Home » Modeling » UML2 » Copy-paste Association as a side-effect when pasting a Class
Copy-paste Association as a side-effect when pasting a Class [message #477381] Wed, 14 May 2008 12:40 Go to next message
Question about a custom UML Editor. Currently, I display Associations
as "children" underneath the Classes that are the source ends of the
Associations. This containment relationship is not in the model itself
(I am using the EMF-generated UML model from the org.eclipse.uml2.uml
plug-in). When I copy-and-paste a Class that is the source of an
Association, I would also like to copy the Association and to set the
source of the new Association to be the copy of the Class. I have tried
overriding ClassItemProvider#createCopyCommand,
ClassItemProvider#createCreatCopyCommand and even the PasteAction
contributed by the UMLActionBarContributor to have this side-effect for
the copy-paste operation, but without much luck. What would be the
recommended way to have this kind of side effect, and how would the
command that performs this side-effect get a reference to both the
original Class and the new Class?
-------Tim--------
Re: Copy-paste Association as a side-effect when pasting a Class [message #477386 is a reply to message #477381] Wed, 14 May 2008 14:44 Go to previous messageGo to next message
I figured out a way to do this by overriding CopyAction#createCommand.
I just find all the Associations that use the selected Class as a source
and add those Associations to the Collection<?> selection parameter.
That seems to give me the desired behavior but I am not sure how ideal
this solution is.
-----Tim------
> -------Tim--------
Re: Copy-paste Association as a side-effect when pasting a Class [message #477406 is a reply to message #477386] Tue, 20 May 2008 11:43 Go to previous message
Tim,
Yes, to achieve a "deep" copy like this, you need to include all the desired
elements in the list of things being copied...
Kenn
"Tim Myer" <timezra@gmail.com> wrote in message
news:g0fbue$kc8$1@build.eclipse.org...
>I figured out a way to do this by overriding CopyAction#createCommand. I
>just find all the Associations that use the selected Class as a source and
>add those Associations to the Collection<?> selection parameter. That seems
>to give me the desired behavior but I am not sure how ideal this solution
>is.
> -----Tim------
> Tim Myer wrote:
>> Question about a custom UML Editor. Currently, I display Associations as
>> -------Tim--------
Re: Copy-paste Association as a side-effect when pasting a Class [message #626565 is a reply to message #477381] Wed, 14 May 2008 14:44 Go to previous message
this solution is.
-----Tim------
> -------Tim--------
Re: Copy-paste Association as a side-effect when pasting a Class [message #626588 is a reply to message #477386] Tue, 20 May 2008 11:43 Go to previous message
Tim,
Kenn
>is.
> -----Tim------
>> -------Tim--------
Previous Topic:Re: Programmatically moving Packages within an UML model
Next Topic:Editor shows api generated import twice
Current Time: Wed Jul 23 02:02:17 EDT 2025
Powered by FUDForum. Page generated in 0.53764 seconds
