ecore::EClass
>> and
>> tranformation.
>> Thank you much.
>> Jihed
Re: problem with UML2.ecore file [message #477772 is a reply to message #477771] Wed, 01 October 2008 18:21 Go to previous message
Hi Jihed,
This doesn't sound like an issue with the opensource UML2 project or any of
its models. It seems to be an issue with the generated UML2.ecore file
that you mention.
There is an ecore version of the uml metamodel already provided by the
project in org.eclipse.uml2.uml\models\UML.ecore. You may want to compare
that with the UML2.ecore that you have produced.
- James.
news:gbvmg6$u53$2@build.eclipse.org...
> Hi james
> the uml model is obtained using an atl transformation. the UML2 metamodel
> James Bruck a
Re: problem with UML2.ecore file [message #626964 is a reply to message #477765] Mon, 29 September 2008 09:55 Go to previous message
Hi Jihed,
- James.
> Hi to all;
> it doesn't works.
> EAttribute
> ecore::EAttribute
> EAnnotation
> ecore::EAnnotation
> ecore::EClass
> and
> tranformation.
> Thank you much.
> Jihed
Re: problem with UML2.ecore file [message #626969 is a reply to message #477766] Wed, 01 October 2008 07:21 Go to previous message
Hi james
> Hi Jihed,
> - James.
>> Hi to all;
>> it doesn't works.
>> EAttribute
>> ecore::EAttribute
>> EAnnotation
>> ecore::EAnnotation
>> ecore::EClass
>> and
>> tranformation.
>> Thank you much.
>> Jihed
Re: problem with UML2.ecore file [message #626970 is a reply to message #477771] Wed, 01 October 2008 18:21 Go to previous message
Hi Jihed,
that you mention.
- James.
> Hi james
> James Bruck a
Previous Topic:eclipse 3.5M2 versus uml2 tools?
Next Topic:eclipse 3.5M2 versus uml2 tools?
Current Time: Sat Jul 19 02:26:47 EDT 2025
Powered by FUDForum. Page generated in 0.04402 seconds
