UML profiles multiplicties [message #477451] |
Tue, 27 May 2008 05:18  |
Originally posted by: Frederik.Gailly.ugent.be
I have defined a UML profile with different stereotype and between these
stereotypes I have defined several directed associations which also
contain multiplicities. When I now apply this profile on a model. The
eclipse validator sees which assoictions are missing but after I add the
correct association the validator still does not pass.
Frederik
Re: UML profiles multiplicties [message #477487 is a reply to message #477477] |
Wed, 04 June 2008 09:17  |
Hi Frederik,
The UML2 tools group can better answer what level of OCL validation support
is provided in their component. I've cc'd the question to that newsgroup.
- James.
"Frederik gailly" <Frederik.Gailly@ugent.be> wrote in message
news:g23c68$bh2$1@build.eclipse.org...
> Hi james
> Thank you for your reaction but I solved this issue. However I still have
> problems evaluating OCL constraint defined in my UML profile. Do the UML2
> tools not support OCL validation?
> Kind Regards,
> Frederik
> James Bruck wrote:
>> Hi Frederik,
>> What is the error that the validator is reporting? What exactly is not
>> passing? Can you explain what the profile looks like and the model
>> element you are applying it to?
>> Cheers,
>> - James.
>> news:g1gjl6$edq$1@build.eclipse.org...
>>> Hi,
>>> Frederik
Re: UML profiles multiplicties [message #626646 is a reply to message #477451] |
Mon, 02 June 2008 11:04  |
Hi Frederik,
passing? Can you explain what the profile looks like and the model element
- James.
> Frederik
Re: UML profiles multiplicties [message #626659 is a reply to message #477464] |
Tue, 03 June 2008 08:07  |
Hi james
have problems evaluating OCL constraint defined in my UML profile. Do
the UML2 tools not support OCL validation?
Kind Regards,
Frederik
James Bruck wrote:
> Hi Frederik,
> Cheers,
> - James.
>> Hi,
>> Frederik
Re: UML profiles multiplicties [message #626669 is a reply to message #477477] |
Hi Frederik,
- James.
> Hi james
> Kind Regards,
> Frederik
> James Bruck wrote:
>> Hi Frederik,
>> Cheers,
>> - James.
>>> Hi,
>>> Frederik
FUDForum. Page generated in 0.04441 seconds
