Home » Modeling » UML2 » EditDomains and EAnnotation.getDetails() returns java.lang.ArrayStoreException?
EditDomains and EAnnotation.getDetails() returns java.lang.ArrayStoreException? [message #477565] Wed, 02 July 2008 13:50 Go to next message
Im trying to add annotation details to a UML2Model using commands and
editdomains. However I get the following exception.
> at org.eclipse.emf.common.util.BasicEList.assign(BasicEList.jav a:191)
> at org.eclipse.emf.common.util.BasicEList.addAllUnique(BasicELi st.java:803)
> at org.eclipse.emf.common.notify.impl.NotifyingListImpl.doAddAl lUnique(NotifyingListImpl.java:506)
> at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addAllU nique(NotifyingListImpl.java:446)
> at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addAllU nique(NotifyingListImpl.java:406)
> at org.eclipse.emf.common.util.BasicEList.addAll(BasicEList.jav a:716)
> at org.eclipse.emf.common.util.BasicEMap.addAll(BasicEMap.java: 1644)
> at org.eclipse.emf.edit.command.AddCommand.doExecute(AddCommand .java:403)
> at org.eclipse.emf.edit.command.AbstractOverrideableCommand.exe cute(AbstractOverrideableCommand.java:131)
> at org.eclipse.emf.common.command.CompoundCommand.execute(Compo undCommand.java:267)
> at org.eclipse.emf.common.command.BasicCommandStack.execute(Bas icCommandStack.java:84)
Ive been trying different kinds of Map.Entry but they all return the
same error. Below is a code snippet.
final String locationKey = "location"; //FIXME
Map.Entry<String, String> entry= new Map.Entry<String, String>(){
String fKey = locationKey;
String fValue;
* @return the key
public String getKey() {
return fKey;
* @return the value
public String getValue() {
return fValue;
* @param theArg0
* @return
public String setValue(String theValue) {
fValue = theValue;
return fValue;
entry.setValue(ref.getLocation().toString());
AddCommand addCmd = new AddCommand(fEditor.getEditingDomain(),
found, EcorePackage.eINSTANCE.getEAnnotation_Details(), entry);
cmd.append(addCmd);
any hints?
thanks
/anders
Re: EditDomains and EAnnotation.getDetails() returns java.lang.ArrayStoreException? [message #477578 is a reply to message #477565] Tue, 08 July 2008 08:16 Go to previous message
Anders,
Comments below.
Anders W.Tell wrote:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
> String fValue;
> * @return the key
> return fKey;
> * @return the value
> return fValue;
> * @param theArg0
> * @return
> fValue = theValue;
> return fValue;
> AddCommand(fEditor.getEditingDomain(), found,
> cmd.append(addCmd);
Use EcoreUtil.create(EcorePackage.Literals.ESTRING_TO_STRING_MAP _ENTRY)
to create an instance.
> any hints?
> thanks
> /anders
Re: EditDomains and EAnnotation.getDetails() returns java.lang.ArrayStoreException? [message #626771 is a reply to message #477565] Tue, 08 July 2008 08:16 Go to previous message
Anders,
Comments below.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
> String fValue;
> * @return the key
> return fKey;
> * @return the value
> return fValue;
> * @param theArg0
> * @return
> fValue = theValue;
> return fValue;
> cmd.append(addCmd);
> any hints?
> thanks
> /anders
Previous Topic:EAnnotation and Cross document reference
Next Topic:Unable to wrap long names... and other n00b questions :)
Current Time: Mon Jul 28 19:23:34 EDT 2025
Powered by FUDForum. Page generated in 0.15935 seconds
