Home » Modeling » UML2 » UML profiles multiplicties
UML profiles multiplicties [message #477451] Tue, 27 May 2008 05:18 Go to next message
Originally posted by: Frederik.Gailly.ugent.be
I have defined a UML profile with different stereotype and between these
stereotypes I have defined several directed associations which also
contain multiplicities. When I now apply this profile on a model. The
eclipse validator sees which assoictions are missing but after I add the
correct association the validator still does not pass.
Frederik
Re: UML profiles multiplicties [message #477464 is a reply to message #477451] Mon, 02 June 2008 11:04 Go to previous messageGo to next message
Hi Frederik,
What is the error that the validator is reporting? What exactly is not
passing? Can you explain what the profile looks like and the model element
you are applying it to?
- James.
"Frederik gailly" <Frederik.Gailly@ugent.be> wrote in message
news:g1gjl6$edq$1@build.eclipse.org...
> Frederik
Re: UML profiles multiplicties [message #477477 is a reply to message #477464] Tue, 03 June 2008 08:07 Go to previous messageGo to next message
Hi james
Thank you for your reaction but I solved this issue. However I still
have problems evaluating OCL constraint defined in my UML profile. Do
the UML2 tools not support OCL validation?
Kind Regards,
Frederik
James Bruck wrote:
> Hi Frederik,
> Cheers,
> - James.
>> Hi,
>> Frederik
Re: UML profiles multiplicties [message #477487 is a reply to message #477477] Wed, 04 June 2008 09:17 Go to previous message
Hi Frederik,
The UML2 tools group can better answer what level of OCL validation support
is provided in their component. I've cc'd the question to that newsgroup.
- James.
news:g23c68$bh2$1@build.eclipse.org...
> Hi james
> Thank you for your reaction but I solved this issue. However I still have
> problems evaluating OCL constraint defined in my UML profile. Do the UML2
> Kind Regards,
> Frederik
> James Bruck wrote:
>> Hi Frederik,
>> element you are applying it to?
>> Cheers,
>> - James.
>>> Hi,
>>> Frederik
Re: UML profiles multiplicties [message #626646 is a reply to message #477451] Mon, 02 June 2008 11:04 Go to previous message
Hi Frederik,
- James.
> Frederik
Re: UML profiles multiplicties [message #626659 is a reply to message #477464] Tue, 03 June 2008 08:07 Go to previous message
Hi james
Kind Regards,
Frederik
James Bruck wrote:
> Hi Frederik,
> Cheers,
> - James.
>> Hi,
>> Frederik
Re: UML profiles multiplicties [message #626669 is a reply to message #477477] Wed, 04 June 2008 09:17 Go to previous message
Hi Frederik,
- James.
> Hi james
> Kind Regards,
> Frederik
> James Bruck wrote:
>> Hi Frederik,
>> Cheers,
>> - James.
>>> Hi,
>>> Frederik
Previous Topic:Ordering in Sequence Diagram
Next Topic:[Announce] MDT UML2 2.2.0RC3 is available
Current Time: Sun Aug 31 13:32:03 EDT 2025
Powered by FUDForum. Page generated in 0.03576 seconds
