Home » Modeling » UML2 » translating java annotations to an UML repesentation
translating java annotations to an UML repesentation [message #477369] Fri, 09 May 2008 14:28 Go to next message
While working with the topcased java2uml importer, I was thinking about
the translation of java annotations to UML elements.
After reading
www.st.informatik.tu-darmstadt.de/database/publications/data /cepa-kloppenburg-aom05.pdf?id=138
I think representing Java Annotations by Stereotypes is the best way to
go and it feels a kind of "natural". Stereotypes are grouped together in
a Profile, and for example "JSR 181"(Java Annotations for Webservice) is
such a kind of Profile.
Are there any other specifications or thought about it ?
greetings, urs.
Re: translating java annotations to an UML repesentation [message #477370 is a reply to message #477369] Fri, 09 May 2008 22:33 Go to previous messageGo to next message
Yes, Java annotations map naturally to UML stereotypes.
But unless you want to create a UML model that maps closely to the
implementation artifacts, you probably won't want to map *every*
annotation (or class, for that matter).
Rafael
> After reading
> greetings, urs.
Re: translating java annotations to an UML repesentation [message #477372 is a reply to message #477370] Sat, 10 May 2008 06:24 Go to previous message
That's what I feel too.
Of course, @Override, or even better @SuspessWarnings don't carries much
semantic weight in the scope of the model. But as you will need to apply
a profile to the model, to apply stereotypes, only annotations mapping
to stereotypes defined by the applied profiles could be processed.
So the deeps of the mapping is controlled by the applied profiles. This
looks like a clean solution.
greetings, urs.
Re: translating java annotations to an UML repesentation [message #626549 is a reply to message #477369] Fri, 09 May 2008 22:33 Go to previous message
Rafael
> After reading
> greetings, urs.
Re: translating java annotations to an UML repesentation [message #626551 is a reply to message #477370] Sat, 10 May 2008 06:24 Go to previous message
greetings, urs.
Previous Topic:Primitive types and Java types in XMI
Next Topic:UML2 from eclipse and customer requirements
Current Time: Sun Jul 20 21:07:13 EDT 2025
Powered by FUDForum. Page generated in 0.11040 seconds
