Home » Modeling » UML2 » Loading a uml model with a profile (in an ATL transformation)
Loading a uml model with a profile (in an ATL transformation) [message #477510] Thu, 12 June 2008 08:20 Go to next message
Originally posted by: karp.no-mail.com
My question is about an ATL transformation but since it seems mostly
EMF/UML2 I ask it here.
I've got a simple transformation that take ModelA.uml in input and
ModelB.uml in output
ModelA.uml uses sterotypes from a profile 'Test.profile.uml'
Here is what I do in my program to register the resources. (ATL use the
EMF ResourceSet)
------------------------8<------------------------
ResourceSet resourceSet = ASMEMFModel.getResourceSet();
resourceSet.getPackageRegistry().put("http://www.eclipse.org/uml2/2.1.0/UML",
UMLPackage.eINSTANCE);
// Profile registration
resourceSet.getPackageRegistry().put("http:///schemas/Test/_UiwQwDhYEd2PFcRE_i9KZg/0",
URI uri =
URI.createURI(" jar:file:///D:/eclipse/eclipse-modeling-ganymede-RC1-win32/A TL_LIBS_RC3/org.eclipse.uml2.uml.resources_2.2.0.v2008051310 30.jar!/");
Map<URI, URI> uRIMap = resourceSet.getURIConverter().getURIMap();
uRIMap.put(URI.createURI(""), URI.createFileURI("PATH"));
uRIMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP),
uri.appendSegment("libraries").appendSegment(""));
uRIMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP),
uri.appendSegment("metamodels").appendSegment(""));
uRIMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP),
uri.appendSegment("profiles").appendSegment(""));
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(UMLResource.FILE_EXTENSION,
UMLResource.Factory.INSTANCE);
------------------------8<-------------------------
I've got a Java project from which I launch programatically the
transformation.
And I've got an ATL project where are located my models, profile, and my
transformation.
Now the problem is that when I launch (programmatically) my
transformation, I obtain this error :
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Package with
uri 'http:///schemas/Test/_UiwQwDhYEd2PFcRE_i9KZg/0' not found.
( file:///D:/Stage/eclipse-modeling-ganymede-RC1-win32/workspa ce/LaunchAtlUml/A,
23, 93)
EMF is looking for the profile in my Java project (LaunchAtlUml is my
Java project). If I put it there, it works fine.
But I would like to keep my profile in my Transformation project.
I suppose I can do that with the URIConverter or something like that.
Any idea ?
Re: Loading a uml model with a profile (in an ATL transformation) [message #477517 is a reply to message #477510] Fri, 13 June 2008 16:18 Go to previous messageGo to next message
Hi karp,
You may want to look at the following extension point:
org.eclipse.emf.ecore.uri_mapping
It can be used in the following way:
<extension
point="org.eclipse.emf.ecore.uri_mapping">
<mapping
source="pathmap://UML_LIBRARIES/"
target="platform:/plugin/org.eclipse.uml2.uml.resources/libraries/ ">
</mapping>
</extension>
- James.
"karp" <karp@no-mail.com> wrote in message
news:g2r4b5$vnj$2@build.eclipse.org...
> EMF ResourceSet)
> URI uri =
> transformation.
> transformation.
> 23, 93)
> EMF is looking for the profile in my Java project (LaunchAtlUml is my Java
> Any idea ?
Re: Loading a uml model with a profile (in an ATL transformation) [message #477550 is a reply to message #477517] Tue, 24 June 2008 04:21 Go to previous messageGo to next message
Thank for your answer,
The problem is I'm in a standalone app outside Eclipse.
And isn't your code sample a bit like what I did in the line below? (I
don't know, I know almost nothing about Eclipse plug-in and extension
point development).
James Bruck has written :
> Hi karp,
> <extension
> <mapping
> </mapping>
> </extension>
> Cheers,
> - James.
>> Hi,
>> EMF ResourceSet)
>> URI uri =
>> transformation.
>> transformation.
>> 23, 93)
>> Any idea ?
Re: Loading a uml model with a profile (in an ATL transformation) [message #477557 is a reply to message #477550] Thu, 26 June 2008 13:56 Go to previous message
Have a look at
http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2. 0_Migration_Guide/guide.html
toward the bottom at the section entitled "programmatic migration".
That shows how to work with a stand-alone app.
Let us know if you still have issues.
- James.
news:g3qar0$qe2$1@build.eclipse.org...
> point development).
>> Hi karp,
>> <extension
>> <mapping
>> </mapping>
>> </extension>
>> Cheers,
>> - James.
>>> Hi,
>>> EMF ResourceSet)
>>> URI uri =
>>> transformation.
>>> transformation.
>>> 23, 93)
>>> Any idea ?
Re: Loading a uml model with a profile (in an ATL transformation) [message #626707 is a reply to message #477510] Fri, 13 June 2008 16:18 Go to previous message
Hi karp,
<extension
<mapping
</mapping>
</extension>
- James.
> EMF ResourceSet)
> URI uri =
> transformation.
> transformation.
> 23, 93)
> Any idea ?
Re: Loading a uml model with a profile (in an ATL transformation) [message #626740 is a reply to message #477517] Tue, 24 June 2008 04:21 Go to previous message
point development).
> Hi karp,
> <extension
> <mapping
> </mapping>
> </extension>
> Cheers,
> - James.
>> Hi,
>> EMF ResourceSet)
>> URI uri =
>> transformation.
>> transformation.
>> 23, 93)
>> Any idea ?
Re: Loading a uml model with a profile (in an ATL transformation) [message #626748 is a reply to message #477550] Thu, 26 June 2008 13:56 Go to previous message
Have a look at
- James.
> point development).
>> Hi karp,
>> <extension
>> <mapping
>> </mapping>
>> </extension>
>> Cheers,
>> - James.
>>> Hi,
>>> EMF ResourceSet)
>>> URI uri =
>>> transformation.
>>> transformation.
>>> 23, 93)
>>> Any idea ?
Previous Topic:Use a UML model with a profile
Next Topic:How to access referenced models
Current Time: Fri Jul 25 11:09:42 EDT 2025
Powered by FUDForum. Page generated in 0.19658 seconds
