Home » Modeling » UML2 » UML Primitive types and non-primitive types
UML Primitive types and non-primitive types [message #477450] |
Mon, 26 May 2008 17:02  |
i have modeled some classes and want to include not the
UMLPrimitiveTypes, but types like Date, List, Map, etc. In my JET for
the concrete language, i than want to map between this "default" types
into the platform specific types, e.g. java.util.List for Java or even
array() for PHP.
What is the best solution for providing these types? One way, we had
suggested, was to remodel all the "default" types we need as
PrimitiveTypes of our model and the simply read them out during the
evaluation of the UML Superstructure.
Another idea was to use the Ecore datatypes.
But i think there is a more elegant solution for this common situation?
Thanks for any meanings
Timothy
Re: UML Primitive types and non-primitive types [message #477455 is a reply to message #477450] |
Wed, 28 May 2008 09:38   |
Hi Timothy,
You could possibly apply the Ecore profile and specify the java types.
Look at the 'Ecore Classifier' stereotype 'instance class name' for example.
Also have a look at the org.eclipse.uml2.uml.resources\libraries . There
are libraries for Java primitive types, XML primitive types etc.
Cheers
- James.
"Timothy Marc" <timothymarc@freenet.de> wrote in message
news:g1f8gs$f3$1@build.eclipse.org...
> i have modeled some classes and want to include not the UMLPrimitiveTypes,
> but types like Date, List, Map, etc. In my JET for the concrete language,
> i than want to map between this "default" types into the platform specific
> types, e.g. java.util.List for Java or even array() for PHP.
> Timothy
Re: UML Primitive types and non-primitive types [message #477459 is a reply to message #477455] |
Thu, 29 May 2008 05:29   |
Hey James,
i see. Let me consider, whether i have understood the import mechanism
correctly:
You can load several ressources into the model by using "Load Resource".
Than, one had to import the required elements such as Primitive Type int
(for Java, e.g.) with the "Element Import" node in the editor. Is that the
correct?
Timothy
"James Bruck" <jbruck@ca.ibm.com> schrieb im Newsbeitrag
news:g1jn7p$s5t$1@build.eclipse.org...
> Hi Timothy,
> example.
> Cheers
> - James.
>> Hi,
>> UMLPrimitiveTypes, but types like Date, List, Map, etc. In my JET for the
>> concrete language, i than want to map between this "default" types into
>> the platform specific types, e.g. java.util.List for Java or even array()
>> for PHP.
>> Timothy
Re: UML Primitive types and non-primitive types [message #477461 is a reply to message #477459] |
Fri, 30 May 2008 10:06   |
Hi Timothy,
Yes... have a look at the getting started article:
http://www.eclipse.org/modeling/mdt/uml2/docs/articles/Intro duction_to_UML2_Profiles/article.html
for tips on how to do this programatically and with the UML editor.
- James.
news:g1lt2g$kj0$1@build.eclipse.org...
> Hey James,
> correctly:
> correct?
> Thanks
> Timothy
>> Hi Timothy,
>> example.
>> There are libraries for Java primitive types, XML primitive types etc.
>> Cheers
>> - James.
>>> Hi,
>>> array() for PHP.
>>> Timothy
Re: UML Primitive types and non-primitive types [message #477469 is a reply to message #477459] |
Mon, 02 June 2008 20:38   |
Timothy,
It's actually not mandatory to import the elements you wish to reference...
all imports accomplish is that they allow reference to imported elements to
be made without having to use their qualified names (much like in Java).
Kenn
> Hey James,
> correctly:
> correct?
> Thanks
> Timothy
>> Hi Timothy,
>> example.
>> Cheers
>> - James.
>>> Hi,
>>> array() for PHP.
>>> Timothy
Re: UML Primitive types and non-primitive types [message #477475 is a reply to message #477469] |
Tue, 03 June 2008 06:58   |
Originally posted by: cdamus.zeligsoft.com
--=-NYBJQnhZXINggnIW7oMe
Content-Type: text/plain
Hi, Kenn,
Where in the UML are references made by name, except in expression
languages such as OCL?
cW
On Mon, 2008-06-02 at 20:38 -0400, Kenn Hussey wrote:
> Timothy,
> Kenn
> > Hey James,
> > correctly:
> > correct?
> > Thanks
> > Timothy
> >> Hi Timothy,
> >> example.
> >> Cheers
> >> - James.
> >>> Hi,
> >>> array() for PHP.
> >>> Timothy
Content-Type: text/html; charset=utf-8
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.16.0">
</HEAD>
<BODY>
Hi, Kenn,<BR>
<BR>
Where in the UML are references made by name, except in expression languages such as OCL?<BR>
<BR>
cW<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
<FONT COLOR="#000000">Timothy,</FONT>
<FONT COLOR="#000000">It's actually not mandatory to import the elements you wish to reference... </FONT>
<FONT COLOR="#000000">all imports accomplish is that they allow reference to imported elements to </FONT>
<FONT COLOR="#000000">be made without having to use their qualified names (much like in Java).</FONT>
<FONT COLOR="#000000">Kenn</FONT>
<FONT COLOR="#000000">"Timothy Marc" <<A HREF="mailto:timothymarc@freenet.de">timothymarc@freenet.de</A>> wrote in message </FONT>
<FONT COLOR="#000000">news:<A HREF="mailto:g1lt2g$kj0$1@build.eclipse.org">g1lt2g$kj0$1@build.eclipse.org</A>...</FONT>
<FONT COLOR="#000000">> Hey James,</FONT>
<FONT COLOR="#000000">></FONT>
<FONT COLOR="#000000">> i see. Let me consider, whether i have understood the import mechanism </FONT>
<FONT COLOR="#000000">> correctly:</FONT>
<FONT COLOR="#000000">> You can load several ressources into the model by using "Load Resource". </FONT>
<FONT COLOR="#000000">> Than, one had to import the required elements such as Primitive Type int </FONT>
<FONT COLOR="#000000">> (for Java, e.g.) with the "Element Import" node in the editor. Is that the </FONT>
<FONT COLOR="#000000">> correct?</FONT>
<FONT COLOR="#000000">> Thanks</FONT>
<FONT COLOR="#000000">> Timothy</FONT>
<FONT COLOR="#000000">> "James Bruck" <<A HREF="mailto:jbruck@ca.ibm.com">jbruck@ca.ibm.com</A>> schrieb im Newsbeitrag </FONT>
<FONT COLOR="#000000">> news:<A HREF="mailto:g1jn7p$s5t$1@build.eclipse.org">g1jn7p$s5t$1@build.eclipse.org</A>...</FONT>
<FONT COLOR="#000000">>> Hi Timothy,</FONT>
<FONT COLOR="#000000">>></FONT>
<FONT COLOR="#000000">>> You could possibly apply the Ecore profile and specify the java types. </FONT>
<FONT COLOR="#000000">>> Look at the 'Ecore Classifier' stereotype 'instance class name' for </FONT>
<FONT COLOR="#000000">>> example.</FONT>
<FONT COLOR="#000000">>> Also have a look at the org.eclipse.uml2.uml.resources\libraries . </FONT>
<FONT COLOR="#000000">>> There are libraries for Java primitive types, XML primitive types etc.</FONT>
<FONT COLOR="#000000">>> Cheers</FONT>
<FONT COLOR="#000000">>> - James.</FONT>
<FONT COLOR="#000000">>> "Timothy Marc" <<A HREF="mailto:timothymarc@freenet.de">timothymarc@freenet.de</A>> wrote in message </FONT>
<FONT COLOR="#000000">>> news:<A HREF="mailto:g1f8gs$f3$1@build.eclipse.org">g1f8gs$f3$1@build.eclipse.org</A>...</FONT>
<FONT COLOR="#000000">>>> Hi,</FONT>
<FONT COLOR="#000000">>>></FONT>
<FONT COLOR="#000000">>>> i have modeled some classes and want to include not the </FONT>
<FONT COLOR="#000000">>>> UMLPrimitiveTypes, but types like Date, List, Map, etc. In my JET for </FONT>
<FONT COLOR="#000000">>>> the concrete language, i than want to map between this "default" types </FONT>
<FONT COLOR="#000000">>>> into the platform specific types, e.g. java.util.List for Java or even </FONT>
<FONT COLOR="#000000">>>> array() for PHP.</FONT>
<FONT COLOR="#000000">>>> What is the best solution for providing these types? One way, we had </FONT>
<FONT COLOR="#000000">>>> suggested, was to remodel all the "default" types we need as </FONT>
<FONT COLOR="#000000">>>> PrimitiveTypes of our model and the simply read them out during the </FONT>
<FONT COLOR="#000000">>>> evaluation of the UML Superstructure.</FONT>
<FONT COLOR="#000000">>>> Another idea was to use the Ecore datatypes.</FONT>
<FONT COLOR="#000000">>>> But i think there is a more elegant solution for this common situation?</FONT>
<FONT COLOR="#000000">>>> Thanks for any meanings</FONT>
<FONT COLOR="#000000">>>> Timothy</FONT>
<FONT COLOR="#000000">> </FONT>
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-NYBJQnhZXINggnIW7oMe--
Re: UML Primitive types and non-primitive types [message #477476 is a reply to message #477475] |
Tue, 03 June 2008 07:20   |
--------------070806000104000404050102
Christian,
It's funny you ask the same question that popped to mind when I read the
aliasing question from Felix. It's a bit odd that there is a feature in
there to support some sort of lexical scoping that's not directly used
by UML itself. I suppose that's convenient to someone, but it seems to
make assumptions about how such lexical scoping ought to work without a
demonstrated use case. I wonder if there are constraints that two
imports use the same unqualified name, or if two imports result in
collisions with each other or a collision with something locally visible
already. I guess package imports can induce all such problems too,
except for the aliasing support...
Christian W. Damus wrote:
> Hi, Kenn,
> cW
>> Timothy,
>> Kenn
>> "Timothy Marc" <timothymarc@freenet.de <mailto:timothymarc@freenet.de>> wrote in message
>> news:g1lt2g$kj0$1@build.eclipse.org <mailto:g1lt2g$kj0$1@build.eclipse.org>...
>> > Hey James,
>> > correctly:
>> > correct?
>> > Thanks
>> > Timothy
>> > "James Bruck" <jbruck@ca.ibm.com <mailto:jbruck@ca.ibm.com>> schrieb im Newsbeitrag
>> > news:g1jn7p$s5t$1@build.eclipse.org <mailto:g1jn7p$s5t$1@build.eclipse.org>...
>> >> Hi Timothy,
>> >> example.
>> >> Cheers
>> >> - James.
>> >> news:g1f8gs$f3$1@build.eclipse.org <mailto:g1f8gs$f3$1@build.eclipse.org>...
>> >>> Hi,
>> >>> array() for PHP.
>> >>> Timothy
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Christian,<br>
<br>
the aliasing question from Felix. It's a bit odd that there is a
feature in there to support some sort of lexical scoping that's not
directly used by UML itself. I suppose that's convenient to someone,
but it seems to make assumptions about how such lexical scoping ought
to work without a demonstrated use case. I wonder if there are
constraints that two imports use the same unqualified name, or if two
imports result in collisions with each other or a collision with
something locally visible already. I guess package imports can induce
all such problems too, except for the aliasing support...<br>
<br>
<br>
<blockquote cite="mid:1212490687.6514.10.camel@cwdlappy" type="cite">
<meta http-equiv="Content-Type" content="text/html; ">
<meta name="GENERATOR" content="GtkHTML/3.16.0">
Hi, Kenn,<br>
<br>
languages such as OCL?<br>
<br>
cW<br>
<br>
<blockquote type="CITE">
<pre><font color="#000000">Timothy,</font>
<font color="#000000">It's actually not mandatory to import the elements you wish to reference... </font>
<font color="#000000">all imports accomplish is that they allow reference to imported elements to </font>
<font color="#000000">be made without having to use their qualified names (much like in Java).</font>
<font color="#000000">Kenn</font>
<font color="#000000">"Timothy Marc" <<a moz-do-not-send="true"
href="mailto:timothymarc@freenet.de">timothymarc@freenet.de</a>> wrote in message </font>
<font color="#000000">news:<a moz-do-not-send="true"
href="mailto:g1lt2g$kj0$1@build.eclipse.org">g1lt2g$kj0$1@build.eclipse.org</a>...</font>
<font color="#000000">> Hey James,</font>
<font color="#000000">></font>
<font color="#000000">> i see. Let me consider, whether i have understood the import mechanism </font>
<font color="#000000">> correctly:</font>
<font color="#000000">> You can load several ressources into the model by using "Load Resource". </font>
<font color="#000000">> Than, one had to import the required elements such as Primitive Type int </font>
<font color="#000000">> (for Java, e.g.) with the "Element Import" node in the editor. Is that the </font>
<font color="#000000">> correct?</font>
<font color="#000000">> Thanks</font>
<font color="#000000">> Timothy</font>
<font color="#000000">> "James Bruck" <<a moz-do-not-send="true"
href="mailto:jbruck@ca.ibm.com">jbruck@ca.ibm.com</a>> schrieb im Newsbeitrag </font>
<font color="#000000">> news:<a moz-do-not-send="true"
href="mailto:g1jn7p$s5t$1@build.eclipse.org">g1jn7p$s5t$1@build.eclipse.org</a>...</font>
<font color="#000000">>> Hi Timothy,</font>
<font color="#000000">>></font>
<font color="#000000">>> You could possibly apply the Ecore profile and specify the java types. </font>
<font color="#000000">>> Look at the 'Ecore Classifier' stereotype 'instance class name' for </font>
<font color="#000000">>> example.</font>
<font color="#000000">>> Also have a look at the org.eclipse.uml2.uml.resources\libraries . </font>
<font color="#000000">>> There are libraries for Java primitive types, XML primitive types etc.</font>
<font color="#000000">>> Cheers</font>
<font color="#000000">>> - James.</font>
<font color="#000000">>> "Timothy Marc" <<a
moz-do-not-send="true" href="mailto:timothymarc@freenet.de">timothymarc@freenet.de</a>> wrote in message </font>
<font color="#000000">>> news:<a moz-do-not-send="true"
href="mailto:g1f8gs$f3$1@build.eclipse.org">g1f8gs$f3$1@build.eclipse.org</a>...</font>
<font color="#000000">>>> Hi,</font>
<font color="#000000">>>></font>
<font color="#000000">>>> i have modeled some classes and want to include not the </font>
<font color="#000000">>>> UMLPrimitiveTypes, but types like Date, List, Map, etc. In my JET for </font>
<font color="#000000">>>> the concrete language, i than want to map between this "default" types </font>
<font color="#000000">>>> into the platform specific types, e.g. java.util.List for Java or even </font>
<font color="#000000">>>> array() for PHP.</font>
<font color="#000000">>>> What is the best solution for providing these types? One way, we had </font>
<font color="#000000">>>> suggested, was to remodel all the "default" types we need as </font>
<font color="#000000">>>> PrimitiveTypes of our model and the simply read them out during the </font>
<font color="#000000">>>> evaluation of the UML Superstructure.</font>
<font color="#000000">>>> Another idea was to use the Ecore datatypes.</font>
<font color="#000000">>>> But i think there is a more elegant solution for this common situation?</font>
<font color="#000000">>>> Thanks for any meanings</font>
<font color="#000000">>>> Timothy</font>
<font color="#000000">> </font>
</pre>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------070806000104000404050102--
Re: UML Primitive types and non-primitive types [message #477480 is a reply to message #477475] |
Tue, 03 June 2008 23:35   |
Christian,
That is useful at the notation level (concrete syntax), if you want to
allow the user to refer to elements from other packages using
unqualified names. Whether a fully qualified name or an unqualified
named was used when referencing an element is lost in the resulting
model. A graphical tool can keep that information in the diagram.
Rafael
> Hi, Kenn,
> cW
>> Timothy,
>> Kenn
>> > Hey James,
>> > correctly:
>> > correct?
>> > Thanks
>> > Timothy
>> >> Hi Timothy,
>> >> example.
>> >> Cheers
>> >> - James.
>> >>> Hi,
>> >>> array() for PHP.
>> >>> Timothy
Re: UML Primitive types and non-primitive types [message #477481 is a reply to message #477480] |
Tue, 03 June 2008 23:40   |
--=-x3pRKMELGMzB1gQ+bsBx
Hi, Rafael,
That makes sense. Textual notations for specifying models, such as HUTN
or something generated by TMF/Xtext, would presumably make use of these
imported names.
Christian
On Tue, 2008-06-03 at 20:35 -0700, Rafael Chaves wrote:
> Christian,
> Rafael
> > Hi, Kenn,
> > cW
> >> Timothy,
> >> Kenn
> >> > Hey James,
> >> > correctly:
> >> > correct?
> >> > Thanks
> >> > Timothy
> >> >> Hi Timothy,
> >> >> example.
> >> >> Cheers
> >> >> - James.
> >> >>> Hi,
> >> >>> array() for PHP.
> >> >>> Timothy
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Rafael,<BR>
<BR>
That makes sense. Textual notations for specifying models, such as HUTN or something generated by TMF/Xtext, would presumably make use of these imported names.<BR>
<BR>
Cheers,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
<FONT COLOR="#000000">Christian,</FONT>
<FONT COLOR="#000000">That is useful at the notation level (concrete syntax), if you want to </FONT>
<FONT COLOR="#000000">allow the user to refer to elements from other packages using </FONT>
<FONT COLOR="#000000">unqualified names. Whether a fully qualified name or an unqualified </FONT>
<FONT COLOR="#000000">named was used when referencing an element is lost in the resulting </FONT>
<FONT COLOR="#000000">model. A graphical tool can keep that information in the diagram.</FONT>
<FONT COLOR="#000000">Rafael</FONT>
<FONT COLOR="#000000">Christian W. Damus wrote:</FONT>
<FONT COLOR="#000000">> Hi, Kenn,</FONT>
<FONT COLOR="#000000">> Where in the UML are references made by name, except in expression </FONT>
<FONT COLOR="#000000">> languages such as OCL?</FONT>
<FONT COLOR="#000000">> cW</FONT>
<FONT COLOR="#000000">> On Mon, 2008-06-02 at 20:38 -0400, Kenn Hussey wrote:</FONT>
<FONT COLOR="#000000">>> Timothy,</FONT>
<FONT COLOR="#000000">>> It's actually not mandatory to import the elements you wish to reference... </FONT>
<FONT COLOR="#000000">>> all imports accomplish is that they allow reference to imported elements to </FONT>
<FONT COLOR="#000000">>> be made without having to use their qualified names (much like in Java).</FONT>
<FONT COLOR="#000000">>> Kenn</FONT>
<FONT COLOR="#000000">>> "Timothy Marc" <<A HREF="mailto:timothymarc@freenet.de">timothymarc@freenet.de</A> <<A HREF="mailto:timothymarc@freenet.de">mailto:timothymarc@freenet.de</A>>> wrote in message </FONT>
<FONT COLOR="#000000">>> news:<A HREF="mailto:g1lt2g$kj0$1@build.eclipse.org">g1lt2g$kj0$1@build.eclipse.org</A> <<A HREF="mailto:g1lt2g$kj0$1@build.eclipse.org">mailto:g1lt2g$kj0$1@build.eclipse.org</A>>...</FONT>
<FONT COLOR="#000000">>> > Hey James,</FONT>
<FONT COLOR="#000000">>> ></FONT>
<FONT COLOR="#000000">>> > i see. Let me consider, whether i have understood the import mechanism </FONT>
<FONT COLOR="#000000">>> > correctly:</FONT>
<FONT COLOR="#000000">>> > You can load several ressources into the model by using "Load Resource". </FONT>
<FONT COLOR="#000000">>> > Than, one had to import the required elements such as Primitive Type int </FONT>
<FONT COLOR="#000000">>> > (for Java, e.g.) with the "Element Import" node in the editor. Is that the </FONT>
<FONT COLOR="#000000">>> > correct?</FONT>
<FONT COLOR="#000000">>> > Thanks</FONT>
<FONT COLOR="#000000">>> > Timothy</FONT>
<FONT COLOR="#000000">>> > "James Bruck" <<A HREF="mailto:jbruck@ca.ibm.com">jbruck@ca.ibm.com</A> <<A HREF="mailto:jbruck@ca.ibm.com">mailto:jbruck@ca.ibm.com</A>>> schrieb im Newsbeitrag </FONT>
<FONT COLOR="#000000">>> > news:<A HREF="mailto:g1jn7p$s5t$1@build.eclipse.org">g1jn7p$s5t$1@build.eclipse.org</A> <<A HREF="mailto:g1jn7p$s5t$1@build.eclipse.org">mailto:g1jn7p$s5t$1@build.eclipse.org</A>>...</FONT>
<FONT COLOR="#000000">>> >> Hi Timothy,</FONT>
<FONT COLOR="#000000">>> >></FONT>
<FONT COLOR="#000000">>> >> You could possibly apply the Ecore profile and specify the java types. </FONT>
<FONT COLOR="#000000">>> >> Look at the 'Ecore Classifier' stereotype 'instance class name' for </FONT>
<FONT COLOR="#000000">>> >> example.</FONT>
<FONT COLOR="#000000">>> >> Also have a look at the org.eclipse.uml2.uml.resources\libraries . </FONT>
<FONT COLOR="#000000">>> >> There are libraries for Java primitive types, XML primitive types etc.</FONT>
<FONT COLOR="#000000">>> >> Cheers</FONT>
<FONT COLOR="#000000">>> >> - James.</FONT>
<FONT COLOR="#000000">>> >> "Timothy Marc" <<A HREF="mailto:timothymarc@freenet.de">timothymarc@freenet.de</A> <<A HREF="mailto:timothymarc@freenet.de">mailto:timothymarc@freenet.de</A>>> wrote in message </FONT>
<FONT COLOR="#000000">>> >> news:<A HREF="mailto:g1f8gs$f3$1@build.eclipse.org">g1f8gs$f3$1@build.eclipse.org</A> <<A HREF="mailto:g1f8gs$f3$1@build.eclipse.org">mailto:g1f8gs$f3$1@build.eclipse.org</A>>...</FONT>
<FONT COLOR="#000000">>> >>> Hi,</FONT>
<FONT COLOR="#000000">>> >>></FONT>
<FONT COLOR="#000000">>> >>> i have modeled some classes and want to include not the </FONT>
<FONT COLOR="#000000">>> >>> UMLPrimitiveTypes, but types like Date, List, Map, etc. In my JET for </FONT>
<FONT COLOR="#000000">>> >>> the concrete language, i than want to map between this "default" types </FONT>
<FONT COLOR="#000000">>> >>> into the platform specific types, e.g. java.util.List for Java or even </FONT>
<FONT COLOR="#000000">>> >>> array() for PHP.</FONT>
<FONT COLOR="#000000">>> >>> What is the best solution for providing these types? One way, we had </FONT>
<FONT COLOR="#000000">>> >>> suggested, was to remodel all the "default" types we need as </FONT>
<FONT COLOR="#000000">>> >>> PrimitiveTypes of our model and the simply read them out during the </FONT>
<FONT COLOR="#000000">>> >>> evaluation of the UML Superstructure.</FONT>
<FONT COLOR="#000000">>> >>> Another idea was to use the Ecore datatypes.</FONT>
<FONT COLOR="#000000">>> >>> But i think there is a more elegant solution for this common situation?</FONT>
<FONT COLOR="#000000">>> >>> Thanks for any meanings</FONT>
<FONT COLOR="#000000">>> >>> Timothy</FONT>
<FONT COLOR="#000000">>> > </FONT>
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-x3pRKMELGMzB1gQ+bsBx--
Re: UML Primitive types and non-primitive types [message #477492 is a reply to message #477476] |
Mon, 09 June 2008 11:52   |
------=_NextPart_000_006D_01C8CA27.49AF2710
charset="utf-8"
Content-Transfer-Encoding: quoted-printable
I assume the references would be in expressions used by constraints, for =
example. In the absence of a surface language, these semantics aren't =
all that meaningful to UML itself...
Kenn
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:g2399u$rbl$2@build.eclipse.org...
Christian,
It's funny you ask the same question that popped to mind when I read =
the aliasing question from Felix. It's a bit odd that there is a =
feature in there to support some sort of lexical scoping that's not =
directly used by UML itself. I suppose that's convenient to someone, =
but it seems to make assumptions about how such lexical scoping ought to =
work without a demonstrated use case. I wonder if there are constraints =
that two imports use the same unqualified name, or if two imports result =
in collisions with each other or a collision with something locally =
visible already. I guess package imports can induce all such problems =
Christian W. Damus wrote:=20
Hi, Kenn,
Where in the UML are references made by name, except in expression =
cW
On Mon, 2008-06-02 at 20:38 -0400, Kenn Hussey wrote:=20
Timothy,
It's actually not mandatory to import the elements you wish to =
reference...=20
all imports accomplish is that they allow reference to imported elements =
to=20
Kenn
"Timothy Marc" <timothymarc@freenet.de> wrote in message=20
> Hey James,
> i see. Let me consider, whether i have understood the import mechanism =
> correctly:
> You can load several ressources into the model by using "Load =
Resource".=20
> Than, one had to import the required elements such as Primitive Type =
int=20
> (for Java, e.g.) with the "Element Import" node in the editor. Is that =
the=20
> correct?
> Thanks
> Timothy
> "James Bruck" <jbruck@ca.ibm.com> schrieb im Newsbeitrag=20
>> Hi Timothy,
>> You could possibly apply the Ecore profile and specify the java =
types.=20
>> Look at the 'Ecore Classifier' stereotype 'instance class name' for=20
>> example.
>> Also have a look at the org.eclipse.uml2.uml.resources\libraries .=20
>> There are libraries for Java primitive types, XML primitive types =
etc.
>> Cheers
>> - James.
>>> Hi,
>>> i have modeled some classes and want to include not the=20
>>> UMLPrimitiveTypes, but types like Date, List, Map, etc. In my JET =
for=20
>>> the concrete language, i than want to map between this "default" =
types=20
>>> into the platform specific types, e.g. java.util.List for Java or =
even=20
>>> array() for PHP.
>>> What is the best solution for providing these types? One way, we had =
>>> suggested, was to remodel all the "default" types we need as=20
>>> PrimitiveTypes of our model and the simply read them out during the=20
>>> But i think there is a more elegant solution for this common =
situation?
>>> Timothy
>=20
=20
charset="utf-8"
=EF=BB=BF<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3Dtext/html;charset=3DUTF-8>
<META content=3D"MSHTML 6.00.6000.16640" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>I assume the references would be in =
expressions=20
used by constraints, for example. In the absence of a surface language, =
these=20
semantics aren't all that meaningful to UML itself...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Kenn</FONT></DIV>
<DIV> </DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:g2399u$rbl$2@build.eclipse.org">news:g2399u$rbl$2@build.ecli=
pse.org</A>...</DIV>Christian,<BR><BR>It's=20
funny you ask the same question that popped to mind when I read the =
aliasing=20
question from Felix. It's a bit odd that there is a feature in =
there to=20
support some sort of lexical scoping that's not directly used by UML=20
itself. I suppose that's convenient to someone, but it seems to =
make=20
assumptions about how such lexical scoping ought to work without a=20
demonstrated use case. I wonder if there are constraints that =
two=20
imports use the same unqualified name, or if two imports result in =
collisions=20
with each other or a collision with something locally visible =
already. I=20
guess package imports can induce all such problems too, except for the =
aliasing support...<BR><BR><BR>Christian W. Damus wrote:=20
<BLOCKQUOTE cite=3Dmid:1212490687.6514.10.camel@cwdlappy =
type=3D"cite">
<META content=3DGtkHTML/3.16.0 name=3DGENERATOR>Hi, =
Kenn,<BR><BR>Where in the=20
UML are references made by name, except in expression languages such =
as=20
OCL?<BR><BR>cW<BR><BR>On Mon, 2008-06-02 at 20:38 -0400, Kenn Hussey =
wrote:=20
<BLOCKQUOTE type=3D"CITE"><PRE><FONT color=3D#000000>Timothy,</FONT>
<FONT color=3D#000000>It's actually not mandatory to import the elements =
<FONT color=3D#000000>all imports accomplish is that they allow =
<FONT color=3D#000000>be made without having to use their qualified =
<FONT color=3D#000000>Kenn</FONT>
<FONT color=3D#000000>"Timothy Marc" <<A =
href=3D"mailto:timothymarc@freenet.de" =
moz-do-not-send=3D"true">timothymarc@freenet.de</A>> wrote in message =
</FONT>
<FONT color=3D#000000>news:<A =
href=3D"mailto:g1lt2g$kj0$1@build.eclipse.org" =
moz-do-not-send=3D"true">g1lt2g$kj0$1@build.eclipse.org</A>...</FONT>
<FONT color=3D#000000>> Hey James,</FONT>
<FONT color=3D#000000>></FONT>
<FONT color=3D#000000>> i see. Let me consider, whether i have =
<FONT color=3D#000000>> correctly:</FONT>
<FONT color=3D#000000>> You can load several ressources into the =
<FONT color=3D#000000>> Than, one had to import the required elements =
<FONT color=3D#000000>> (for Java, e.g.) with the "Element Import" =
<FONT color=3D#000000>> correct?</FONT>
<FONT color=3D#000000>> Thanks</FONT>
<FONT color=3D#000000>> Timothy</FONT>
<FONT color=3D#000000>> "James Bruck" <<A =
href=3D"mailto:jbruck@ca.ibm.com" =
moz-do-not-send=3D"true">jbruck@ca.ibm.com</A>> schrieb im =
Newsbeitrag </FONT>
<FONT color=3D#000000>> news:<A =
href=3D"mailto:g1jn7p$s5t$1@build.eclipse.org" =
moz-do-not-send=3D"true">g1jn7p$s5t$1@build.eclipse.org</A>...</FONT>
<FONT color=3D#000000>>> Hi Timothy,</FONT>
<FONT color=3D#000000>>></FONT>
<FONT color=3D#000000>>> You could possibly apply the Ecore =
<FONT color=3D#000000>>> Look at the 'Ecore Classifier' stereotype =
<FONT color=3D#000000>>> example.</FONT>
<FONT color=3D#000000>>> Also have a look at the =
<FONT color=3D#000000>>> There are libraries for Java primitive =
<FONT color=3D#000000>>> Cheers</FONT>
<FONT color=3D#000000>>> - James.</FONT>
<FONT color=3D#000000>>> "Timothy Marc" <<A =
</FONT>
<FONT color=3D#000000>>> news:<A =
href=3D"mailto:g1f8gs$f3$1@build.eclipse.org" =
moz-do-not-send=3D"true">g1f8gs$f3$1@build.eclipse.org</A>...</FONT>
<FONT color=3D#000000>>>> Hi,</FONT>
<FONT color=3D#000000>>>></FONT>
<FONT color=3D#000000>>>> i have modeled some classes and want =
<FONT color=3D#000000>>>> UMLPrimitiveTypes, but types like =
<FONT color=3D#000000>>>> the concrete language, i than want to =
<FONT color=3D#000000>>>> into the platform specific types, =
<FONT color=3D#000000>>>> array() for PHP.</FONT>
<FONT color=3D#000000>>>> What is the best solution for =
<FONT color=3D#000000>>>> suggested, was to remodel all the =
<FONT color=3D#000000>>>> PrimitiveTypes of our model and the =
<FONT color=3D#000000>>>> evaluation of the UML =
<FONT color=3D#000000>>>> Another idea was to use the Ecore =
datatypes.</FONT>
<FONT color=3D#000000>>>> But i think there is a more elegant =
<FONT color=3D#000000>>>> Thanks for any meanings</FONT>
<FONT color=3D#000000>>>> Timothy</FONT>
<FONT color=3D#000000>> </FONT>
</PRE></BLOCKQUOTE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY ></HTML>
------=_NextPart_000_006D_01C8CA27.49AF2710--
Re: UML plugin for graphically creating and editing UML models [message #477538 is a reply to message #477534] |
Wed, 18 June 2008 10:37   |
Originally posted by: jmcq.cs.nuim.ie
Thanks for the help that was exactly what I was looking for.
Currently, I'm trying to familiarise myself with the UML metamodel and
how class and sequence diagrams are represented as instances of the UML
metamodel (the one provided by the UML2 project). So to do this I'm
creating some class and sequence diagrams using the modelling tools (e.g
papyrus and topcased) and looking at the corresponding .uml files.
However, one thing that has me confused is that it appears that not all
attributes and references of certain metamodel elements are available.
For example, when you look at the actual metamodel file the element
Class has several attributes and references (e.g. ownedAttribute,
extension, superClass etc.) and also inherited ones (eg. attribute,
package, ownedPort, generalization etc.).
I've noticed that only some of these can be given values either via the
properties view or the add child option from the menu (e.g.
ownedAttribute, ownedPort, generalization) but others can not be given
values at all (e.g. superClass, extension, attribute, package).
Is this a choice made by the particular modelling tool or is it as a
result of the UML metamodel? For example, does it depend on the value of
certain attributes (changeable, derived etc) of the attributes and
references?
I'd really appreciate if someone could clarify this point for me or
direct me to some reading material that would help me understand this
better.
Thanks in advance,
Jacqui
James Bruck wrote:
> ... I believe this is the link ...
> http://wiki.eclipse.org/MDT-UML2-Tool-Compatibility
> "urs zeidler" <me@urszeidler.de> wrote in message
> news:g37ooe$mop$1@build.eclipse.org...
>> Jacqui wrote:
>>> Hi all,
>>> Can anyone recommend an Eclipse plugin that supports the creation and
>>> editing of UML Class and Sequence diagrams graphically and also allows
>>> you to view these diagrams as .uml files (i.e. instances of the UML2
>>> metamodel provided by the UML project).
>>> Alternatively, can anyone recommend where I could find an example of a
>>> UML sequence diagram in .uml format and its corresponding visual
>>> representation.
>>> Thanks in advance,
>>> Jacqui
>> Try http://www.topcased.org but I think there is a list in the wiki gives
>> you all the choice.
>> greetings
Re: UML plugin for graphically creating and editing UML models [message #477539 is a reply to message #477538] |
Wed, 18 June 2008 16:15   |
Hi Jacqui,
From the upper right corner of the properties view select the "Show Advanced
Properties" button (second button in the list). That will reveal more
properties.
I hope that is what you are looking for.
- James.
"Jacqui" <jmcq@cs.nuim.ie> wrote in message
news:g3b6j4$52i$1@build.eclipse.org...
> Currently, I'm trying to familiarise myself with the UML metamodel and how
> attributes and references of certain metamodel elements are available. For
> example, when you look at the actual metamodel file the element Class has
> several attributes and references (e.g. ownedAttribute, extension,
> superClass etc.) and also inherited ones (eg. attribute, package,
> references?
> I'd really appreciate if someone could clarify this point for me or direct
> me to some reading material that would help me understand this better.
> Thanks in advance,
> Jacqui
>>> Jacqui wrote:
>>>> Hi all,
>>>> representation.
>>>> Thanks in advance,
>>>> Jacqui
>>> gives you all the choice.
>>> greetings
Re: UML plugin for graphically creating and editing UML models [message #477541 is a reply to message #477539] |
Wed, 18 June 2008 17:13  |
Thanks James - this is exactly what I was looking for.
How silly of me trying to make it more complicated than it is!
Thanks again.
Jacqui
James Bruck wrote:
> Hi Jacqui,
> properties.
> Cheers,
> - James.
>> Hi,
>> references?
>> Thanks in advance,
>> Jacqui
>>>> Jacqui wrote:
>>>>> Hi all,
>>>>> representation.
>>>>> Thanks in advance,
>>>>> Jacqui
>>>> greetings
Re: UML Primitive types and non-primitive types [message #626637 is a reply to message #477450] |
Hi Timothy,
Cheers
- James.
> Timothy
Re: UML Primitive types and non-primitive types [message #626641 is a reply to message #477455] |
Hey James,
correctly:
correct?
Timothy
> Hi Timothy,
> example.
> Cheers
> - James.
>> Hi,
>> for PHP.
>> Timothy
Re: UML Primitive types and non-primitive types [message #626643 is a reply to message #477459] |
Hi Timothy,
- James.
> Hey James,
> correctly:
> correct?
> Thanks
> Timothy
>> Hi Timothy,
>> example.
>> Cheers
>> - James.
>>> Hi,
>>> array() for PHP.
>>> Timothy
Re: UML Primitive types and non-primitive types [message #626651 is a reply to message #477459] |
Timothy,
Kenn
> Hey James,
> correctly:
> correct?
> Thanks
> Timothy
>> Hi Timothy,
>> example.
>> Cheers
>> - James.
>>> Hi,
>>> array() for PHP.
>>> Timothy
Re: UML Primitive types and non-primitive types [message #626657 is a reply to message #477469] |
Hi, Kenn,
cW
> Timothy,
> Kenn
> > Hey James,
> > correctly:
> > correct?
> > Thanks
> > Timothy
> >> Hi Timothy,
> >> example.
> >> Cheers
> >> - James.
> >>> Hi,
> >>> array() for PHP.
> >>> Timothy
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Kenn,<BR>
<BR>
<BR>
cW<BR>
<BR>
<PRE>
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
Re: UML Primitive types and non-primitive types [message #626658 is a reply to message #477475] |
Christian,
> Hi, Kenn,
> cW
>> Timothy,
>> Kenn
>> > Hey James,
>> > correctly:
>> > correct?
>> > Thanks
>> > Timothy
>> >> Hi Timothy,
>> >> example.
>> >> Cheers
>> >> - James.
>> >>> Hi,
>> >>> array() for PHP.
>> >>> Timothy
<html>
<head>
</head>
Christian,<br>
<br>
<br>
<br>
Hi, Kenn,<br>
<br>
<br>
cW<br>
<br>
</pre>
</blockquote>
</blockquote>
<br>
</body>
</html>
Re: UML Primitive types and non-primitive types [message #626662 is a reply to message #477475] |
Christian,
Rafael
> Hi, Kenn,
> cW
>> Timothy,
>> Kenn
>> > Hey James,
>> > correctly:
>> > correct?
>> > Thanks
>> > Timothy
>> >> Hi Timothy,
>> >> example.
>> >> Cheers
>> >> - James.
>> >>> Hi,
>> >>> array() for PHP.
>> >>> Timothy
Re: UML Primitive types and non-primitive types [message #626663 is a reply to message #477480] |
Hi, Rafael,
imported names.
Christian
> Christian,
> Rafael
> > Hi, Kenn,
> > cW
> >> Timothy,
> >> Kenn
> >> > Hey James,
> >> > correctly:
> >> > correct?
> >> > Thanks
> >> > Timothy
> >> >> Hi Timothy,
> >> >> example.
> >> >> Cheers
> >> >> - James.
> >> >>> Hi,
> >> >>> array() for PHP.
> >> >>> Timothy
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Rafael,<BR>
<BR>
<BR>
Cheers,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
Re: UML Primitive types and non-primitive types [message #626674 is a reply to message #477476] |
charset="utf-8"
Kenn
Christian,
Hi, Kenn,
cW
Timothy,
reference...=20
to=20
Kenn
> Hey James,
> correctly:
Resource".=20
int=20
the=20
> correct?
> Thanks
> Timothy
>> Hi Timothy,
types.=20
>> example.
etc.
>> Cheers
>> - James.
>>> Hi,
for=20
types=20
even=20
>>> array() for PHP.
situation?
>>> Timothy
>=20
=20
charset="utf-8"
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
expressions=20
these=20
<DIV> </DIV>
<BLOCKQUOTE=20
aliasing=20
there to=20
make=20
two=20
collisions=20
already. I=20
type=3D"cite">
as=20
wrote:=20
</FONT>
Newsbeitrag </FONT>
</FONT>
datatypes.</FONT>
UML plugin for graphically creating and editing UML models [message #626716 is a reply to message #477450] |
Mon, 16 June 2008 16:25  |
Hi all,
representation.
Thanks in advance,
Jacqui
Re: UML plugin for graphically creating and editing UML models [message #626717 is a reply to message #477526] |
Tue, 17 June 2008 03:22  |
Jacqui wrote:
> Hi all,
> representation.
> Thanks in advance,
> Jacqui
greetings
Re: UML plugin for graphically creating and editing UML models [message #626728 is a reply to message #477534] |
references?
better.
Thanks in advance,
Jacqui
>> Jacqui wrote:
>>> Hi all,
>>> representation.
>>> Thanks in advance,
>>> Jacqui
>> you all the choice.
>> greetings
Re: UML plugin for graphically creating and editing UML models [message #626729 is a reply to message #477538] |
Hi Jacqui,
properties.
- James.
> references?
> Thanks in advance,
> Jacqui
>>> Jacqui wrote:
>>>> Hi all,
>>>> representation.
>>>> Thanks in advance,
>>>> Jacqui
>>> greetings
Re: UML plugin for graphically creating and editing UML models [message #626731 is a reply to message #477539] |
Thanks again.
Jacqui
James Bruck wrote:
> Hi Jacqui,
> properties.
> Cheers,
> - James.
>> Hi,
>> references?
>> Thanks in advance,
>> Jacqui
>>>> Jacqui wrote:
>>>>> Hi all,
>>>>> representation.
>>>>> Thanks in advance,
>>>>> Jacqui
>>>> greetings
Current Time: Fri Jul 25 22:55:56 EDT 2025
Powered by FUDForum. Page generated in 0.08476 seconds
